root/Development/ray/src/cv/bsdf2rado.c
Tue Dec 7 23:55:02 2021 UTC (3 years, 10 months ago) by greg
Thu Sep 9 15:17:45 2021 UTC (4 years, 1 month ago) by greg
Changes since 2.3: +5 -5 lines
fix(bsdf2rado): switched to using grid_res
Tue Aug 31 01:09:24 2021 UTC (4 years, 2 months ago) by greg
Changes since 2.2: +6 -6 lines
perf(bsdf2rado): minor adjustments
Sat Mar 27 17:50:18 2021 UTC (4 years, 7 months ago) by greg
Diff to previous 2.1
Thu Jun 7 15:39:36 2018 UTC (7 years, 4 months ago) by greg
CVS Tags: rad5R2, rad5R3
Resurrected original bsdf2rad utility (optional build)
