root/Development/ray/src/cv/bsdf2ttree.c
Revision: 2.28
Committed: Mon Mar 24 03:50:28 2014 UTC (11 years, 9 months ago) by greg
CVS Tags: rad4R2
Changes since 2.27: +29 -21 lines
Fixed one minor and one major bug in super-sampling (major bug in transmission)
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.28 static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.27 2014/03/12 22:24:59 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Load measured BSDF interpolant and write out as XML file with tensor tree.
6     *
7     * G. Ward
8     */
9
10     #define _USE_MATH_DEFINES
11     #include <stdio.h>
12     #include <stdlib.h>
13     #include <math.h>
14 greg 2.23 #include "random.h"
15 greg 2.1 #include "platform.h"
16 greg 2.22 #include "rtprocess.h"
17 greg 2.11 #include "calcomp.h"
18 greg 2.1 #include "bsdfrep.h"
19     /* global argv[0] */
20     char *progname;
21     /* percentage to cull (<0 to turn off) */
22 greg 2.7 double pctcull = 90.;
23 greg 2.1 /* sampling order */
24     int samp_order = 6;
25 greg 2.15 /* super-sampling threshold */
26     const double ssamp_thresh = 0.35;
27     /* number of super-samples */
28 greg 2.28 #ifndef NSSAMP
29     #define NSSAMP 100
30     #endif
31 greg 2.18 /* limit on number of RBF lobes */
32     static int lobe_lim = 15000;
33 greg 2.26 /* progress bar length */
34     static int do_prog = 79;
35
36
37     /* Start new progress bar */
38     #define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else
39
40     /* Draw progress bar of the appropriate length */
41     static void
42     prog_show(double frac)
43     {
44     char pbar[256];
45     int nchars;
46
47     if (do_prog <= 0) return;
48     if (do_prog > sizeof(pbar)-2)
49     do_prog = sizeof(pbar)-2;
50     if (frac < 0) frac = 0;
51     else if (frac > 1) frac = 1;
52     nchars = do_prog*frac + .5;
53     pbar[0] = '\r';
54     memset(pbar+1, '*', nchars);
55     memset(pbar+1+nchars, '-', do_prog-nchars);
56     pbar[do_prog+1] = '\0';
57     fputs(pbar, stderr);
58     }
59
60     /* Finish progress bar */
61 greg 2.27 static void
62     prog_done(void)
63     {
64     int n = do_prog;
65
66     if (n <= 1) return;
67     fputc('\r', stderr);
68     while (n--)
69     fputc(' ', stderr);
70     fputc('\r', stderr);
71     }
72 greg 2.1
73 greg 2.11 /* Output XML prologue to stdout */
74     static void
75     xml_prologue(int ac, char *av[])
76     {
77     puts("<?xml version=\"1.0\" encoding=\"UTF-8\"?>");
78     puts("<WindowElement xmlns=\"http://windows.lbl.gov\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:schemaLocation=\"http://windows.lbl.gov/BSDF-v1.4.xsd\">");
79     fputs("<!-- File produced by:", stdout);
80     while (ac-- > 0) {
81     fputc(' ', stdout);
82     fputs(*av++, stdout);
83     }
84     puts(" -->");
85     puts("<WindowElementType>System</WindowElementType>");
86     puts("<FileType>BSDF</FileType>");
87     puts("<Optical>");
88     puts("<Layer>");
89     puts("\t<Material>");
90 greg 2.21 printf("\t\t<Name>%s</Name>\n", bsdf_name[0] ? bsdf_name : "Unknown");
91     printf("\t\t<Manufacturer>%s</Manufacturer>\n",
92     bsdf_manuf[0] ? bsdf_manuf : "Unknown");
93 greg 2.11 puts("\t\t<DeviceType>Other</DeviceType>");
94     puts("\t</Material>");
95     puts("\t<DataDefinition>");
96     printf("\t\t<IncidentDataStructure>TensorTree%c</IncidentDataStructure>\n",
97     single_plane_incident ? '3' : '4');
98     puts("\t</DataDefinition>");
99     }
100
101     /* Output XML data prologue to stdout */
102     static void
103     data_prologue()
104     {
105     static const char *bsdf_type[4] = {
106     "Reflection Front",
107     "Transmission Front",
108     "Transmission Back",
109     "Reflection Back"
110     };
111
112     puts("\t<WavelengthData>");
113     puts("\t\t<LayerNumber>System</LayerNumber>");
114     puts("\t\t<Wavelength unit=\"Integral\">Visible</Wavelength>");
115     puts("\t\t<SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>");
116     puts("\t\t<DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>");
117     puts("\t\t<WavelengthDataBlock>");
118     printf("\t\t\t<WavelengthDataDirection>%s</WavelengthDataDirection>\n",
119     bsdf_type[(input_orient>0)<<1 | (output_orient>0)]);
120     puts("\t\t\t<AngleBasis>LBNL/Shirley-Chiu</AngleBasis>");
121     puts("\t\t\t<ScatteringDataType>BTDF</ScatteringDataType>");
122     puts("\t\t\t<ScatteringData>");
123     }
124
125     /* Output XML data epilogue to stdout */
126     static void
127     data_epilogue(void)
128     {
129     puts("\t\t\t</ScatteringData>");
130     puts("\t\t</WavelengthDataBlock>");
131     puts("\t</WavelengthData>");
132     }
133
134     /* Output XML epilogue to stdout */
135     static void
136     xml_epilogue(void)
137     {
138     puts("</Layer>");
139     puts("</Optical>");
140     puts("</WindowElement>");
141     }
142
143 greg 2.15 /* Compute absolute relative difference */
144     static double
145     abs_diff(double v1, double v0)
146     {
147     if ((v0 < 0) | (v1 < 0))
148     return(.0);
149     v1 = (v1-v0)*2./(v0+v1+.0001);
150     if (v1 < 0)
151     return(-v1);
152     return(v1);
153     }
154
155 greg 2.1 /* Interpolate and output isotropic BSDF data */
156     static void
157 greg 2.11 eval_isotropic(char *funame)
158 greg 2.1 {
159     const int sqres = 1<<samp_order;
160     FILE *ofp = NULL;
161 greg 2.17 int assignD = 0;
162 greg 2.1 char cmd[128];
163     int ix, ox, oy;
164 greg 2.11 double iovec[6];
165 greg 2.4 float bsdf;
166 greg 2.15
167 greg 2.11 data_prologue(); /* begin output */
168     if (pctcull >= 0) {
169 greg 2.20 sprintf(cmd, "rttree_reduce -a -h -ff -r 3 -t %f -g %d",
170 greg 2.1 pctcull, samp_order);
171     fflush(stdout);
172     ofp = popen(cmd, "w");
173     if (ofp == NULL) {
174     fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
175     progname);
176     exit(1);
177     }
178     SET_FILE_BINARY(ofp);
179 greg 2.25 #ifdef getc_unlocked /* avoid lock/unlock overhead */
180     flockfile(ofp);
181     #endif
182 greg 2.1 } else
183     fputs("{\n", stdout);
184 greg 2.17 /* need to assign Dx, Dy, Dz? */
185     if (funame != NULL)
186     assignD = (fundefined(funame) < 6);
187 greg 2.1 /* run through directions */
188     for (ix = 0; ix < sqres/2; ix++) {
189 greg 2.11 RBFNODE *rbf = NULL;
190 greg 2.14 iovec[0] = 2.*(ix+.5)/sqres - 1.;
191 greg 2.11 iovec[1] = .0;
192     iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]);
193     if (funame == NULL)
194 greg 2.18 rbf = advect_rbf(iovec, lobe_lim);
195 greg 2.15 for (ox = 0; ox < sqres; ox++) {
196     float last_bsdf = -1;
197 greg 2.1 for (oy = 0; oy < sqres; oy++) {
198 greg 2.11 SDsquare2disk(iovec+3, (ox+.5)/sqres, (oy+.5)/sqres);
199     iovec[5] = output_orient *
200     sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
201     if (funame == NULL)
202 greg 2.15 bsdf = eval_rbfrep(rbf, iovec+3) *
203 greg 2.11 output_orient/iovec[5];
204 greg 2.15 else {
205 greg 2.17 if (assignD) {
206     varset("Dx", '=', -iovec[3]);
207     varset("Dy", '=', -iovec[4]);
208     varset("Dz", '=', -iovec[5]);
209     ++eclock;
210     }
211 greg 2.15 bsdf = funvalue(funame, 6, iovec);
212 greg 2.28 #if (NSSAMP > 0)
213 greg 2.15 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
214 greg 2.28 int ssi;
215     double ssa[3], ssvec[6], sum = 0;
216     /* super-sample voxel */
217     for (ssi = NSSAMP; ssi--; ) {
218     SDmultiSamp(ssa, 3, (ssi+frandom()) *
219     (1./NSSAMP));
220 greg 2.15 ssvec[0] = 2.*(ix+ssa[0])/sqres - 1.;
221     ssvec[1] = .0;
222     ssvec[2] = input_orient *
223     sqrt(1. - ssvec[0]*ssvec[0]);
224     SDsquare2disk(ssvec+3, (ox+ssa[1])/sqres,
225     (oy+ssa[2])/sqres);
226     ssvec[5] = output_orient *
227     sqrt(1. - ssvec[3]*ssvec[3] -
228     ssvec[4]*ssvec[4]);
229 greg 2.17 if (assignD) {
230 greg 2.28 varset("Dx", '=', -ssvec[3]);
231     varset("Dy", '=', -ssvec[4]);
232     varset("Dz", '=', -ssvec[5]);
233 greg 2.17 ++eclock;
234     }
235 greg 2.16 sum += funvalue(funame, 6, ssvec);
236 greg 2.15 }
237 greg 2.28 bsdf = sum/NSSAMP;
238 greg 2.15 }
239 greg 2.28 #endif
240 greg 2.15 }
241 greg 2.1 if (pctcull >= 0)
242     fwrite(&bsdf, sizeof(bsdf), 1, ofp);
243     else
244     printf("\t%.3e\n", bsdf);
245 greg 2.15 last_bsdf = bsdf;
246 greg 2.1 }
247 greg 2.15 }
248 greg 2.3 if (rbf != NULL)
249     free(rbf);
250 greg 2.26 prog_show((ix+1.)*(2./sqres));
251 greg 2.1 }
252     if (pctcull >= 0) { /* finish output */
253     if (pclose(ofp)) {
254     fprintf(stderr, "%s: error running '%s'\n",
255     progname, cmd);
256     exit(1);
257     }
258     } else {
259     for (ix = sqres*sqres*sqres/2; ix--; )
260     fputs("\t0\n", stdout);
261     fputs("}\n", stdout);
262     }
263 greg 2.11 data_epilogue();
264 greg 2.26 prog_done();
265 greg 2.1 }
266
267     /* Interpolate and output anisotropic BSDF data */
268     static void
269 greg 2.11 eval_anisotropic(char *funame)
270 greg 2.1 {
271     const int sqres = 1<<samp_order;
272     FILE *ofp = NULL;
273 greg 2.17 int assignD = 0;
274 greg 2.1 char cmd[128];
275     int ix, iy, ox, oy;
276 greg 2.11 double iovec[6];
277 greg 2.4 float bsdf;
278 greg 2.15
279 greg 2.11 data_prologue(); /* begin output */
280     if (pctcull >= 0) {
281 greg 2.19 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d",
282     (input_orient>0 ^ output_orient>0) ? "" : " -a",
283 greg 2.1 pctcull, samp_order);
284     fflush(stdout);
285     ofp = popen(cmd, "w");
286     if (ofp == NULL) {
287     fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
288     progname);
289     exit(1);
290     }
291 greg 2.25 SET_FILE_BINARY(ofp);
292     #ifdef getc_unlocked /* avoid lock/unlock overhead */
293     flockfile(ofp);
294     #endif
295 greg 2.1 } else
296     fputs("{\n", stdout);
297 greg 2.17 /* need to assign Dx, Dy, Dz? */
298     if (funame != NULL)
299     assignD = (fundefined(funame) < 6);
300 greg 2.1 /* run through directions */
301     for (ix = 0; ix < sqres; ix++)
302     for (iy = 0; iy < sqres; iy++) {
303 greg 2.11 RBFNODE *rbf = NULL; /* Klems reversal */
304 greg 2.15 SDsquare2disk(iovec, 1.-(ix+.5)/sqres, 1.-(iy+.5)/sqres);
305 greg 2.11 iovec[2] = input_orient *
306     sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]);
307     if (funame == NULL)
308 greg 2.18 rbf = advect_rbf(iovec, lobe_lim);
309 greg 2.15 for (ox = 0; ox < sqres; ox++) {
310     float last_bsdf = -1;
311 greg 2.1 for (oy = 0; oy < sqres; oy++) {
312 greg 2.11 SDsquare2disk(iovec+3, (ox+.5)/sqres, (oy+.5)/sqres);
313     iovec[5] = output_orient *
314     sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
315     if (funame == NULL)
316 greg 2.15 bsdf = eval_rbfrep(rbf, iovec+3) *
317 greg 2.11 output_orient/iovec[5];
318 greg 2.15 else {
319 greg 2.17 if (assignD) {
320     varset("Dx", '=', -iovec[3]);
321     varset("Dy", '=', -iovec[4]);
322     varset("Dz", '=', -iovec[5]);
323     ++eclock;
324     }
325 greg 2.15 bsdf = funvalue(funame, 6, iovec);
326 greg 2.28 #if (NSSAMP > 0)
327 greg 2.15 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
328 greg 2.28 int ssi;
329     double ssa[4], ssvec[6], sum = 0;
330     /* super-sample voxel */
331     for (ssi = NSSAMP; ssi--; ) {
332     SDmultiSamp(ssa, 4, (ssi+frandom()) *
333     (1./NSSAMP));
334 greg 2.15 SDsquare2disk(ssvec, 1.-(ix+ssa[0])/sqres,
335     1.-(iy+ssa[1])/sqres);
336 greg 2.28 ssvec[2] = input_orient *
337 greg 2.15 sqrt(1. - ssvec[0]*ssvec[0] -
338     ssvec[1]*ssvec[1]);
339     SDsquare2disk(ssvec+3, (ox+ssa[2])/sqres,
340     (oy+ssa[3])/sqres);
341     ssvec[5] = output_orient *
342     sqrt(1. - ssvec[3]*ssvec[3] -
343     ssvec[4]*ssvec[4]);
344 greg 2.17 if (assignD) {
345 greg 2.28 varset("Dx", '=', -ssvec[3]);
346     varset("Dy", '=', -ssvec[4]);
347     varset("Dz", '=', -ssvec[5]);
348 greg 2.17 ++eclock;
349     }
350 greg 2.16 sum += funvalue(funame, 6, ssvec);
351 greg 2.15 }
352 greg 2.28 bsdf = sum/NSSAMP;
353 greg 2.15 }
354 greg 2.28 #endif
355 greg 2.15 }
356 greg 2.1 if (pctcull >= 0)
357     fwrite(&bsdf, sizeof(bsdf), 1, ofp);
358     else
359     printf("\t%.3e\n", bsdf);
360 greg 2.15 last_bsdf = bsdf;
361 greg 2.1 }
362 greg 2.15 }
363 greg 2.3 if (rbf != NULL)
364     free(rbf);
365 greg 2.26 prog_show((ix*sqres+iy+1.)/(sqres*sqres));
366 greg 2.1 }
367     if (pctcull >= 0) { /* finish output */
368     if (pclose(ofp)) {
369     fprintf(stderr, "%s: error running '%s'\n",
370     progname, cmd);
371     exit(1);
372     }
373     } else
374     fputs("}\n", stdout);
375 greg 2.11 data_epilogue();
376 greg 2.26 prog_done();
377 greg 2.5 }
378
379 greg 2.1 /* Read in BSDF and interpolate as tensor tree representation */
380     int
381     main(int argc, char *argv[])
382     {
383 greg 2.11 int dofwd = 0, dobwd = 1;
384     int i, na;
385 greg 2.1
386 greg 2.5 progname = argv[0];
387 greg 2.11 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
388     esupport &= ~(E_INCHAN|E_OUTCHAN);
389     scompile("PI:3.14159265358979323846", NULL, 0);
390     biggerlib();
391     for (i = 1; i < argc-1 && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
392     switch (argv[i][1]) { /* get options */
393     case 'e':
394     scompile(argv[++i], NULL, 0);
395     break;
396     case 'f':
397     if (!argv[i][2])
398     fcompile(argv[++i]);
399     else
400     dofwd = (argv[i][0] == '+');
401     break;
402     case 'b':
403     dobwd = (argv[i][0] == '+');
404     break;
405 greg 2.1 case 't':
406 greg 2.11 switch (argv[i][2]) {
407     case '3':
408 greg 2.13 single_plane_incident = 1;
409 greg 2.11 break;
410     case '4':
411 greg 2.13 single_plane_incident = 0;
412 greg 2.11 break;
413     case '\0':
414     pctcull = atof(argv[++i]);
415     break;
416     default:
417     goto userr;
418     }
419 greg 2.1 break;
420     case 'g':
421 greg 2.5 samp_order = atoi(argv[++i]);
422 greg 2.1 break;
423 greg 2.18 case 'l':
424     lobe_lim = atoi(argv[++i]);
425     break;
426 greg 2.26 case 'p':
427     do_prog = atoi(argv[i]+2);
428     break;
429 greg 2.1 default:
430     goto userr;
431     }
432 greg 2.11 if (single_plane_incident >= 0) { /* function-based BSDF? */
433     void (*evf)(char *s) = single_plane_incident ?
434     &eval_isotropic : &eval_anisotropic;
435 greg 2.17 if (i != argc-1 || fundefined(argv[i]) < 3) {
436 greg 2.12 fprintf(stderr,
437     "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
438     progname);
439 greg 2.24 fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n");
440 greg 2.11 goto userr;
441 greg 2.12 }
442 greg 2.17 ++eclock;
443 greg 2.11 xml_prologue(argc, argv); /* start XML output */
444     if (dofwd) {
445     input_orient = -1;
446     output_orient = -1;
447 greg 2.26 prog_start("Evaluating outside reflectance");
448     (*evf)(argv[i]);
449 greg 2.11 output_orient = 1;
450 greg 2.26 prog_start("Evaluating outside->inside transmission");
451     (*evf)(argv[i]);
452 greg 2.11 }
453     if (dobwd) {
454     input_orient = 1;
455     output_orient = 1;
456 greg 2.26 prog_start("Evaluating inside reflectance");
457     (*evf)(argv[i]);
458 greg 2.11 output_orient = -1;
459 greg 2.26 prog_start("Evaluating inside->outside transmission");
460     (*evf)(argv[i]);
461 greg 2.11 }
462     xml_epilogue(); /* finish XML output & exit */
463     return(0);
464     }
465     if (i < argc) { /* open input files if given */
466 greg 2.12 int nbsdf = 0;
467 greg 2.11 for ( ; i < argc; i++) { /* interpolate each component */
468 greg 2.26 char pbuf[256];
469 greg 2.11 FILE *fpin = fopen(argv[i], "rb");
470     if (fpin == NULL) {
471     fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
472     progname, argv[i]);
473     return(1);
474     }
475     if (!load_bsdf_rep(fpin))
476     return(1);
477     fclose(fpin);
478 greg 2.12 if (!nbsdf++) /* start XML on first dist. */
479     xml_prologue(argc, argv);
480 greg 2.26 sprintf(pbuf, "Interpolating component '%s'", argv[i]);
481     prog_start(pbuf);
482 greg 2.11 if (single_plane_incident)
483     eval_isotropic(NULL);
484     else
485     eval_anisotropic(NULL);
486     }
487     xml_epilogue(); /* finish XML output & exit */
488     return(0);
489     }
490     SET_FILE_BINARY(stdin); /* load from stdin */
491     if (!load_bsdf_rep(stdin))
492 greg 2.1 return(1);
493 greg 2.5 xml_prologue(argc, argv); /* start XML output */
494 greg 2.26 prog_start("Interpolating from standard input");
495 greg 2.1 if (single_plane_incident) /* resample dist. */
496 greg 2.11 eval_isotropic(NULL);
497 greg 2.1 else
498 greg 2.11 eval_anisotropic(NULL);
499     xml_epilogue(); /* finish XML output & exit */
500 greg 2.1 return(0);
501     userr:
502     fprintf(stderr,
503 greg 2.18 "Usage: %s [-g Nlog2][-t pctcull][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n",
504 greg 2.11 progname);
505     fprintf(stderr,
506     " or: %s -t{3|4} [-g Nlog2][-t pctcull][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
507 greg 2.1 progname);
508     return(1);
509     }
