root/radiance/ray/src/cv/bsdf2ttree.c
Revision: 2.56
Committed: Fri Nov 13 19:21:11 2020 UTC (4 years, 5 months ago) by greg
Changes since 2.55: +62 -57 lines
feat(bsdf2ttree): made it so options/parameters may differ per input SIR
2 static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.55 2020/10/28 18:54:21 greg Exp $";
5 * Load measured BSDF interpolant and write out as XML file with tensor tree.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdlib.h>
12 #include <math.h>
13 #include <ctype.h>
14 #include "random.h"
15 #include "platform.h"
16 #include "paths.h"
17 #include "rtio.h"
18 #include "calcomp.h"
19 #include "bsdfrep.h"
20 /* global argv[0] */
21 char *progname;
22 /* reciprocity averaging option */
23 static const char *recip = " -a";
24 /* percentage to cull (<0 to turn off) */
25 static double pctcull = 90.;
26 /* sampling order */
27 static int samp_order = 6;
28 /* super-sampling threshold */
29 static double ssamp_thresh = 0.35;
30 /* number of super-samples */
31 static int nssamp = 256;
32 /* limit on number of RBF lobes */
33 static int lobe_lim = 15000;
34 /* progress bar length */
35 static int do_prog = 79;
36
37 #define MAXCARG 512 /* wrapBSDF command */
38 static char *wrapBSDF[MAXCARG] = {"wrapBSDF", "-U"};
39 static int wbsdfac = 2;
40
41 /* Add argument to wrapBSDF, allocating space if !isstatic */
42 static void
43 add_wbsdf(const char *arg, int isstatic)
44 {
45 if (arg == NULL)
46 return;
47 if (wbsdfac >= MAXCARG-1) {
48 fputs(progname, stderr);
49 fputs(": too many command arguments to wrapBSDF\n", stderr);
50 exit(1);
51 }
52 if (!*arg)
53 arg = "";
54 else if (!isstatic)
55 arg = savqstr((char *)arg);
56
57 wrapBSDF[wbsdfac++] = (char *)arg;
58 }
59
60 /* Create Yuv component file and add appropriate arguments */
61 static char *
62 create_component_file(int c)
63 {
64 static const char sname[3][6] = {"CIE-Y", "CIE-u", "CIE-v"};
65 static const char cname[4][4] = {"-rf", "-tf", "-tb", "-rb"};
66 char *tfname = mktemp(savqstr(TEMPLATE));
67
68 add_wbsdf("-s", 1); add_wbsdf(sname[c], 1);
69 add_wbsdf(cname[(input_orient>0)<<1 | (output_orient>0)], 1);
70 add_wbsdf(tfname, 1);
71 return(tfname);
72 }
73
74 /* Start new progress bar */
75 #define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else
76
77 /* Draw progress bar of the appropriate length */
78 static void
79 prog_show(double frac)
80 {
81 static unsigned call_cnt = 0;
82 static char lastc[] = "-\\|/";
83 char pbar[256];
84 int nchars;
85
86 if (do_prog <= 1) return;
87 if (do_prog > sizeof(pbar)-2)
88 do_prog = sizeof(pbar)-2;
89 if (frac < 0) frac = 0;
90 else if (frac >= 1) frac = .9999;
91 nchars = do_prog*frac;
92 pbar[0] = '\r';
93 memset(pbar+1, '*', nchars);
94 pbar[nchars+1] = lastc[call_cnt++ & 3];
95 memset(pbar+2+nchars, '-', do_prog-nchars-1);
96 pbar[do_prog+1] = '\0';
97 fputs(pbar, stderr);
98 }
99
100 /* Finish progress bar */
101 static void
102 prog_done(void)
103 {
104 int n = do_prog;
105
106 if (n <= 1) return;
107 fputc('\r', stderr);
108 while (n--)
109 fputc(' ', stderr);
110 fputc('\r', stderr);
111 }
112
113 /* Compute absolute relative difference */
114 static double
115 abs_diff(double v1, double v0)
116 {
117 if ((v0 < 0) | (v1 < 0))
118 return(.0);
119 v1 = (v1-v0)*2./(v0+v1+.0001);
120 if (v1 < 0)
121 return(-v1);
122 return(v1);
123 }
124
125 /* Interpolate and output isotropic BSDF data */
126 static void
127 eval_isotropic(char *funame)
128 {
129 const int sqres = 1<<samp_order;
130 const double sqfact = 1./(double)sqres;
131 float *val_last = NULL;
132 float *val_next = NULL;
133 SDValue *sdv_next = NULL;
134 FILE *ofp, *uvfp[2];
135 int assignD = 0;
136 char cmd[128];
137 int ix, ox, oy;
138 double iovec[6];
139 float bsdf, uv[2];
140
141 if (pctcull >= 0) {
142 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
143 recip, pctcull, samp_order, create_component_file(0));
144 ofp = popen(cmd, "w");
145 if (ofp == NULL) {
146 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
147 progname);
148 exit(1);
149 }
150 SET_FILE_BINARY(ofp);
151 #ifdef getc_unlocked /* avoid lock/unlock overhead */
152 flockfile(ofp);
153 #endif
154 if (rbf_colorimetry == RBCtristimulus) {
155 double uvcull = 100. - (100.-pctcull)*.25;
156 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
157 recip, uvcull, samp_order, create_component_file(1));
158 uvfp[0] = popen(cmd, "w");
159 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
160 recip, uvcull, samp_order, create_component_file(2));
161 uvfp[1] = popen(cmd, "w");
162 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
163 fprintf(stderr, "%s: cannot open pipes to uv output\n",
164 progname);
165 exit(1);
166 }
167 SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
168 #ifdef getc_unlocked
169 flockfile(uvfp[0]); flockfile(uvfp[1]);
170 #endif
171 }
172 } else {
173 ofp = fopen(create_component_file(0), "w");
174 if (ofp == NULL) {
175 fprintf(stderr, "%s: cannot create Y output file\n",
176 progname);
177 exit(1);
178 }
179 fputs("{\n", ofp);
180 if (rbf_colorimetry == RBCtristimulus) {
181 uvfp[0] = fopen(create_component_file(1), "w");
182 uvfp[1] = fopen(create_component_file(2), "w");
183 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
184 fprintf(stderr, "%s: cannot create uv output file(s)\n",
185 progname);
186 exit(1);
187 }
188 fputs("{\n", uvfp[0]);
189 fputs("{\n", uvfp[1]);
190 }
191 }
192 if (funame != NULL) /* need to assign Dx, Dy, Dz? */
193 assignD = (fundefined(funame) < 6);
194 val_last = (float *)calloc(sqres, sizeof(float));
195 if (funame == NULL)
196 sdv_next = (SDValue *)malloc(sizeof(SDValue)*sqres);
197 else
198 val_next = (float *)malloc(sizeof(float)*sqres);
199 /* run through directions */
200 for (ix = 0; ix < sqres/2; ix++) {
201 const int zipsgn = (ix & 1)*2 - 1;
202 RBFNODE *rbf = NULL;
203 iovec[0] = 2.*sqfact*(ix+.5) - 1.;
204 iovec[1] = zipsgn*sqfact*.5;
205 iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]
206 - iovec[1]*iovec[1]);
207 if (funame == NULL)
208 rbf = advect_rbf(iovec, lobe_lim);
209 /* presample first row */
210 for (oy = 0; oy < sqres; oy++) {
211 SDsquare2disk(iovec+3, .5*sqfact, (oy+.5)*sqfact);
212 iovec[5] = output_orient *
213 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
214 if (funame == NULL) {
215 eval_rbfcol(&sdv_next[oy], rbf, iovec+3);
216 } else {
217 if (assignD) {
218 varset("Dx", '=', -iovec[3]);
219 varset("Dy", '=', -iovec[4]);
220 varset("Dz", '=', -iovec[5]);
221 ++eclock;
222 }
223 val_next[oy] = funvalue(funame, 6, iovec);
224 }
225 }
226 for (ox = 0; ox < sqres; ox++) {
227 /*
228 * Super-sample when we detect a difference from before
229 * or after in this row, above or below.
230 */
231 for (oy = 0; oy < sqres; oy++) {
232 if (ox < sqres-1) { /* keeping one row ahead... */
233 SDsquare2disk(iovec+3, (ox+1.5)*sqfact, (oy+.5)*sqfact);
234 iovec[5] = output_orient *
235 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
236 }
237 if (funame == NULL) {
238 SDValue sdv = sdv_next[oy];
239 bsdf = sdv.cieY;
240 if (ox < sqres-1)
241 eval_rbfcol(&sdv_next[oy], rbf, iovec+3);
242 if (abs_diff(bsdf, sdv_next[oy].cieY) > ssamp_thresh ||
243 (ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) ||
244 (oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) ||
245 (oy < sqres-1 &&
246 abs_diff(bsdf, sdv_next[oy+1].cieY) > ssamp_thresh)) {
247 int ssi;
248 double ssa[2], sum = 0, usum = 0, vsum = 0;
249 /* super-sample voxel */
250 for (ssi = nssamp; ssi--; ) {
251 SDmultiSamp(ssa, 2, (ssi+frandom()) /
252 (double)nssamp);
253 SDsquare2disk(iovec+3, (ox+ssa[0])*sqfact,
254 (oy+ssa[1])*sqfact);
255 iovec[5] = output_orient *
256 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
257 eval_rbfcol(&sdv, rbf, iovec+3);
258 sum += sdv.cieY;
259 if (rbf_colorimetry == RBCtristimulus) {
260 sdv.cieY /=
261 -2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.;
262 usum += 4.*sdv.spec.cx * sdv.cieY;
263 vsum += 9.*sdv.spec.cy * sdv.cieY;
264 }
265 }
266 bsdf = sum / (double)nssamp;
267 if (rbf_colorimetry == RBCtristimulus) {
268 uv[0] = usum / (sum+FTINY);
269 uv[1] = vsum / (sum+FTINY);
270 }
271 } else
272 if (rbf_colorimetry == RBCtristimulus) {
273 uv[0] = uv[1] = 1. /
274 (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
275 uv[0] *= 4.*sdv.spec.cx;
276 uv[1] *= 9.*sdv.spec.cy;
277 }
278 } else {
279 bsdf = val_next[oy];
280 if (ox < sqres-1) {
281 if (assignD) {
282 varset("Dx", '=', -iovec[3]);
283 varset("Dy", '=', -iovec[4]);
284 varset("Dz", '=', -iovec[5]);
285 ++eclock;
286 }
287 val_next[oy] = funvalue(funame, 6, iovec);
288 }
289 if (abs_diff(bsdf, val_next[oy]) > ssamp_thresh ||
290 (ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) ||
291 (oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) ||
292 (oy < sqres-1 &&
293 abs_diff(bsdf, val_next[oy+1]) > ssamp_thresh)) {
294 int ssi;
295 double ssa[4], ssvec[6], sum = 0;
296 /* super-sample voxel */
297 for (ssi = nssamp; ssi--; ) {
298 SDmultiSamp(ssa, 4, (ssi+frandom()) /
299 (double)nssamp);
300 ssvec[0] = 2.*sqfact*(ix+ssa[0]) - 1.;
301 ssvec[1] = zipsgn*sqfact*ssa[1];
302 ssvec[2] = 1. - ssvec[0]*ssvec[0]
303 - ssvec[1]*ssvec[1];
304 if (ssvec[2] < .0) {
305 ssvec[1] = 0;
306 ssvec[2] = 1. - ssvec[0]*ssvec[0];
307 }
308 ssvec[2] = input_orient * sqrt(ssvec[2]);
309 SDsquare2disk(ssvec+3, (ox+ssa[2])*sqfact,
310 (oy+ssa[3])*sqfact);
311 ssvec[5] = output_orient *
312 sqrt(1. - ssvec[3]*ssvec[3] -
313 ssvec[4]*ssvec[4]);
314 if (assignD) {
315 varset("Dx", '=', -ssvec[3]);
316 varset("Dy", '=', -ssvec[4]);
317 varset("Dz", '=', -ssvec[5]);
318 ++eclock;
319 }
320 sum += funvalue(funame, 6, ssvec);
321 }
322 bsdf = sum / (double)nssamp;
323 }
324 }
325 if (pctcull >= 0)
326 putbinary(&bsdf, sizeof(bsdf), 1, ofp);
327 else
328 fprintf(ofp, "\t%.3e\n", bsdf);
329
330 if (rbf_colorimetry == RBCtristimulus) {
331 if (pctcull >= 0) {
332 putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]);
333 putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]);
334 } else {
335 fprintf(uvfp[0], "\t%.3e\n", uv[0]);
336 fprintf(uvfp[1], "\t%.3e\n", uv[1]);
337 }
338 }
339 if (val_last != NULL)
340 val_last[oy] = bsdf;
341 }
342 }
343 if (rbf != NULL)
344 free(rbf);
345 prog_show((ix+1.)*(2.*sqfact));
346 }
347 prog_done();
348 if (val_last != NULL) {
349 free(val_last);
350 if (val_next != NULL) free(val_next);
351 if (sdv_next != NULL) free(sdv_next);
352 }
353 if (pctcull >= 0) { /* finish output */
354 if (pclose(ofp)) {
355 fprintf(stderr, "%s: error running rttree_reduce on Y\n",
356 progname);
357 exit(1);
358 }
359 if (rbf_colorimetry == RBCtristimulus &&
360 (pclose(uvfp[0]) || pclose(uvfp[1]))) {
361 fprintf(stderr, "%s: error running rttree_reduce on uv\n",
362 progname);
363 exit(1);
364 }
365 } else {
366 for (ix = sqres*sqres*sqres/2; ix--; )
367 fputs("\t0\n", ofp);
368 fputs("}\n", ofp);
369 if (fclose(ofp)) {
370 fprintf(stderr, "%s: error writing Y file\n",
371 progname);
372 exit(1);
373 }
374 if (rbf_colorimetry == RBCtristimulus) {
375 for (ix = sqres*sqres*sqres/2; ix--; ) {
376 fputs("\t0\n", uvfp[0]);
377 fputs("\t0\n", uvfp[1]);
378 }
379 fputs("}\n", uvfp[0]);
380 fputs("}\n", uvfp[1]);
381 if (fclose(uvfp[0]) || fclose(uvfp[1])) {
382 fprintf(stderr, "%s: error writing uv file(s)\n",
383 progname);
384 exit(1);
385 }
386 }
387 }
388 }
389
390 /* Interpolate and output anisotropic BSDF data */
391 static void
392 eval_anisotropic(char *funame)
393 {
394 const int sqres = 1<<samp_order;
395 const double sqfact = 1./(double)sqres;
396 float *val_last = NULL;
397 float *val_next = NULL;
398 SDValue *sdv_next = NULL;
399 FILE *ofp, *uvfp[2];
400 int assignD = 0;
401 char cmd[128];
402 int ix, iy, ox, oy;
403 double iovec[6];
404 float bsdf, uv[2];
405
406 if (pctcull >= 0) {
407 const char *avgopt = (input_orient>0 ^ output_orient>0)
408 ? "" : recip;
409 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
410 avgopt, pctcull, samp_order,
411 create_component_file(0));
412 ofp = popen(cmd, "w");
413 if (ofp == NULL) {
414 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
415 progname);
416 exit(1);
417 }
418 SET_FILE_BINARY(ofp);
419 #ifdef getc_unlocked /* avoid lock/unlock overhead */
420 flockfile(ofp);
421 #endif
422 if (rbf_colorimetry == RBCtristimulus) {
423 double uvcull = 100. - (100.-pctcull)*.25;
424 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
425 avgopt, uvcull, samp_order,
426 create_component_file(1));
427 uvfp[0] = popen(cmd, "w");
428 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
429 avgopt, uvcull, samp_order,
430 create_component_file(2));
431 uvfp[1] = popen(cmd, "w");
432 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
433 fprintf(stderr, "%s: cannot open pipes to uv output\n",
434 progname);
435 exit(1);
436 }
437 SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
438 #ifdef getc_unlocked
439 flockfile(uvfp[0]); flockfile(uvfp[1]);
440 #endif
441 }
442 } else {
443 ofp = fopen(create_component_file(0), "w");
444 if (ofp == NULL) {
445 fprintf(stderr, "%s: cannot create Y output file\n",
446 progname);
447 exit(1);
448 }
449 fputs("{\n", ofp);
450 if (rbf_colorimetry == RBCtristimulus) {
451 uvfp[0] = fopen(create_component_file(1), "w");
452 uvfp[1] = fopen(create_component_file(2), "w");
453 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
454 fprintf(stderr, "%s: cannot create uv output file(s)\n",
455 progname);
456 exit(1);
457 }
458 fputs("{\n", uvfp[0]);
459 fputs("{\n", uvfp[1]);
460 }
461 }
462 if (funame != NULL) /* need to assign Dx, Dy, Dz? */
463 assignD = (fundefined(funame) < 6);
464 val_last = (float *)calloc(sqres, sizeof(float));
465 if (funame == NULL)
466 sdv_next = (SDValue *)malloc(sizeof(SDValue)*sqres);
467 else
468 val_next = (float *)malloc(sizeof(float)*sqres);
469 /* run through directions */
470 for (ix = 0; ix < sqres; ix++)
471 for (iy = 0; iy < sqres; iy++) {
472 RBFNODE *rbf = NULL; /* Klems reversal */
473 SDsquare2disk(iovec, 1.-(ix+.5)*sqfact, 1.-(iy+.5)*sqfact);
474 iovec[2] = input_orient *
475 sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]);
476 if (funame == NULL)
477 rbf = advect_rbf(iovec, lobe_lim);
478 /* presample first row */
479 for (oy = 0; oy < sqres; oy++) {
480 SDsquare2disk(iovec+3, .5*sqfact, (oy+.5)*sqfact);
481 iovec[5] = output_orient *
482 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
483 if (funame == NULL) {
484 eval_rbfcol(&sdv_next[oy], rbf, iovec+3);
485 } else {
486 if (assignD) {
487 varset("Dx", '=', -iovec[3]);
488 varset("Dy", '=', -iovec[4]);
489 varset("Dz", '=', -iovec[5]);
490 ++eclock;
491 }
492 val_next[oy] = funvalue(funame, 6, iovec);
493 }
494 }
495 for (ox = 0; ox < sqres; ox++) {
496 /*
497 * Super-sample when we detect a difference from before
498 * or after in this row, above or below.
499 */
500 for (oy = 0; oy < sqres; oy++) {
501 if (ox < sqres-1) { /* keeping one row ahead... */
502 SDsquare2disk(iovec+3, (ox+1.5)*sqfact, (oy+.5)*sqfact);
503 iovec[5] = output_orient *
504 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
505 }
506 if (funame == NULL) {
507 SDValue sdv = sdv_next[oy];
508 bsdf = sdv.cieY;
509 if (ox < sqres-1)
510 eval_rbfcol(&sdv_next[oy], rbf, iovec+3);
511 if (abs_diff(bsdf, sdv_next[oy].cieY) > ssamp_thresh ||
512 (ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) ||
513 (oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) ||
514 (oy < sqres-1 &&
515 abs_diff(bsdf, sdv_next[oy+1].cieY) > ssamp_thresh)) {
516 int ssi;
517 double ssa[2], sum = 0, usum = 0, vsum = 0;
518 /* super-sample voxel */
519 for (ssi = nssamp; ssi--; ) {
520 SDmultiSamp(ssa, 2, (ssi+frandom()) /
521 (double)nssamp);
522 SDsquare2disk(iovec+3, (ox+ssa[0])*sqfact,
523 (oy+ssa[1])*sqfact);
524 iovec[5] = output_orient *
525 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
526 eval_rbfcol(&sdv, rbf, iovec+3);
527 sum += sdv.cieY;
528 if (rbf_colorimetry == RBCtristimulus) {
529 sdv.cieY /=
530 -2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.;
531 usum += 4.*sdv.spec.cx * sdv.cieY;
532 vsum += 9.*sdv.spec.cy * sdv.cieY;
533 }
534 }
535 bsdf = sum / (double)nssamp;
536 if (rbf_colorimetry == RBCtristimulus) {
537 uv[0] = usum / (sum+FTINY);
538 uv[1] = vsum / (sum+FTINY);
539 }
540 } else
541 if (rbf_colorimetry == RBCtristimulus) {
542 uv[0] = uv[1] = 1. /
543 (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
544 uv[0] *= 4.*sdv.spec.cx;
545 uv[1] *= 9.*sdv.spec.cy;
546 }
547 } else {
548 bsdf = val_next[oy];
549 if (ox < sqres-1) {
550 if (assignD) {
551 varset("Dx", '=', -iovec[3]);
552 varset("Dy", '=', -iovec[4]);
553 varset("Dz", '=', -iovec[5]);
554 ++eclock;
555 }
556 val_next[oy] = funvalue(funame, 6, iovec);
557 }
558 if (abs_diff(bsdf, val_next[oy]) > ssamp_thresh ||
559 (ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) ||
560 (oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) ||
561 (oy < sqres-1 &&
562 abs_diff(bsdf, val_next[oy+1]) > ssamp_thresh)) {
563 int ssi;
564 double ssa[4], ssvec[6], sum = 0;
565 /* super-sample voxel */
566 for (ssi = nssamp; ssi--; ) {
567 SDmultiSamp(ssa, 4, (ssi+frandom()) /
568 (double)nssamp);
569 SDsquare2disk(ssvec, 1.-(ix+ssa[0])*sqfact,
570 1.-(iy+ssa[1])*sqfact);
571 ssvec[2] = input_orient *
572 sqrt(1. - ssvec[0]*ssvec[0] -
573 ssvec[1]*ssvec[1]);
574 SDsquare2disk(ssvec+3, (ox+ssa[2])*sqfact,
575 (oy+ssa[3])*sqfact);
576 ssvec[5] = output_orient *
577 sqrt(1. - ssvec[3]*ssvec[3] -
578 ssvec[4]*ssvec[4]);
579 if (assignD) {
580 varset("Dx", '=', -ssvec[3]);
581 varset("Dy", '=', -ssvec[4]);
582 varset("Dz", '=', -ssvec[5]);
583 ++eclock;
584 }
585 sum += funvalue(funame, 6, ssvec);
586 }
587 bsdf = sum / (double)nssamp;
588 }
589 }
590 if (pctcull >= 0)
591 putbinary(&bsdf, sizeof(bsdf), 1, ofp);
592 else
593 fprintf(ofp, "\t%.3e\n", bsdf);
594
595 if (rbf_colorimetry == RBCtristimulus) {
596 if (pctcull >= 0) {
597 putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]);
598 putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]);
599 } else {
600 fprintf(uvfp[0], "\t%.3e\n", uv[0]);
601 fprintf(uvfp[1], "\t%.3e\n", uv[1]);
602 }
603 }
604 if (val_last != NULL)
605 val_last[oy] = bsdf;
606 }
607 }
608 if (rbf != NULL)
609 free(rbf);
610 prog_show((ix*sqres+iy+1.)/(sqres*sqres));
611 }
612 prog_done();
613 if (val_last != NULL) {
614 free(val_last);
615 if (val_next != NULL) free(val_next);
616 if (sdv_next != NULL) free(sdv_next);
617 }
618 if (pctcull >= 0) { /* finish output */
619 if (pclose(ofp)) {
620 fprintf(stderr, "%s: error running rttree_reduce on Y\n",
621 progname);
622 exit(1);
623 }
624 if (rbf_colorimetry == RBCtristimulus &&
625 (pclose(uvfp[0]) || pclose(uvfp[1]))) {
626 fprintf(stderr, "%s: error running rttree_reduce on uv\n",
627 progname);
628 exit(1);
629 }
630 } else {
631 fputs("}\n", ofp);
632 if (fclose(ofp)) {
633 fprintf(stderr, "%s: error writing Y file\n",
634 progname);
635 exit(1);
636 }
637 if (rbf_colorimetry == RBCtristimulus) {
638 fputs("}\n", uvfp[0]);
639 fputs("}\n", uvfp[1]);
640 if (fclose(uvfp[0]) || fclose(uvfp[1])) {
641 fprintf(stderr, "%s: error writing uv file(s)\n",
642 progname);
643 exit(1);
644 }
645 }
646 }
647 }
648
649 #if defined(_WIN32) || defined(_WIN64)
650 /* Execute wrapBSDF command (may never return) */
651 static int
652 wrap_up(void)
653 {
654 char cmd[32700];
655
656 if (bsdf_manuf[0]) {
657 add_wbsdf("-f", 1);
658 strcpy(cmd, "m=");
659 strcpy(cmd+2, bsdf_manuf);
660 add_wbsdf(cmd, 0);
661 }
662 if (bsdf_name[0]) {
663 add_wbsdf("-f", 1);
664 strcpy(cmd, "n=");
665 strcpy(cmd+2, bsdf_name);
666 add_wbsdf(cmd, 0);
667 }
668 if (!convert_commandline(cmd, sizeof(cmd), wrapBSDF)) {
669 fputs(progname, stderr);
670 fputs(": command line too long in wrap_up()\n", stderr);
671 return(1);
672 }
673 return(system(cmd));
674 }
675 #else
676 /* Execute wrapBSDF command (may never return) */
677 static int
678 wrap_up(void)
679 {
680 char buf[256];
681 char *compath = getpath((char *)wrapBSDF[0], getenv("PATH"), X_OK);
682
683 if (compath == NULL) {
684 fprintf(stderr, "%s: cannot locate %s\n", progname, wrapBSDF[0]);
685 return(1);
686 }
687 if (bsdf_manuf[0]) {
688 add_wbsdf("-f", 1);
689 strcpy(buf, "m=");
690 strcpy(buf+2, bsdf_manuf);
691 add_wbsdf(buf, 0);
692 }
693 if (bsdf_name[0]) {
694 add_wbsdf("-f", 1);
695 strcpy(buf, "n=");
696 strcpy(buf+2, bsdf_name);
697 add_wbsdf(buf, 0);
698 }
699 execv(compath, wrapBSDF); /* successful call never returns */
700 perror(compath);
701 return(1);
702 }
703 #endif
704
705 #define HEAD_BUFLEN 10240
706 static char head_buf[HEAD_BUFLEN];
707 static int cur_headlen = 0;
708
709 /* Record header line as comment associated with this SIR input */
710 static int
711 record2header(char *s)
712 {
713 int len = strlen(s);
714
715 if (cur_headlen+len >= HEAD_BUFLEN-6)
716 return(0);
717 /* includes EOL */
718 strcpy(head_buf+cur_headlen, s);
719 cur_headlen += len;
720
721 #if defined(_WIN32) || defined(_WIN64)
722 if (head_buf[cur_headlen-1] == '\n')
723 head_buf[cur_headlen-1] = '\t';
724 #endif
725 return(1);
726 }
727
728 /* Finish off header for this file */
729 static void
730 done_header(void)
731 {
732 while (cur_headlen > 0 && isspace(head_buf[cur_headlen-1]))
733 --cur_headlen;
734 head_buf[cur_headlen] = '\0';
735 if (!cur_headlen)
736 return;
737 add_wbsdf("-C", 1);
738 add_wbsdf(head_buf, 0);
739 head_buf[cur_headlen=0] = '\0';
740 }
741
742 /* Read in BSDF and interpolate as tensor tree representation */
743 int
744 main(int argc, char *argv[])
745 {
746 static const char tfmt[2][4] = {"t4", "t3"};
747 int dofwd = 0, dobwd = 1;
748 int nsirs = 0;
749 char buf[1024];
750 int i;
751
752 progname = argv[0];
753 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
754 esupport &= ~(E_INCHAN|E_OUTCHAN);
755 scompile("PI:3.14159265358979323846", NULL, 0);
756 biggerlib();
757 strcpy(buf, "File produced by: ");
758 if (convert_commandline(buf+18, sizeof(buf)-18, argv) != NULL) {
759 add_wbsdf("-C", 1); add_wbsdf(buf, 0);
760 }
761 for (i = 1; i < argc; i++)
762 if ((argv[i][0] == '-') | (argv[i][0] == '+')) {
763 switch (argv[i][1]) { /* get option */
764 case 'e':
765 scompile(argv[++i], NULL, 0);
766 if (single_plane_incident < 0)
767 single_plane_incident = 0;
768 break;
769 case 'f':
770 if (!argv[i][2]) {
771 if (strchr(argv[++i], '=') != NULL) {
772 add_wbsdf("-f", 1);
773 add_wbsdf(argv[i], 1);
774 } else {
775 char *fpath = getpath(argv[i],
776 getrlibpath(), 0);
777 if (fpath == NULL) {
778 fprintf(stderr,
779 "%s: cannot find file '%s'\n",
780 argv[0], argv[i]);
781 return(1);
782 }
783 fcompile(fpath);
784 if (single_plane_incident < 0)
785 single_plane_incident = 0;
786 }
787 } else
788 dofwd = (argv[i][0] == '+');
789 break;
790 case 'a':
791 recip = (argv[i][0] == '+') ? " -a" : "";
792 break;
793 case 'b':
794 dobwd = (argv[i][0] == '+');
795 break;
796 case 'n':
797 nssamp = atoi(argv[++i]);
798 if (nssamp <= 0)
799 goto userr;
800 break;
801 case 's':
802 ssamp_thresh = atof(argv[++i]);
803 if (ssamp_thresh <= FTINY)
804 goto userr;
805 break;
806 case 't':
807 switch (argv[i][2]) {
808 case '3':
809 single_plane_incident = 1;
810 break;
811 case '4':
812 single_plane_incident = 0;
813 break;
814 case '\0':
815 pctcull = atof(argv[++i]);
816 break;
817 default:
818 goto userr;
819 }
820 break;
821 case 'g':
822 samp_order = atoi(argv[++i]);
823 break;
824 case 'l':
825 lobe_lim = atoi(argv[++i]);
826 break;
827 case 'p':
828 do_prog = atoi(argv[i]+2);
829 break;
830 case 'W':
831 add_wbsdf(argv[i], 1);
832 break;
833 case 'u':
834 case 'C':
835 add_wbsdf(argv[i], 1);
836 add_wbsdf(argv[++i], 1);
837 break;
838 default:
839 goto userr;
840 }
841 } else { /* input SIR or function */
842 FILE *fpin;
843 if (!nsirs & (single_plane_incident >= 0))
844 break; /* must be a function */
845 if (nsirs >= 4) {
846 fprintf(stderr, "At most 4 SIR inputs supported\n");
847 goto userr;
848 }
849 fpin = fopen(argv[i], "rb"); /* open SIR file */
850 if (fpin == NULL) {
851 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
852 progname, argv[i]);
853 return(1);
854 }
855 sprintf(buf, "%s:\n", argv[i]);
856 record2header(buf);
857 sir_headshare = &record2header;
858 if (!load_bsdf_rep(fpin))
859 return(1);
860 fclose(fpin);
861 done_header();
862 sprintf(buf, "Interpolating component '%s'", argv[i]);
863 prog_start(buf);
864 if (!nsirs++) {
865 add_wbsdf("-a", 1);
866 add_wbsdf(tfmt[single_plane_incident], 1);
867 }
868 if (single_plane_incident)
869 eval_isotropic(NULL);
870 else
871 eval_anisotropic(NULL);
872 }
873 if (i < argc) { /* function-based BSDF? */
874 void (*evf)(char *s) = single_plane_incident ?
875 eval_isotropic : eval_anisotropic;
876 if (i != argc-1 || fundefined(argv[i]) < 3) {
877 fprintf(stderr,
878 "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
879 progname);
880 fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n");
881 goto userr;
882 }
883 ++eclock;
884 add_wbsdf("-a", 1);
885 add_wbsdf(tfmt[single_plane_incident], 1);
886 if (dofwd) {
887 input_orient = -1;
888 output_orient = -1;
889 prog_start("Evaluating outside reflectance");
890 (*evf)(argv[i]);
891 output_orient = 1;
892 prog_start("Evaluating outside->inside transmission");
893 (*evf)(argv[i]);
894 }
895 if (dobwd) {
896 input_orient = 1;
897 output_orient = 1;
898 prog_start("Evaluating inside reflectance");
899 (*evf)(argv[i]);
900 output_orient = -1;
901 prog_start("Evaluating inside->outside transmission");
902 (*evf)(argv[i]);
903 }
904 } else if (!nsirs) { /* else load SIR from stdin? */
905 record2header("<stdin>:\n");
906 sir_headshare = &record2header;
907 if (!load_bsdf_rep(stdin))
908 return(1);
909 done_header();
910 prog_start("Interpolating from standard input");
911 add_wbsdf("-a", 1);
912 add_wbsdf(tfmt[single_plane_incident], 1);
913 if (single_plane_incident) /* resample dist. */
914 eval_isotropic(NULL);
915 else
916 eval_anisotropic(NULL);
917 }
918 return(wrap_up()); /* call wrapBSDF */
919 userr:
920 fprintf(stderr,
921 "Usage: %s [{+|-}a][-g Nlog2][-t pctcull][-n nss][-s thresh][-l maxlobes][bsdf.sir ..] > bsdf.xml\n",
922 progname);
923 fprintf(stderr,
924 " or: %s -t{3|4} [{+|-}a][-g Nlog2][-t pctcull][-n nss][-s thresh][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
925 progname);
926 return(1);
927 }
