root/Development/ray/src/cv/bsdf2rado.c
Revision: 2.6
Committed: Thu Jun 5 19:10:31 2025 UTC (5 months, 1 week ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.5: +2 -4 lines
refactor: Made progname declarations more consistent
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.6 static const char RCSid[] = "$Id: bsdf2rado.c,v 2.5 2021/12/07 23:55:02 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Plot 3-D BSDF output based on scattering interpolant or XML representation
6     */
7
8     #define _USE_MATH_DEFINES
9     #include <stdio.h>
10     #include <string.h>
11     #include <stdlib.h>
12     #include <math.h>
13     #include "rtprocess.h"
14     #include "bsdfrep.h"
15
16     const float colarr[6][3] = {
17     .7, 1., .7,
18     1., .7, .7,
19     .7, .7, 1.,
20     1., .5, 1.,
21     1., 1., .5,
22     .5, 1., 1.
23     };
24
25     #if defined(_WIN32) || defined(_WIN64)
26     char validf[] = "-e \"valid(s,t)=X`SYS(s,t)^2+Y`SYS(s,t)^2+Z`SYS(s,t)^2-1e-7\"";
27     #else
28     char validf[] = "-e 'valid(s,t)=X`SYS(s,t)^2+Y`SYS(s,t)^2+Z`SYS(s,t)^2-1e-7'";
29     #endif
30
31     /* Produce a Radiance model plotting the indicated incident direction(s) */
32     int
33     main(int argc, char *argv[])
34     {
35     int showPeaks = 0;
36     int doTrans = 0;
37     int inpXML = -1;
38     RBFNODE *rbf = NULL;
39     FILE *fp;
40     char buf[128];
41     SDData myBSDF;
42     double bsdf, min_log;
43     FVECT idir, odir;
44     int i, j, n;
45     /* check arguments */
46 greg 2.6 fixargv0(argv[0]);
47 greg 2.1 if (argc > 1 && !strcmp(argv[1], "-p")) {
48     ++showPeaks;
49     ++argv; --argc;
50     }
51     if (argc > 1 && !strcmp(argv[1], "-t")) {
52     ++doTrans;
53     ++argv; --argc;
54     }
55     if (argc >= 4 && (n = strlen(argv[1])-4) > 0) {
56     if (!strcasecmp(argv[1]+n, ".xml"))
57     inpXML = 1;
58     else if (!strcasecmp(argv[1]+n, ".sir"))
59     inpXML = 0;
60     }
61     if (inpXML < 0) {
62     fprintf(stderr, "Usage: %s [-p] bsdf.sir theta1 phi1 .. > output.rad\n", progname);
63     fprintf(stderr, " Or: %s [-t] bsdf.xml theta1 phi1 .. > output.rad\n", progname);
64     return(1);
65     }
66     /* load input */
67     if (inpXML) {
68     SDclearBSDF(&myBSDF, argv[1]);
69     if (SDreportError(SDloadFile(&myBSDF, argv[1]), stderr))
70     return(1);
71     bsdf_min = 1./M_PI;
72     if (myBSDF.rf != NULL && myBSDF.rLambFront.cieY < bsdf_min*M_PI)
73     bsdf_min = myBSDF.rLambFront.cieY/M_PI;
74     if (myBSDF.rb != NULL && myBSDF.rLambBack.cieY < bsdf_min*M_PI)
75     bsdf_min = myBSDF.rLambBack.cieY/M_PI;
76 greg 2.2 if (myBSDF.tf != NULL && myBSDF.tLambFront.cieY < bsdf_min*M_PI)
77     bsdf_min = myBSDF.tLambFront.cieY/M_PI;
78     if (myBSDF.tb != NULL && myBSDF.tLambBack.cieY < bsdf_min*M_PI)
79     bsdf_min = myBSDF.tLambBack.cieY/M_PI;
80 greg 2.1 if (doTrans && (myBSDF.tf == NULL) & (myBSDF.tb == NULL)) {
81     fprintf(stderr, "%s: no transmitted component in '%s'\n",
82     progname, argv[1]);
83     return(1);
84     }
85     } else {
86     fp = fopen(argv[1], "rb");
87     if (fp == NULL) {
88     fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
89     progname, argv[1]);
90     return(1);
91     }
92     if (!load_bsdf_rep(fp))
93     return(1);
94     fclose(fp);
95     }
96     #ifdef DEBUG
97 greg 2.3 fprintf(stderr, "Minimum BSDF set to %.4g\n", bsdf_min);
98 greg 2.1 #endif
99 greg 2.3 min_log = log(bsdf_min*.5 + 1e-6);
100 greg 2.1 /* output BSDF rep. */
101     for (n = 0; (n < 6) & (2*n+3 < argc); n++) {
102     double theta = (M_PI/180.)*atof(argv[2*n+2]);
103     double phi = (M_PI/180.)*atof(argv[2*n+3]);
104     if (theta < -FTINY) {
105     fprintf(stderr, "%s: theta values must be positive\n",
106     progname);
107     return(1);
108     }
109     if (inpXML) {
110     input_orient = (theta <= M_PI/2.) ? 1 : -1;
111     output_orient = doTrans ? -input_orient : input_orient;
112     }
113     idir[2] = sin(theta);
114     idir[0] = idir[2] * cos(phi);
115     idir[1] = idir[2] * sin(phi);
116     idir[2] = input_orient * sqrt(1. - idir[2]*idir[2]);
117     #ifdef DEBUG
118 greg 2.4 fprintf(stderr, "Computing BSDF for incident direction (%.2f,%.2f)\n",
119 greg 2.1 get_theta180(idir), get_phi360(idir));
120     #endif
121     if (!inpXML)
122     rbf = advect_rbf(idir, 15000);
123     #ifdef DEBUG
124     if (inpXML)
125 greg 2.3 fprintf(stderr, "Hemispherical %s: %.4f\n",
126 greg 2.1 (output_orient > 0 ^ input_orient > 0 ?
127     "transmission" : "reflection"),
128     SDdirectHemi(idir, SDsampSp|SDsampDf |
129     (output_orient > 0 ^ input_orient > 0 ?
130     SDsampT : SDsampR), &myBSDF));
131     else if (rbf == NULL)
132     fputs("Empty RBF\n", stderr);
133     else
134 greg 2.3 fprintf(stderr, "Hemispherical %s: %.4f\n",
135 greg 2.1 (output_orient > 0 ^ input_orient > 0 ?
136     "transmission" : "reflection"),
137     rbf->vtotal);
138     #endif
139     printf("# Incident direction (theta,phi) = (%.2f,%.2f) deg.\n\n",
140     (180./M_PI)*theta, (180./M_PI)*phi);
141     printf("void trans tmat\n0\n0\n7 %f %f %f .04 .04 .9 1\n",
142     colarr[n][0], colarr[n][1], colarr[n][2]);
143     if (showPeaks && rbf != NULL) {
144     printf("void plastic pmat\n0\n0\n5 %f %f %f .04 .08\n",
145     1.-colarr[n][0], 1.-colarr[n][1], 1.-colarr[n][2]);
146     for (i = 0; i < rbf->nrbf; i++) {
147     ovec_from_pos(odir, rbf->rbfa[i].gx, rbf->rbfa[i].gy);
148     bsdf = eval_rbfrep(rbf, odir);
149     bsdf = log(bsdf + 1e-5) - min_log;
150     printf("pmat sphere p%d\n0\n0\n4 %f %f %f %f\n",
151     i+1, odir[0]*bsdf, odir[1]*bsdf, odir[2]*bsdf,
152     .007*bsdf);
153     }
154     }
155     fflush(stdout);
156     sprintf(buf, "gensurf tmat bsdf%d - - - %d %d %s", n+1,
157 greg 2.4 grid_res-1, grid_res-1, validf);
158 greg 2.1 fp = popen(buf, "w");
159     if (fp == NULL) {
160     fprintf(stderr, "%s: cannot open '| %s'\n", progname, buf);
161     return(1);
162     }
163 greg 2.4 for (i = 0; i < grid_res; i++)
164     for (j = 0; j < grid_res; j++) {
165 greg 2.1 ovec_from_pos(odir, i, j);
166     if (inpXML) {
167     SDValue sval;
168 greg 2.5 if (SDreportError(SDevalBSDF(&sval, idir,
169     odir, &myBSDF), stderr))
170 greg 2.1 return(1);
171     bsdf = sval.cieY;
172     } else
173     bsdf = eval_rbfrep(rbf, odir);
174 greg 2.3 bsdf = log(bsdf + 1e-6) - min_log;
175 greg 2.1 fprintf(fp, "%.8e %.8e %.8e\n",
176     odir[0]*bsdf, odir[1]*bsdf, odir[2]*bsdf);
177     }
178     if (rbf != NULL)
179     free(rbf);
180     if (pclose(fp))
181     return(1);
182     }
183     return(0);
184     }
