root/radiance/ray/src/cv/bsdf2ttree.c
Revision: 2.21
Committed: Sat Nov 9 05:47:49 2013 UTC (11 years, 7 months ago) by greg
Changes since 2.20: +4 -3 lines
2 static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.20 2013/10/03 17:27:41 greg Exp $";
5 * Load measured BSDF interpolant and write out as XML file with tensor tree.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdio.h>
12 #include <stdlib.h>
13 #include <math.h>
14 #include "platform.h"
15 #include "calcomp.h"
16 #include "bsdfrep.h"
17 /* global argv[0] */
18 char *progname;
19 /* percentage to cull (<0 to turn off) */
20 double pctcull = 90.;
21 /* sampling order */
22 int samp_order = 6;
23 /* super-sampling threshold */
24 const double ssamp_thresh = 0.35;
25 /* number of super-samples */
26 const int nssamp = 100;
27 /* limit on number of RBF lobes */
28 static int lobe_lim = 15000;
29
30 /* Output XML prologue to stdout */
31 static void
32 xml_prologue(int ac, char *av[])
33 {
34 puts("<?xml version=\"1.0\" encoding=\"UTF-8\"?>");
35 puts("<WindowElement xmlns=\"http://windows.lbl.gov\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:schemaLocation=\"http://windows.lbl.gov/BSDF-v1.4.xsd\">");
36 fputs("<!-- File produced by:", stdout);
37 while (ac-- > 0) {
38 fputc(' ', stdout);
39 fputs(*av++, stdout);
40 }
41 puts(" -->");
42 puts("<WindowElementType>System</WindowElementType>");
43 puts("<FileType>BSDF</FileType>");
44 puts("<Optical>");
45 puts("<Layer>");
46 puts("\t<Material>");
47 printf("\t\t<Name>%s</Name>\n", bsdf_name[0] ? bsdf_name : "Unknown");
48 printf("\t\t<Manufacturer>%s</Manufacturer>\n",
49 bsdf_manuf[0] ? bsdf_manuf : "Unknown");
50 puts("\t\t<DeviceType>Other</DeviceType>");
51 puts("\t</Material>");
52 puts("\t<DataDefinition>");
53 printf("\t\t<IncidentDataStructure>TensorTree%c</IncidentDataStructure>\n",
54 single_plane_incident ? '3' : '4');
55 puts("\t</DataDefinition>");
56 }
57
58 /* Output XML data prologue to stdout */
59 static void
60 data_prologue()
61 {
62 static const char *bsdf_type[4] = {
63 "Reflection Front",
64 "Transmission Front",
65 "Transmission Back",
66 "Reflection Back"
67 };
68
69 puts("\t<WavelengthData>");
70 puts("\t\t<LayerNumber>System</LayerNumber>");
71 puts("\t\t<Wavelength unit=\"Integral\">Visible</Wavelength>");
72 puts("\t\t<SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>");
73 puts("\t\t<DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>");
74 puts("\t\t<WavelengthDataBlock>");
75 printf("\t\t\t<WavelengthDataDirection>%s</WavelengthDataDirection>\n",
76 bsdf_type[(input_orient>0)<<1 | (output_orient>0)]);
77 puts("\t\t\t<AngleBasis>LBNL/Shirley-Chiu</AngleBasis>");
78 puts("\t\t\t<ScatteringDataType>BTDF</ScatteringDataType>");
79 puts("\t\t\t<ScatteringData>");
80 }
81
82 /* Output XML data epilogue to stdout */
83 static void
84 data_epilogue(void)
85 {
86 puts("\t\t\t</ScatteringData>");
87 puts("\t\t</WavelengthDataBlock>");
88 puts("\t</WavelengthData>");
89 }
90
91 /* Output XML epilogue to stdout */
92 static void
93 xml_epilogue(void)
94 {
95 puts("</Layer>");
96 puts("</Optical>");
97 puts("</WindowElement>");
98 }
99
100 /* Compute absolute relative difference */
101 static double
102 abs_diff(double v1, double v0)
103 {
104 if ((v0 < 0) | (v1 < 0))
105 return(.0);
106 v1 = (v1-v0)*2./(v0+v1+.0001);
107 if (v1 < 0)
108 return(-v1);
109 return(v1);
110 }
111
112 /* Interpolate and output isotropic BSDF data */
113 static void
114 eval_isotropic(char *funame)
115 {
116 const int sqres = 1<<samp_order;
117 FILE *ofp = NULL;
118 int assignD = 0;
119 char cmd[128];
120 int ix, ox, oy;
121 double iovec[6];
122 float bsdf;
123
124 data_prologue(); /* begin output */
125 if (pctcull >= 0) {
126 sprintf(cmd, "rttree_reduce -a -h -ff -r 3 -t %f -g %d",
127 pctcull, samp_order);
128 fflush(stdout);
129 ofp = popen(cmd, "w");
130 if (ofp == NULL) {
131 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
132 progname);
133 exit(1);
134 }
135 SET_FILE_BINARY(ofp);
136 } else
137 fputs("{\n", stdout);
138 /* need to assign Dx, Dy, Dz? */
139 if (funame != NULL)
140 assignD = (fundefined(funame) < 6);
141 /* run through directions */
142 for (ix = 0; ix < sqres/2; ix++) {
143 RBFNODE *rbf = NULL;
144 iovec[0] = 2.*(ix+.5)/sqres - 1.;
145 iovec[1] = .0;
146 iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]);
147 if (funame == NULL)
148 rbf = advect_rbf(iovec, lobe_lim);
149 for (ox = 0; ox < sqres; ox++) {
150 float last_bsdf = -1;
151 for (oy = 0; oy < sqres; oy++) {
152 SDsquare2disk(iovec+3, (ox+.5)/sqres, (oy+.5)/sqres);
153 iovec[5] = output_orient *
154 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
155 if (funame == NULL)
156 bsdf = eval_rbfrep(rbf, iovec+3) *
157 output_orient/iovec[5];
158 else {
159 double ssa[3], ssvec[6], sum;
160 int ssi;
161 if (assignD) {
162 varset("Dx", '=', -iovec[3]);
163 varset("Dy", '=', -iovec[4]);
164 varset("Dz", '=', -iovec[5]);
165 ++eclock;
166 }
167 bsdf = funvalue(funame, 6, iovec);
168 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
169 sum = 0; /* super-sample voxel */
170 for (ssi = nssamp; ssi--; ) {
171 SDmultiSamp(ssa, 3, (ssi+drand48())/nssamp);
172 ssvec[0] = 2.*(ix+ssa[0])/sqres - 1.;
173 ssvec[1] = .0;
174 ssvec[2] = input_orient *
175 sqrt(1. - ssvec[0]*ssvec[0]);
176 SDsquare2disk(ssvec+3, (ox+ssa[1])/sqres,
177 (oy+ssa[2])/sqres);
178 ssvec[5] = output_orient *
179 sqrt(1. - ssvec[3]*ssvec[3] -
180 ssvec[4]*ssvec[4]);
181 if (assignD) {
182 varset("Dx", '=', -iovec[3]);
183 varset("Dy", '=', -iovec[4]);
184 varset("Dz", '=', -iovec[5]);
185 ++eclock;
186 }
187 sum += funvalue(funame, 6, ssvec);
188 }
189 bsdf = sum/nssamp;
190 }
191 }
192 if (pctcull >= 0)
193 fwrite(&bsdf, sizeof(bsdf), 1, ofp);
194 else
195 printf("\t%.3e\n", bsdf);
196 last_bsdf = bsdf;
197 }
198 }
199 if (rbf != NULL)
200 free(rbf);
201 }
202 if (pctcull >= 0) { /* finish output */
203 if (pclose(ofp)) {
204 fprintf(stderr, "%s: error running '%s'\n",
205 progname, cmd);
206 exit(1);
207 }
208 } else {
209 for (ix = sqres*sqres*sqres/2; ix--; )
210 fputs("\t0\n", stdout);
211 fputs("}\n", stdout);
212 }
213 data_epilogue();
214 }
215
216 /* Interpolate and output anisotropic BSDF data */
217 static void
218 eval_anisotropic(char *funame)
219 {
220 const int sqres = 1<<samp_order;
221 FILE *ofp = NULL;
222 int assignD = 0;
223 char cmd[128];
224 int ix, iy, ox, oy;
225 double iovec[6];
226 float bsdf;
227
228 data_prologue(); /* begin output */
229 if (pctcull >= 0) {
230 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d",
231 (input_orient>0 ^ output_orient>0) ? "" : " -a",
232 pctcull, samp_order);
233 fflush(stdout);
234 ofp = popen(cmd, "w");
235 if (ofp == NULL) {
236 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
237 progname);
238 exit(1);
239 }
240 } else
241 fputs("{\n", stdout);
242 /* need to assign Dx, Dy, Dz? */
243 if (funame != NULL)
244 assignD = (fundefined(funame) < 6);
245 /* run through directions */
246 for (ix = 0; ix < sqres; ix++)
247 for (iy = 0; iy < sqres; iy++) {
248 RBFNODE *rbf = NULL; /* Klems reversal */
249 SDsquare2disk(iovec, 1.-(ix+.5)/sqres, 1.-(iy+.5)/sqres);
250 iovec[2] = input_orient *
251 sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]);
252 if (funame == NULL)
253 rbf = advect_rbf(iovec, lobe_lim);
254 for (ox = 0; ox < sqres; ox++) {
255 float last_bsdf = -1;
256 for (oy = 0; oy < sqres; oy++) {
257 SDsquare2disk(iovec+3, (ox+.5)/sqres, (oy+.5)/sqres);
258 iovec[5] = output_orient *
259 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
260 if (funame == NULL)
261 bsdf = eval_rbfrep(rbf, iovec+3) *
262 output_orient/iovec[5];
263 else {
264 double ssa[4], ssvec[6], sum;
265 int ssi;
266 if (assignD) {
267 varset("Dx", '=', -iovec[3]);
268 varset("Dy", '=', -iovec[4]);
269 varset("Dz", '=', -iovec[5]);
270 ++eclock;
271 }
272 bsdf = funvalue(funame, 6, iovec);
273 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
274 sum = 0; /* super-sample voxel */
275 for (ssi = nssamp; ssi--; ) {
276 SDmultiSamp(ssa, 4, (ssi+drand48())/nssamp);
277 SDsquare2disk(ssvec, 1.-(ix+ssa[0])/sqres,
278 1.-(iy+ssa[1])/sqres);
279 ssvec[2] = output_orient *
280 sqrt(1. - ssvec[0]*ssvec[0] -
281 ssvec[1]*ssvec[1]);
282 SDsquare2disk(ssvec+3, (ox+ssa[2])/sqres,
283 (oy+ssa[3])/sqres);
284 ssvec[5] = output_orient *
285 sqrt(1. - ssvec[3]*ssvec[3] -
286 ssvec[4]*ssvec[4]);
287 if (assignD) {
288 varset("Dx", '=', -iovec[3]);
289 varset("Dy", '=', -iovec[4]);
290 varset("Dz", '=', -iovec[5]);
291 ++eclock;
292 }
293 sum += funvalue(funame, 6, ssvec);
294 }
295 bsdf = sum/nssamp;
296 }
297 }
298 if (pctcull >= 0)
299 fwrite(&bsdf, sizeof(bsdf), 1, ofp);
300 else
301 printf("\t%.3e\n", bsdf);
302 last_bsdf = bsdf;
303 }
304 }
305 if (rbf != NULL)
306 free(rbf);
307 }
308 if (pctcull >= 0) { /* finish output */
309 if (pclose(ofp)) {
310 fprintf(stderr, "%s: error running '%s'\n",
311 progname, cmd);
312 exit(1);
313 }
314 } else
315 fputs("}\n", stdout);
316 data_epilogue();
317 }
318
319 /* Read in BSDF and interpolate as tensor tree representation */
320 int
321 main(int argc, char *argv[])
322 {
323 int dofwd = 0, dobwd = 1;
324 int i, na;
325
326 progname = argv[0];
327 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
328 esupport &= ~(E_INCHAN|E_OUTCHAN);
329 scompile("PI:3.14159265358979323846", NULL, 0);
330 biggerlib();
331 for (i = 1; i < argc-1 && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
332 switch (argv[i][1]) { /* get options */
333 case 'e':
334 scompile(argv[++i], NULL, 0);
335 break;
336 case 'f':
337 if (!argv[i][2])
338 fcompile(argv[++i]);
339 else
340 dofwd = (argv[i][0] == '+');
341 break;
342 case 'b':
343 dobwd = (argv[i][0] == '+');
344 break;
345 case 't':
346 switch (argv[i][2]) {
347 case '3':
348 single_plane_incident = 1;
349 break;
350 case '4':
351 single_plane_incident = 0;
352 break;
353 case '\0':
354 pctcull = atof(argv[++i]);
355 break;
356 default:
357 goto userr;
358 }
359 break;
360 case 'g':
361 samp_order = atoi(argv[++i]);
362 break;
363 case 'l':
364 lobe_lim = atoi(argv[++i]);
365 break;
366 default:
367 goto userr;
368 }
369 if (single_plane_incident >= 0) { /* function-based BSDF? */
370 void (*evf)(char *s) = single_plane_incident ?
371 &eval_isotropic : &eval_anisotropic;
372 if (i != argc-1 || fundefined(argv[i]) < 3) {
373 fprintf(stderr,
374 "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
375 progname);
376 fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n",
377 progname);
378 goto userr;
379 }
380 ++eclock;
381 xml_prologue(argc, argv); /* start XML output */
382 if (dofwd) {
383 input_orient = -1;
384 output_orient = -1;
385 (*evf)(argv[i]); /* outside reflectance */
386 output_orient = 1;
387 (*evf)(argv[i]); /* outside -> inside */
388 }
389 if (dobwd) {
390 input_orient = 1;
391 output_orient = 1;
392 (*evf)(argv[i]); /* inside reflectance */
393 output_orient = -1;
394 (*evf)(argv[i]); /* inside -> outside */
395 }
396 xml_epilogue(); /* finish XML output & exit */
397 return(0);
398 }
399 if (i < argc) { /* open input files if given */
400 int nbsdf = 0;
401 for ( ; i < argc; i++) { /* interpolate each component */
402 FILE *fpin = fopen(argv[i], "rb");
403 if (fpin == NULL) {
404 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
405 progname, argv[i]);
406 return(1);
407 }
408 if (!load_bsdf_rep(fpin))
409 return(1);
410 fclose(fpin);
411 if (!nbsdf++) /* start XML on first dist. */
412 xml_prologue(argc, argv);
413 if (single_plane_incident)
414 eval_isotropic(NULL);
415 else
416 eval_anisotropic(NULL);
417 }
418 xml_epilogue(); /* finish XML output & exit */
419 return(0);
420 }
421 SET_FILE_BINARY(stdin); /* load from stdin */
422 if (!load_bsdf_rep(stdin))
423 return(1);
424 xml_prologue(argc, argv); /* start XML output */
425 if (single_plane_incident) /* resample dist. */
426 eval_isotropic(NULL);
427 else
428 eval_anisotropic(NULL);
429 xml_epilogue(); /* finish XML output & exit */
430 return(0);
431 userr:
432 fprintf(stderr,
433 "Usage: %s [-g Nlog2][-t pctcull][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n",
434 progname);
435 fprintf(stderr,
436 " or: %s -t{3|4} [-g Nlog2][-t pctcull][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
437 progname);
438 return(1);
439 }
