root/radiance/ray/src/cv/bsdf2rad.c
Revision: 2.40
Committed: Tue Apr 22 04:45:25 2025 UTC (5 weeks ago) by greg
fix: Added check to return value of pclose() in several tools
2 static const char RCSid[] = "$Id: bsdf2rad.c,v 2.39 2021/12/07 23:55:02 greg Exp $";
5 * Plot 3-D BSDF output based on scattering interpolant or XML representation
6 */
7
8 #include <stdlib.h>
9 #include "rtio.h"
10 #include "paths.h"
11 #include "rtmath.h"
12 #include "bsdfrep.h"
13
14 #ifndef NINCIDENT
15 #define NINCIDENT 37 /* number of samples/hemisphere */
16 #endif
17 #ifndef GRIDSTEP
18 #define GRIDSTEP 2 /* our grid step size */
19 #endif
20 #define SAMPRES (GRIDRES/GRIDSTEP)
21
22 int front_comp = 0; /* front component flags (SDsamp*) */
23 int back_comp = 0; /* back component flags */
24 double overall_min = 1./PI; /* overall minimum BSDF value */
25 double min_log10; /* smallest log10 value for plotting */
26 double overall_max = .0; /* overall maximum BSDF value */
27
28 char ourTempDir[TEMPLEN+1] = ""; /* our temporary directory */
29
30 const char frpref[] = "rf";
31 const char ftpref[] = "tf";
32 const char brpref[] = "rb";
33 const char btpref[] = "tb";
34 const char dsuffix[] = ".txt";
35
36 const char sph_fmat[] = "fBSDFmat";
37 const char sph_bmat[] = "bBSDFmat";
38 const double sph_rad = 10.;
39 const double sph_xoffset = 15.;
40
41 #define bsdf_rad (sph_rad*.25)
42 #define arrow_rad (bsdf_rad*.015)
43
44 #define set_minlog() overall_min = (overall_min < 1e-5) ? 1e-5 : overall_min; \
45 min_log10 = log10(overall_min) - .1
46
47 char *progname;
48
49 /* Get Fibonacci sphere vector (0 to NINCIDENT-1) */
50 static RREAL *
51 get_ivector(FVECT iv, int i)
52 {
53 const double phistep = PI*(3. - 2.236067978);
54 double r;
55
56 iv[2] = 1. - (i+.5)*(1./NINCIDENT);
57 r = sqrt(1. - iv[2]*iv[2]);
58 iv[0] = r * cos((i+1.)*phistep);
59 iv[1] = r * sin((i+1.)*phistep);
60
61 return(iv);
62 }
63
64 /* Convert incident vector into sphere position */
65 static RREAL *
66 cvt_sposition(FVECT sp, const FVECT iv, int inc_side)
67 {
68 sp[0] = -iv[0]*sph_rad + inc_side*sph_xoffset;
69 sp[1] = -iv[1]*sph_rad;
70 sp[2] = iv[2]*sph_rad;
71
72 return(sp);
73 }
74
75 /* Get temporary file name */
76 static char *
77 tfile_name(const char *prefix, const char *suffix, int i)
78 {
79 static char buf[256];
80
81 if (!ourTempDir[0]) { /* create temporary directory */
82 mktemp(strcpy(ourTempDir,TEMPLATE));
83 if (mkdir(ourTempDir, 0777) < 0) {
84 perror("mkdir");
85 exit(1);
86 }
87 }
88 if (!prefix) prefix = "T";
89 if (!suffix) suffix = "";
90 sprintf(buf, "%s/%s%03d%s", ourTempDir, prefix, i, suffix);
91 return(buf);
92 }
93
94 /* Remove temporary directory & contents */
95 static void
96 cleanup_tmp(void)
97 {
98 char buf[128];
99
100 if (!ourTempDir[0])
101 return;
102 #if defined(_WIN32) || defined(_WIN64)
103 sprintf(buf, "RMDIR %s /S /Q", ourTempDir);
104 #else
105 sprintf(buf, "rm -rf %s", ourTempDir);
106 #endif
107 system(buf);
108 }
109
110 /* Run the specified command, returning 1 if OK */
111 static int
112 run_cmd(const char *cmd)
113 {
114 fflush(stdout);
115 if (system(cmd)) {
116 fprintf(stderr, "%s: error running: %s\n", progname, cmd);
117 return(0);
118 }
119 return(1);
120 }
121
122 /* Plot surface points for the given BSDF incident angle */
123 static int
124 plotBSDF(const char *fname, const FVECT ivec, int dfl, const SDData *sd)
125 {
126 FILE *fp = fopen(fname, "w");
127 int i, j;
128
129 if (fp == NULL) {
130 fprintf(stderr, "%s: cannot open '%s' for writing\n",
131 progname, fname);
132 return(0);
133 }
134 if (ivec[2] > 0) {
135 input_orient = 1;
136 output_orient = dfl&SDsampR ? 1 : -1;
137 } else {
138 input_orient = -1;
139 output_orient = dfl&SDsampR ? -1 : 1;
140 }
141 for (i = SAMPRES; i--; )
142 for (j = 0; j < SAMPRES; j++) {
143 FVECT ovec;
144 SDValue sval;
145 double bsdf;
146 ovec_from_pos(ovec, i*GRIDSTEP, j*GRIDSTEP);
147 if (SDreportError(SDevalBSDF(&sval, ivec,
148 ovec, sd), stderr))
149 return(0);
150 if (sval.cieY > overall_max)
151 overall_max = sval.cieY;
152 bsdf = (sval.cieY < overall_min) ? overall_min : sval.cieY;
153 bsdf = log10(bsdf) - min_log10;
154 fprintf(fp, "%.5f %.5f %.5f\n",
155 ovec[0]*bsdf, ovec[1]*bsdf, ovec[2]*bsdf);
156 }
157 if (fclose(fp) == EOF) {
158 fprintf(stderr, "%s: error writing data to '%s'\n",
159 progname, fname);
160 return(0);
161 }
162 return(1);
163 }
164
165 /* Build BSDF values from loaded XML file */
166 static int
167 build_wBSDF(const SDData *sd)
168 {
169 FVECT ivec;
170 int i;
171
172 if (front_comp & SDsampR)
173 for (i = 0; i < NINCIDENT; i++) {
174 get_ivector(ivec, i);
175 if (!plotBSDF(tfile_name(frpref, dsuffix, i),
176 ivec, SDsampR, sd))
177 return(0);
178 }
179 if (front_comp & SDsampT)
180 for (i = 0; i < NINCIDENT; i++) {
181 get_ivector(ivec, i);
182 if (!plotBSDF(tfile_name(ftpref, dsuffix, i),
183 ivec, SDsampT, sd))
184 return(0);
185 }
186 if (back_comp & SDsampR)
187 for (i = 0; i < NINCIDENT; i++) {
188 get_ivector(ivec, i);
189 ivec[0] = -ivec[0]; ivec[2] = -ivec[2];
190 if (!plotBSDF(tfile_name(brpref, dsuffix, i),
191 ivec, SDsampR, sd))
192 return(0);
193 }
194 if (back_comp & SDsampT)
195 for (i = 0; i < NINCIDENT; i++) {
196 get_ivector(ivec, i);
197 ivec[0] = -ivec[0]; ivec[2] = -ivec[2];
198 if (!plotBSDF(tfile_name(btpref, dsuffix, i),
199 ivec, SDsampT, sd))
200 return(0);
201 }
202 return(1);
203 }
204
205 /* Plot surface points using radial basis function */
206 static int
207 plotRBF(const char *fname, const RBFNODE *rbf)
208 {
209 FILE *fp = fopen(fname, "w");
210 int i, j;
211
212 if (fp == NULL) {
213 fprintf(stderr, "%s: cannot open '%s' for writing\n",
214 progname, fname);
215 return(0);
216 }
217 for (i = SAMPRES; i--; )
218 for (j = 0; j < SAMPRES; j++) {
219 FVECT ovec;
220 double bsdf;
221 ovec_from_pos(ovec, i*GRIDSTEP, j*GRIDSTEP);
222 bsdf = eval_rbfrep(rbf, ovec);
223 if (bsdf > overall_max)
224 overall_max = bsdf;
225 else if (bsdf < overall_min)
226 bsdf = overall_min;
227 bsdf = log10(bsdf) - min_log10;
228 fprintf(fp, "%.5f %.5f %.5f\n",
229 ovec[0]*bsdf, ovec[1]*bsdf, ovec[2]*bsdf);
230 }
231 if (fclose(fp) == EOF) {
232 fprintf(stderr, "%s: error writing data to '%s'\n",
233 progname, fname);
234 return(0);
235 }
236 return(1);
237 }
238
239 /* Build BSDF values from scattering interpolant representation */
240 static int
241 build_wRBF(void)
242 {
243 const char *pref;
244 int i;
245
246 if (input_orient > 0) {
247 if (output_orient > 0)
248 pref = frpref;
249 else
250 pref = ftpref;
251 } else if (output_orient < 0)
252 pref = brpref;
253 else
254 pref = btpref;
255
256 for (i = 0; i < NINCIDENT; i++) {
257 FVECT ivec;
258 RBFNODE *rbf;
259 get_ivector(ivec, i);
260 if (input_orient < 0) {
261 ivec[0] = -ivec[0]; ivec[2] = -ivec[2];
262 }
263 rbf = advect_rbf(ivec, 15000);
264 if (!plotRBF(tfile_name(pref, dsuffix, i), rbf))
265 return(0);
266 if (rbf) free(rbf);
267 }
268 return(1); /* next call frees */
269 }
270
271 /* Put out mirror arrow for the given incident vector */
272 static void
273 put_mirror_arrow(const FVECT origin, const FVECT nrm)
274 {
275 const double arrow_len = 1.2*bsdf_rad;
276 const double tip_len = 0.2*bsdf_rad;
277 static int cnt = 1;
278 FVECT refl;
279 int i;
280
281 refl[0] = 2.*nrm[2]*nrm[0];
282 refl[1] = 2.*nrm[2]*nrm[1];
283 refl[2] = 2.*nrm[2]*nrm[2] - 1.;
284
285 printf("\n# Mirror arrow #%d\n", cnt);
286 printf("\nshaft_mat cylinder inc_dir%d\n0\n0\n7", cnt);
287 printf("\n\t%f %f %f\n\t%f %f %f\n\t%f\n",
288 origin[0], origin[1], origin[2]+arrow_len,
289 origin[0], origin[1], origin[2],
290 arrow_rad);
291 printf("\nshaft_mat cylinder mir_dir%d\n0\n0\n7", cnt);
292 printf("\n\t%f %f %f\n\t%f %f %f\n\t%f\n",
293 origin[0], origin[1], origin[2],
294 origin[0] + arrow_len*refl[0],
295 origin[1] + arrow_len*refl[1],
296 origin[2] + arrow_len*refl[2],
297 arrow_rad);
298 printf("\ntip_mat cone mir_tip%d\n0\n0\n8", cnt);
299 printf("\n\t%f %f %f\n\t%f %f %f\n\t%f 0\n",
300 origin[0] + (arrow_len-.5*tip_len)*refl[0],
301 origin[1] + (arrow_len-.5*tip_len)*refl[1],
302 origin[2] + (arrow_len-.5*tip_len)*refl[2],
303 origin[0] + (arrow_len+.5*tip_len)*refl[0],
304 origin[1] + (arrow_len+.5*tip_len)*refl[1],
305 origin[2] + (arrow_len+.5*tip_len)*refl[2],
306 2.*arrow_rad);
307 ++cnt;
308 }
309
310 /* Put out transmitted direction arrow for the given incident vector */
311 static void
312 put_trans_arrow(const FVECT origin)
313 {
314 const double arrow_len = 1.2*bsdf_rad;
315 const double tip_len = 0.2*bsdf_rad;
316 static int cnt = 1;
317 int i;
318
319 printf("\n# Transmission arrow #%d\n", cnt);
320 printf("\nshaft_mat cylinder trans_dir%d\n0\n0\n7", cnt);
321 printf("\n\t%f %f %f\n\t%f %f %f\n\t%f\n",
322 origin[0], origin[1], origin[2],
323 origin[0], origin[1], origin[2]-arrow_len,
324 arrow_rad);
325 printf("\ntip_mat cone trans_tip%d\n0\n0\n8", cnt);
326 printf("\n\t%f %f %f\n\t%f %f %f\n\t%f 0\n",
327 origin[0], origin[1], origin[2]-arrow_len+.5*tip_len,
328 origin[0], origin[1], origin[2]-arrow_len-.5*tip_len,
329 2.*arrow_rad);
330 ++cnt;
331 }
332
333 /* Compute rotation (x,y,z) => (xp,yp,zp) */
334 static int
335 addrot(char *xf, const FVECT xp, const FVECT yp, const FVECT zp)
336 {
337 int n = 0;
338 double theta;
339
340 if (yp[2]*yp[2] + zp[2]*zp[2] < 2.*FTINY*FTINY) {
341 /* Special case for X' along Z-axis */
342 theta = -atan2(yp[0], yp[1]);
343 sprintf(xf, " -ry %f -rz %f",
344 xp[2] < 0.0 ? 90.0 : -90.0,
345 theta*(180./PI));
346 return(4);
347 }
348 theta = atan2(yp[2], zp[2]);
349 if (!FABSEQ(theta,0.0)) {
350 sprintf(xf, " -rx %f", theta*(180./PI));
351 while (*xf) ++xf;
352 n += 2;
353 }
354 theta = Asin(-xp[2]);
355 if (!FABSEQ(theta,0.0)) {
356 sprintf(xf, " -ry %f", theta*(180./PI));
357 while (*xf) ++xf;
358 n += 2;
359 }
360 theta = atan2(xp[1], xp[0]);
361 if (!FABSEQ(theta,0.0)) {
362 sprintf(xf, " -rz %f", theta*(180./PI));
363 /* while (*xf) ++xf; */
364 n += 2;
365 }
366 return(n);
367 }
368
369 /* Put out BSDF surfaces */
370 static int
371 put_BSDFs(void)
372 {
373 const double scalef = bsdf_rad/(log10(overall_max) - min_log10);
374 FVECT ivec, sorg, nrm, upv;
375 RREAL vMtx[3][3];
376 char *fname;
377 char cmdbuf[256];
378 char rotargs[64];
379 int nrota;
380 int i;
381
382 printf("\n# Gensurf output corresponding to %d incident directions\n",
383 NINCIDENT);
384
385 printf("\nvoid glow tip_mat\n0\n0\n4 1 0 1 0\n");
386 printf("\nvoid mixfunc shaft_mat\n4 tip_mat void 0.25 .\n0\n0\n");
387
388 for (i = 0; i < NINCIDENT; i++) {
389 get_ivector(ivec, i);
390 nrm[0] = -ivec[0]; nrm[1] = -ivec[1]; nrm[2] = ivec[2];
391 upv[0] = nrm[0]*nrm[1]*(nrm[2] - 1.);
392 upv[1] = nrm[0]*nrm[0] + nrm[1]*nrm[1]*nrm[2];
393 upv[2] = -nrm[1]*(nrm[0]*nrm[0] + nrm[1]*nrm[1]);
394 if (SDcompXform(vMtx, nrm, upv) != SDEnone)
395 continue;
396 nrota = addrot(rotargs, vMtx[0], vMtx[1], vMtx[2]);
397 if (front_comp) {
398 cvt_sposition(sorg, ivec, 1);
399 printf("\nvoid colorfunc scale_pat\n");
400 printf("10 bsdf_red bsdf_grn bsdf_blu bsdf2rad.cal\n");
401 printf("\t-s %f -t %f %f %f\n0\n0\n",
402 bsdf_rad, sorg[0], sorg[1], sorg[2]);
403 printf("\nscale_pat glow scale_mat\n0\n0\n4 1 1 1 0\n");
404 }
405 if (front_comp & SDsampR) {
406 put_mirror_arrow(sorg, nrm);
407 fname = tfile_name(frpref, dsuffix, i);
408 sprintf(cmdbuf,
409 "gensurf scale_mat %s%d %s %s %s %d %d | xform %s -s %f -t %f %f %f",
410 frpref, i, fname, fname, fname, SAMPRES-1, SAMPRES-1,
411 rotargs, scalef, sorg[0], sorg[1], sorg[2]);
412 if (!run_cmd(cmdbuf))
413 return(0);
414 }
415 if (front_comp & SDsampT) {
416 put_trans_arrow(sorg);
417 fname = tfile_name(ftpref, dsuffix, i);
418 sprintf(cmdbuf,
419 "gensurf scale_mat %s%d %s %s %s %d %d | xform -I %s -s %f -t %f %f %f",
420 ftpref, i, fname, fname, fname, SAMPRES-1, SAMPRES-1,
421 rotargs, scalef, sorg[0], sorg[1], sorg[2]);
422 if (!run_cmd(cmdbuf))
423 return(0);
424 }
425 if (back_comp) {
426 cvt_sposition(sorg, ivec, -1);
427 printf("\nvoid colorfunc scale_pat\n");
428 printf("10 bsdf_red bsdf_grn bsdf_blu bsdf2rad.cal\n");
429 printf("\t-s %f -t %f %f %f\n0\n0\n",
430 bsdf_rad, sorg[0], sorg[1], sorg[2]);
431 printf("\nscale_pat glow scale_mat\n0\n0\n4 1 1 1 0\n");
432 }
433 if (back_comp & SDsampR) {
434 put_mirror_arrow(sorg, nrm);
435 fname = tfile_name(brpref, dsuffix, i);
436 sprintf(cmdbuf,
437 "gensurf scale_mat %s%d %s %s %s %d %d | xform -I -ry 180 %s -s %f -t %f %f %f",
438 brpref, i, fname, fname, fname, SAMPRES-1, SAMPRES-1,
439 rotargs, scalef, sorg[0], sorg[1], sorg[2]);
440 if (!run_cmd(cmdbuf))
441 return(0);
442 }
443 if (back_comp & SDsampT) {
444 put_trans_arrow(sorg);
445 fname = tfile_name(btpref, dsuffix, i);
446 sprintf(cmdbuf,
447 "gensurf scale_mat %s%d %s %s %s %d %d | xform -ry 180 %s -s %f -t %f %f %f",
448 btpref, i, fname, fname, fname, SAMPRES-1, SAMPRES-1,
449 rotargs, scalef, sorg[0], sorg[1], sorg[2]);
450 if (!run_cmd(cmdbuf))
451 return(0);
452 }
453 }
454 return(1);
455 }
456
457 /* Put our hemisphere material */
458 static void
459 put_matBSDF(const char *XMLfile)
460 {
461 const char *curdir = "./";
462
463 if (!XMLfile) { /* simple material */
464 printf("\n# Simplified material because we have no XML input\n");
465 printf("\nvoid brightfunc latlong\n2 latlong bsdf2rad.cal\n0\n0\n");
466 if ((front_comp|back_comp) & SDsampT)
467 printf("\nlatlong trans %s\n0\n0\n7 .75 .75 .75 0 .04 .5 .8\n",
468 sph_fmat);
469 else
470 printf("\nlatlong plastic %s\n0\n0\n5 .5 .5 .5 0 0\n",
471 sph_fmat);
472 printf("\ninherit alias %s %s\n", sph_bmat, sph_fmat);
473 return;
474 }
475 switch (XMLfile[0]) { /* avoid RAYPATH search */
476 case '.':
477 case '~':
478 CASEDIRSEP:
479 curdir = "";
480 break;
481 case '\0':
482 fprintf(stderr, "%s: empty file name in put_matBSDF\n", progname);
483 exit(1);
484 break;
485 }
486 printf("\n# Actual BSDF materials for rendering the hemispheres\n");
487 printf("\nvoid BSDF BSDF_f\n6 0 \"%s%s\" upx upy upz bsdf2rad.cal\n0\n0\n",
488 curdir, XMLfile);
489 printf("\nvoid plastic black\n0\n0\n5 0 0 0 0 0\n");
490 printf("\nvoid mixfunc %s\n4 BSDF_f black latlong bsdf2rad.cal\n0\n0\n",
491 sph_fmat);
492 printf("\nvoid BSDF BSDF_b\n8 0 \"%s%s\" upx upy upz bsdf2rad.cal -ry 180\n0\n0\n",
493 curdir, XMLfile);
494 printf("\nvoid mixfunc %s\n4 BSDF_b black latlong bsdf2rad.cal\n0\n0\n",
495 sph_bmat);
496 }
497
498 /* Put out overhead parallel light source */
499 static void
500 put_source(void)
501 {
502 printf("\n# Overhead parallel light source\n");
503 printf("\nvoid light bright\n0\n0\n3 2500 2500 2500\n");
504 printf("\nbright source light\n0\n0\n4 0 0 1 2\n");
505 printf("\n# Material used for labels\n");
506 printf("\nvoid trans vellum\n0\n0\n7 1 1 1 0 0 .5 0\n");
507 }
508
509 /* Put out hemisphere(s) */
510 static void
511 put_hemispheres(void)
512 {
513 const int nsegs = 131;
514
515 printf("\n# Hemisphere(s) for showing BSDF appearance (if XML file)\n");
516 if (front_comp) {
517 printf(
518 "\n!genrev %s Front \"R*sin(A*t)\" \"R*cos(A*t)\" %d -e \"R:%g;A:%f\" -s | xform -t %g 0 0\n",
519 sph_fmat, nsegs, sph_rad, 0.5*PI, sph_xoffset);
520 printf("\nvoid brighttext front_text\n3 helvet.fnt . FRONT\n0\n");
521 printf("12\n\t%f %f 0\n\t%f 0 0\n\t0 %f 0\n\t.01 1 -.1\n",
522 -.22*sph_rad + sph_xoffset, -1.4*sph_rad,
523 .35/5.*sph_rad, -1.6*.35/5.*sph_rad);
524 printf("\nfront_text alias front_label_mat vellum\n");
525 printf("\nfront_label_mat polygon front_label\n0\n0\n12");
526 printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
527 -.25*sph_rad + sph_xoffset, -1.3*sph_rad,
528 -.25*sph_rad + sph_xoffset, (-1.4-1.6*.35/5.-.1)*sph_rad,
529 .25*sph_rad + sph_xoffset, (-1.4-1.6*.35/5.-.1)*sph_rad,
530 .25*sph_rad + sph_xoffset, -1.3*sph_rad );
531 }
532 if (back_comp) {
533 printf(
534 "\n!genrev %s Back \"R*cos(A*t)\" \"R*sin(A*t)\" %d -e \"R:%g;A:%f\" -s | xform -t %g 0 0\n",
535 sph_bmat, nsegs, sph_rad, 0.5*PI, -sph_xoffset);
536 printf("\nvoid brighttext back_text\n3 helvet.fnt . BACK\n0\n");
537 printf("12\n\t%f %f 0\n\t%f 0 0\n\t0 %f 0\n\t.01 1 -.1\n",
538 -.22*sph_rad - sph_xoffset, -1.4*sph_rad,
539 .35/4.*sph_rad, -1.6*.35/4.*sph_rad);
540 printf("\nback_text alias back_label_mat vellum\n");
541 printf("\nback_label_mat polygon back_label\n0\n0\n12");
542 printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
543 -.25*sph_rad - sph_xoffset, -1.3*sph_rad,
544 -.25*sph_rad - sph_xoffset, (-1.4-1.6*.35/4.-.1)*sph_rad,
545 .25*sph_rad - sph_xoffset, (-1.4-1.6*.35/4.-.1)*sph_rad,
546 .25*sph_rad - sph_xoffset, -1.3*sph_rad );
547 }
548 }
549
550 /* Put out falsecolor scale and name label */
551 static void
552 put_scale(void)
553 {
554 const double max_log10 = log10(overall_max);
555 const double leg_width = 2.*.75*(fabs(sph_xoffset) - sph_rad);
556 const double leg_height = 2.*sph_rad;
557 const int text_lines = 6;
558 const int text_digits = 8;
559 char fmt[16];
560 int i;
561
562 printf("\n# BSDF legend with falsecolor scale\n");
563 printf("\nvoid colorfunc lscale\n10 sca_red(Py) sca_grn(Py) sca_blu(Py)");
564 printf("\n\tbsdf2rad.cal -s %f -t 0 %f 0\n0\n0\n", leg_height, -.5*leg_height);
565 sprintf(fmt, "%%.%df", text_digits-3);
566 for (i = 0; i < text_lines; i++) {
567 char vbuf[16];
568 sprintf(vbuf, fmt, pow(10., (i+.5)/text_lines*(max_log10-min_log10)+min_log10));
569 printf("\nlscale brighttext lscale\n");
570 printf("3 helvet.fnt . %s\n0\n12\n", vbuf);
571 printf("\t%f %f 0\n", -.45*leg_width, ((i+.9)/text_lines-.5)*leg_height);
572 printf("\t%f 0 0\n", .8*leg_width/strlen(vbuf));
573 printf("\t0 %f 0\n", -.9/text_lines*leg_height);
574 printf("\t.01 1 -.1\n");
575 }
576 printf("\nlscale alias legend_mat vellum\n");
577 printf("\nlegend_mat polygon legend\n0\n0\n12");
578 printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
579 -.5*leg_width, .5*leg_height,
580 -.5*leg_width, -.5*leg_height,
581 .5*leg_width, -.5*leg_height,
582 .5*leg_width, .5*leg_height);
583 printf("\nvoid brighttext BSDFtitle\n3 helvet.fnt . BSDF\n0\n12\n");
584 printf("\t%f %f 0\n", -.25*leg_width, .7*leg_height);
585 printf("\t%f 0 0\n", .4/4.*leg_width);
586 printf("\t0 %f 0\n", -.1*leg_height);
587 printf("\t.01 1 -.1\n");
588 printf("\nBSDFtitle alias title_mat vellum\n");
589 printf("\ntitle_mat polygon title\n0\n0\n12");
590 printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
591 -.3*leg_width, .75*leg_height,
592 -.3*leg_width, .55*leg_height,
593 .3*leg_width, .55*leg_height,
594 .3*leg_width, .75*leg_height);
595 if (!bsdf_name[0])
596 return;
597 printf("\nvoid brighttext BSDFname\n3 helvet.fnt . \"%s\"\n0\n12\n", bsdf_name);
598 printf("\t%f %f 0\n", -.95*leg_width, -.6*leg_height);
599 printf("\t%f 0 0\n", 1.8/strlen(bsdf_name)*leg_width);
600 printf("\t0 %f 0\n", -.1*leg_height);
601 printf("\t.01 1 -.1\n");
602 printf("\nBSDFname alias name_mat vellum\n");
603 printf("\nname_mat polygon name\n0\n0\n12");
604 printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
605 -leg_width, -.55*leg_height,
606 -leg_width, -.75*leg_height,
607 leg_width, -.75*leg_height,
608 leg_width, -.55*leg_height);
609 }
610
611 /* Convert MGF to Radiance in output */
612 static void
613 convert_mgf(const char *mgfdata)
614 {
615 int len = strlen(mgfdata);
616 char mgfn[128];
617 char radfn[128];
618 char cmdbuf[256];
619 float xmin, xmax, ymin, ymax, zmin, zmax;
620 double max_dim;
621 int fd;
622 FILE *fp;
623
624 if (!len) return;
625 strcpy(mgfn, tfile_name("geom", ".mgf", 0));
626 fd = open(mgfn, O_WRONLY|O_CREAT, 0666);
627 if (fd < 0 || write(fd, mgfdata, len) != len) {
628 fprintf(stderr, "%s: cannot write file '%s'\n",
629 progname, mgfn);
630 return;
631 }
632 close(fd);
633 strcpy(radfn, tfile_name("geom", ".rad", 0));
634 sprintf(cmdbuf, "mgf2rad %s > %s", mgfn, radfn);
635 if (!run_cmd(cmdbuf))
636 return;
637 sprintf(cmdbuf, "getbbox -w -h %s", radfn);
638 if ((fp = popen(cmdbuf, "r")) == NULL ||
639 fscanf(fp, "%f %f %f %f %f %f",
640 &xmin, &xmax, &ymin, &ymax, &zmin, &zmax) != 6
641 || pclose(fp) != 0) {
642 fprintf(stderr, "%s: error reading from command: %s\n",
643 progname, cmdbuf);
644 return;
645 }
646 max_dim = ymax - ymin;
647 if (xmax - xmin > max_dim)
648 max_dim = xmax - xmin;
649 if (front_comp) {
650 printf("\n# BSDF system geometry (front view)\n");
651 sprintf(cmdbuf, "xform -t %f %f %f -s %f -t %f %f 0 %s",
652 -.5*(xmin+xmax), -.5*(ymin+ymax), -zmax,
653 1.5*sph_rad/max_dim,
654 sph_xoffset, -2.5*sph_rad,
655 radfn);
656 if (!run_cmd(cmdbuf))
657 return;
658 }
659 if (back_comp) {
660 printf("\n# BSDF system geometry (back view)\n");
661 sprintf(cmdbuf, "xform -t %f %f %f -s %f -ry 180 -t %f %f 0 %s",
662 -.5*(xmin+xmax), -.5*(ymin+ymax), -zmin,
663 1.5*sph_rad/max_dim,
664 -sph_xoffset, -2.5*sph_rad,
665 radfn);
666 if (!run_cmd(cmdbuf))
667 return;
668 }
669 }
670
671 /* Check RBF input header line & get minimum BSDF value */
672 static int
673 rbf_headline(char *s, void *p)
674 {
675 char fmt[MAXFMTLEN];
676
677 if (formatval(fmt, s)) {
678 if (strcmp(fmt, BSDFREP_FMT))
679 return(-1);
680 return(0);
681 }
682 if (!strncmp(s, "IO_SIDES=", 9)) {
683 sscanf(s+9, "%d %d", &input_orient, &output_orient);
684 if (input_orient == output_orient) {
685 if (input_orient > 0)
686 front_comp |= SDsampR;
687 else
688 back_comp |= SDsampR;
689 } else if (input_orient > 0)
690 front_comp |= SDsampT;
691 else
692 back_comp |= SDsampT;
693 return(0);
694 }
695 if (!strncmp(s, "BSDFMIN=", 8)) {
696 sscanf(s+8, "%lf", &bsdf_min);
697 if (bsdf_min < overall_min)
698 overall_min = bsdf_min;
699 return(0);
700 }
701 return(0);
702 }
703
704 /* Produce a Radiance model plotting the given BSDF representation */
705 int
706 main(int argc, char *argv[])
707 {
708 int inpXML = -1;
709 double myLim[2];
710 SDData myBSDF;
711 int a, n;
712 /* check arguments */
713 progname = argv[0];
714 a = 1;
715 myLim[0] = -1; myLim[1] = -2; /* specified BSDF range? */
716 if (argc > a+3 && argv[a][0] == '-' && argv[a][1] == 'r') {
717 myLim[0] = atof(argv[++a]);
718 myLim[1] = atof(argv[++a]);
719 ++a;
720 }
721 if (argc > a && (n = strlen(argv[a])-4) > 0) {
722 if (!strcasecmp(argv[a]+n, ".xml"))
723 inpXML = 1;
724 else if (!strcasecmp(argv[a]+n, ".sir"))
725 inpXML = 0;
726 }
727 if (inpXML < 0 || inpXML & (argc > a+1)) {
728 fprintf(stderr, "Usage: %s [-r min max] bsdf.xml > output.rad\n", progname);
729 fprintf(stderr, " Or: %s [-r min max] hemi1.sir hemi2.sir .. > output.rad\n", progname);
730 return(1);
731 }
732 fputs("# ", stdout); /* copy our command */
733 printargs(argc, argv, stdout);
734 /* evaluate BSDF */
735 if (inpXML) {
736 SDclearBSDF(&myBSDF, argv[a]);
737 if (SDreportError(SDloadFile(&myBSDF, argv[a]), stderr))
738 return(1);
739 if (myBSDF.rf != NULL) front_comp |= SDsampR;
740 if (myBSDF.tf != NULL) front_comp |= SDsampT;
741 if (myBSDF.rb != NULL) back_comp |= SDsampR;
742 if (myBSDF.tb != NULL) back_comp |= SDsampT;
743 if (!front_comp & !back_comp) {
744 fprintf(stderr, "%s: nothing to plot in '%s'\n",
745 progname, argv[a]);
746 return(1);
747 }
748 if (myLim[0] >= 0)
749 overall_min = myLim[0];
750 else {
751 if (front_comp & SDsampR && myBSDF.rLambFront.cieY < overall_min*PI)
752 overall_min = myBSDF.rLambFront.cieY/PI;
753 if (back_comp & SDsampR && myBSDF.rLambBack.cieY < overall_min*PI)
754 overall_min = myBSDF.rLambBack.cieY/PI;
755 if (front_comp & SDsampT && myBSDF.tLambFront.cieY < overall_min*PI)
756 overall_min = myBSDF.tLambFront.cieY/PI;
757 if (back_comp & SDsampT && myBSDF.tLambBack.cieY < overall_min*PI)
758 overall_min = myBSDF.tLambBack.cieY/PI;
759 }
760 set_minlog();
761 if (!build_wBSDF(&myBSDF))
762 return(1);
763 if (myBSDF.matn[0])
764 strcpy(bsdf_name, myBSDF.matn);
765 else
766 strcpy(bsdf_name, myBSDF.name);
767 strcpy(bsdf_manuf, myBSDF.makr);
768 put_matBSDF(argv[a]);
769 } else {
770 FILE *fp[4];
771 if (argc > a+4) {
772 fprintf(stderr, "%s: more than 4 hemispheres!\n", progname);
773 return(1);
774 }
775 for (n = a; n < argc; n++) {
776 fp[n-a] = fopen(argv[n], "rb");
777 if (fp[n-a] == NULL) {
778 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
779 progname, argv[n]);
780 return(1);
781 }
782 if (getheader(fp[n-a], rbf_headline, NULL) < 0) {
783 fprintf(stderr, "%s: bad BSDF interpolant '%s'\n",
784 progname, argv[n]);
785 return(1);
786 }
787 }
788 if (myLim[0] >= 0)
789 overall_min = myLim[0];
790 set_minlog();
791 for (n = a; n < argc; n++) {
792 if (fseek(fp[n-a], 0L, SEEK_SET) < 0) {
793 fprintf(stderr, "%s: cannot seek on '%s'\n",
794 progname, argv[n]);
795 return(1);
796 }
797 if (!load_bsdf_rep(fp[n-a]))
798 return(1);
799 fclose(fp[n-a]);
800 if (!build_wRBF())
801 return(1);
802 }
803 put_matBSDF(NULL);
804 }
805 if (myLim[1] > myLim[0]) /* override maximum BSDF? */
806 overall_max = myLim[1];
807 put_source(); /* before hemispheres & labels */
808 put_hemispheres();
809 put_scale();
810 if (inpXML && myBSDF.mgf)
811 convert_mgf(myBSDF.mgf);
812 if (!put_BSDFs()) /* most of the output happens here */
813 return(1);
814 cleanup_tmp();
815 return(0);
816 }
