root/radiance/ray/src/cv/bsdf2ttree.c
Thu Aug 21 10:33:48 2014 UTC (9 years, 8 months ago) by greg
CVS Tags: rad4R2P1, rad4R2P2
Changes since 2.28: +3 -5 lines
Diff to previous 2.28
Revision 2.28 - (view) (download) (annotate) - [selected]
Mon Mar 24 03:50:28 2014 UTC (10 years, 1 month ago) by greg
CVS Tags: rad4R2
Changes since 2.27: +29 -21 lines
Diff to previous 2.27
Fixed one minor and one major bug in super-sampling (major bug in transmission)
Wed Mar 12 22:24:59 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.26: +12 -2 lines
Diff to previous 2.26 , to selected 2.28
Changed progress bar to erase itself when done
Wed Mar 12 21:15:31 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.25: +49 -5 lines
Diff to previous 2.25 , to selected 2.28
Disabled DEBUG statements in BSDF programs and added progress bars
Tue Mar 11 19:37:45 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.24: +8 -1 lines
Diff to previous 2.24 , to selected 2.28
Added flockfile calls to reduce i/o overhead
Sat Mar 8 01:05:00 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.23: +2 -3 lines
Diff to previous 2.23 , to selected 2.28
Fixed compiler warnings
Tue Nov 26 17:35:59 2013 UTC (10 years, 5 months ago) by greg
Changes since 2.22: +4 -3 lines
Diff to previous 2.22 , to selected 2.28
Include random.h for Windows instead of calling drand48
Tue Nov 26 17:33:55 2013 UTC (10 years, 5 months ago) by greg
Diff to previous 2.21 , to selected 2.28
Sat Nov 9 05:47:49 2013 UTC (10 years, 5 months ago) by greg
Changes since 2.20: +4 -3 lines
Diff to previous 2.20 , to selected 2.28
Thu Oct 3 17:27:41 2013 UTC (10 years, 6 months ago) by greg
Changes since 2.19: +2 -3 lines
Diff to previous 2.19 , to selected 2.28
Re-allowed rttree_reduce -a option for isotropic transmission
Thu Oct 3 17:01:02 2013 UTC (10 years, 6 months ago) by greg
Changes since 2.18: +5 -3 lines
Diff to previous 2.18 , to selected 2.28
Fixed call to rttree_reduce to avoid -a on transmitted components
Thu Sep 26 17:05:00 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.17: +9 -4 lines
Diff to previous 2.17 , to selected 2.28
Added -l option to limit maximum number of RBF lobes for interpolation
Fri Aug 2 20:56:19 2013 UTC (10 years, 8 months ago) by greg
Changes since 2.16: +37 -2 lines
Diff to previous 2.16 , to selected 2.28
Added ability to use Dx, Dy and Dz instead of last 3 function parameters
Wed May 15 17:29:30 2013 UTC (10 years, 11 months ago) by greg
Diff to previous 2.15 , to selected 2.28
Switched float to double for summing variable
Wed May 15 03:22:31 2013 UTC (10 years, 11 months ago) by greg
Changes since 2.14: +75 -21 lines
Diff to previous 2.14 , to selected 2.28
Added super-sampling at peaks
Sat Mar 23 04:14:50 2013 UTC (11 years, 1 month ago) by greg
Diff to previous 2.13 , to selected 2.28
Fixed different bug in -t3 option
Sat Mar 23 02:21:14 2013 UTC (11 years, 1 month ago) by greg
Diff to previous 2.12 , to selected 2.28
Fixed bug in -t3/-t4 option
Fri Mar 22 16:39:00 2013 UTC (11 years, 1 month ago) by greg
Changes since 2.11: +9 -3 lines
Diff to previous 2.11 , to selected 2.28
Fixed bug for BSDF file input and added further error messages
Fri Mar 22 02:15:06 2013 UTC (11 years, 1 month ago) by greg
Changes since 2.10: +195 -105 lines
Diff to previous 2.10 , to selected 2.28
Added ability to generate tensor tree directly from function
Wed Dec 12 04:49:59 2012 UTC (11 years, 4 months ago) by greg
Changes since 2.9: +3 -2 lines
Diff to previous 2.9 , to selected 2.28
Fixed main bug, which was forgetting Klems axis reversal
Thu Nov 22 06:07:17 2012 UTC (11 years, 5 months ago) by greg
Diff to previous 2.8 , to selected 2.28
Tue Nov 13 04:23:38 2012 UTC (11 years, 5 months ago) by greg
Diff to previous 2.7 , to selected 2.28
Tried to improve convergence of RBF fit
Sat Nov 10 19:47:42 2012 UTC (11 years, 5 months ago) by greg
Changes since 2.6: +10 -10 lines
Diff to previous 2.6 , to selected 2.28
Minor bug fixes
Fri Nov 9 02:25:32 2012 UTC (11 years, 5 months ago) by greg
Changes since 2.5: +26 -45 lines
Diff to previous 2.5 , to selected 2.28
Made code a little more readable
Fri Nov 9 02:16:29 2012 UTC (11 years, 5 months ago) by greg
Changes since 2.4: +91 -15 lines
Diff to previous 2.4 , to selected 2.28
Added data to complete XML file output
Wed Nov 7 03:04:23 2012 UTC (11 years, 5 months ago) by greg
Changes since 2.3: +5 -5 lines
Diff to previous 2.3 , to selected 2.28
Added GRIDRES to saved BSDF representation
Tue Oct 23 05:10:42 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.2: +5 -4 lines
Diff to previous 2.2 , to selected 2.28
Hopeful bug fix in BSDF interpolation code
Sat Oct 20 17:01:26 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.1: +8 -3 lines
Diff to previous 2.1 , to selected 2.28
Bug fixes in loading BSDF interpolant data
Fri Oct 19 04:14:29 2012 UTC (11 years, 6 months ago) by greg
Diff to selected 2.28
