root/radiance/ray/src/cv/bsdf2rad.cal
Tue Apr 11 18:26:55 2017 UTC (8 years ago) by greg
CVS Tags: HEAD, rad5R1, rad5R2, rad5R3, rad5R4
Fixed BSDF material orientation for back side
Tue Apr 11 02:34:10 2017 UTC (8 years ago) by greg
Added special case for pole
Tue Apr 11 02:21:37 2017 UTC (8 years ago) by greg
Changes since 2.3: +7 -2 lines
Fixed issue with up vector that was misorienting 3-D plots
Mon Apr 10 15:44:20 2017 UTC (8 years ago) by greg
Eliminated use of antimatter in favor of genrev
Mon Apr 10 06:09:14 2017 UTC (8 years ago) by greg
Changes since 2.1: +10 -6 lines
Diff to previous 2.1
Swapped Front & Back hemisphere placement and additional tweaks
Sun Apr 9 21:39:26 2017 UTC (8 years ago) by greg
