root/radiance/ray/src/cv/bsdf2ttree.c
Revision: 2.49
Committed: Fri May 8 22:34:21 2020 UTC (5 years ago) by greg
Changes since 2.48: +17 -3 lines
Forgot to clear the flags from previous row
2 static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.48 2020/05/07 16:54:10 greg Exp $";
5 * Load measured BSDF interpolant and write out as XML file with tensor tree.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdlib.h>
12 #include <math.h>
13 #include "random.h"
14 #include "platform.h"
15 #include "paths.h"
16 #include "rtio.h"
17 #include "calcomp.h"
18 #include "bsdfrep.h"
19 /* global argv[0] */
20 char *progname;
21 /* reciprocity averaging option */
22 static const char *recip = " -a";
23 /* percentage to cull (<0 to turn off) */
24 static double pctcull = 90.;
25 /* sampling order */
26 static int samp_order = 6;
27 /* super-sampling threshold */
28 static double ssamp_thresh = 0.35;
29 /* number of super-samples */
30 #ifndef NSSAMP
31 #define NSSAMP 256
32 #endif
33 /* limit on number of RBF lobes */
34 static int lobe_lim = 15000;
35 /* progress bar length */
36 static int do_prog = 79;
37
38 #define MAXCARG 512 /* wrapBSDF command */
39 static char *wrapBSDF[MAXCARG] = {"wrapBSDF", "-U"};
40 static int wbsdfac = 2;
41
42 /* Add argument to wrapBSDF, allocating space if !isstatic */
43 static void
44 add_wbsdf(const char *arg, int isstatic)
45 {
46 if (arg == NULL)
47 return;
48 if (wbsdfac >= MAXCARG-1) {
49 fputs(progname, stderr);
50 fputs(": too many command arguments to wrapBSDF\n", stderr);
51 exit(1);
52 }
53 if (!*arg)
54 arg = "";
55 else if (!isstatic)
56 arg = savqstr((char *)arg);
57
58 wrapBSDF[wbsdfac++] = (char *)arg;
59 }
60
61 /* Create Yuv component file and add appropriate arguments */
62 static char *
63 create_component_file(int c)
64 {
65 static const char sname[3][6] = {"CIE-Y", "CIE-u", "CIE-v"};
66 static const char cname[4][4] = {"-rf", "-tf", "-tb", "-rb"};
67 char *tfname = mktemp(savqstr(TEMPLATE));
68
69 add_wbsdf("-s", 1); add_wbsdf(sname[c], 1);
70 add_wbsdf(cname[(input_orient>0)<<1 | (output_orient>0)], 1);
71 add_wbsdf(tfname, 1);
72 return(tfname);
73 }
74
75 /* Start new progress bar */
76 #define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else
77
78 /* Draw progress bar of the appropriate length */
79 static void
80 prog_show(double frac)
81 {
82 static unsigned call_cnt = 0;
83 static char lastc[] = "-\\|/";
84 char pbar[256];
85 int nchars;
86
87 if (do_prog <= 1) return;
88 if (do_prog > sizeof(pbar)-2)
89 do_prog = sizeof(pbar)-2;
90 if (frac < 0) frac = 0;
91 else if (frac >= 1) frac = .9999;
92 nchars = do_prog*frac;
93 pbar[0] = '\r';
94 memset(pbar+1, '*', nchars);
95 pbar[nchars+1] = lastc[call_cnt++ & 3];
96 memset(pbar+2+nchars, '-', do_prog-nchars-1);
97 pbar[do_prog+1] = '\0';
98 fputs(pbar, stderr);
99 }
100
101 /* Finish progress bar */
102 static void
103 prog_done(void)
104 {
105 int n = do_prog;
106
107 if (n <= 1) return;
108 fputc('\r', stderr);
109 while (n--)
110 fputc(' ', stderr);
111 fputc('\r', stderr);
112 }
113
114 /* Compute absolute relative difference */
115 static double
116 abs_diff(double v1, double v0)
117 {
118 if ((v0 < 0) | (v1 < 0))
119 return(.0);
120 v1 = (v1-v0)*2./(v0+v1+.0001);
121 if (v1 < 0)
122 return(-v1);
123 return(v1);
124 }
125
126 /* Interpolate and output isotropic BSDF data */
127 static void
128 eval_isotropic(char *funame)
129 {
130 const int sqres = 1<<samp_order;
131 const double sqfact = 1./(double)sqres;
132 float *ryval = NULL;
133 char *rtrip = NULL;
134 FILE *ofp, *uvfp[2];
135 int assignD = 0;
136 char cmd[128];
137 int ix, ox, oy;
138 double iovec[6];
139 float bsdf, uv[2];
140
141 if (pctcull >= 0) {
142 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
143 recip, pctcull, samp_order, create_component_file(0));
144 ofp = popen(cmd, "w");
145 if (ofp == NULL) {
146 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
147 progname);
148 exit(1);
149 }
150 SET_FILE_BINARY(ofp);
151 #ifdef getc_unlocked /* avoid lock/unlock overhead */
152 flockfile(ofp);
153 #endif
154 if (rbf_colorimetry == RBCtristimulus) {
155 double uvcull = 100. - (100.-pctcull)*.25;
156 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
157 recip, uvcull, samp_order, create_component_file(1));
158 uvfp[0] = popen(cmd, "w");
159 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
160 recip, uvcull, samp_order, create_component_file(2));
161 uvfp[1] = popen(cmd, "w");
162 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
163 fprintf(stderr, "%s: cannot open pipes to uv output\n",
164 progname);
165 exit(1);
166 }
167 SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
168 #ifdef getc_unlocked
169 flockfile(uvfp[0]); flockfile(uvfp[1]);
170 #endif
171 }
172 } else {
173 ofp = fopen(create_component_file(0), "w");
174 if (ofp == NULL) {
175 fprintf(stderr, "%s: cannot create Y output file\n",
176 progname);
177 exit(1);
178 }
179 fputs("{\n", ofp);
180 if (rbf_colorimetry == RBCtristimulus) {
181 uvfp[0] = fopen(create_component_file(1), "w");
182 uvfp[1] = fopen(create_component_file(2), "w");
183 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
184 fprintf(stderr, "%s: cannot create uv output file(s)\n",
185 progname);
186 exit(1);
187 }
188 fputs("{\n", uvfp[0]);
189 fputs("{\n", uvfp[1]);
190 }
191 }
192 if (funame != NULL) /* need to assign Dx, Dy, Dz? */
193 assignD = (fundefined(funame) < 6);
194 #if (NSSAMP > 0)
195 rtrip = (char *)malloc(sqres); /* track sample triggerings */
196 ryval = (float *)calloc(sqres, sizeof(float));
197 #endif
198 /* run through directions */
199 for (ix = 0; ix < sqres/2; ix++) {
200 const int zipsgn = (ix & 1)*2 - 1;
201 RBFNODE *rbf = NULL;
202 iovec[0] = 2.*sqfact*(ix+.5) - 1.;
203 iovec[1] = zipsgn*sqfact*.5;
204 iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]
205 - iovec[1]*iovec[1]);
206 if (funame == NULL)
207 rbf = advect_rbf(iovec, lobe_lim);
208 for (ox = 0; ox < sqres; ox++) {
209 SDValue sdv_next;
210 SDsquare2disk(iovec+3, (ox+.5)*sqfact, .5*sqfact);
211 iovec[5] = output_orient *
212 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
213 if (funame == NULL) {
214 eval_rbfcol(&sdv_next, rbf, iovec+3);
215 } else {
216 sdv_next.spec = c_dfcolor;
217 if (assignD) {
218 varset("Dx", '=', -iovec[3]);
219 varset("Dy", '=', -iovec[4]);
220 varset("Dz", '=', -iovec[5]);
221 ++eclock;
222 }
223 sdv_next.cieY = funvalue(funame, 6, iovec);
224 }
225 /*
226 * Super-sample when we detect a difference from before
227 * or after in this row, or the previous row in this column.
228 * Also super-sample if the previous neighbors performed
229 * super-sampling, regardless of any differences.
230 */
231 memset(rtrip, 0, sqres);
232 for (oy = 0; oy < sqres; oy++) {
233 int trip;
234 bsdf = sdv_next.cieY; /* keeping one step ahead... */
235 if (oy < sqres-1) {
236 SDsquare2disk(iovec+3, (ox+.5)*sqfact, (oy+1.5)*sqfact);
237 iovec[5] = output_orient *
238 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
239 }
240 if (funame == NULL) {
241 SDValue sdv = sdv_next;
242 if (oy < sqres-1)
243 eval_rbfcol(&sdv_next, rbf, iovec+3);
244 #if (NSSAMP > 0)
245 trip = (abs_diff(bsdf, sdv_next.cieY) > ssamp_thresh ||
246 (ox && abs_diff(bsdf, ryval[oy]) > ssamp_thresh) ||
247 (oy && abs_diff(bsdf, ryval[oy-1]) > ssamp_thresh));
248 if (trip | rtrip[oy] || (oy && rtrip[oy-1])) {
249 int ssi;
250 double ssa[2], sum = 0, usum = 0, vsum = 0;
251 /* super-sample voxel */
252 for (ssi = NSSAMP; ssi--; ) {
253 SDmultiSamp(ssa, 2, (ssi+frandom()) *
254 (1./NSSAMP));
255 SDsquare2disk(iovec+3, (ox+ssa[0])*sqfact,
256 (oy+ssa[1])*sqfact);
257 iovec[5] = output_orient *
258 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
259 eval_rbfcol(&sdv, rbf, iovec+3);
260 sum += sdv.cieY;
261 if (rbf_colorimetry == RBCtristimulus) {
262 sdv.cieY /=
263 -2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.;
264 usum += 4.*sdv.spec.cx * sdv.cieY;
265 vsum += 9.*sdv.spec.cy * sdv.cieY;
266 }
267 }
268 bsdf = sum * (1./NSSAMP);
269 if (rbf_colorimetry == RBCtristimulus) {
270 uv[0] = usum / (sum+FTINY);
271 uv[1] = vsum / (sum+FTINY);
272 }
273 } else
274 #endif
275 if (rbf_colorimetry == RBCtristimulus) {
276 uv[0] = uv[1] = 1. /
277 (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
278 uv[0] *= 4.*sdv.spec.cx;
279 uv[1] *= 9.*sdv.spec.cy;
280 }
281 } else {
282 if (oy < sqres-1) {
283 if (assignD) {
284 varset("Dx", '=', -iovec[3]);
285 varset("Dy", '=', -iovec[4]);
286 varset("Dz", '=', -iovec[5]);
287 ++eclock;
288 }
289 sdv_next.cieY = funvalue(funame, 6, iovec);
290 }
291 #if (NSSAMP > 0)
292 trip = (abs_diff(bsdf, sdv_next.cieY) > ssamp_thresh ||
293 (ox && abs_diff(bsdf, ryval[oy]) > ssamp_thresh) ||
294 (oy && abs_diff(bsdf, ryval[oy-1]) > ssamp_thresh));
295 if (trip | rtrip[oy] || (oy && rtrip[oy-1])) {
296 int ssi;
297 double ssa[4], ssvec[6], sum = 0;
298 /* super-sample voxel */
299 for (ssi = NSSAMP; ssi--; ) {
300 SDmultiSamp(ssa, 4, (ssi+frandom()) *
301 (1./NSSAMP));
302 ssvec[0] = 2.*sqfact*(ix+ssa[0]) - 1.;
303 ssvec[1] = zipsgn*sqfact*ssa[1];
304 ssvec[2] = 1. - ssvec[0]*ssvec[0]
305 - ssvec[1]*ssvec[1];
306 if (ssvec[2] < .0) {
307 ssvec[1] = 0;
308 ssvec[2] = 1. - ssvec[0]*ssvec[0];
309 }
310 ssvec[2] = input_orient * sqrt(ssvec[2]);
311 SDsquare2disk(ssvec+3, (ox+ssa[2])*sqfact,
312 (oy+ssa[3])*sqfact);
313 ssvec[5] = output_orient *
314 sqrt(1. - ssvec[3]*ssvec[3] -
315 ssvec[4]*ssvec[4]);
316 if (assignD) {
317 varset("Dx", '=', -ssvec[3]);
318 varset("Dy", '=', -ssvec[4]);
319 varset("Dz", '=', -ssvec[5]);
320 ++eclock;
321 }
322 sum += funvalue(funame, 6, ssvec);
323 }
324 bsdf = sum * (1./NSSAMP);
325 }
326 #endif
327 }
328 if (pctcull >= 0)
329 putbinary(&bsdf, sizeof(bsdf), 1, ofp);
330 else
331 fprintf(ofp, "\t%.3e\n", bsdf);
332
333 if (rbf_colorimetry == RBCtristimulus) {
334 if (pctcull >= 0) {
335 putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]);
336 putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]);
337 } else {
338 fprintf(uvfp[0], "\t%.3e\n", uv[0]);
339 fprintf(uvfp[1], "\t%.3e\n", uv[1]);
340 }
341 }
342 if (ryval != NULL) {
343 rtrip[oy] = trip;
344 ryval[oy] = bsdf;
345 }
346 }
347 }
348 if (rbf != NULL)
349 free(rbf);
350 prog_show((ix+1.)*(2.*sqfact));
351 }
352 prog_done();
353 if (ryval != NULL) {
354 free(rtrip);
355 free(ryval);
356 }
357 if (pctcull >= 0) { /* finish output */
358 if (pclose(ofp)) {
359 fprintf(stderr, "%s: error running rttree_reduce on Y\n",
360 progname);
361 exit(1);
362 }
363 if (rbf_colorimetry == RBCtristimulus &&
364 (pclose(uvfp[0]) || pclose(uvfp[1]))) {
365 fprintf(stderr, "%s: error running rttree_reduce on uv\n",
366 progname);
367 exit(1);
368 }
369 } else {
370 for (ix = sqres*sqres*sqres/2; ix--; )
371 fputs("\t0\n", ofp);
372 fputs("}\n", ofp);
373 if (fclose(ofp)) {
374 fprintf(stderr, "%s: error writing Y file\n",
375 progname);
376 exit(1);
377 }
378 if (rbf_colorimetry == RBCtristimulus) {
379 for (ix = sqres*sqres*sqres/2; ix--; ) {
380 fputs("\t0\n", uvfp[0]);
381 fputs("\t0\n", uvfp[1]);
382 }
383 fputs("}\n", uvfp[0]);
384 fputs("}\n", uvfp[1]);
385 if (fclose(uvfp[0]) || fclose(uvfp[1])) {
386 fprintf(stderr, "%s: error writing uv file(s)\n",
387 progname);
388 exit(1);
389 }
390 }
391 }
392 }
393
394 /* Interpolate and output anisotropic BSDF data */
395 static void
396 eval_anisotropic(char *funame)
397 {
398 const int sqres = 1<<samp_order;
399 const double sqfact = 1./(double)sqres;
400 float *ryval = NULL;
401 char *rtrip = NULL;
402 FILE *ofp, *uvfp[2];
403 int assignD = 0;
404 char cmd[128];
405 int ix, iy, ox, oy;
406 double iovec[6];
407 float bsdf, uv[2];
408
409 if (pctcull >= 0) {
410 const char *avgopt = (input_orient>0 ^ output_orient>0)
411 ? "" : recip;
412 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
413 avgopt, pctcull, samp_order,
414 create_component_file(0));
415 ofp = popen(cmd, "w");
416 if (ofp == NULL) {
417 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
418 progname);
419 exit(1);
420 }
421 SET_FILE_BINARY(ofp);
422 #ifdef getc_unlocked /* avoid lock/unlock overhead */
423 flockfile(ofp);
424 #endif
425 if (rbf_colorimetry == RBCtristimulus) {
426 double uvcull = 100. - (100.-pctcull)*.25;
427 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
428 avgopt, uvcull, samp_order,
429 create_component_file(1));
430 uvfp[0] = popen(cmd, "w");
431 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
432 avgopt, uvcull, samp_order,
433 create_component_file(2));
434 uvfp[1] = popen(cmd, "w");
435 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
436 fprintf(stderr, "%s: cannot open pipes to uv output\n",
437 progname);
438 exit(1);
439 }
440 SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
441 #ifdef getc_unlocked
442 flockfile(uvfp[0]); flockfile(uvfp[1]);
443 #endif
444 }
445 } else {
446 ofp = fopen(create_component_file(0), "w");
447 if (ofp == NULL) {
448 fprintf(stderr, "%s: cannot create Y output file\n",
449 progname);
450 exit(1);
451 }
452 fputs("{\n", ofp);
453 if (rbf_colorimetry == RBCtristimulus) {
454 uvfp[0] = fopen(create_component_file(1), "w");
455 uvfp[1] = fopen(create_component_file(2), "w");
456 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
457 fprintf(stderr, "%s: cannot create uv output file(s)\n",
458 progname);
459 exit(1);
460 }
461 fputs("{\n", uvfp[0]);
462 fputs("{\n", uvfp[1]);
463 }
464 }
465 if (funame != NULL) /* need to assign Dx, Dy, Dz? */
466 assignD = (fundefined(funame) < 6);
467 #if (NSSAMP > 0)
468 rtrip = (char *)malloc(sqres); /* track sample triggerings */
469 ryval = (float *)calloc(sqres, sizeof(float));
470 #endif
471 /* run through directions */
472 for (ix = 0; ix < sqres; ix++)
473 for (iy = 0; iy < sqres; iy++) {
474 RBFNODE *rbf = NULL; /* Klems reversal */
475 SDsquare2disk(iovec, 1.-(ix+.5)*sqfact, 1.-(iy+.5)*sqfact);
476 iovec[2] = input_orient *
477 sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]);
478 if (funame == NULL)
479 rbf = advect_rbf(iovec, lobe_lim);
480 for (ox = 0; ox < sqres; ox++) {
481 SDValue sdv_next;
482 SDsquare2disk(iovec+3, (ox+.5)*sqfact, .5*sqfact);
483 iovec[5] = output_orient *
484 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
485 if (funame == NULL) {
486 eval_rbfcol(&sdv_next, rbf, iovec+3);
487 } else {
488 sdv_next.spec = c_dfcolor;
489 if (assignD) {
490 varset("Dx", '=', -iovec[3]);
491 varset("Dy", '=', -iovec[4]);
492 varset("Dz", '=', -iovec[5]);
493 ++eclock;
494 }
495 sdv_next.cieY = funvalue(funame, 6, iovec);
496 }
497 /*
498 * Super-sample when we detect a difference from before
499 * or after in this row, or the previous row in this column.
500 * Also super-sample if the previous neighbors performed
501 * super-sampling, regardless of any differences.
502 */
503 memset(rtrip, 0, sqres);
504 for (oy = 0; oy < sqres; oy++) {
505 int trip;
506 bsdf = sdv_next.cieY; /* keeping one step ahead... */
507 if (oy < sqres-1) {
508 SDsquare2disk(iovec+3, (ox+.5)*sqfact, (oy+1.5)*sqfact);
509 iovec[5] = output_orient *
510 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
511 }
512 if (funame == NULL) {
513 SDValue sdv = sdv_next;
514 if (oy < sqres-1)
515 eval_rbfcol(&sdv_next, rbf, iovec+3);
516 #if (NSSAMP > 0)
517 trip = (abs_diff(bsdf, sdv_next.cieY) > ssamp_thresh ||
518 (ox && abs_diff(bsdf, ryval[oy]) > ssamp_thresh) ||
519 (oy && abs_diff(bsdf, ryval[oy-1]) > ssamp_thresh));
520 if (trip | rtrip[oy] || (oy && rtrip[oy-1])) {
521 int ssi;
522 double ssa[2], sum = 0, usum = 0, vsum = 0;
523 /* super-sample voxel */
524 for (ssi = NSSAMP; ssi--; ) {
525 SDmultiSamp(ssa, 2, (ssi+frandom()) *
526 (1./NSSAMP));
527 SDsquare2disk(iovec+3, (ox+ssa[0])*sqfact,
528 (oy+ssa[1])*sqfact);
529 iovec[5] = output_orient *
530 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
531 eval_rbfcol(&sdv, rbf, iovec+3);
532 sum += sdv.cieY;
533 if (rbf_colorimetry == RBCtristimulus) {
534 sdv.cieY /=
535 -2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.;
536 usum += 4.*sdv.spec.cx * sdv.cieY;
537 vsum += 9.*sdv.spec.cy * sdv.cieY;
538 }
539 }
540 bsdf = sum * (1./NSSAMP);
541 if (rbf_colorimetry == RBCtristimulus) {
542 uv[0] = usum / (sum+FTINY);
543 uv[1] = vsum / (sum+FTINY);
544 }
545 } else
546 #endif
547 if (rbf_colorimetry == RBCtristimulus) {
548 uv[0] = uv[1] = 1. /
549 (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
550 uv[0] *= 4.*sdv.spec.cx;
551 uv[1] *= 9.*sdv.spec.cy;
552 }
553 } else {
554 if (oy < sqres-1) {
555 if (assignD) {
556 varset("Dx", '=', -iovec[3]);
557 varset("Dy", '=', -iovec[4]);
558 varset("Dz", '=', -iovec[5]);
559 ++eclock;
560 }
561 sdv_next.cieY = funvalue(funame, 6, iovec);
562 }
563 #if (NSSAMP > 0)
564 trip = (abs_diff(bsdf, sdv_next.cieY) > ssamp_thresh ||
565 (ox && abs_diff(bsdf, ryval[oy]) > ssamp_thresh) ||
566 (oy && abs_diff(bsdf, ryval[oy-1]) > ssamp_thresh));
567 if (trip | rtrip[oy] || (oy && rtrip[oy-1])) {
568 int ssi;
569 double ssa[4], ssvec[6], sum = 0;
570 /* super-sample voxel */
571 for (ssi = NSSAMP; ssi--; ) {
572 SDmultiSamp(ssa, 4, (ssi+frandom()) *
573 (1./NSSAMP));
574 SDsquare2disk(ssvec, 1.-(ix+ssa[0])*sqfact,
575 1.-(iy+ssa[1])*sqfact);
576 ssvec[2] = input_orient *
577 sqrt(1. - ssvec[0]*ssvec[0] -
578 ssvec[1]*ssvec[1]);
579 SDsquare2disk(ssvec+3, (ox+ssa[2])*sqfact,
580 (oy+ssa[3])*sqfact);
581 ssvec[5] = output_orient *
582 sqrt(1. - ssvec[3]*ssvec[3] -
583 ssvec[4]*ssvec[4]);
584 if (assignD) {
585 varset("Dx", '=', -ssvec[3]);
586 varset("Dy", '=', -ssvec[4]);
587 varset("Dz", '=', -ssvec[5]);
588 ++eclock;
589 }
590 sum += funvalue(funame, 6, ssvec);
591 }
592 bsdf = sum * (1./NSSAMP);
593 }
594 #endif
595 }
596 if (pctcull >= 0)
597 putbinary(&bsdf, sizeof(bsdf), 1, ofp);
598 else
599 fprintf(ofp, "\t%.3e\n", bsdf);
600
601 if (rbf_colorimetry == RBCtristimulus) {
602 if (pctcull >= 0) {
603 putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]);
604 putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]);
605 } else {
606 fprintf(uvfp[0], "\t%.3e\n", uv[0]);
607 fprintf(uvfp[1], "\t%.3e\n", uv[1]);
608 }
609 }
610 if (ryval != NULL) {
611 rtrip[oy] = trip;
612 ryval[oy] = bsdf;
613 }
614 }
615 if (rbf != NULL)
616 free(rbf);
617 prog_show((ix*sqres+iy+1.)/(sqres*sqres));
618 }
619 }
620 prog_done();
621 if (ryval != NULL) {
622 free(rtrip);
623 free(ryval);
624 }
625 if (pctcull >= 0) { /* finish output */
626 if (pclose(ofp)) {
627 fprintf(stderr, "%s: error running rttree_reduce on Y\n",
628 progname);
629 exit(1);
630 }
631 if (rbf_colorimetry == RBCtristimulus &&
632 (pclose(uvfp[0]) || pclose(uvfp[1]))) {
633 fprintf(stderr, "%s: error running rttree_reduce on uv\n",
634 progname);
635 exit(1);
636 }
637 } else {
638 fputs("}\n", ofp);
639 if (fclose(ofp)) {
640 fprintf(stderr, "%s: error writing Y file\n",
641 progname);
642 exit(1);
643 }
644 if (rbf_colorimetry == RBCtristimulus) {
645 fputs("}\n", uvfp[0]);
646 fputs("}\n", uvfp[1]);
647 if (fclose(uvfp[0]) || fclose(uvfp[1])) {
648 fprintf(stderr, "%s: error writing uv file(s)\n",
649 progname);
650 exit(1);
651 }
652 }
653 }
654 }
655
656 #if defined(_WIN32) || defined(_WIN64)
657 /* Execute wrapBSDF command (may never return) */
658 static int
659 wrap_up(void)
660 {
661 char cmd[8192];
662
663 if (bsdf_manuf[0]) {
664 add_wbsdf("-f", 1);
665 strcpy(cmd, "m=");
666 strcpy(cmd+2, bsdf_manuf);
667 add_wbsdf(cmd, 0);
668 }
669 if (bsdf_name[0]) {
670 add_wbsdf("-f", 1);
671 strcpy(cmd, "n=");
672 strcpy(cmd+2, bsdf_name);
673 add_wbsdf(cmd, 0);
674 }
675 if (!convert_commandline(cmd, sizeof(cmd), wrapBSDF)) {
676 fputs(progname, stderr);
677 fputs(": command line too long in wrap_up()\n", stderr);
678 return(1);
679 }
680 return(system(cmd));
681 }
682 #else
683 /* Execute wrapBSDF command (may never return) */
684 static int
685 wrap_up(void)
686 {
687 char buf[256];
688 char *compath = getpath((char *)wrapBSDF[0], getenv("PATH"), X_OK);
689
690 if (compath == NULL) {
691 fprintf(stderr, "%s: cannot locate %s\n", progname, wrapBSDF[0]);
692 return(1);
693 }
694 if (bsdf_manuf[0]) {
695 add_wbsdf("-f", 1);
696 strcpy(buf, "m=");
697 strcpy(buf+2, bsdf_manuf);
698 add_wbsdf(buf, 0);
699 }
700 if (bsdf_name[0]) {
701 add_wbsdf("-f", 1);
702 strcpy(buf, "n=");
703 strcpy(buf+2, bsdf_name);
704 add_wbsdf(buf, 0);
705 }
706 execv(compath, wrapBSDF); /* successful call never returns */
707 perror(compath);
708 return(1);
709 }
710 #endif
711
712 /* Read in BSDF and interpolate as tensor tree representation */
713 int
714 main(int argc, char *argv[])
715 {
716 static char tfmt[2][4] = {"t4", "t3"};
717 int dofwd = 0, dobwd = 1;
718 char buf[2048];
719 int i, na;
720
721 progname = argv[0];
722 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
723 esupport &= ~(E_INCHAN|E_OUTCHAN);
724 scompile("PI:3.14159265358979323846", NULL, 0);
725 biggerlib();
726 for (i = 1; i < argc && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
727 switch (argv[i][1]) { /* get options */
728 case 'e':
729 scompile(argv[++i], NULL, 0);
730 if (single_plane_incident < 0)
731 single_plane_incident = 0;
732 break;
733 case 'f':
734 if (!argv[i][2]) {
735 if (strchr(argv[++i], '=') != NULL) {
736 add_wbsdf("-f", 1);
737 add_wbsdf(argv[i], 1);
738 } else {
739 char *fpath = getpath(argv[i],
740 getrlibpath(), 0);
741 if (fpath == NULL) {
742 fprintf(stderr,
743 "%s: cannot find file '%s'\n",
744 argv[0], argv[i]);
745 return(1);
746 }
747 fcompile(fpath);
748 if (single_plane_incident < 0)
749 single_plane_incident = 0;
750 }
751 } else
752 dofwd = (argv[i][0] == '+');
753 break;
754 case 'a':
755 recip = (argv[i][0] == '+') ? " -a" : "";
756 break;
757 case 'b':
758 dobwd = (argv[i][0] == '+');
759 break;
760 case 't':
761 switch (argv[i][2]) {
762 case '3':
763 single_plane_incident = 1;
764 break;
765 case '4':
766 single_plane_incident = 0;
767 break;
768 case '\0':
769 pctcull = atof(argv[++i]);
770 break;
771 default:
772 goto userr;
773 }
774 break;
775 case 'g':
776 samp_order = atoi(argv[++i]);
777 break;
778 case 'l':
779 lobe_lim = atoi(argv[++i]);
780 break;
781 case 'p':
782 do_prog = atoi(argv[i]+2);
783 break;
784 case 'W':
785 add_wbsdf(argv[i], 1);
786 break;
787 case 'u':
788 case 'C':
789 add_wbsdf(argv[i], 1);
790 add_wbsdf(argv[++i], 1);
791 break;
792 default:
793 goto userr;
794 }
795 strcpy(buf, "File produced by: ");
796 if (convert_commandline(buf+18, sizeof(buf)-18, argv) != NULL) {
797 add_wbsdf("-C", 1); add_wbsdf(buf, 0);
798 }
799 if (single_plane_incident >= 0) { /* function-based BSDF? */
800 void (*evf)(char *s) = single_plane_incident ?
801 eval_isotropic : eval_anisotropic;
802 if (i != argc-1 || fundefined(argv[i]) < 3) {
803 fprintf(stderr,
804 "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
805 progname);
806 fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n");
807 goto userr;
808 }
809 ++eclock;
810 ssamp_thresh *= 0.5; /* lower sampling threshold */
811 add_wbsdf("-a", 1);
812 add_wbsdf(tfmt[single_plane_incident], 1);
813 if (dofwd) {
814 input_orient = -1;
815 output_orient = -1;
816 prog_start("Evaluating outside reflectance");
817 (*evf)(argv[i]);
818 output_orient = 1;
819 prog_start("Evaluating outside->inside transmission");
820 (*evf)(argv[i]);
821 }
822 if (dobwd) {
823 input_orient = 1;
824 output_orient = 1;
825 prog_start("Evaluating inside reflectance");
826 (*evf)(argv[i]);
827 output_orient = -1;
828 prog_start("Evaluating inside->outside transmission");
829 (*evf)(argv[i]);
830 }
831 return(wrap_up());
832 }
833 if (i < argc) { /* open input files if given */
834 int nbsdf = 0;
835 for ( ; i < argc; i++) { /* interpolate each component */
836 char pbuf[256];
837 FILE *fpin = fopen(argv[i], "rb");
838 if (fpin == NULL) {
839 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
840 progname, argv[i]);
841 return(1);
842 }
843 if (!load_bsdf_rep(fpin))
844 return(1);
845 fclose(fpin);
846 sprintf(pbuf, "Interpolating component '%s'", argv[i]);
847 prog_start(pbuf);
848 if (!nbsdf++) {
849 add_wbsdf("-a", 1);
850 add_wbsdf(tfmt[single_plane_incident], 1);
851 }
852 if (single_plane_incident)
853 eval_isotropic(NULL);
854 else
855 eval_anisotropic(NULL);
856 }
857 return(wrap_up());
858 }
859 SET_FILE_BINARY(stdin); /* load from stdin */
860 if (!load_bsdf_rep(stdin))
861 return(1);
862 prog_start("Interpolating from standard input");
863 add_wbsdf("-a", 1);
864 add_wbsdf(tfmt[single_plane_incident], 1);
865 if (single_plane_incident) /* resample dist. */
866 eval_isotropic(NULL);
867 else
868 eval_anisotropic(NULL);
869
870 return(wrap_up());
871 userr:
872 fprintf(stderr,
873 "Usage: %s [{+|-}a][-g Nlog2][-t pctcull][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n",
874 progname);
875 fprintf(stderr,
876 " or: %s -t{3|4} [{+|-}a][-g Nlog2][-t pctcull][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
877 progname);
878 return(1);
879 }
