perf(bsdf2ttree): BREAKING CHANGE - changed reciprocity averaging default from "on" (+a) to "off" (-a)
fix: made it so '+f' works as '+forward' instead of trying to load file
refactor: removed prefix from SDdisk2square() and SDsquare2disk() & made consistent
style: line returns where they didn't belong
feat(bsdf2ttree): made it so options/parameters may differ per input SIR
fix(bsdf2klems, bsdf2ttree): increased command-line buffer to accommodate comments in Windows
fix(bsdf2klems, bsdf2ttree): preventing issues on Windows with newlines in commands
feat(bsdf2klems, bsdf2ttree): added XML header comments copying useful information from SIR inputs
Added -n and -s options to bsdf2ttree to control super-sampling
Fixed curly bracket in the wrong place (loop is WAAY too long!)
Hopefully final sampling improvement -- tests for differences on all sides
Forgot to clear the flags from previous row
Different thresholds for interpolant data versus function specification
Various improvements to adaptive sampling method
Increased super-sampling amount and sensitivity
Improved finding of peak in isotropic function (and RBF) input
Added super-sampling for peaky radial basis functions
Removed unnecessary calls to c_ccvt()
Minor cosmetic fixes
Decreased number of super-samples to improve speed
Minor cleanup and fixes
Refactored bsdf2ttree for Yuv representation
Fixing premature and accidental check-in
Improved progress bar feedback
Fixed one minor and one major bug in super-sampling (major bug in transmission)
Changed progress bar to erase itself when done
Disabled DEBUG statements in BSDF programs and added progress bars
Added flockfile calls to reduce i/o overhead
Fixed compiler warnings
Include random.h for Windows instead of calling drand48
Re-allowed rttree_reduce -a option for isotropic transmission
Fixed call to rttree_reduce to avoid -a on transmitted components
Added -l option to limit maximum number of RBF lobes for interpolation
Added ability to use Dx, Dy and Dz instead of last 3 function parameters
Switched float to double for summing variable
Added super-sampling at peaks
Fixed different bug in -t3 option
Fixed bug in -t3/-t4 option
Fixed bug for BSDF file input and added further error messages
Added ability to generate tensor tree directly from function
Fixed main bug, which was forgetting Klems axis reversal
Tried to improve convergence of RBF fit
Minor bug fixes
Made code a little more readable
Added data to complete XML file output
Added GRIDRES to saved BSDF representation
Hopeful bug fix in BSDF interpolation code
Bug fixes in loading BSDF interpolant data
