root/radiance/ray/src/cv/bsdf2ttree.c
Revision: 2.63
Committed: Tue Jun 3 21:31:51 2025 UTC (3 weeks ago) by greg
Changes since 2.62: +3 -5 lines
2 static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.62 2025/05/21 20:42:48 greg Exp $";
5 * Load measured BSDF interpolant and write out as XML file with tensor tree.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdlib.h>
12 #include <math.h>
13 #include <ctype.h>
14 #include "random.h"
15 #include "platform.h"
16 #include "paths.h"
17 #include "rtio.h"
18 #include "calcomp.h"
19 #include "bsdfrep.h"
20 /* reciprocity averaging option */
21 static const char *recip = "";
22 /* percentage to cull (<0 to turn off) */
23 static double pctcull = 90.;
24 /* sampling order */
25 static int samp_order = 6;
26 /* super-sampling threshold */
27 static double ssamp_thresh = 0.35;
28 /* number of super-samples */
29 static int nssamp = 64;
30 /* limit on number of RBF lobes */
31 static int lobe_lim = 15000;
32 /* progress bar length */
33 static int do_prog = 79;
34
35 #define MAXCARG 512 /* wrapBSDF command */
36 static char *wrapBSDF[MAXCARG] = {"wrapBSDF", "-U"};
37 static int wbsdfac = 2;
38
39 /* Add argument to wrapBSDF, allocating space if !isstatic */
40 static void
41 add_wbsdf(const char *arg, int isstatic)
42 {
43 if (arg == NULL)
44 return;
45 if (wbsdfac >= MAXCARG-1) {
46 fputs(progname, stderr);
47 fputs(": too many command arguments to wrapBSDF\n", stderr);
48 exit(1);
49 }
50 if (!*arg)
51 arg = "";
52 else if (!isstatic)
53 arg = savqstr((char *)arg);
54
55 wrapBSDF[wbsdfac++] = (char *)arg;
56 }
57
58 /* Create Yuv component file and add appropriate arguments */
59 static char *
60 create_component_file(int c)
61 {
62 static const char sname[3][6] = {"CIE-Y", "CIE-u", "CIE-v"};
63 static const char cname[4][4] = {"-rf", "-tf", "-tb", "-rb"};
64 char *tfname = mktemp(savqstr(TEMPLATE));
65
66 add_wbsdf("-s", 1); add_wbsdf(sname[c], 1);
67 add_wbsdf(cname[(input_orient>0)<<1 | (output_orient>0)], 1);
68 add_wbsdf(tfname, 1);
69 return(tfname);
70 }
71
72 /* Start new progress bar */
73 #define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else
74
75 /* Draw progress bar of the appropriate length */
76 static void
77 prog_show(double frac)
78 {
79 static unsigned call_cnt = 0;
80 static char lastc[] = "-\\|/";
81 char pbar[256];
82 int nchars;
83
84 if (do_prog <= 1) return;
85 if (do_prog > sizeof(pbar)-2)
86 do_prog = sizeof(pbar)-2;
87 if (frac < 0) frac = 0;
88 else if (frac >= 1) frac = .9999;
89 nchars = do_prog*frac;
90 pbar[0] = '\r';
91 memset(pbar+1, '*', nchars);
92 pbar[nchars+1] = lastc[call_cnt++ & 3];
93 memset(pbar+2+nchars, '-', do_prog-nchars-1);
94 pbar[do_prog+1] = '\0';
95 fputs(pbar, stderr);
96 }
97
98 /* Finish progress bar */
99 static void
100 prog_done(void)
101 {
102 int n = do_prog;
103
104 if (n <= 1) return;
105 fputc('\r', stderr);
106 while (n--)
107 fputc(' ', stderr);
108 fputc('\r', stderr);
109 }
110
111 /* Compute absolute relative difference */
112 static double
113 abs_diff(double v1, double v0)
114 {
115 if ((v0 < 0) | (v1 < 0))
116 return(.0);
117 v1 = (v1-v0)*2./(v0+v1+.0001);
118 if (v1 < 0)
119 return(-v1);
120 return(v1);
121 }
122
123 /* Interpolate and output isotropic BSDF data */
124 static void
125 eval_isotropic(char *funame)
126 {
127 const int sqres = 1<<samp_order;
128 const double sqfact = 1./(double)sqres;
129 float *val_last = NULL;
130 float *val_next = NULL;
131 SDValue *sdv_next = NULL;
132 FILE *ofp, *uvfp[2];
133 int assignD = 0;
134 char cmd[128];
135 int ix, ox, oy;
136 RREAL iovec[6];
137 float bsdf, uv[2];
138
139 if (pctcull >= 0) {
140 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
141 recip, pctcull, samp_order, create_component_file(0));
142 ofp = popen(cmd, "w");
143 if (ofp == NULL) {
144 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
145 progname);
146 exit(1);
147 }
148 SET_FILE_BINARY(ofp);
149 #ifdef getc_unlocked /* avoid lock/unlock overhead */
150 flockfile(ofp);
151 #endif
152 if (rbf_colorimetry == RBCtristimulus) {
153 double uvcull = 100. - (100.-pctcull)*.25;
154 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
155 recip, uvcull, samp_order, create_component_file(1));
156 uvfp[0] = popen(cmd, "w");
157 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
158 recip, uvcull, samp_order, create_component_file(2));
159 uvfp[1] = popen(cmd, "w");
160 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
161 fprintf(stderr, "%s: cannot open pipes to uv output\n",
162 progname);
163 exit(1);
164 }
165 SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
166 #ifdef getc_unlocked
167 flockfile(uvfp[0]); flockfile(uvfp[1]);
168 #endif
169 }
170 } else {
171 ofp = fopen(create_component_file(0), "w");
172 if (ofp == NULL) {
173 fprintf(stderr, "%s: cannot create Y output file\n",
174 progname);
175 exit(1);
176 }
177 fputs("{\n", ofp);
178 if (rbf_colorimetry == RBCtristimulus) {
179 uvfp[0] = fopen(create_component_file(1), "w");
180 uvfp[1] = fopen(create_component_file(2), "w");
181 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
182 fprintf(stderr, "%s: cannot create uv output file(s)\n",
183 progname);
184 exit(1);
185 }
186 fputs("{\n", uvfp[0]);
187 fputs("{\n", uvfp[1]);
188 }
189 }
190 if (funame != NULL) /* need to assign Dx, Dy, Dz? */
191 assignD = (fundefined(funame) < 6);
192 val_last = (float *)calloc(sqres, sizeof(float));
193 if (funame == NULL)
194 sdv_next = (SDValue *)malloc(sizeof(SDValue)*sqres);
195 else
196 val_next = (float *)malloc(sizeof(float)*sqres);
197 /* run through directions */
198 for (ix = 0; ix < sqres/2; ix++) {
199 const int zipsgn = (ix & 1)*2 - 1;
200 RBFNODE *rbf = NULL;
201 iovec[0] = 2.*sqfact*(ix+.5) - 1.;
202 iovec[1] = zipsgn*sqfact*.5;
203 iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]
204 - iovec[1]*iovec[1]);
205 if (funame == NULL)
206 rbf = advect_rbf(iovec, lobe_lim);
207 /* presample first row */
208 for (oy = 0; oy < sqres; oy++) {
209 square2disk(iovec+3, .5*sqfact, (oy+.5)*sqfact);
210 iovec[5] = output_orient *
211 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
212 if (funame == NULL) {
213 eval_rbfcol(&sdv_next[oy], rbf, iovec+3);
214 } else {
215 if (assignD) {
216 varset("Dx", '=', -iovec[3]);
217 varset("Dy", '=', -iovec[4]);
218 varset("Dz", '=', -iovec[5]);
219 ++eclock;
220 }
221 val_next[oy] = funvalue(funame, 6, iovec);
222 }
223 }
224 for (ox = 0; ox < sqres; ox++) {
225 /*
226 * Super-sample when we detect a difference from before
227 * or after in this row, above or below.
228 */
229 for (oy = 0; oy < sqres; oy++) {
230 if (ox < sqres-1) { /* keeping one row ahead... */
231 square2disk(iovec+3, (ox+1.5)*sqfact, (oy+.5)*sqfact);
232 iovec[5] = output_orient *
233 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
234 }
235 if (funame == NULL) {
236 SDValue sdv = sdv_next[oy];
237 bsdf = sdv.cieY;
238 if (ox < sqres-1)
239 eval_rbfcol(&sdv_next[oy], rbf, iovec+3);
240 if (abs_diff(bsdf, sdv_next[oy].cieY) > ssamp_thresh ||
241 (ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) ||
242 (oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) ||
243 (oy < sqres-1 &&
244 abs_diff(bsdf, sdv_next[oy+1].cieY) > ssamp_thresh)) {
245 int ssi;
246 double ssa[2], sum = 0, usum = 0, vsum = 0;
247 /* super-sample voxel */
248 for (ssi = nssamp; ssi--; ) {
249 SDmultiSamp(ssa, 2, (ssi+frandom()) /
250 (double)nssamp);
251 square2disk(iovec+3, (ox+ssa[0])*sqfact,
252 (oy+ssa[1])*sqfact);
253 iovec[5] = output_orient *
254 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
255 eval_rbfcol(&sdv, rbf, iovec+3);
256 sum += sdv.cieY;
257 if (rbf_colorimetry == RBCtristimulus) {
258 sdv.cieY /=
259 -2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.;
260 usum += 4.*sdv.spec.cx * sdv.cieY;
261 vsum += 9.*sdv.spec.cy * sdv.cieY;
262 }
263 }
264 bsdf = sum / (double)nssamp;
265 if (rbf_colorimetry == RBCtristimulus) {
266 uv[0] = usum / (sum+FTINY);
267 uv[1] = vsum / (sum+FTINY);
268 }
269 } else if (rbf_colorimetry == RBCtristimulus) {
270 uv[0] = uv[1] = 1. /
271 (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
272 uv[0] *= 4.*sdv.spec.cx;
273 uv[1] *= 9.*sdv.spec.cy;
274 }
275 } else {
276 bsdf = val_next[oy];
277 if (ox < sqres-1) {
278 if (assignD) {
279 varset("Dx", '=', -iovec[3]);
280 varset("Dy", '=', -iovec[4]);
281 varset("Dz", '=', -iovec[5]);
282 ++eclock;
283 }
284 val_next[oy] = funvalue(funame, 6, iovec);
285 }
286 if (abs_diff(bsdf, val_next[oy]) > ssamp_thresh ||
287 (ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) ||
288 (oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) ||
289 (oy < sqres-1 &&
290 abs_diff(bsdf, val_next[oy+1]) > ssamp_thresh)) {
291 int ssi;
292 double ssa[4], ssvec[6], sum = 0;
293 /* super-sample voxel */
294 for (ssi = nssamp; ssi--; ) {
295 SDmultiSamp(ssa, 4, (ssi+frandom()) /
296 (double)nssamp);
297 ssvec[0] = 2.*sqfact*(ix+ssa[0]) - 1.;
298 ssvec[1] = zipsgn*sqfact*ssa[1];
299 ssvec[2] = 1. - ssvec[0]*ssvec[0]
300 - ssvec[1]*ssvec[1];
301 if (ssvec[2] < .0) {
302 ssvec[1] = 0;
303 ssvec[2] = 1. - ssvec[0]*ssvec[0];
304 }
305 ssvec[2] = input_orient * sqrt(ssvec[2]);
306 square2disk(ssvec+3, (ox+ssa[2])*sqfact,
307 (oy+ssa[3])*sqfact);
308 ssvec[5] = output_orient *
309 sqrt(1. - ssvec[3]*ssvec[3] -
310 ssvec[4]*ssvec[4]);
311 if (assignD) {
312 varset("Dx", '=', -ssvec[3]);
313 varset("Dy", '=', -ssvec[4]);
314 varset("Dz", '=', -ssvec[5]);
315 ++eclock;
316 }
317 sum += funvalue(funame, 6, ssvec);
318 }
319 bsdf = sum / (double)nssamp;
320 }
321 }
322 if (pctcull >= 0)
323 putbinary(&bsdf, sizeof(bsdf), 1, ofp);
324 else
325 fprintf(ofp, "\t%.3e\n", bsdf);
326
327 if (rbf_colorimetry == RBCtristimulus) {
328 if (pctcull >= 0) {
329 putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]);
330 putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]);
331 } else {
332 fprintf(uvfp[0], "\t%.3e\n", uv[0]);
333 fprintf(uvfp[1], "\t%.3e\n", uv[1]);
334 }
335 }
336 if (val_last != NULL)
337 val_last[oy] = bsdf;
338 }
339 }
340 if (rbf != NULL)
341 free(rbf);
342 prog_show((ix+1.)*(2.*sqfact));
343 }
344 prog_done();
345 if (val_last != NULL) {
346 free(val_last);
347 if (val_next != NULL) free(val_next);
348 if (sdv_next != NULL) free(sdv_next);
349 }
350 if (pctcull >= 0) { /* finish output */
351 if (pclose(ofp)) {
352 fprintf(stderr, "%s: error running rttree_reduce on Y\n",
353 progname);
354 exit(1);
355 }
356 if (rbf_colorimetry == RBCtristimulus &&
357 (pclose(uvfp[0]) || pclose(uvfp[1]))) {
358 fprintf(stderr, "%s: error running rttree_reduce on uv\n",
359 progname);
360 exit(1);
361 }
362 } else {
363 for (ix = sqres*sqres*sqres/2; ix--; )
364 fputs("\t0\n", ofp);
365 fputs("}\n", ofp);
366 if (fclose(ofp)) {
367 fprintf(stderr, "%s: error writing Y file\n",
368 progname);
369 exit(1);
370 }
371 if (rbf_colorimetry == RBCtristimulus) {
372 for (ix = sqres*sqres*sqres/2; ix--; ) {
373 fputs("\t0\n", uvfp[0]);
374 fputs("\t0\n", uvfp[1]);
375 }
376 fputs("}\n", uvfp[0]);
377 fputs("}\n", uvfp[1]);
378 if (fclose(uvfp[0]) || fclose(uvfp[1])) {
379 fprintf(stderr, "%s: error writing uv file(s)\n",
380 progname);
381 exit(1);
382 }
383 }
384 }
385 }
386
387 /* Interpolate and output anisotropic BSDF data */
388 static void
389 eval_anisotropic(char *funame)
390 {
391 const int sqres = 1<<samp_order;
392 const double sqfact = 1./(double)sqres;
393 float *val_last = NULL;
394 float *val_next = NULL;
395 SDValue *sdv_next = NULL;
396 FILE *ofp, *uvfp[2];
397 int assignD = 0;
398 char cmd[128];
399 int ix, iy, ox, oy;
400 RREAL iovec[6];
401 float bsdf, uv[2];
402
403 if (pctcull >= 0) {
404 const char *avgopt = (input_orient>0 ^ output_orient>0)
405 ? "" : recip;
406 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
407 avgopt, pctcull, samp_order,
408 create_component_file(0));
409 ofp = popen(cmd, "w");
410 if (ofp == NULL) {
411 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
412 progname);
413 exit(1);
414 }
415 SET_FILE_BINARY(ofp);
416 #ifdef getc_unlocked /* avoid lock/unlock overhead */
417 flockfile(ofp);
418 #endif
419 if (rbf_colorimetry == RBCtristimulus) {
420 double uvcull = 100. - (100.-pctcull)*.25;
421 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
422 avgopt, uvcull, samp_order,
423 create_component_file(1));
424 uvfp[0] = popen(cmd, "w");
425 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
426 avgopt, uvcull, samp_order,
427 create_component_file(2));
428 uvfp[1] = popen(cmd, "w");
429 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
430 fprintf(stderr, "%s: cannot open pipes to uv output\n",
431 progname);
432 exit(1);
433 }
434 SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
435 #ifdef getc_unlocked
436 flockfile(uvfp[0]); flockfile(uvfp[1]);
437 #endif
438 }
439 } else {
440 ofp = fopen(create_component_file(0), "w");
441 if (ofp == NULL) {
442 fprintf(stderr, "%s: cannot create Y output file\n",
443 progname);
444 exit(1);
445 }
446 fputs("{\n", ofp);
447 if (rbf_colorimetry == RBCtristimulus) {
448 uvfp[0] = fopen(create_component_file(1), "w");
449 uvfp[1] = fopen(create_component_file(2), "w");
450 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
451 fprintf(stderr, "%s: cannot create uv output file(s)\n",
452 progname);
453 exit(1);
454 }
455 fputs("{\n", uvfp[0]);
456 fputs("{\n", uvfp[1]);
457 }
458 }
459 if (funame != NULL) /* need to assign Dx, Dy, Dz? */
460 assignD = (fundefined(funame) < 6);
461 val_last = (float *)calloc(sqres, sizeof(float));
462 if (funame == NULL)
463 sdv_next = (SDValue *)malloc(sizeof(SDValue)*sqres);
464 else
465 val_next = (float *)malloc(sizeof(float)*sqres);
466 /* run through directions */
467 for (ix = 0; ix < sqres; ix++)
468 for (iy = 0; iy < sqres; iy++) {
469 RBFNODE *rbf = NULL; /* Klems reversal */
470 square2disk(iovec, 1.-(ix+.5)*sqfact, 1.-(iy+.5)*sqfact);
471 iovec[2] = input_orient *
472 sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]);
473 if (funame == NULL)
474 rbf = advect_rbf(iovec, lobe_lim);
475 /* presample first row */
476 for (oy = 0; oy < sqres; oy++) {
477 square2disk(iovec+3, .5*sqfact, (oy+.5)*sqfact);
478 iovec[5] = output_orient *
479 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
480 if (funame == NULL) {
481 eval_rbfcol(&sdv_next[oy], rbf, iovec+3);
482 } else {
483 if (assignD) {
484 varset("Dx", '=', -iovec[3]);
485 varset("Dy", '=', -iovec[4]);
486 varset("Dz", '=', -iovec[5]);
487 ++eclock;
488 }
489 val_next[oy] = funvalue(funame, 6, iovec);
490 }
491 }
492 for (ox = 0; ox < sqres; ox++) {
493 /*
494 * Super-sample when we detect a difference from before
495 * or after in this row, above or below.
496 */
497 for (oy = 0; oy < sqres; oy++) {
498 if (ox < sqres-1) { /* keeping one row ahead... */
499 square2disk(iovec+3, (ox+1.5)*sqfact, (oy+.5)*sqfact);
500 iovec[5] = output_orient *
501 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
502 }
503 if (funame == NULL) {
504 SDValue sdv = sdv_next[oy];
505 bsdf = sdv.cieY;
506 if (ox < sqres-1)
507 eval_rbfcol(&sdv_next[oy], rbf, iovec+3);
508 if (abs_diff(bsdf, sdv_next[oy].cieY) > ssamp_thresh ||
509 (ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) ||
510 (oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) ||
511 (oy < sqres-1 &&
512 abs_diff(bsdf, sdv_next[oy+1].cieY) > ssamp_thresh)) {
513 int ssi;
514 double ssa[2], sum = 0, usum = 0, vsum = 0;
515 /* super-sample voxel */
516 for (ssi = nssamp; ssi--; ) {
517 SDmultiSamp(ssa, 2, (ssi+frandom()) /
518 (double)nssamp);
519 square2disk(iovec+3, (ox+ssa[0])*sqfact,
520 (oy+ssa[1])*sqfact);
521 iovec[5] = output_orient *
522 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
523 eval_rbfcol(&sdv, rbf, iovec+3);
524 sum += sdv.cieY;
525 if (rbf_colorimetry == RBCtristimulus) {
526 sdv.cieY /=
527 -2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.;
528 usum += 4.*sdv.spec.cx * sdv.cieY;
529 vsum += 9.*sdv.spec.cy * sdv.cieY;
530 }
531 }
532 bsdf = sum / (double)nssamp;
533 if (rbf_colorimetry == RBCtristimulus) {
534 uv[0] = usum / (sum+FTINY);
535 uv[1] = vsum / (sum+FTINY);
536 }
537 } else if (rbf_colorimetry == RBCtristimulus) {
538 uv[0] = uv[1] = 1. /
539 (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
540 uv[0] *= 4.*sdv.spec.cx;
541 uv[1] *= 9.*sdv.spec.cy;
542 }
543 } else {
544 bsdf = val_next[oy];
545 if (ox < sqres-1) {
546 if (assignD) {
547 varset("Dx", '=', -iovec[3]);
548 varset("Dy", '=', -iovec[4]);
549 varset("Dz", '=', -iovec[5]);
550 ++eclock;
551 }
552 val_next[oy] = funvalue(funame, 6, iovec);
553 }
554 if (abs_diff(bsdf, val_next[oy]) > ssamp_thresh ||
555 (ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) ||
556 (oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) ||
557 (oy < sqres-1 &&
558 abs_diff(bsdf, val_next[oy+1]) > ssamp_thresh)) {
559 int ssi;
560 double ssa[4], ssvec[6], sum = 0;
561 /* super-sample voxel */
562 for (ssi = nssamp; ssi--; ) {
563 SDmultiSamp(ssa, 4, (ssi+frandom()) /
564 (double)nssamp);
565 square2disk(ssvec, 1.-(ix+ssa[0])*sqfact,
566 1.-(iy+ssa[1])*sqfact);
567 ssvec[2] = input_orient *
568 sqrt(1. - ssvec[0]*ssvec[0] -
569 ssvec[1]*ssvec[1]);
570 square2disk(ssvec+3, (ox+ssa[2])*sqfact,
571 (oy+ssa[3])*sqfact);
572 ssvec[5] = output_orient *
573 sqrt(1. - ssvec[3]*ssvec[3] -
574 ssvec[4]*ssvec[4]);
575 if (assignD) {
576 varset("Dx", '=', -ssvec[3]);
577 varset("Dy", '=', -ssvec[4]);
578 varset("Dz", '=', -ssvec[5]);
579 ++eclock;
580 }
581 sum += funvalue(funame, 6, ssvec);
582 }
583 bsdf = sum / (double)nssamp;
584 }
585 }
586 if (pctcull >= 0)
587 putbinary(&bsdf, sizeof(bsdf), 1, ofp);
588 else
589 fprintf(ofp, "\t%.3e\n", bsdf);
590
591 if (rbf_colorimetry == RBCtristimulus) {
592 if (pctcull >= 0) {
593 putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]);
594 putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]);
595 } else {
596 fprintf(uvfp[0], "\t%.3e\n", uv[0]);
597 fprintf(uvfp[1], "\t%.3e\n", uv[1]);
598 }
599 }
600 if (val_last != NULL)
601 val_last[oy] = bsdf;
602 }
603 }
604 if (rbf != NULL)
605 free(rbf);
606 prog_show((ix*sqres+iy+1.)/(sqres*sqres));
607 }
608 prog_done();
609 if (val_last != NULL) {
610 free(val_last);
611 if (val_next != NULL) free(val_next);
612 if (sdv_next != NULL) free(sdv_next);
613 }
614 if (pctcull >= 0) { /* finish output */
615 if (pclose(ofp)) {
616 fprintf(stderr, "%s: error running rttree_reduce on Y\n",
617 progname);
618 exit(1);
619 }
620 if (rbf_colorimetry == RBCtristimulus &&
621 (pclose(uvfp[0]) || pclose(uvfp[1]))) {
622 fprintf(stderr, "%s: error running rttree_reduce on uv\n",
623 progname);
624 exit(1);
625 }
626 } else {
627 fputs("}\n", ofp);
628 if (fclose(ofp)) {
629 fprintf(stderr, "%s: error writing Y file\n",
630 progname);
631 exit(1);
632 }
633 if (rbf_colorimetry == RBCtristimulus) {
634 fputs("}\n", uvfp[0]);
635 fputs("}\n", uvfp[1]);
636 if (fclose(uvfp[0]) || fclose(uvfp[1])) {
637 fprintf(stderr, "%s: error writing uv file(s)\n",
638 progname);
639 exit(1);
640 }
641 }
642 }
643 }
644
645 #if defined(_WIN32) || defined(_WIN64)
646 /* Execute wrapBSDF command (may never return) */
647 static int
648 wrap_up(void)
649 {
650 char cmd[32700];
651
652 if (bsdf_manuf[0]) {
653 add_wbsdf("-f", 1);
654 strcpy(cmd, "m=");
655 strcpy(cmd+2, bsdf_manuf);
656 add_wbsdf(cmd, 0);
657 }
658 if (bsdf_name[0]) {
659 add_wbsdf("-f", 1);
660 strcpy(cmd, "n=");
661 strcpy(cmd+2, bsdf_name);
662 add_wbsdf(cmd, 0);
663 }
664 if (!convert_commandline(cmd, sizeof(cmd), wrapBSDF)) {
665 fputs(progname, stderr);
666 fputs(": command line too long in wrap_up()\n", stderr);
667 return(1);
668 }
669 return(system(cmd));
670 }
671 #else
672 /* Execute wrapBSDF command (may never return) */
673 static int
674 wrap_up(void)
675 {
676 char buf[256];
677 char *compath = getpath((char *)wrapBSDF[0], getenv("PATH"), X_OK);
678
679 if (compath == NULL) {
680 fprintf(stderr, "%s: cannot locate %s\n", progname, wrapBSDF[0]);
681 return(1);
682 }
683 if (bsdf_manuf[0]) {
684 add_wbsdf("-f", 1);
685 strcpy(buf, "m=");
686 strcpy(buf+2, bsdf_manuf);
687 add_wbsdf(buf, 0);
688 }
689 if (bsdf_name[0]) {
690 add_wbsdf("-f", 1);
691 strcpy(buf, "n=");
692 strcpy(buf+2, bsdf_name);
693 add_wbsdf(buf, 0);
694 }
695 execv(compath, wrapBSDF); /* successful call never returns */
696 perror(compath);
697 return(1);
698 }
699 #endif
700
701 #define HEAD_BUFLEN 10240
702 static char head_buf[HEAD_BUFLEN];
703 static int cur_headlen = 0;
704
705 /* Record header line as comment associated with this SIR input */
706 static int
707 record2header(char *s)
708 {
709 int len = strlen(s);
710
711 if (cur_headlen+len >= HEAD_BUFLEN-6)
712 return(0);
713 /* includes EOL */
714 strcpy(head_buf+cur_headlen, s);
715 cur_headlen += len;
716
717 #if defined(_WIN32) || defined(_WIN64)
718 if (head_buf[cur_headlen-1] == '\n')
719 head_buf[cur_headlen-1] = '\t';
720 #endif
721 return(1);
722 }
723
724 /* Finish off header for this file */
725 static void
726 done_header(void)
727 {
728 while (cur_headlen > 0 && isspace(head_buf[cur_headlen-1]))
729 --cur_headlen;
730 head_buf[cur_headlen] = '\0';
731 if (!cur_headlen)
732 return;
733 add_wbsdf("-C", 1);
734 add_wbsdf(head_buf, 0);
735 head_buf[cur_headlen=0] = '\0';
736 }
737
738 /* Read in BSDF and interpolate as tensor tree representation */
739 int
740 main(int argc, char *argv[])
741 {
742 static const char tfmt[2][4] = {"t4", "t3"};
743 int dofwd = 0, dobwd = 1;
744 int nsirs = 0;
745 char buf[1024];
746 int i;
747 /* set global progname */
748 fixargv0(argv[0]);
749 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
750 esupport &= ~(E_INCHAN|E_OUTCHAN);
751 scompile("PI:3.14159265358979323846", NULL, 0);
752 biggerlib();
753 strcpy(buf, "File produced by: ");
754 if (convert_commandline(buf+18, sizeof(buf)-18, argv) != NULL) {
755 add_wbsdf("-C", 1); add_wbsdf(buf, 0);
756 }
757 for (i = 1; i < argc; i++)
758 if ((argv[i][0] == '-') | (argv[i][0] == '+')) {
759 switch (argv[i][1]) { /* get option */
760 case 'e':
761 scompile(argv[++i], NULL, 0);
762 if (single_plane_incident < 0)
763 single_plane_incident = 0;
764 break;
765 case 'f':
766 if ((argv[i][0] == '-') & !argv[i][2]) {
767 if (strchr(argv[++i], '=') != NULL) {
768 add_wbsdf("-f", 1);
769 add_wbsdf(argv[i], 1);
770 } else {
771 char *fpath = getpath(argv[i],
772 getrlibpath(), 0);
773 if (fpath == NULL) {
774 fprintf(stderr,
775 "%s: cannot find file '%s'\n",
776 argv[0], argv[i]);
777 return(1);
778 }
779 fcompile(fpath);
780 if (single_plane_incident < 0)
781 single_plane_incident = 0;
782 }
783 } else
784 dofwd = (argv[i][0] == '+');
785 break;
786 case 'a':
787 recip = (argv[i][0] == '+') ? " -a" : "";
788 break;
789 case 'b':
790 dobwd = (argv[i][0] == '+');
791 break;
792 case 'n':
793 nssamp = atoi(argv[++i]);
794 if (nssamp <= 0)
795 goto userr;
796 break;
797 case 's':
798 ssamp_thresh = atof(argv[++i]);
799 if (ssamp_thresh <= FTINY)
800 goto userr;
801 break;
802 case 't':
803 switch (argv[i][2]) {
804 case '3':
805 single_plane_incident = 1;
806 break;
807 case '4':
808 single_plane_incident = 0;
809 break;
810 case '\0':
811 pctcull = atof(argv[++i]);
812 break;
813 default:
814 goto userr;
815 }
816 break;
817 case 'g':
818 samp_order = atoi(argv[++i]);
819 break;
820 case 'l':
821 lobe_lim = atoi(argv[++i]);
822 break;
823 case 'p':
824 do_prog = atoi(argv[i]+2);
825 break;
826 case 'W':
827 add_wbsdf(argv[i], 1);
828 break;
829 case 'u':
830 case 'C':
831 add_wbsdf(argv[i], 1);
832 add_wbsdf(argv[++i], 1);
833 break;
834 default:
835 goto userr;
836 }
837 } else { /* input SIR or function */
838 FILE *fpin;
839 if (!nsirs & (single_plane_incident >= 0))
840 break; /* must be a function */
841 if (nsirs >= 4) {
842 fprintf(stderr, "At most 4 SIR inputs supported\n");
843 goto userr;
844 }
845 fpin = fopen(argv[i], "rb"); /* open SIR file */
846 if (fpin == NULL) {
847 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
848 progname, argv[i]);
849 return(1);
850 }
851 sprintf(buf, "%s:\n", argv[i]);
852 record2header(buf);
853 sir_headshare = &record2header;
854 if (!load_bsdf_rep(fpin))
855 return(1);
856 fclose(fpin);
857 done_header();
858 sprintf(buf, "Interpolating component '%s'", argv[i]);
859 prog_start(buf);
860 if (!nsirs++) {
861 add_wbsdf("-a", 1);
862 add_wbsdf(tfmt[single_plane_incident], 1);
863 }
864 if (single_plane_incident)
865 eval_isotropic(NULL);
866 else
867 eval_anisotropic(NULL);
868 }
869 if (i < argc) { /* function-based BSDF? */
870 void (*evf)(char *s) = single_plane_incident ?
871 eval_isotropic : eval_anisotropic;
872 if (i != argc-1 || fundefined(argv[i]) < 3) {
873 fprintf(stderr,
874 "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
875 progname);
876 fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n");
877 goto userr;
878 }
879 doptimize(1); /* optimize definitions */
880 ++eclock;
881 add_wbsdf("-a", 1);
882 add_wbsdf(tfmt[single_plane_incident], 1);
883 if (dofwd) {
884 input_orient = -1;
885 output_orient = -1;
886 prog_start("Evaluating outside reflectance");
887 (*evf)(argv[i]);
888 output_orient = 1;
889 prog_start("Evaluating outside->inside transmission");
890 (*evf)(argv[i]);
891 }
892 if (dobwd) {
893 input_orient = 1;
894 output_orient = 1;
895 prog_start("Evaluating inside reflectance");
896 (*evf)(argv[i]);
897 output_orient = -1;
898 prog_start("Evaluating inside->outside transmission");
899 (*evf)(argv[i]);
900 }
901 } else if (!nsirs) { /* else load SIR from stdin? */
902 record2header("<stdin>:\n");
903 sir_headshare = &record2header;
904 if (!load_bsdf_rep(stdin))
905 return(1);
906 done_header();
907 prog_start("Interpolating from standard input");
908 add_wbsdf("-a", 1);
909 add_wbsdf(tfmt[single_plane_incident], 1);
910 if (single_plane_incident) /* resample dist. */
911 eval_isotropic(NULL);
912 else
913 eval_anisotropic(NULL);
914 }
915 return(wrap_up()); /* call wrapBSDF */
916 userr:
917 fprintf(stderr,
918 "Usage: %s [{+|-}a][-g Nlog2][-t pctcull][-n nss][-s thresh][-l maxlobes][bsdf.sir ..] > bsdf.xml\n",
919 progname);
920 fprintf(stderr,
921 " or: %s -t{3|4} [{+|-}a][-g Nlog2][-t pctcull][-n nss][-s thresh][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
922 progname);
923 return(1);
924 }
