root/radiance/ray/src/cv/bsdf2ttree.c
Revision: 2.45
Committed: Wed May 6 01:30:00 2020 UTC (5 years, 1 month ago) by greg
Changes since 2.44: +20 -12 lines
Improved finding of peak in isotropic function (and RBF) input
2 static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.44 2019/12/28 18:05:14 greg Exp $";
5 * Load measured BSDF interpolant and write out as XML file with tensor tree.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdlib.h>
12 #include <math.h>
13 #include "random.h"
14 #include "platform.h"
15 #include "paths.h"
16 #include "rtio.h"
17 #include "calcomp.h"
18 #include "bsdfrep.h"
19 /* global argv[0] */
20 char *progname;
21 /* reciprocity averaging option */
22 static const char *recip = " -a";
23 /* percentage to cull (<0 to turn off) */
24 static double pctcull = 90.;
25 /* sampling order */
26 static int samp_order = 6;
27 /* super-sampling threshold */
28 const double ssamp_thresh = 0.35;
29 /* number of super-samples */
30 #ifndef NSSAMP
31 #define NSSAMP 64
32 #endif
33 /* limit on number of RBF lobes */
34 static int lobe_lim = 15000;
35 /* progress bar length */
36 static int do_prog = 79;
37
38 #define MAXCARG 512 /* wrapBSDF command */
39 static char *wrapBSDF[MAXCARG] = {"wrapBSDF", "-U"};
40 static int wbsdfac = 2;
41
42 /* Add argument to wrapBSDF, allocating space if !isstatic */
43 static void
44 add_wbsdf(const char *arg, int isstatic)
45 {
46 if (arg == NULL)
47 return;
48 if (wbsdfac >= MAXCARG-1) {
49 fputs(progname, stderr);
50 fputs(": too many command arguments to wrapBSDF\n", stderr);
51 exit(1);
52 }
53 if (!*arg)
54 arg = "";
55 else if (!isstatic)
56 arg = savqstr((char *)arg);
57
58 wrapBSDF[wbsdfac++] = (char *)arg;
59 }
60
61 /* Create Yuv component file and add appropriate arguments */
62 static char *
63 create_component_file(int c)
64 {
65 static const char sname[3][6] = {"CIE-Y", "CIE-u", "CIE-v"};
66 static const char cname[4][4] = {"-rf", "-tf", "-tb", "-rb"};
67 char *tfname = mktemp(savqstr(TEMPLATE));
68
69 add_wbsdf("-s", 1); add_wbsdf(sname[c], 1);
70 add_wbsdf(cname[(input_orient>0)<<1 | (output_orient>0)], 1);
71 add_wbsdf(tfname, 1);
72 return(tfname);
73 }
74
75 /* Start new progress bar */
76 #define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else
77
78 /* Draw progress bar of the appropriate length */
79 static void
80 prog_show(double frac)
81 {
82 static unsigned call_cnt = 0;
83 static char lastc[] = "-\\|/";
84 char pbar[256];
85 int nchars;
86
87 if (do_prog <= 1) return;
88 if (do_prog > sizeof(pbar)-2)
89 do_prog = sizeof(pbar)-2;
90 if (frac < 0) frac = 0;
91 else if (frac >= 1) frac = .9999;
92 nchars = do_prog*frac;
93 pbar[0] = '\r';
94 memset(pbar+1, '*', nchars);
95 pbar[nchars+1] = lastc[call_cnt++ & 3];
96 memset(pbar+2+nchars, '-', do_prog-nchars-1);
97 pbar[do_prog+1] = '\0';
98 fputs(pbar, stderr);
99 }
100
101 /* Finish progress bar */
102 static void
103 prog_done(void)
104 {
105 int n = do_prog;
106
107 if (n <= 1) return;
108 fputc('\r', stderr);
109 while (n--)
110 fputc(' ', stderr);
111 fputc('\r', stderr);
112 }
113
114 /* Compute absolute relative difference */
115 static double
116 abs_diff(double v1, double v0)
117 {
118 if ((v0 < 0) | (v1 < 0))
119 return(.0);
120 v1 = (v1-v0)*2./(v0+v1+.0001);
121 if (v1 < 0)
122 return(-v1);
123 return(v1);
124 }
125
126 /* Interpolate and output isotropic BSDF data */
127 static void
128 eval_isotropic(char *funame)
129 {
130 const int sqres = 1<<samp_order;
131 const double sqfact = 1./(double)sqres;
132 FILE *ofp, *uvfp[2];
133 int assignD = 0;
134 char cmd[128];
135 int ix, ox, oy;
136 double iovec[6];
137 float bsdf, uv[2];
138
139 if (pctcull >= 0) {
140 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
141 recip, pctcull, samp_order, create_component_file(0));
142 ofp = popen(cmd, "w");
143 if (ofp == NULL) {
144 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
145 progname);
146 exit(1);
147 }
148 SET_FILE_BINARY(ofp);
149 #ifdef getc_unlocked /* avoid lock/unlock overhead */
150 flockfile(ofp);
151 #endif
152 if (rbf_colorimetry == RBCtristimulus) {
153 double uvcull = 100. - (100.-pctcull)*.25;
154 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
155 recip, uvcull, samp_order, create_component_file(1));
156 uvfp[0] = popen(cmd, "w");
157 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
158 recip, uvcull, samp_order, create_component_file(2));
159 uvfp[1] = popen(cmd, "w");
160 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
161 fprintf(stderr, "%s: cannot open pipes to uv output\n",
162 progname);
163 exit(1);
164 }
165 SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
166 #ifdef getc_unlocked
167 flockfile(uvfp[0]); flockfile(uvfp[1]);
168 #endif
169 }
170 } else {
171 ofp = fopen(create_component_file(0), "w");
172 if (ofp == NULL) {
173 fprintf(stderr, "%s: cannot create Y output file\n",
174 progname);
175 exit(1);
176 }
177 fputs("{\n", ofp);
178 if (rbf_colorimetry == RBCtristimulus) {
179 uvfp[0] = fopen(create_component_file(1), "w");
180 uvfp[1] = fopen(create_component_file(2), "w");
181 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
182 fprintf(stderr, "%s: cannot create uv output file(s)\n",
183 progname);
184 exit(1);
185 }
186 fputs("{\n", uvfp[0]);
187 fputs("{\n", uvfp[1]);
188 }
189 }
190 if (funame != NULL) /* need to assign Dx, Dy, Dz? */
191 assignD = (fundefined(funame) < 6);
192 /* run through directions */
193 for (ix = 0; ix < sqres/2; ix++) {
194 const int zipsgn = (ix & 1)*2 - 1;
195 RBFNODE *rbf = NULL;
196 iovec[0] = 2.*sqfact*(ix+.5) - 1.;
197 iovec[1] = zipsgn*sqfact*.5;
198 iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]
199 - iovec[1]*iovec[1]);
200 if (funame == NULL)
201 rbf = advect_rbf(iovec, lobe_lim);
202 for (ox = 0; ox < sqres; ox++) {
203 float last_bsdf = -1;
204 for (oy = 0; oy < sqres; oy++) {
205 SDsquare2disk(iovec+3, (ox+.5)*sqfact, (oy+.5)*sqfact);
206 iovec[5] = output_orient *
207 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
208 if (funame == NULL) {
209 SDValue sdv;
210 eval_rbfcol(&sdv, rbf, iovec+3);
211 bsdf = sdv.cieY;
212 #if (NSSAMP > 0)
213 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
214 int ssi;
215 double ssa[2], sum = 0, usum = 0, vsum = 0;
216 /* super-sample voxel */
217 for (ssi = NSSAMP; ssi--; ) {
218 SDmultiSamp(ssa, 2, (ssi+frandom()) *
219 (1./NSSAMP));
220 SDsquare2disk(iovec+3, (ox+ssa[0])*sqfact,
221 (oy+ssa[1])*sqfact);
222 iovec[5] = output_orient *
223 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
224 eval_rbfcol(&sdv, rbf, iovec+3);
225 sum += sdv.cieY;
226 if (rbf_colorimetry == RBCtristimulus) {
227 sdv.cieY /=
228 -2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.;
229 usum += 4.*sdv.spec.cx * sdv.cieY;
230 vsum += 9.*sdv.spec.cy * sdv.cieY;
231 }
232 }
233 bsdf = sum * (1./NSSAMP);
234 if (rbf_colorimetry == RBCtristimulus) {
235 uv[0] = usum / (sum+FTINY);
236 uv[1] = vsum / (sum+FTINY);
237 }
238 } else
239 #endif
240 if (rbf_colorimetry == RBCtristimulus) {
241 uv[0] = uv[1] = 1. /
242 (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
243 uv[0] *= 4.*sdv.spec.cx;
244 uv[1] *= 9.*sdv.spec.cy;
245 }
246 } else {
247 if (assignD) {
248 varset("Dx", '=', -iovec[3]);
249 varset("Dy", '=', -iovec[4]);
250 varset("Dz", '=', -iovec[5]);
251 ++eclock;
252 }
253 bsdf = funvalue(funame, 6, iovec);
254 #if (NSSAMP > 0)
255 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
256 int ssi;
257 double ssa[4], ssvec[6], sum = 0;
258 /* super-sample voxel */
259 for (ssi = NSSAMP; ssi--; ) {
260 SDmultiSamp(ssa, 4, (ssi+frandom()) *
261 (1./NSSAMP));
262 ssvec[0] = 2.*sqfact*(ix+ssa[0]) - 1.;
263 ssvec[1] = zipsgn*sqfact*ssa[1];
264 ssvec[2] = 1. - ssvec[0]*ssvec[0]
265 - ssvec[1]*ssvec[1];
266 if (ssvec[2] < .0) {
267 ssvec[1] = 0;
268 ssvec[2] = 1. - ssvec[0]*ssvec[0];
269 }
270 ssvec[2] = input_orient * sqrt(ssvec[2]);
271 SDsquare2disk(ssvec+3, (ox+ssa[2])*sqfact,
272 (oy+ssa[3])*sqfact);
273 ssvec[5] = output_orient *
274 sqrt(1. - ssvec[3]*ssvec[3] -
275 ssvec[4]*ssvec[4]);
276 if (assignD) {
277 varset("Dx", '=', -ssvec[3]);
278 varset("Dy", '=', -ssvec[4]);
279 varset("Dz", '=', -ssvec[5]);
280 ++eclock;
281 }
282 sum += funvalue(funame, 6, ssvec);
283 }
284 bsdf = sum * (1./NSSAMP);
285 }
286 #endif
287 }
288 if (pctcull >= 0)
289 putbinary(&bsdf, sizeof(bsdf), 1, ofp);
290 else
291 fprintf(ofp, "\t%.3e\n", bsdf);
292
293 if (rbf_colorimetry == RBCtristimulus) {
294 if (pctcull >= 0) {
295 putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]);
296 putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]);
297 } else {
298 fprintf(uvfp[0], "\t%.3e\n", uv[0]);
299 fprintf(uvfp[1], "\t%.3e\n", uv[1]);
300 }
301 }
302 last_bsdf = bsdf;
303 }
304 }
305 if (rbf != NULL)
306 free(rbf);
307 prog_show((ix+1.)*(2.*sqfact));
308 }
309 prog_done();
310 if (pctcull >= 0) { /* finish output */
311 if (pclose(ofp)) {
312 fprintf(stderr, "%s: error running rttree_reduce on Y\n",
313 progname);
314 exit(1);
315 }
316 if (rbf_colorimetry == RBCtristimulus &&
317 (pclose(uvfp[0]) || pclose(uvfp[1]))) {
318 fprintf(stderr, "%s: error running rttree_reduce on uv\n",
319 progname);
320 exit(1);
321 }
322 } else {
323 for (ix = sqres*sqres*sqres/2; ix--; )
324 fputs("\t0\n", ofp);
325 fputs("}\n", ofp);
326 if (fclose(ofp)) {
327 fprintf(stderr, "%s: error writing Y file\n",
328 progname);
329 exit(1);
330 }
331 if (rbf_colorimetry == RBCtristimulus) {
332 for (ix = sqres*sqres*sqres/2; ix--; ) {
333 fputs("\t0\n", uvfp[0]);
334 fputs("\t0\n", uvfp[1]);
335 }
336 fputs("}\n", uvfp[0]);
337 fputs("}\n", uvfp[1]);
338 if (fclose(uvfp[0]) || fclose(uvfp[1])) {
339 fprintf(stderr, "%s: error writing uv file(s)\n",
340 progname);
341 exit(1);
342 }
343 }
344 }
345 }
346
347 /* Interpolate and output anisotropic BSDF data */
348 static void
349 eval_anisotropic(char *funame)
350 {
351 const int sqres = 1<<samp_order;
352 const double sqfact = 1./(double)sqres;
353 FILE *ofp, *uvfp[2];
354 int assignD = 0;
355 char cmd[128];
356 int ix, iy, ox, oy;
357 double iovec[6];
358 float bsdf, uv[2];
359
360 if (pctcull >= 0) {
361 const char *avgopt = (input_orient>0 ^ output_orient>0)
362 ? "" : recip;
363 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
364 avgopt, pctcull, samp_order,
365 create_component_file(0));
366 ofp = popen(cmd, "w");
367 if (ofp == NULL) {
368 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
369 progname);
370 exit(1);
371 }
372 SET_FILE_BINARY(ofp);
373 #ifdef getc_unlocked /* avoid lock/unlock overhead */
374 flockfile(ofp);
375 #endif
376 if (rbf_colorimetry == RBCtristimulus) {
377 double uvcull = 100. - (100.-pctcull)*.25;
378 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
379 avgopt, uvcull, samp_order,
380 create_component_file(1));
381 uvfp[0] = popen(cmd, "w");
382 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
383 avgopt, uvcull, samp_order,
384 create_component_file(2));
385 uvfp[1] = popen(cmd, "w");
386 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
387 fprintf(stderr, "%s: cannot open pipes to uv output\n",
388 progname);
389 exit(1);
390 }
391 SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
392 #ifdef getc_unlocked
393 flockfile(uvfp[0]); flockfile(uvfp[1]);
394 #endif
395 }
396 } else {
397 ofp = fopen(create_component_file(0), "w");
398 if (ofp == NULL) {
399 fprintf(stderr, "%s: cannot create Y output file\n",
400 progname);
401 exit(1);
402 }
403 fputs("{\n", ofp);
404 if (rbf_colorimetry == RBCtristimulus) {
405 uvfp[0] = fopen(create_component_file(1), "w");
406 uvfp[1] = fopen(create_component_file(2), "w");
407 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
408 fprintf(stderr, "%s: cannot create uv output file(s)\n",
409 progname);
410 exit(1);
411 }
412 fputs("{\n", uvfp[0]);
413 fputs("{\n", uvfp[1]);
414 }
415 }
416 if (funame != NULL) /* need to assign Dx, Dy, Dz? */
417 assignD = (fundefined(funame) < 6);
418 /* run through directions */
419 for (ix = 0; ix < sqres; ix++)
420 for (iy = 0; iy < sqres; iy++) {
421 RBFNODE *rbf = NULL; /* Klems reversal */
422 SDsquare2disk(iovec, 1.-(ix+.5)*sqfact, 1.-(iy+.5)*sqfact);
423 iovec[2] = input_orient *
424 sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]);
425 if (funame == NULL)
426 rbf = advect_rbf(iovec, lobe_lim);
427 for (ox = 0; ox < sqres; ox++) {
428 float last_bsdf = -1;
429 for (oy = 0; oy < sqres; oy++) {
430 SDsquare2disk(iovec+3, (ox+.5)*sqfact, (oy+.5)*sqfact);
431 iovec[5] = output_orient *
432 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
433 if (funame == NULL) {
434 SDValue sdv;
435 eval_rbfcol(&sdv, rbf, iovec+3);
436 bsdf = sdv.cieY;
437 #if (NSSAMP > 0)
438 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
439 int ssi;
440 double ssa[2], sum = 0, usum = 0, vsum = 0;
441 /* super-sample voxel */
442 for (ssi = NSSAMP; ssi--; ) {
443 SDmultiSamp(ssa, 2, (ssi+frandom()) *
444 (1./NSSAMP));
445 SDsquare2disk(iovec+3, (ox+ssa[0])*sqfact,
446 (oy+ssa[1])*sqfact);
447 iovec[5] = output_orient *
448 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
449 eval_rbfcol(&sdv, rbf, iovec+3);
450 sum += sdv.cieY;
451 if (rbf_colorimetry == RBCtristimulus) {
452 sdv.cieY /=
453 -2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.;
454 usum += 4.*sdv.spec.cx * sdv.cieY;
455 vsum += 9.*sdv.spec.cy * sdv.cieY;
456 }
457 }
458 bsdf = sum * (1./NSSAMP);
459 if (rbf_colorimetry == RBCtristimulus) {
460 uv[0] = usum / (sum+FTINY);
461 uv[1] = vsum / (sum+FTINY);
462 }
463 } else
464 #endif
465 if (rbf_colorimetry == RBCtristimulus) {
466 uv[0] = uv[1] = 1. /
467 (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
468 uv[0] *= 4.*sdv.spec.cx;
469 uv[1] *= 9.*sdv.spec.cy;
470 }
471 } else {
472 if (assignD) {
473 varset("Dx", '=', -iovec[3]);
474 varset("Dy", '=', -iovec[4]);
475 varset("Dz", '=', -iovec[5]);
476 ++eclock;
477 }
478 bsdf = funvalue(funame, 6, iovec);
479 #if (NSSAMP > 0)
480 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
481 int ssi;
482 double ssa[4], ssvec[6], sum = 0;
483 /* super-sample voxel */
484 for (ssi = NSSAMP; ssi--; ) {
485 SDmultiSamp(ssa, 4, (ssi+frandom()) *
486 (1./NSSAMP));
487 SDsquare2disk(ssvec, 1.-(ix+ssa[0])*sqfact,
488 1.-(iy+ssa[1])*sqfact);
489 ssvec[2] = input_orient *
490 sqrt(1. - ssvec[0]*ssvec[0] -
491 ssvec[1]*ssvec[1]);
492 SDsquare2disk(ssvec+3, (ox+ssa[2])*sqfact,
493 (oy+ssa[3])*sqfact);
494 ssvec[5] = output_orient *
495 sqrt(1. - ssvec[3]*ssvec[3] -
496 ssvec[4]*ssvec[4]);
497 if (assignD) {
498 varset("Dx", '=', -ssvec[3]);
499 varset("Dy", '=', -ssvec[4]);
500 varset("Dz", '=', -ssvec[5]);
501 ++eclock;
502 }
503 sum += funvalue(funame, 6, ssvec);
504 }
505 bsdf = sum * (1./NSSAMP);
506 }
507 #endif
508 }
509 if (pctcull >= 0)
510 putbinary(&bsdf, sizeof(bsdf), 1, ofp);
511 else
512 fprintf(ofp, "\t%.3e\n", bsdf);
513
514 if (rbf_colorimetry == RBCtristimulus) {
515 if (pctcull >= 0) {
516 putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]);
517 putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]);
518 } else {
519 fprintf(uvfp[0], "\t%.3e\n", uv[0]);
520 fprintf(uvfp[1], "\t%.3e\n", uv[1]);
521 }
522 }
523 last_bsdf = bsdf;
524 }
525 }
526 if (rbf != NULL)
527 free(rbf);
528 prog_show((ix*sqres+iy+1.)/(sqres*sqres));
529 }
530 prog_done();
531 if (pctcull >= 0) { /* finish output */
532 if (pclose(ofp)) {
533 fprintf(stderr, "%s: error running rttree_reduce on Y\n",
534 progname);
535 exit(1);
536 }
537 if (rbf_colorimetry == RBCtristimulus &&
538 (pclose(uvfp[0]) || pclose(uvfp[1]))) {
539 fprintf(stderr, "%s: error running rttree_reduce on uv\n",
540 progname);
541 exit(1);
542 }
543 } else {
544 fputs("}\n", ofp);
545 if (fclose(ofp)) {
546 fprintf(stderr, "%s: error writing Y file\n",
547 progname);
548 exit(1);
549 }
550 if (rbf_colorimetry == RBCtristimulus) {
551 fputs("}\n", uvfp[0]);
552 fputs("}\n", uvfp[1]);
553 if (fclose(uvfp[0]) || fclose(uvfp[1])) {
554 fprintf(stderr, "%s: error writing uv file(s)\n",
555 progname);
556 exit(1);
557 }
558 }
559 }
560 }
561
562 #if defined(_WIN32) || defined(_WIN64)
563 /* Execute wrapBSDF command (may never return) */
564 static int
565 wrap_up(void)
566 {
567 char cmd[8192];
568
569 if (bsdf_manuf[0]) {
570 add_wbsdf("-f", 1);
571 strcpy(cmd, "m=");
572 strcpy(cmd+2, bsdf_manuf);
573 add_wbsdf(cmd, 0);
574 }
575 if (bsdf_name[0]) {
576 add_wbsdf("-f", 1);
577 strcpy(cmd, "n=");
578 strcpy(cmd+2, bsdf_name);
579 add_wbsdf(cmd, 0);
580 }
581 if (!convert_commandline(cmd, sizeof(cmd), wrapBSDF)) {
582 fputs(progname, stderr);
583 fputs(": command line too long in wrap_up()\n", stderr);
584 return(1);
585 }
586 return(system(cmd));
587 }
588 #else
589 /* Execute wrapBSDF command (may never return) */
590 static int
591 wrap_up(void)
592 {
593 char buf[256];
594 char *compath = getpath((char *)wrapBSDF[0], getenv("PATH"), X_OK);
595
596 if (compath == NULL) {
597 fprintf(stderr, "%s: cannot locate %s\n", progname, wrapBSDF[0]);
598 return(1);
599 }
600 if (bsdf_manuf[0]) {
601 add_wbsdf("-f", 1);
602 strcpy(buf, "m=");
603 strcpy(buf+2, bsdf_manuf);
604 add_wbsdf(buf, 0);
605 }
606 if (bsdf_name[0]) {
607 add_wbsdf("-f", 1);
608 strcpy(buf, "n=");
609 strcpy(buf+2, bsdf_name);
610 add_wbsdf(buf, 0);
611 }
612 execv(compath, wrapBSDF); /* successful call never returns */
613 perror(compath);
614 return(1);
615 }
616 #endif
617
618 /* Read in BSDF and interpolate as tensor tree representation */
619 int
620 main(int argc, char *argv[])
621 {
622 static char tfmt[2][4] = {"t4", "t3"};
623 int dofwd = 0, dobwd = 1;
624 char buf[2048];
625 int i, na;
626
627 progname = argv[0];
628 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
629 esupport &= ~(E_INCHAN|E_OUTCHAN);
630 scompile("PI:3.14159265358979323846", NULL, 0);
631 biggerlib();
632 for (i = 1; i < argc && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
633 switch (argv[i][1]) { /* get options */
634 case 'e':
635 scompile(argv[++i], NULL, 0);
636 break;
637 case 'f':
638 if (!argv[i][2]) {
639 if (strchr(argv[++i], '=') != NULL) {
640 add_wbsdf("-f", 1);
641 add_wbsdf(argv[i], 1);
642 } else {
643 char *fpath = getpath(argv[i],
644 getrlibpath(), 0);
645 if (fpath == NULL) {
646 fprintf(stderr,
647 "%s: cannot find file '%s'\n",
648 argv[0], argv[i]);
649 return(1);
650 }
651 fcompile(fpath);
652 if (single_plane_incident < 0)
653 single_plane_incident = 0;
654 }
655 } else
656 dofwd = (argv[i][0] == '+');
657 break;
658 case 'a':
659 recip = (argv[i][0] == '+') ? " -a" : "";
660 break;
661 case 'b':
662 dobwd = (argv[i][0] == '+');
663 break;
664 case 't':
665 switch (argv[i][2]) {
666 case '3':
667 single_plane_incident = 1;
668 break;
669 case '4':
670 single_plane_incident = 0;
671 break;
672 case '\0':
673 pctcull = atof(argv[++i]);
674 break;
675 default:
676 goto userr;
677 }
678 break;
679 case 'g':
680 samp_order = atoi(argv[++i]);
681 break;
682 case 'l':
683 lobe_lim = atoi(argv[++i]);
684 break;
685 case 'p':
686 do_prog = atoi(argv[i]+2);
687 break;
688 case 'W':
689 add_wbsdf(argv[i], 1);
690 break;
691 case 'u':
692 case 'C':
693 add_wbsdf(argv[i], 1);
694 add_wbsdf(argv[++i], 1);
695 break;
696 default:
697 goto userr;
698 }
699 strcpy(buf, "File produced by: ");
700 if (convert_commandline(buf+18, sizeof(buf)-18, argv) != NULL) {
701 add_wbsdf("-C", 1); add_wbsdf(buf, 0);
702 }
703 if (single_plane_incident >= 0) { /* function-based BSDF? */
704 void (*evf)(char *s) = single_plane_incident ?
705 eval_isotropic : eval_anisotropic;
706 if (i != argc-1 || fundefined(argv[i]) < 3) {
707 fprintf(stderr,
708 "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
709 progname);
710 fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n");
711 goto userr;
712 }
713 ++eclock;
714 add_wbsdf("-a", 1);
715 add_wbsdf(tfmt[single_plane_incident], 1);
716 if (dofwd) {
717 input_orient = -1;
718 output_orient = -1;
719 prog_start("Evaluating outside reflectance");
720 (*evf)(argv[i]);
721 output_orient = 1;
722 prog_start("Evaluating outside->inside transmission");
723 (*evf)(argv[i]);
724 }
725 if (dobwd) {
726 input_orient = 1;
727 output_orient = 1;
728 prog_start("Evaluating inside reflectance");
729 (*evf)(argv[i]);
730 output_orient = -1;
731 prog_start("Evaluating inside->outside transmission");
732 (*evf)(argv[i]);
733 }
734 return(wrap_up());
735 }
736 if (i < argc) { /* open input files if given */
737 int nbsdf = 0;
738 for ( ; i < argc; i++) { /* interpolate each component */
739 char pbuf[256];
740 FILE *fpin = fopen(argv[i], "rb");
741 if (fpin == NULL) {
742 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
743 progname, argv[i]);
744 return(1);
745 }
746 if (!load_bsdf_rep(fpin))
747 return(1);
748 fclose(fpin);
749 sprintf(pbuf, "Interpolating component '%s'", argv[i]);
750 prog_start(pbuf);
751 if (!nbsdf++) {
752 add_wbsdf("-a", 1);
753 add_wbsdf(tfmt[single_plane_incident], 1);
754 }
755 if (single_plane_incident)
756 eval_isotropic(NULL);
757 else
758 eval_anisotropic(NULL);
759 }
760 return(wrap_up());
761 }
762 SET_FILE_BINARY(stdin); /* load from stdin */
763 if (!load_bsdf_rep(stdin))
764 return(1);
765 prog_start("Interpolating from standard input");
766 add_wbsdf("-a", 1);
767 add_wbsdf(tfmt[single_plane_incident], 1);
768 if (single_plane_incident) /* resample dist. */
769 eval_isotropic(NULL);
770 else
771 eval_anisotropic(NULL);
772
773 return(wrap_up());
774 userr:
775 fprintf(stderr,
776 "Usage: %s [{+|-}a][-g Nlog2][-t pctcull][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n",
777 progname);
778 fprintf(stderr,
779 " or: %s -t{3|4} [{+|-}a][-g Nlog2][-t pctcull][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
780 progname);
781 return(1);
782 }
