--- ray/src/cv/bsdf2ttree.c 2013/11/09 05:47:49 2.21 +++ ray/src/cv/bsdf2ttree.c 2023/07/26 15:50:03 2.59 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.21 2013/11/09 05:47:49 greg Exp $"; +static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.59 2023/07/26 15:50:03 greg Exp $"; #endif /* * Load measured BSDF interpolant and write out as XML file with tensor tree. @@ -8,93 +8,106 @@ static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.21 */ #define _USE_MATH_DEFINES -#include #include #include +#include +#include "random.h" #include "platform.h" +#include "paths.h" +#include "rtio.h" #include "calcomp.h" #include "bsdfrep.h" /* global argv[0] */ char *progname; + /* reciprocity averaging option */ +static const char *recip = " -a"; /* percentage to cull (<0 to turn off) */ -double pctcull = 90.; +static double pctcull = 90.; /* sampling order */ -int samp_order = 6; +static int samp_order = 6; /* super-sampling threshold */ -const double ssamp_thresh = 0.35; +static double ssamp_thresh = 0.35; /* number of super-samples */ -const int nssamp = 100; +static int nssamp = 256; /* limit on number of RBF lobes */ static int lobe_lim = 15000; + /* progress bar length */ +static int do_prog = 79; -/* Output XML prologue to stdout */ +#define MAXCARG 512 /* wrapBSDF command */ +static char *wrapBSDF[MAXCARG] = {"wrapBSDF", "-U"}; +static int wbsdfac = 2; + +/* Add argument to wrapBSDF, allocating space if !isstatic */ static void -xml_prologue(int ac, char *av[]) +add_wbsdf(const char *arg, int isstatic) { - puts(""); - puts(""); - fputs(""); - puts("System"); - puts("BSDF"); - puts(""); - puts(""); - puts("\t"); - printf("\t\t%s\n", bsdf_name[0] ? bsdf_name : "Unknown"); - printf("\t\t%s\n", - bsdf_manuf[0] ? bsdf_manuf : "Unknown"); - puts("\t\tOther"); - puts("\t"); - puts("\t"); - printf("\t\tTensorTree%c\n", - single_plane_incident ? '3' : '4'); - puts("\t"); + if (!*arg) + arg = ""; + else if (!isstatic) + arg = savqstr((char *)arg); + + wrapBSDF[wbsdfac++] = (char *)arg; } -/* Output XML data prologue to stdout */ -static void -data_prologue() +/* Create Yuv component file and add appropriate arguments */ +static char * +create_component_file(int c) { - static const char *bsdf_type[4] = { - "Reflection Front", - "Transmission Front", - "Transmission Back", - "Reflection Back" - }; + static const char sname[3][6] = {"CIE-Y", "CIE-u", "CIE-v"}; + static const char cname[4][4] = {"-rf", "-tf", "-tb", "-rb"}; + char *tfname = mktemp(savqstr(TEMPLATE)); - puts("\t"); - puts("\t\tSystem"); - puts("\t\tVisible"); - puts("\t\tCIE Illuminant D65 1nm.ssp"); - puts("\t\tASTM E308 1931 Y.dsp"); - puts("\t\t"); - printf("\t\t\t%s\n", - bsdf_type[(input_orient>0)<<1 | (output_orient>0)]); - puts("\t\t\tLBNL/Shirley-Chiu"); - puts("\t\t\tBTDF"); - puts("\t\t\t"); + add_wbsdf("-s", 1); add_wbsdf(sname[c], 1); + add_wbsdf(cname[(input_orient>0)<<1 | (output_orient>0)], 1); + add_wbsdf(tfname, 1); + return(tfname); } -/* Output XML data epilogue to stdout */ +/* Start new progress bar */ +#define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else + +/* Draw progress bar of the appropriate length */ static void -data_epilogue(void) +prog_show(double frac) { - puts("\t\t\t"); - puts("\t\t"); - puts("\t"); + static unsigned call_cnt = 0; + static char lastc[] = "-\\|/"; + char pbar[256]; + int nchars; + + if (do_prog <= 1) return; + if (do_prog > sizeof(pbar)-2) + do_prog = sizeof(pbar)-2; + if (frac < 0) frac = 0; + else if (frac >= 1) frac = .9999; + nchars = do_prog*frac; + pbar[0] = '\r'; + memset(pbar+1, '*', nchars); + pbar[nchars+1] = lastc[call_cnt++ & 3]; + memset(pbar+2+nchars, '-', do_prog-nchars-1); + pbar[do_prog+1] = '\0'; + fputs(pbar, stderr); } -/* Output XML epilogue to stdout */ +/* Finish progress bar */ static void -xml_epilogue(void) +prog_done(void) { - puts(""); - puts(""); - puts(""); + int n = do_prog; + + if (n <= 1) return; + fputc('\r', stderr); + while (n--) + fputc(' ', stderr); + fputc('\r', stderr); } /* Compute absolute relative difference */ @@ -114,18 +127,20 @@ static void eval_isotropic(char *funame) { const int sqres = 1<= 0) { - sprintf(cmd, "rttree_reduce -a -h -ff -r 3 -t %f -g %d", - pctcull, samp_order); - fflush(stdout); + sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s", + recip, pctcull, samp_order, create_component_file(0)); ofp = popen(cmd, "w"); if (ofp == NULL) { fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n", @@ -133,84 +148,242 @@ eval_isotropic(char *funame) exit(1); } SET_FILE_BINARY(ofp); - } else - fputs("{\n", stdout); - /* need to assign Dx, Dy, Dz? */ - if (funame != NULL) +#ifdef getc_unlocked /* avoid lock/unlock overhead */ + flockfile(ofp); +#endif + if (rbf_colorimetry == RBCtristimulus) { + double uvcull = 100. - (100.-pctcull)*.25; + sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s", + recip, uvcull, samp_order, create_component_file(1)); + uvfp[0] = popen(cmd, "w"); + sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s", + recip, uvcull, samp_order, create_component_file(2)); + uvfp[1] = popen(cmd, "w"); + if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) { + fprintf(stderr, "%s: cannot open pipes to uv output\n", + progname); + exit(1); + } + SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]); +#ifdef getc_unlocked + flockfile(uvfp[0]); flockfile(uvfp[1]); +#endif + } + } else { + ofp = fopen(create_component_file(0), "w"); + if (ofp == NULL) { + fprintf(stderr, "%s: cannot create Y output file\n", + progname); + exit(1); + } + fputs("{\n", ofp); + if (rbf_colorimetry == RBCtristimulus) { + uvfp[0] = fopen(create_component_file(1), "w"); + uvfp[1] = fopen(create_component_file(2), "w"); + if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) { + fprintf(stderr, "%s: cannot create uv output file(s)\n", + progname); + exit(1); + } + fputs("{\n", uvfp[0]); + fputs("{\n", uvfp[1]); + } + } + if (funame != NULL) /* need to assign Dx, Dy, Dz? */ assignD = (fundefined(funame) < 6); + val_last = (float *)calloc(sqres, sizeof(float)); + if (funame == NULL) + sdv_next = (SDValue *)malloc(sizeof(SDValue)*sqres); + else + val_next = (float *)malloc(sizeof(float)*sqres); /* run through directions */ for (ix = 0; ix < sqres/2; ix++) { - RBFNODE *rbf = NULL; - iovec[0] = 2.*(ix+.5)/sqres - 1.; - iovec[1] = .0; - iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]); + const int zipsgn = (ix & 1)*2 - 1; + RBFNODE *rbf = NULL; + iovec[0] = 2.*sqfact*(ix+.5) - 1.; + iovec[1] = zipsgn*sqfact*.5; + iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0] + - iovec[1]*iovec[1]); if (funame == NULL) rbf = advect_rbf(iovec, lobe_lim); + /* presample first row */ + for (oy = 0; oy < sqres; oy++) { + square2disk(iovec+3, .5*sqfact, (oy+.5)*sqfact); + iovec[5] = output_orient * + sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]); + if (funame == NULL) { + eval_rbfcol(&sdv_next[oy], rbf, iovec+3); + } else { + if (assignD) { + varset("Dx", '=', -iovec[3]); + varset("Dy", '=', -iovec[4]); + varset("Dz", '=', -iovec[5]); + ++eclock; + } + val_next[oy] = funvalue(funame, 6, iovec); + } + } for (ox = 0; ox < sqres; ox++) { - float last_bsdf = -1; + /* + * Super-sample when we detect a difference from before + * or after in this row, above or below. + */ for (oy = 0; oy < sqres; oy++) { - SDsquare2disk(iovec+3, (ox+.5)/sqres, (oy+.5)/sqres); - iovec[5] = output_orient * + if (ox < sqres-1) { /* keeping one row ahead... */ + square2disk(iovec+3, (ox+1.5)*sqfact, (oy+.5)*sqfact); + iovec[5] = output_orient * sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]); - if (funame == NULL) - bsdf = eval_rbfrep(rbf, iovec+3) * - output_orient/iovec[5]; - else { - double ssa[3], ssvec[6], sum; - int ssi; - if (assignD) { - varset("Dx", '=', -iovec[3]); - varset("Dy", '=', -iovec[4]); - varset("Dz", '=', -iovec[5]); - ++eclock; + } + if (funame == NULL) { + SDValue sdv = sdv_next[oy]; + bsdf = sdv.cieY; + if (ox < sqres-1) + eval_rbfcol(&sdv_next[oy], rbf, iovec+3); + if (abs_diff(bsdf, sdv_next[oy].cieY) > ssamp_thresh || + (ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) || + (oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) || + (oy < sqres-1 && + abs_diff(bsdf, sdv_next[oy+1].cieY) > ssamp_thresh)) { + int ssi; + double ssa[2], sum = 0, usum = 0, vsum = 0; + /* super-sample voxel */ + for (ssi = nssamp; ssi--; ) { + SDmultiSamp(ssa, 2, (ssi+frandom()) / + (double)nssamp); + square2disk(iovec+3, (ox+ssa[0])*sqfact, + (oy+ssa[1])*sqfact); + iovec[5] = output_orient * + sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]); + eval_rbfcol(&sdv, rbf, iovec+3); + sum += sdv.cieY; + if (rbf_colorimetry == RBCtristimulus) { + sdv.cieY /= + -2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.; + usum += 4.*sdv.spec.cx * sdv.cieY; + vsum += 9.*sdv.spec.cy * sdv.cieY; + } + } + bsdf = sum / (double)nssamp; + if (rbf_colorimetry == RBCtristimulus) { + uv[0] = usum / (sum+FTINY); + uv[1] = vsum / (sum+FTINY); + } + } else if (rbf_colorimetry == RBCtristimulus) { + uv[0] = uv[1] = 1. / + (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.); + uv[0] *= 4.*sdv.spec.cx; + uv[1] *= 9.*sdv.spec.cy; } - bsdf = funvalue(funame, 6, iovec); - if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) { - sum = 0; /* super-sample voxel */ + } else { + bsdf = val_next[oy]; + if (ox < sqres-1) { + if (assignD) { + varset("Dx", '=', -iovec[3]); + varset("Dy", '=', -iovec[4]); + varset("Dz", '=', -iovec[5]); + ++eclock; + } + val_next[oy] = funvalue(funame, 6, iovec); + } + if (abs_diff(bsdf, val_next[oy]) > ssamp_thresh || + (ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) || + (oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) || + (oy < sqres-1 && + abs_diff(bsdf, val_next[oy+1]) > ssamp_thresh)) { + int ssi; + double ssa[4], ssvec[6], sum = 0; + /* super-sample voxel */ for (ssi = nssamp; ssi--; ) { - SDmultiSamp(ssa, 3, (ssi+drand48())/nssamp); - ssvec[0] = 2.*(ix+ssa[0])/sqres - 1.; - ssvec[1] = .0; - ssvec[2] = input_orient * - sqrt(1. - ssvec[0]*ssvec[0]); - SDsquare2disk(ssvec+3, (ox+ssa[1])/sqres, - (oy+ssa[2])/sqres); + SDmultiSamp(ssa, 4, (ssi+frandom()) / + (double)nssamp); + ssvec[0] = 2.*sqfact*(ix+ssa[0]) - 1.; + ssvec[1] = zipsgn*sqfact*ssa[1]; + ssvec[2] = 1. - ssvec[0]*ssvec[0] + - ssvec[1]*ssvec[1]; + if (ssvec[2] < .0) { + ssvec[1] = 0; + ssvec[2] = 1. - ssvec[0]*ssvec[0]; + } + ssvec[2] = input_orient * sqrt(ssvec[2]); + square2disk(ssvec+3, (ox+ssa[2])*sqfact, + (oy+ssa[3])*sqfact); ssvec[5] = output_orient * sqrt(1. - ssvec[3]*ssvec[3] - ssvec[4]*ssvec[4]); if (assignD) { - varset("Dx", '=', -iovec[3]); - varset("Dy", '=', -iovec[4]); - varset("Dz", '=', -iovec[5]); + varset("Dx", '=', -ssvec[3]); + varset("Dy", '=', -ssvec[4]); + varset("Dz", '=', -ssvec[5]); ++eclock; } sum += funvalue(funame, 6, ssvec); } - bsdf = sum/nssamp; + bsdf = sum / (double)nssamp; } } if (pctcull >= 0) - fwrite(&bsdf, sizeof(bsdf), 1, ofp); + putbinary(&bsdf, sizeof(bsdf), 1, ofp); else - printf("\t%.3e\n", bsdf); - last_bsdf = bsdf; + fprintf(ofp, "\t%.3e\n", bsdf); + + if (rbf_colorimetry == RBCtristimulus) { + if (pctcull >= 0) { + putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]); + putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]); + } else { + fprintf(uvfp[0], "\t%.3e\n", uv[0]); + fprintf(uvfp[1], "\t%.3e\n", uv[1]); + } + } + if (val_last != NULL) + val_last[oy] = bsdf; } } if (rbf != NULL) free(rbf); + prog_show((ix+1.)*(2.*sqfact)); } + prog_done(); + if (val_last != NULL) { + free(val_last); + if (val_next != NULL) free(val_next); + if (sdv_next != NULL) free(sdv_next); + } if (pctcull >= 0) { /* finish output */ if (pclose(ofp)) { - fprintf(stderr, "%s: error running '%s'\n", - progname, cmd); + fprintf(stderr, "%s: error running rttree_reduce on Y\n", + progname); exit(1); } + if (rbf_colorimetry == RBCtristimulus && + (pclose(uvfp[0]) || pclose(uvfp[1]))) { + fprintf(stderr, "%s: error running rttree_reduce on uv\n", + progname); + exit(1); + } } else { for (ix = sqres*sqres*sqres/2; ix--; ) - fputs("\t0\n", stdout); - fputs("}\n", stdout); + fputs("\t0\n", ofp); + fputs("}\n", ofp); + if (fclose(ofp)) { + fprintf(stderr, "%s: error writing Y file\n", + progname); + exit(1); + } + if (rbf_colorimetry == RBCtristimulus) { + for (ix = sqres*sqres*sqres/2; ix--; ) { + fputs("\t0\n", uvfp[0]); + fputs("\t0\n", uvfp[1]); + } + fputs("}\n", uvfp[0]); + fputs("}\n", uvfp[1]); + if (fclose(uvfp[0]) || fclose(uvfp[1])) { + fprintf(stderr, "%s: error writing uv file(s)\n", + progname); + exit(1); + } + } } - data_epilogue(); } /* Interpolate and output anisotropic BSDF data */ @@ -218,130 +391,416 @@ static void eval_anisotropic(char *funame) { const int sqres = 1<= 0) { - sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d", - (input_orient>0 ^ output_orient>0) ? "" : " -a", - pctcull, samp_order); - fflush(stdout); + const char *avgopt = (input_orient>0 ^ output_orient>0) + ? "" : recip; + sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s", + avgopt, pctcull, samp_order, + create_component_file(0)); ofp = popen(cmd, "w"); if (ofp == NULL) { fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n", progname); exit(1); } - } else - fputs("{\n", stdout); - /* need to assign Dx, Dy, Dz? */ - if (funame != NULL) + SET_FILE_BINARY(ofp); +#ifdef getc_unlocked /* avoid lock/unlock overhead */ + flockfile(ofp); +#endif + if (rbf_colorimetry == RBCtristimulus) { + double uvcull = 100. - (100.-pctcull)*.25; + sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s", + avgopt, uvcull, samp_order, + create_component_file(1)); + uvfp[0] = popen(cmd, "w"); + sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s", + avgopt, uvcull, samp_order, + create_component_file(2)); + uvfp[1] = popen(cmd, "w"); + if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) { + fprintf(stderr, "%s: cannot open pipes to uv output\n", + progname); + exit(1); + } + SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]); +#ifdef getc_unlocked + flockfile(uvfp[0]); flockfile(uvfp[1]); +#endif + } + } else { + ofp = fopen(create_component_file(0), "w"); + if (ofp == NULL) { + fprintf(stderr, "%s: cannot create Y output file\n", + progname); + exit(1); + } + fputs("{\n", ofp); + if (rbf_colorimetry == RBCtristimulus) { + uvfp[0] = fopen(create_component_file(1), "w"); + uvfp[1] = fopen(create_component_file(2), "w"); + if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) { + fprintf(stderr, "%s: cannot create uv output file(s)\n", + progname); + exit(1); + } + fputs("{\n", uvfp[0]); + fputs("{\n", uvfp[1]); + } + } + if (funame != NULL) /* need to assign Dx, Dy, Dz? */ assignD = (fundefined(funame) < 6); + val_last = (float *)calloc(sqres, sizeof(float)); + if (funame == NULL) + sdv_next = (SDValue *)malloc(sizeof(SDValue)*sqres); + else + val_next = (float *)malloc(sizeof(float)*sqres); /* run through directions */ for (ix = 0; ix < sqres; ix++) for (iy = 0; iy < sqres; iy++) { RBFNODE *rbf = NULL; /* Klems reversal */ - SDsquare2disk(iovec, 1.-(ix+.5)/sqres, 1.-(iy+.5)/sqres); + square2disk(iovec, 1.-(ix+.5)*sqfact, 1.-(iy+.5)*sqfact); iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]); if (funame == NULL) rbf = advect_rbf(iovec, lobe_lim); + /* presample first row */ + for (oy = 0; oy < sqres; oy++) { + square2disk(iovec+3, .5*sqfact, (oy+.5)*sqfact); + iovec[5] = output_orient * + sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]); + if (funame == NULL) { + eval_rbfcol(&sdv_next[oy], rbf, iovec+3); + } else { + if (assignD) { + varset("Dx", '=', -iovec[3]); + varset("Dy", '=', -iovec[4]); + varset("Dz", '=', -iovec[5]); + ++eclock; + } + val_next[oy] = funvalue(funame, 6, iovec); + } + } for (ox = 0; ox < sqres; ox++) { - float last_bsdf = -1; + /* + * Super-sample when we detect a difference from before + * or after in this row, above or below. + */ for (oy = 0; oy < sqres; oy++) { - SDsquare2disk(iovec+3, (ox+.5)/sqres, (oy+.5)/sqres); - iovec[5] = output_orient * + if (ox < sqres-1) { /* keeping one row ahead... */ + square2disk(iovec+3, (ox+1.5)*sqfact, (oy+.5)*sqfact); + iovec[5] = output_orient * sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]); - if (funame == NULL) - bsdf = eval_rbfrep(rbf, iovec+3) * - output_orient/iovec[5]; - else { - double ssa[4], ssvec[6], sum; - int ssi; - if (assignD) { - varset("Dx", '=', -iovec[3]); - varset("Dy", '=', -iovec[4]); - varset("Dz", '=', -iovec[5]); - ++eclock; + } + if (funame == NULL) { + SDValue sdv = sdv_next[oy]; + bsdf = sdv.cieY; + if (ox < sqres-1) + eval_rbfcol(&sdv_next[oy], rbf, iovec+3); + if (abs_diff(bsdf, sdv_next[oy].cieY) > ssamp_thresh || + (ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) || + (oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) || + (oy < sqres-1 && + abs_diff(bsdf, sdv_next[oy+1].cieY) > ssamp_thresh)) { + int ssi; + double ssa[2], sum = 0, usum = 0, vsum = 0; + /* super-sample voxel */ + for (ssi = nssamp; ssi--; ) { + SDmultiSamp(ssa, 2, (ssi+frandom()) / + (double)nssamp); + square2disk(iovec+3, (ox+ssa[0])*sqfact, + (oy+ssa[1])*sqfact); + iovec[5] = output_orient * + sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]); + eval_rbfcol(&sdv, rbf, iovec+3); + sum += sdv.cieY; + if (rbf_colorimetry == RBCtristimulus) { + sdv.cieY /= + -2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.; + usum += 4.*sdv.spec.cx * sdv.cieY; + vsum += 9.*sdv.spec.cy * sdv.cieY; + } + } + bsdf = sum / (double)nssamp; + if (rbf_colorimetry == RBCtristimulus) { + uv[0] = usum / (sum+FTINY); + uv[1] = vsum / (sum+FTINY); + } + } else if (rbf_colorimetry == RBCtristimulus) { + uv[0] = uv[1] = 1. / + (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.); + uv[0] *= 4.*sdv.spec.cx; + uv[1] *= 9.*sdv.spec.cy; } - bsdf = funvalue(funame, 6, iovec); - if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) { - sum = 0; /* super-sample voxel */ + } else { + bsdf = val_next[oy]; + if (ox < sqres-1) { + if (assignD) { + varset("Dx", '=', -iovec[3]); + varset("Dy", '=', -iovec[4]); + varset("Dz", '=', -iovec[5]); + ++eclock; + } + val_next[oy] = funvalue(funame, 6, iovec); + } + if (abs_diff(bsdf, val_next[oy]) > ssamp_thresh || + (ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) || + (oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) || + (oy < sqres-1 && + abs_diff(bsdf, val_next[oy+1]) > ssamp_thresh)) { + int ssi; + double ssa[4], ssvec[6], sum = 0; + /* super-sample voxel */ for (ssi = nssamp; ssi--; ) { - SDmultiSamp(ssa, 4, (ssi+drand48())/nssamp); - SDsquare2disk(ssvec, 1.-(ix+ssa[0])/sqres, - 1.-(iy+ssa[1])/sqres); - ssvec[2] = output_orient * + SDmultiSamp(ssa, 4, (ssi+frandom()) / + (double)nssamp); + square2disk(ssvec, 1.-(ix+ssa[0])*sqfact, + 1.-(iy+ssa[1])*sqfact); + ssvec[2] = input_orient * sqrt(1. - ssvec[0]*ssvec[0] - ssvec[1]*ssvec[1]); - SDsquare2disk(ssvec+3, (ox+ssa[2])/sqres, - (oy+ssa[3])/sqres); + square2disk(ssvec+3, (ox+ssa[2])*sqfact, + (oy+ssa[3])*sqfact); ssvec[5] = output_orient * sqrt(1. - ssvec[3]*ssvec[3] - ssvec[4]*ssvec[4]); if (assignD) { - varset("Dx", '=', -iovec[3]); - varset("Dy", '=', -iovec[4]); - varset("Dz", '=', -iovec[5]); + varset("Dx", '=', -ssvec[3]); + varset("Dy", '=', -ssvec[4]); + varset("Dz", '=', -ssvec[5]); ++eclock; } sum += funvalue(funame, 6, ssvec); } - bsdf = sum/nssamp; + bsdf = sum / (double)nssamp; } } if (pctcull >= 0) - fwrite(&bsdf, sizeof(bsdf), 1, ofp); + putbinary(&bsdf, sizeof(bsdf), 1, ofp); else - printf("\t%.3e\n", bsdf); - last_bsdf = bsdf; + fprintf(ofp, "\t%.3e\n", bsdf); + + if (rbf_colorimetry == RBCtristimulus) { + if (pctcull >= 0) { + putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]); + putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]); + } else { + fprintf(uvfp[0], "\t%.3e\n", uv[0]); + fprintf(uvfp[1], "\t%.3e\n", uv[1]); + } + } + if (val_last != NULL) + val_last[oy] = bsdf; } } if (rbf != NULL) free(rbf); + prog_show((ix*sqres+iy+1.)/(sqres*sqres)); } + prog_done(); + if (val_last != NULL) { + free(val_last); + if (val_next != NULL) free(val_next); + if (sdv_next != NULL) free(sdv_next); + } if (pctcull >= 0) { /* finish output */ if (pclose(ofp)) { - fprintf(stderr, "%s: error running '%s'\n", - progname, cmd); + fprintf(stderr, "%s: error running rttree_reduce on Y\n", + progname); exit(1); } - } else - fputs("}\n", stdout); - data_epilogue(); + if (rbf_colorimetry == RBCtristimulus && + (pclose(uvfp[0]) || pclose(uvfp[1]))) { + fprintf(stderr, "%s: error running rttree_reduce on uv\n", + progname); + exit(1); + } + } else { + fputs("}\n", ofp); + if (fclose(ofp)) { + fprintf(stderr, "%s: error writing Y file\n", + progname); + exit(1); + } + if (rbf_colorimetry == RBCtristimulus) { + fputs("}\n", uvfp[0]); + fputs("}\n", uvfp[1]); + if (fclose(uvfp[0]) || fclose(uvfp[1])) { + fprintf(stderr, "%s: error writing uv file(s)\n", + progname); + exit(1); + } + } + } } +#if defined(_WIN32) || defined(_WIN64) +/* Execute wrapBSDF command (may never return) */ +static int +wrap_up(void) +{ + char cmd[32700]; + + if (bsdf_manuf[0]) { + add_wbsdf("-f", 1); + strcpy(cmd, "m="); + strcpy(cmd+2, bsdf_manuf); + add_wbsdf(cmd, 0); + } + if (bsdf_name[0]) { + add_wbsdf("-f", 1); + strcpy(cmd, "n="); + strcpy(cmd+2, bsdf_name); + add_wbsdf(cmd, 0); + } + if (!convert_commandline(cmd, sizeof(cmd), wrapBSDF)) { + fputs(progname, stderr); + fputs(": command line too long in wrap_up()\n", stderr); + return(1); + } + return(system(cmd)); +} +#else +/* Execute wrapBSDF command (may never return) */ +static int +wrap_up(void) +{ + char buf[256]; + char *compath = getpath((char *)wrapBSDF[0], getenv("PATH"), X_OK); + + if (compath == NULL) { + fprintf(stderr, "%s: cannot locate %s\n", progname, wrapBSDF[0]); + return(1); + } + if (bsdf_manuf[0]) { + add_wbsdf("-f", 1); + strcpy(buf, "m="); + strcpy(buf+2, bsdf_manuf); + add_wbsdf(buf, 0); + } + if (bsdf_name[0]) { + add_wbsdf("-f", 1); + strcpy(buf, "n="); + strcpy(buf+2, bsdf_name); + add_wbsdf(buf, 0); + } + execv(compath, wrapBSDF); /* successful call never returns */ + perror(compath); + return(1); +} +#endif + +#define HEAD_BUFLEN 10240 +static char head_buf[HEAD_BUFLEN]; +static int cur_headlen = 0; + +/* Record header line as comment associated with this SIR input */ +static int +record2header(char *s) +{ + int len = strlen(s); + + if (cur_headlen+len >= HEAD_BUFLEN-6) + return(0); + /* includes EOL */ + strcpy(head_buf+cur_headlen, s); + cur_headlen += len; + +#if defined(_WIN32) || defined(_WIN64) + if (head_buf[cur_headlen-1] == '\n') + head_buf[cur_headlen-1] = '\t'; +#endif + return(1); +} + +/* Finish off header for this file */ +static void +done_header(void) +{ + while (cur_headlen > 0 && isspace(head_buf[cur_headlen-1])) + --cur_headlen; + head_buf[cur_headlen] = '\0'; + if (!cur_headlen) + return; + add_wbsdf("-C", 1); + add_wbsdf(head_buf, 0); + head_buf[cur_headlen=0] = '\0'; +} + /* Read in BSDF and interpolate as tensor tree representation */ int main(int argc, char *argv[]) { - int dofwd = 0, dobwd = 1; - int i, na; + static const char tfmt[2][4] = {"t4", "t3"}; + int dofwd = 0, dobwd = 1; + int nsirs = 0; + char buf[1024]; + int i; progname = argv[0]; esupport |= E_VARIABLE|E_FUNCTION|E_RCONST; esupport &= ~(E_INCHAN|E_OUTCHAN); scompile("PI:3.14159265358979323846", NULL, 0); biggerlib(); - for (i = 1; i < argc-1 && (argv[i][0] == '-') | (argv[i][0] == '+'); i++) - switch (argv[i][1]) { /* get options */ + strcpy(buf, "File produced by: "); + if (convert_commandline(buf+18, sizeof(buf)-18, argv) != NULL) { + add_wbsdf("-C", 1); add_wbsdf(buf, 0); + } + for (i = 1; i < argc; i++) + if ((argv[i][0] == '-') | (argv[i][0] == '+')) { + switch (argv[i][1]) { /* get option */ case 'e': scompile(argv[++i], NULL, 0); + if (single_plane_incident < 0) + single_plane_incident = 0; break; case 'f': - if (!argv[i][2]) - fcompile(argv[++i]); - else + if ((argv[i][0] == '-') & !argv[i][2]) { + if (strchr(argv[++i], '=') != NULL) { + add_wbsdf("-f", 1); + add_wbsdf(argv[i], 1); + } else { + char *fpath = getpath(argv[i], + getrlibpath(), 0); + if (fpath == NULL) { + fprintf(stderr, + "%s: cannot find file '%s'\n", + argv[0], argv[i]); + return(1); + } + fcompile(fpath); + if (single_plane_incident < 0) + single_plane_incident = 0; + } + } else dofwd = (argv[i][0] == '+'); break; + case 'a': + recip = (argv[i][0] == '+') ? " -a" : ""; + break; case 'b': dobwd = (argv[i][0] == '+'); break; + case 'n': + nssamp = atoi(argv[++i]); + if (nssamp <= 0) + goto userr; + break; + case 's': + ssamp_thresh = atof(argv[++i]); + if (ssamp_thresh <= FTINY) + goto userr; + break; case 't': switch (argv[i][2]) { case '3': @@ -363,77 +822,104 @@ main(int argc, char *argv[]) case 'l': lobe_lim = atoi(argv[++i]); break; + case 'p': + do_prog = atoi(argv[i]+2); + break; + case 'W': + add_wbsdf(argv[i], 1); + break; + case 'u': + case 'C': + add_wbsdf(argv[i], 1); + add_wbsdf(argv[++i], 1); + break; default: goto userr; } - if (single_plane_incident >= 0) { /* function-based BSDF? */ + } else { /* input SIR or function */ + FILE *fpin; + if (!nsirs & (single_plane_incident >= 0)) + break; /* must be a function */ + if (nsirs >= 4) { + fprintf(stderr, "At most 4 SIR inputs supported\n"); + goto userr; + } + fpin = fopen(argv[i], "rb"); /* open SIR file */ + if (fpin == NULL) { + fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n", + progname, argv[i]); + return(1); + } + sprintf(buf, "%s:\n", argv[i]); + record2header(buf); + sir_headshare = &record2header; + if (!load_bsdf_rep(fpin)) + return(1); + fclose(fpin); + done_header(); + sprintf(buf, "Interpolating component '%s'", argv[i]); + prog_start(buf); + if (!nsirs++) { + add_wbsdf("-a", 1); + add_wbsdf(tfmt[single_plane_incident], 1); + } + if (single_plane_incident) + eval_isotropic(NULL); + else + eval_anisotropic(NULL); + } + if (i < argc) { /* function-based BSDF? */ void (*evf)(char *s) = single_plane_incident ? - &eval_isotropic : &eval_anisotropic; + eval_isotropic : eval_anisotropic; if (i != argc-1 || fundefined(argv[i]) < 3) { fprintf(stderr, "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n", progname); - fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n", - progname); + fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n"); goto userr; } ++eclock; - xml_prologue(argc, argv); /* start XML output */ + add_wbsdf("-a", 1); + add_wbsdf(tfmt[single_plane_incident], 1); if (dofwd) { input_orient = -1; output_orient = -1; - (*evf)(argv[i]); /* outside reflectance */ + prog_start("Evaluating outside reflectance"); + (*evf)(argv[i]); output_orient = 1; - (*evf)(argv[i]); /* outside -> inside */ + prog_start("Evaluating outside->inside transmission"); + (*evf)(argv[i]); } if (dobwd) { input_orient = 1; output_orient = 1; - (*evf)(argv[i]); /* inside reflectance */ + prog_start("Evaluating inside reflectance"); + (*evf)(argv[i]); output_orient = -1; - (*evf)(argv[i]); /* inside -> outside */ + prog_start("Evaluating inside->outside transmission"); + (*evf)(argv[i]); } - xml_epilogue(); /* finish XML output & exit */ - return(0); + } else if (!nsirs) { /* else load SIR from stdin? */ + record2header(":\n"); + sir_headshare = &record2header; + if (!load_bsdf_rep(stdin)) + return(1); + done_header(); + prog_start("Interpolating from standard input"); + add_wbsdf("-a", 1); + add_wbsdf(tfmt[single_plane_incident], 1); + if (single_plane_incident) /* resample dist. */ + eval_isotropic(NULL); + else + eval_anisotropic(NULL); } - if (i < argc) { /* open input files if given */ - int nbsdf = 0; - for ( ; i < argc; i++) { /* interpolate each component */ - FILE *fpin = fopen(argv[i], "rb"); - if (fpin == NULL) { - fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n", - progname, argv[i]); - return(1); - } - if (!load_bsdf_rep(fpin)) - return(1); - fclose(fpin); - if (!nbsdf++) /* start XML on first dist. */ - xml_prologue(argc, argv); - if (single_plane_incident) - eval_isotropic(NULL); - else - eval_anisotropic(NULL); - } - xml_epilogue(); /* finish XML output & exit */ - return(0); - } - SET_FILE_BINARY(stdin); /* load from stdin */ - if (!load_bsdf_rep(stdin)) - return(1); - xml_prologue(argc, argv); /* start XML output */ - if (single_plane_incident) /* resample dist. */ - eval_isotropic(NULL); - else - eval_anisotropic(NULL); - xml_epilogue(); /* finish XML output & exit */ - return(0); + return(wrap_up()); /* call wrapBSDF */ userr: fprintf(stderr, - "Usage: %s [-g Nlog2][-t pctcull][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n", + "Usage: %s [{+|-}a][-g Nlog2][-t pctcull][-n nss][-s thresh][-l maxlobes][bsdf.sir ..] > bsdf.xml\n", progname); fprintf(stderr, - " or: %s -t{3|4} [-g Nlog2][-t pctcull][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n", + " or: %s -t{3|4} [{+|-}a][-g Nlog2][-t pctcull][-n nss][-s thresh][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n", progname); return(1); }
