root/radiance/ray/src/cv/bsdf2ttree.c
Revision: 2.52
Committed: Mon May 18 20:08:57 2020 UTC (4 years ago) by greg
Changes since 2.51: +30 -35 lines
Added -n and -s options to bsdf2ttree to control super-sampling
2 static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.51 2020/05/15 03:02:32 greg Exp $";
5 * Load measured BSDF interpolant and write out as XML file with tensor tree.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdlib.h>
12 #include <math.h>
13 #include "random.h"
14 #include "platform.h"
15 #include "paths.h"
16 #include "rtio.h"
17 #include "calcomp.h"
18 #include "bsdfrep.h"
19 /* global argv[0] */
20 char *progname;
21 /* reciprocity averaging option */
22 static const char *recip = " -a";
23 /* percentage to cull (<0 to turn off) */
24 static double pctcull = 90.;
25 /* sampling order */
26 static int samp_order = 6;
27 /* super-sampling threshold */
28 static double ssamp_thresh = 0.35;
29 /* number of super-samples */
30 static int nssamp = 256;
31 /* limit on number of RBF lobes */
32 static int lobe_lim = 15000;
33 /* progress bar length */
34 static int do_prog = 79;
35
36 #define MAXCARG 512 /* wrapBSDF command */
37 static char *wrapBSDF[MAXCARG] = {"wrapBSDF", "-U"};
38 static int wbsdfac = 2;
39
40 /* Add argument to wrapBSDF, allocating space if !isstatic */
41 static void
42 add_wbsdf(const char *arg, int isstatic)
43 {
44 if (arg == NULL)
45 return;
46 if (wbsdfac >= MAXCARG-1) {
47 fputs(progname, stderr);
48 fputs(": too many command arguments to wrapBSDF\n", stderr);
49 exit(1);
50 }
51 if (!*arg)
52 arg = "";
53 else if (!isstatic)
54 arg = savqstr((char *)arg);
55
56 wrapBSDF[wbsdfac++] = (char *)arg;
57 }
58
59 /* Create Yuv component file and add appropriate arguments */
60 static char *
61 create_component_file(int c)
62 {
63 static const char sname[3][6] = {"CIE-Y", "CIE-u", "CIE-v"};
64 static const char cname[4][4] = {"-rf", "-tf", "-tb", "-rb"};
65 char *tfname = mktemp(savqstr(TEMPLATE));
66
67 add_wbsdf("-s", 1); add_wbsdf(sname[c], 1);
68 add_wbsdf(cname[(input_orient>0)<<1 | (output_orient>0)], 1);
69 add_wbsdf(tfname, 1);
70 return(tfname);
71 }
72
73 /* Start new progress bar */
74 #define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else
75
76 /* Draw progress bar of the appropriate length */
77 static void
78 prog_show(double frac)
79 {
80 static unsigned call_cnt = 0;
81 static char lastc[] = "-\\|/";
82 char pbar[256];
83 int nchars;
84
85 if (do_prog <= 1) return;
86 if (do_prog > sizeof(pbar)-2)
87 do_prog = sizeof(pbar)-2;
88 if (frac < 0) frac = 0;
89 else if (frac >= 1) frac = .9999;
90 nchars = do_prog*frac;
91 pbar[0] = '\r';
92 memset(pbar+1, '*', nchars);
93 pbar[nchars+1] = lastc[call_cnt++ & 3];
94 memset(pbar+2+nchars, '-', do_prog-nchars-1);
95 pbar[do_prog+1] = '\0';
96 fputs(pbar, stderr);
97 }
98
99 /* Finish progress bar */
100 static void
101 prog_done(void)
102 {
103 int n = do_prog;
104
105 if (n <= 1) return;
106 fputc('\r', stderr);
107 while (n--)
108 fputc(' ', stderr);
109 fputc('\r', stderr);
110 }
111
112 /* Compute absolute relative difference */
113 static double
114 abs_diff(double v1, double v0)
115 {
116 if ((v0 < 0) | (v1 < 0))
117 return(.0);
118 v1 = (v1-v0)*2./(v0+v1+.0001);
119 if (v1 < 0)
120 return(-v1);
121 return(v1);
122 }
123
124 /* Interpolate and output isotropic BSDF data */
125 static void
126 eval_isotropic(char *funame)
127 {
128 const int sqres = 1<<samp_order;
129 const double sqfact = 1./(double)sqres;
130 float *val_last = NULL;
131 float *val_next = NULL;
132 SDValue *sdv_next = NULL;
133 FILE *ofp, *uvfp[2];
134 int assignD = 0;
135 char cmd[128];
136 int ix, ox, oy;
137 double iovec[6];
138 float bsdf, uv[2];
139
140 if (pctcull >= 0) {
141 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
142 recip, pctcull, samp_order, create_component_file(0));
143 ofp = popen(cmd, "w");
144 if (ofp == NULL) {
145 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
146 progname);
147 exit(1);
148 }
149 SET_FILE_BINARY(ofp);
150 #ifdef getc_unlocked /* avoid lock/unlock overhead */
151 flockfile(ofp);
152 #endif
153 if (rbf_colorimetry == RBCtristimulus) {
154 double uvcull = 100. - (100.-pctcull)*.25;
155 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
156 recip, uvcull, samp_order, create_component_file(1));
157 uvfp[0] = popen(cmd, "w");
158 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
159 recip, uvcull, samp_order, create_component_file(2));
160 uvfp[1] = popen(cmd, "w");
161 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
162 fprintf(stderr, "%s: cannot open pipes to uv output\n",
163 progname);
164 exit(1);
165 }
166 SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
167 #ifdef getc_unlocked
168 flockfile(uvfp[0]); flockfile(uvfp[1]);
169 #endif
170 }
171 } else {
172 ofp = fopen(create_component_file(0), "w");
173 if (ofp == NULL) {
174 fprintf(stderr, "%s: cannot create Y output file\n",
175 progname);
176 exit(1);
177 }
178 fputs("{\n", ofp);
179 if (rbf_colorimetry == RBCtristimulus) {
180 uvfp[0] = fopen(create_component_file(1), "w");
181 uvfp[1] = fopen(create_component_file(2), "w");
182 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
183 fprintf(stderr, "%s: cannot create uv output file(s)\n",
184 progname);
185 exit(1);
186 }
187 fputs("{\n", uvfp[0]);
188 fputs("{\n", uvfp[1]);
189 }
190 }
191 if (funame != NULL) /* need to assign Dx, Dy, Dz? */
192 assignD = (fundefined(funame) < 6);
193 val_last = (float *)calloc(sqres, sizeof(float));
194 if (funame == NULL)
195 sdv_next = (SDValue *)malloc(sizeof(SDValue)*sqres);
196 else
197 val_next = (float *)malloc(sizeof(float)*sqres);
198 /* run through directions */
199 for (ix = 0; ix < sqres/2; ix++) {
200 const int zipsgn = (ix & 1)*2 - 1;
201 RBFNODE *rbf = NULL;
202 iovec[0] = 2.*sqfact*(ix+.5) - 1.;
203 iovec[1] = zipsgn*sqfact*.5;
204 iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]
205 - iovec[1]*iovec[1]);
206 if (funame == NULL)
207 rbf = advect_rbf(iovec, lobe_lim);
208 /* presample first row */
209 for (oy = 0; oy < sqres; oy++) {
210 SDsquare2disk(iovec+3, .5*sqfact, (oy+.5)*sqfact);
211 iovec[5] = output_orient *
212 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
213 if (funame == NULL) {
214 eval_rbfcol(&sdv_next[oy], rbf, iovec+3);
215 } else {
216 if (assignD) {
217 varset("Dx", '=', -iovec[3]);
218 varset("Dy", '=', -iovec[4]);
219 varset("Dz", '=', -iovec[5]);
220 ++eclock;
221 }
222 val_next[oy] = funvalue(funame, 6, iovec);
223 }
224 }
225 for (ox = 0; ox < sqres; ox++) {
226 /*
227 * Super-sample when we detect a difference from before
228 * or after in this row, above or below.
229 */
230 for (oy = 0; oy < sqres; oy++) {
231 if (ox < sqres-1) { /* keeping one row ahead... */
232 SDsquare2disk(iovec+3, (ox+1.5)*sqfact, (oy+.5)*sqfact);
233 iovec[5] = output_orient *
234 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
235 }
236 if (funame == NULL) {
237 SDValue sdv = sdv_next[oy];
238 bsdf = sdv.cieY;
239 if (ox < sqres-1)
240 eval_rbfcol(&sdv_next[oy], rbf, iovec+3);
241 if (abs_diff(bsdf, sdv_next[oy].cieY) > ssamp_thresh ||
242 (ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) ||
243 (oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) ||
244 (oy < sqres-1 &&
245 abs_diff(bsdf, sdv_next[oy+1].cieY) > ssamp_thresh)) {
246 int ssi;
247 double ssa[2], sum = 0, usum = 0, vsum = 0;
248 /* super-sample voxel */
249 for (ssi = nssamp; ssi--; ) {
250 SDmultiSamp(ssa, 2, (ssi+frandom()) /
251 (double)nssamp);
252 SDsquare2disk(iovec+3, (ox+ssa[0])*sqfact,
253 (oy+ssa[1])*sqfact);
254 iovec[5] = output_orient *
255 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
256 eval_rbfcol(&sdv, rbf, iovec+3);
257 sum += sdv.cieY;
258 if (rbf_colorimetry == RBCtristimulus) {
259 sdv.cieY /=
260 -2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.;
261 usum += 4.*sdv.spec.cx * sdv.cieY;
262 vsum += 9.*sdv.spec.cy * sdv.cieY;
263 }
264 }
265 bsdf = sum / (double)nssamp;
266 if (rbf_colorimetry == RBCtristimulus) {
267 uv[0] = usum / (sum+FTINY);
268 uv[1] = vsum / (sum+FTINY);
269 }
270 } else
271 if (rbf_colorimetry == RBCtristimulus) {
272 uv[0] = uv[1] = 1. /
273 (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
274 uv[0] *= 4.*sdv.spec.cx;
275 uv[1] *= 9.*sdv.spec.cy;
276 }
277 } else {
278 bsdf = val_next[oy];
279 if (ox < sqres-1) {
280 if (assignD) {
281 varset("Dx", '=', -iovec[3]);
282 varset("Dy", '=', -iovec[4]);
283 varset("Dz", '=', -iovec[5]);
284 ++eclock;
285 }
286 val_next[oy] = funvalue(funame, 6, iovec);
287 }
288 if (abs_diff(bsdf, val_next[oy]) > ssamp_thresh ||
289 (ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) ||
290 (oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) ||
291 (oy < sqres-1 &&
292 abs_diff(bsdf, val_next[oy+1]) > ssamp_thresh)) {
293 int ssi;
294 double ssa[4], ssvec[6], sum = 0;
295 /* super-sample voxel */
296 for (ssi = nssamp; ssi--; ) {
297 SDmultiSamp(ssa, 4, (ssi+frandom()) /
298 (double)nssamp);
299 ssvec[0] = 2.*sqfact*(ix+ssa[0]) - 1.;
300 ssvec[1] = zipsgn*sqfact*ssa[1];
301 ssvec[2] = 1. - ssvec[0]*ssvec[0]
302 - ssvec[1]*ssvec[1];
303 if (ssvec[2] < .0) {
304 ssvec[1] = 0;
305 ssvec[2] = 1. - ssvec[0]*ssvec[0];
306 }
307 ssvec[2] = input_orient * sqrt(ssvec[2]);
308 SDsquare2disk(ssvec+3, (ox+ssa[2])*sqfact,
309 (oy+ssa[3])*sqfact);
310 ssvec[5] = output_orient *
311 sqrt(1. - ssvec[3]*ssvec[3] -
312 ssvec[4]*ssvec[4]);
313 if (assignD) {
314 varset("Dx", '=', -ssvec[3]);
315 varset("Dy", '=', -ssvec[4]);
316 varset("Dz", '=', -ssvec[5]);
317 ++eclock;
318 }
319 sum += funvalue(funame, 6, ssvec);
320 }
321 bsdf = sum / (double)nssamp;
322 }
323 }
324 if (pctcull >= 0)
325 putbinary(&bsdf, sizeof(bsdf), 1, ofp);
326 else
327 fprintf(ofp, "\t%.3e\n", bsdf);
328
329 if (rbf_colorimetry == RBCtristimulus) {
330 if (pctcull >= 0) {
331 putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]);
332 putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]);
333 } else {
334 fprintf(uvfp[0], "\t%.3e\n", uv[0]);
335 fprintf(uvfp[1], "\t%.3e\n", uv[1]);
336 }
337 }
338 if (val_last != NULL)
339 val_last[oy] = bsdf;
340 }
341 }
342 if (rbf != NULL)
343 free(rbf);
344 prog_show((ix+1.)*(2.*sqfact));
345 }
346 prog_done();
347 if (val_last != NULL) {
348 free(val_last);
349 if (val_next != NULL) free(val_next);
350 if (sdv_next != NULL) free(sdv_next);
351 }
352 if (pctcull >= 0) { /* finish output */
353 if (pclose(ofp)) {
354 fprintf(stderr, "%s: error running rttree_reduce on Y\n",
355 progname);
356 exit(1);
357 }
358 if (rbf_colorimetry == RBCtristimulus &&
359 (pclose(uvfp[0]) || pclose(uvfp[1]))) {
360 fprintf(stderr, "%s: error running rttree_reduce on uv\n",
361 progname);
362 exit(1);
363 }
364 } else {
365 for (ix = sqres*sqres*sqres/2; ix--; )
366 fputs("\t0\n", ofp);
367 fputs("}\n", ofp);
368 if (fclose(ofp)) {
369 fprintf(stderr, "%s: error writing Y file\n",
370 progname);
371 exit(1);
372 }
373 if (rbf_colorimetry == RBCtristimulus) {
374 for (ix = sqres*sqres*sqres/2; ix--; ) {
375 fputs("\t0\n", uvfp[0]);
376 fputs("\t0\n", uvfp[1]);
377 }
378 fputs("}\n", uvfp[0]);
379 fputs("}\n", uvfp[1]);
380 if (fclose(uvfp[0]) || fclose(uvfp[1])) {
381 fprintf(stderr, "%s: error writing uv file(s)\n",
382 progname);
383 exit(1);
384 }
385 }
386 }
387 }
388
389 /* Interpolate and output anisotropic BSDF data */
390 static void
391 eval_anisotropic(char *funame)
392 {
393 const int sqres = 1<<samp_order;
394 const double sqfact = 1./(double)sqres;
395 float *val_last = NULL;
396 float *val_next = NULL;
397 SDValue *sdv_next = NULL;
398 FILE *ofp, *uvfp[2];
399 int assignD = 0;
400 char cmd[128];
401 int ix, iy, ox, oy;
402 double iovec[6];
403 float bsdf, uv[2];
404
405 if (pctcull >= 0) {
406 const char *avgopt = (input_orient>0 ^ output_orient>0)
407 ? "" : recip;
408 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
409 avgopt, pctcull, samp_order,
410 create_component_file(0));
411 ofp = popen(cmd, "w");
412 if (ofp == NULL) {
413 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
414 progname);
415 exit(1);
416 }
417 SET_FILE_BINARY(ofp);
418 #ifdef getc_unlocked /* avoid lock/unlock overhead */
419 flockfile(ofp);
420 #endif
421 if (rbf_colorimetry == RBCtristimulus) {
422 double uvcull = 100. - (100.-pctcull)*.25;
423 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
424 avgopt, uvcull, samp_order,
425 create_component_file(1));
426 uvfp[0] = popen(cmd, "w");
427 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
428 avgopt, uvcull, samp_order,
429 create_component_file(2));
430 uvfp[1] = popen(cmd, "w");
431 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
432 fprintf(stderr, "%s: cannot open pipes to uv output\n",
433 progname);
434 exit(1);
435 }
436 SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
437 #ifdef getc_unlocked
438 flockfile(uvfp[0]); flockfile(uvfp[1]);
439 #endif
440 }
441 } else {
442 ofp = fopen(create_component_file(0), "w");
443 if (ofp == NULL) {
444 fprintf(stderr, "%s: cannot create Y output file\n",
445 progname);
446 exit(1);
447 }
448 fputs("{\n", ofp);
449 if (rbf_colorimetry == RBCtristimulus) {
450 uvfp[0] = fopen(create_component_file(1), "w");
451 uvfp[1] = fopen(create_component_file(2), "w");
452 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
453 fprintf(stderr, "%s: cannot create uv output file(s)\n",
454 progname);
455 exit(1);
456 }
457 fputs("{\n", uvfp[0]);
458 fputs("{\n", uvfp[1]);
459 }
460 }
461 if (funame != NULL) /* need to assign Dx, Dy, Dz? */
462 assignD = (fundefined(funame) < 6);
463 val_last = (float *)calloc(sqres, sizeof(float));
464 if (funame == NULL)
465 sdv_next = (SDValue *)malloc(sizeof(SDValue)*sqres);
466 else
467 val_next = (float *)malloc(sizeof(float)*sqres);
468 /* run through directions */
469 for (ix = 0; ix < sqres; ix++)
470 for (iy = 0; iy < sqres; iy++) {
471 RBFNODE *rbf = NULL; /* Klems reversal */
472 SDsquare2disk(iovec, 1.-(ix+.5)*sqfact, 1.-(iy+.5)*sqfact);
473 iovec[2] = input_orient *
474 sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]);
475 if (funame == NULL)
476 rbf = advect_rbf(iovec, lobe_lim);
477 /* presample first row */
478 for (oy = 0; oy < sqres; oy++) {
479 SDsquare2disk(iovec+3, .5*sqfact, (oy+.5)*sqfact);
480 iovec[5] = output_orient *
481 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
482 if (funame == NULL) {
483 eval_rbfcol(&sdv_next[oy], rbf, iovec+3);
484 } else {
485 if (assignD) {
486 varset("Dx", '=', -iovec[3]);
487 varset("Dy", '=', -iovec[4]);
488 varset("Dz", '=', -iovec[5]);
489 ++eclock;
490 }
491 val_next[oy] = funvalue(funame, 6, iovec);
492 }
493 }
494 for (ox = 0; ox < sqres; ox++) {
495 /*
496 * Super-sample when we detect a difference from before
497 * or after in this row, above or below.
498 */
499 for (oy = 0; oy < sqres; oy++) {
500 if (ox < sqres-1) { /* keeping one row ahead... */
501 SDsquare2disk(iovec+3, (ox+1.5)*sqfact, (oy+.5)*sqfact);
502 iovec[5] = output_orient *
503 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
504 }
505 if (funame == NULL) {
506 SDValue sdv = sdv_next[oy];
507 bsdf = sdv.cieY;
508 if (ox < sqres-1)
509 eval_rbfcol(&sdv_next[oy], rbf, iovec+3);
510 if (abs_diff(bsdf, sdv_next[oy].cieY) > ssamp_thresh ||
511 (ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) ||
512 (oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) ||
513 (oy < sqres-1 &&
514 abs_diff(bsdf, sdv_next[oy+1].cieY) > ssamp_thresh)) {
515 int ssi;
516 double ssa[2], sum = 0, usum = 0, vsum = 0;
517 /* super-sample voxel */
518 for (ssi = nssamp; ssi--; ) {
519 SDmultiSamp(ssa, 2, (ssi+frandom()) /
520 (double)nssamp);
521 SDsquare2disk(iovec+3, (ox+ssa[0])*sqfact,
522 (oy+ssa[1])*sqfact);
523 iovec[5] = output_orient *
524 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
525 eval_rbfcol(&sdv, rbf, iovec+3);
526 sum += sdv.cieY;
527 if (rbf_colorimetry == RBCtristimulus) {
528 sdv.cieY /=
529 -2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.;
530 usum += 4.*sdv.spec.cx * sdv.cieY;
531 vsum += 9.*sdv.spec.cy * sdv.cieY;
532 }
533 }
534 bsdf = sum / (double)nssamp;
535 if (rbf_colorimetry == RBCtristimulus) {
536 uv[0] = usum / (sum+FTINY);
537 uv[1] = vsum / (sum+FTINY);
538 }
539 } else
540 if (rbf_colorimetry == RBCtristimulus) {
541 uv[0] = uv[1] = 1. /
542 (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
543 uv[0] *= 4.*sdv.spec.cx;
544 uv[1] *= 9.*sdv.spec.cy;
545 }
546 } else {
547 bsdf = val_next[oy];
548 if (ox < sqres-1) {
549 if (assignD) {
550 varset("Dx", '=', -iovec[3]);
551 varset("Dy", '=', -iovec[4]);
552 varset("Dz", '=', -iovec[5]);
553 ++eclock;
554 }
555 val_next[oy] = funvalue(funame, 6, iovec);
556 }
557 if (abs_diff(bsdf, val_next[oy]) > ssamp_thresh ||
558 (ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) ||
559 (oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) ||
560 (oy < sqres-1 &&
561 abs_diff(bsdf, val_next[oy+1]) > ssamp_thresh)) {
562 int ssi;
563 double ssa[4], ssvec[6], sum = 0;
564 /* super-sample voxel */
565 for (ssi = nssamp; ssi--; ) {
566 SDmultiSamp(ssa, 4, (ssi+frandom()) /
567 (double)nssamp);
568 SDsquare2disk(ssvec, 1.-(ix+ssa[0])*sqfact,
569 1.-(iy+ssa[1])*sqfact);
570 ssvec[2] = input_orient *
571 sqrt(1. - ssvec[0]*ssvec[0] -
572 ssvec[1]*ssvec[1]);
573 SDsquare2disk(ssvec+3, (ox+ssa[2])*sqfact,
574 (oy+ssa[3])*sqfact);
575 ssvec[5] = output_orient *
576 sqrt(1. - ssvec[3]*ssvec[3] -
577 ssvec[4]*ssvec[4]);
578 if (assignD) {
579 varset("Dx", '=', -ssvec[3]);
580 varset("Dy", '=', -ssvec[4]);
581 varset("Dz", '=', -ssvec[5]);
582 ++eclock;
583 }
584 sum += funvalue(funame, 6, ssvec);
585 }
586 bsdf = sum / (double)nssamp;
587 }
588 }
589 if (pctcull >= 0)
590 putbinary(&bsdf, sizeof(bsdf), 1, ofp);
591 else
592 fprintf(ofp, "\t%.3e\n", bsdf);
593
594 if (rbf_colorimetry == RBCtristimulus) {
595 if (pctcull >= 0) {
596 putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]);
597 putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]);
598 } else {
599 fprintf(uvfp[0], "\t%.3e\n", uv[0]);
600 fprintf(uvfp[1], "\t%.3e\n", uv[1]);
601 }
602 }
603 if (val_last != NULL)
604 val_last[oy] = bsdf;
605 }
606 }
607 if (rbf != NULL)
608 free(rbf);
609 prog_show((ix*sqres+iy+1.)/(sqres*sqres));
610 }
611 prog_done();
612 if (val_last != NULL) {
613 free(val_last);
614 if (val_next != NULL) free(val_next);
615 if (sdv_next != NULL) free(sdv_next);
616 }
617 if (pctcull >= 0) { /* finish output */
618 if (pclose(ofp)) {
619 fprintf(stderr, "%s: error running rttree_reduce on Y\n",
620 progname);
621 exit(1);
622 }
623 if (rbf_colorimetry == RBCtristimulus &&
624 (pclose(uvfp[0]) || pclose(uvfp[1]))) {
625 fprintf(stderr, "%s: error running rttree_reduce on uv\n",
626 progname);
627 exit(1);
628 }
629 } else {
630 fputs("}\n", ofp);
631 if (fclose(ofp)) {
632 fprintf(stderr, "%s: error writing Y file\n",
633 progname);
634 exit(1);
635 }
636 if (rbf_colorimetry == RBCtristimulus) {
637 fputs("}\n", uvfp[0]);
638 fputs("}\n", uvfp[1]);
639 if (fclose(uvfp[0]) || fclose(uvfp[1])) {
640 fprintf(stderr, "%s: error writing uv file(s)\n",
641 progname);
642 exit(1);
643 }
644 }
645 }
646 }
647
648 #if defined(_WIN32) || defined(_WIN64)
649 /* Execute wrapBSDF command (may never return) */
650 static int
651 wrap_up(void)
652 {
653 char cmd[8192];
654
655 if (bsdf_manuf[0]) {
656 add_wbsdf("-f", 1);
657 strcpy(cmd, "m=");
658 strcpy(cmd+2, bsdf_manuf);
659 add_wbsdf(cmd, 0);
660 }
661 if (bsdf_name[0]) {
662 add_wbsdf("-f", 1);
663 strcpy(cmd, "n=");
664 strcpy(cmd+2, bsdf_name);
665 add_wbsdf(cmd, 0);
666 }
667 if (!convert_commandline(cmd, sizeof(cmd), wrapBSDF)) {
668 fputs(progname, stderr);
669 fputs(": command line too long in wrap_up()\n", stderr);
670 return(1);
671 }
672 return(system(cmd));
673 }
674 #else
675 /* Execute wrapBSDF command (may never return) */
676 static int
677 wrap_up(void)
678 {
679 char buf[256];
680 char *compath = getpath((char *)wrapBSDF[0], getenv("PATH"), X_OK);
681
682 if (compath == NULL) {
683 fprintf(stderr, "%s: cannot locate %s\n", progname, wrapBSDF[0]);
684 return(1);
685 }
686 if (bsdf_manuf[0]) {
687 add_wbsdf("-f", 1);
688 strcpy(buf, "m=");
689 strcpy(buf+2, bsdf_manuf);
690 add_wbsdf(buf, 0);
691 }
692 if (bsdf_name[0]) {
693 add_wbsdf("-f", 1);
694 strcpy(buf, "n=");
695 strcpy(buf+2, bsdf_name);
696 add_wbsdf(buf, 0);
697 }
698 execv(compath, wrapBSDF); /* successful call never returns */
699 perror(compath);
700 return(1);
701 }
702 #endif
703
704 /* Read in BSDF and interpolate as tensor tree representation */
705 int
706 main(int argc, char *argv[])
707 {
708 static char tfmt[2][4] = {"t4", "t3"};
709 int dofwd = 0, dobwd = 1;
710 char buf[2048];
711 int i, na;
712
713 progname = argv[0];
714 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
715 esupport &= ~(E_INCHAN|E_OUTCHAN);
716 scompile("PI:3.14159265358979323846", NULL, 0);
717 biggerlib();
718 for (i = 1; i < argc && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
719 switch (argv[i][1]) { /* get options */
720 case 'e':
721 scompile(argv[++i], NULL, 0);
722 if (single_plane_incident < 0)
723 single_plane_incident = 0;
724 break;
725 case 'f':
726 if (!argv[i][2]) {
727 if (strchr(argv[++i], '=') != NULL) {
728 add_wbsdf("-f", 1);
729 add_wbsdf(argv[i], 1);
730 } else {
731 char *fpath = getpath(argv[i],
732 getrlibpath(), 0);
733 if (fpath == NULL) {
734 fprintf(stderr,
735 "%s: cannot find file '%s'\n",
736 argv[0], argv[i]);
737 return(1);
738 }
739 fcompile(fpath);
740 if (single_plane_incident < 0)
741 single_plane_incident = 0;
742 }
743 } else
744 dofwd = (argv[i][0] == '+');
745 break;
746 case 'a':
747 recip = (argv[i][0] == '+') ? " -a" : "";
748 break;
749 case 'b':
750 dobwd = (argv[i][0] == '+');
751 break;
752 case 'n':
753 nssamp = atoi(argv[++i]);
754 if (nssamp <= 0)
755 goto userr;
756 break;
757 case 's':
758 ssamp_thresh = atof(argv[++i]);
759 if (ssamp_thresh <= FTINY)
760 goto userr;
761 break;
762 case 't':
763 switch (argv[i][2]) {
764 case '3':
765 single_plane_incident = 1;
766 break;
767 case '4':
768 single_plane_incident = 0;
769 break;
770 case '\0':
771 pctcull = atof(argv[++i]);
772 break;
773 default:
774 goto userr;
775 }
776 break;
777 case 'g':
778 samp_order = atoi(argv[++i]);
779 break;
780 case 'l':
781 lobe_lim = atoi(argv[++i]);
782 break;
783 case 'p':
784 do_prog = atoi(argv[i]+2);
785 break;
786 case 'W':
787 add_wbsdf(argv[i], 1);
788 break;
789 case 'u':
790 case 'C':
791 add_wbsdf(argv[i], 1);
792 add_wbsdf(argv[++i], 1);
793 break;
794 default:
795 goto userr;
796 }
797 strcpy(buf, "File produced by: ");
798 if (convert_commandline(buf+18, sizeof(buf)-18, argv) != NULL) {
799 add_wbsdf("-C", 1); add_wbsdf(buf, 0);
800 }
801 if (single_plane_incident >= 0) { /* function-based BSDF? */
802 void (*evf)(char *s) = single_plane_incident ?
803 eval_isotropic : eval_anisotropic;
804 if (i != argc-1 || fundefined(argv[i]) < 3) {
805 fprintf(stderr,
806 "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
807 progname);
808 fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n");
809 goto userr;
810 }
811 ++eclock;
812 add_wbsdf("-a", 1);
813 add_wbsdf(tfmt[single_plane_incident], 1);
814 if (dofwd) {
815 input_orient = -1;
816 output_orient = -1;
817 prog_start("Evaluating outside reflectance");
818 (*evf)(argv[i]);
819 output_orient = 1;
820 prog_start("Evaluating outside->inside transmission");
821 (*evf)(argv[i]);
822 }
823 if (dobwd) {
824 input_orient = 1;
825 output_orient = 1;
826 prog_start("Evaluating inside reflectance");
827 (*evf)(argv[i]);
828 output_orient = -1;
829 prog_start("Evaluating inside->outside transmission");
830 (*evf)(argv[i]);
831 }
832 return(wrap_up());
833 }
834 if (i < argc) { /* open input files if given */
835 int nbsdf = 0;
836 for ( ; i < argc; i++) { /* interpolate each component */
837 char pbuf[256];
838 FILE *fpin = fopen(argv[i], "rb");
839 if (fpin == NULL) {
840 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
841 progname, argv[i]);
842 return(1);
843 }
844 if (!load_bsdf_rep(fpin))
845 return(1);
846 fclose(fpin);
847 sprintf(pbuf, "Interpolating component '%s'", argv[i]);
848 prog_start(pbuf);
849 if (!nbsdf++) {
850 add_wbsdf("-a", 1);
851 add_wbsdf(tfmt[single_plane_incident], 1);
852 }
853 if (single_plane_incident)
854 eval_isotropic(NULL);
855 else
856 eval_anisotropic(NULL);
857 }
858 return(wrap_up());
859 }
860 SET_FILE_BINARY(stdin); /* load from stdin */
861 if (!load_bsdf_rep(stdin))
862 return(1);
863 prog_start("Interpolating from standard input");
864 add_wbsdf("-a", 1);
865 add_wbsdf(tfmt[single_plane_incident], 1);
866 if (single_plane_incident) /* resample dist. */
867 eval_isotropic(NULL);
868 else
869 eval_anisotropic(NULL);
870
871 return(wrap_up());
872 userr:
873 fprintf(stderr,
874 "Usage: %s [{+|-}a][-g Nlog2][-t pctcull][-n nss][-s thresh][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n",
875 progname);
876 fprintf(stderr,
877 " or: %s -t{3|4} [{+|-}a][-g Nlog2][-t pctcull][-n nss][-s thresh][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
878 progname);
879 return(1);
880 }
