| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: bsdf2rad.c,v 2.20 2017/04/10 06:09:14 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Plot 3-D BSDF output based on scattering interpolant or XML representation
| 6 |
| 7 |
| 8 |
#include <stdio.h>
| 9 |
#include <string.h>
| 10 |
#include <stdlib.h>
| 11 |
#include "paths.h"
| 12 |
#include "rtmath.h"
| 13 |
#include "resolu.h"
| 14 |
#include "bsdfrep.h"
| 15 |
| 16 |
#define NINCIDENT 37 /* number of samples/hemisphere */
| 17 |
| 18 |
#define GRIDSTEP 2 /* our grid step size */
| 19 |
#define SAMPRES (GRIDRES/GRIDSTEP)
| 20 |
| 21 |
int front_comp = 0; /* front component flags (SDsamp*) */
| 22 |
int back_comp = 0; /* back component flags */
| 23 |
double overall_min = 1./PI; /* overall minimum BSDF value */
| 24 |
double min_log10; /* smallest log10 value for plotting */
| 25 |
double overall_max = .0; /* overall maximum BSDF value */
| 26 |
| 27 |
char ourTempDir[TEMPLEN] = ""; /* our temporary directory */
| 28 |
| 29 |
const FVECT Yaxis = {0., 1., 0.};
| 30 |
| 31 |
const char frpref[] = "frefl";
| 32 |
const char ftpref[] = "ftrans";
| 33 |
const char brpref[] = "brefl";
| 34 |
const char btpref[] = "btrans";
| 35 |
const char dsuffix[] = ".txt";
| 36 |
| 37 |
const char sph_mat[] = "BSDFmat";
| 38 |
const double sph_rad = 10.;
| 39 |
const double sph_xoffset = 15.;
| 40 |
| 41 |
#define bsdf_rad (sph_rad*.25)
| 42 |
#define arrow_rad (bsdf_rad*.015)
| 43 |
| 44 |
#define FEQ(a,b) ((a)-(b) <= 1e-7 && (b)-(a) <= 1e-7)
| 45 |
| 46 |
#define set_minlog() (min_log10 = log10(overall_min + 1e-5) - .1)
| 47 |
| 48 |
char *progname;
| 49 |
| 50 |
/* Get Fibonacci sphere vector (0 to NINCIDENT-1) */
| 51 |
static RREAL *
| 52 |
get_ivector(FVECT iv, int i)
| 53 |
| 54 |
const double phistep = PI*(3. - 2.236067978);
| 55 |
double r;
| 56 |
| 57 |
iv[2] = 1. - (i+.5)*(1./NINCIDENT);
| 58 |
r = sqrt(1. - iv[2]*iv[2]);
| 59 |
iv[0] = r * cos((i+1.)*phistep);
| 60 |
iv[1] = r * sin((i+1.)*phistep);
| 61 |
| 62 |
return(iv);
| 63 |
| 64 |
| 65 |
/* Convert incident vector into sphere position */
| 66 |
static RREAL *
| 67 |
cvt_sposition(FVECT sp, const FVECT iv, int inc_side)
| 68 |
| 69 |
sp[0] = -iv[0]*sph_rad + inc_side*sph_xoffset;
| 70 |
sp[1] = -iv[1]*sph_rad;
| 71 |
sp[2] = iv[2]*sph_rad;
| 72 |
| 73 |
return(sp);
| 74 |
| 75 |
| 76 |
/* Get temporary file name */
| 77 |
static char *
| 78 |
tfile_name(const char *prefix, const char *suffix, int i)
| 79 |
| 80 |
static char buf[128];
| 81 |
| 82 |
if (!ourTempDir[0]) { /* create temporary directory */
| 83 |
mktemp(strcpy(ourTempDir,TEMPLATE));
| 84 |
if (mkdir(ourTempDir, 0777) < 0) {
| 85 |
perror("mkdir");
| 86 |
exit(1);
| 87 |
| 88 |
| 89 |
if (!prefix) prefix = "T";
| 90 |
if (!suffix) suffix = "";
| 91 |
sprintf(buf, "%s/%s%03d%s", ourTempDir, prefix, i, suffix);
| 92 |
return(buf);
| 93 |
| 94 |
| 95 |
/* Remove temporary directory & contents */
| 96 |
static void
| 97 |
cleanup_tmp(void)
| 98 |
| 99 |
char buf[128];
| 100 |
| 101 |
if (!ourTempDir[0])
| 102 |
return;
| 103 |
#if defined(_WIN32) || defined(_WIN64)
| 104 |
sprintf(buf, "RMDIR %s /S /Q", ourTempDir);
| 105 |
#else
| 106 |
sprintf(buf, "rm -rf %s", ourTempDir);
| 107 |
#endif
| 108 |
system(buf);
| 109 |
| 110 |
| 111 |
/* Run the specified command, returning 1 if OK */
| 112 |
static int
| 113 |
run_cmd(const char *cmd)
| 114 |
| 115 |
fflush(stdout);
| 116 |
if (system(cmd)) {
| 117 |
fprintf(stderr, "%s: error running: %s\n", progname, cmd);
| 118 |
return(0);
| 119 |
| 120 |
return(1);
| 121 |
| 122 |
| 123 |
/* Plot surface points for the given BSDF incident angle */
| 124 |
static int
| 125 |
plotBSDF(const char *fname, const FVECT ivec, int dfl, const SDData *sd)
| 126 |
| 127 |
FILE *fp = fopen(fname, "w");
| 128 |
int i, j;
| 129 |
| 130 |
if (fp == NULL) {
| 131 |
fprintf(stderr, "%s: cannot open '%s' for writing\n",
| 132 |
progname, fname);
| 133 |
return(0);
| 134 |
| 135 |
if (ivec[2] > 0) {
| 136 |
input_orient = 1;
| 137 |
output_orient = dfl&SDsampR ? 1 : -1;
| 138 |
} else {
| 139 |
input_orient = -1;
| 140 |
output_orient = dfl&SDsampR ? -1 : 1;
| 141 |
| 142 |
for (i = SAMPRES; i--; )
| 143 |
for (j = 0; j < SAMPRES; j++) {
| 144 |
FVECT ovec;
| 145 |
SDValue sval;
| 146 |
double bsdf;
| 147 |
ovec_from_pos(ovec, i*GRIDSTEP, j*GRIDSTEP);
| 148 |
if (SDreportError(SDevalBSDF(&sval, ovec,
| 149 |
ivec, sd), stderr))
| 150 |
return(0);
| 151 |
if (sval.cieY > overall_max)
| 152 |
overall_max = sval.cieY;
| 153 |
bsdf = (sval.cieY < overall_min) ? overall_min : sval.cieY;
| 154 |
bsdf = log10(bsdf) - min_log10;
| 155 |
fprintf(fp, "%.5f %.5f %.5f\n",
| 156 |
ovec[0]*bsdf, ovec[1]*bsdf, ovec[2]*bsdf);
| 157 |
| 158 |
if (fclose(fp) == EOF) {
| 159 |
fprintf(stderr, "%s: error writing data to '%s'\n",
| 160 |
progname, fname);
| 161 |
return(0);
| 162 |
| 163 |
return(1);
| 164 |
| 165 |
| 166 |
/* Build BSDF values from loaded XML file */
| 167 |
static int
| 168 |
build_wBSDF(const SDData *sd)
| 169 |
| 170 |
FVECT ivec;
| 171 |
int i;
| 172 |
| 173 |
if (front_comp & SDsampR)
| 174 |
for (i = 0; i < NINCIDENT; i++) {
| 175 |
get_ivector(ivec, i);
| 176 |
if (!plotBSDF(tfile_name(frpref, dsuffix, i),
| 177 |
ivec, SDsampR, sd))
| 178 |
return(0);
| 179 |
| 180 |
if (front_comp & SDsampT)
| 181 |
| 182 |
| 183 |
if (!plotBSDF(tfile_name(ftpref, dsuffix, i),
| 184 |
ivec, SDsampT, sd))
| 185 |
return(0);
| 186 |
| 187 |
if (back_comp & SDsampR)
| 188 |
| 189 |
| 190 |
ivec[0] = -ivec[0]; ivec[2] = -ivec[2];
| 191 |
if (!plotBSDF(tfile_name(brpref, dsuffix, i),
| 192 |
ivec, SDsampR, sd))
| 193 |
return(0);
| 194 |
| 195 |
if (back_comp & SDsampT)
| 196 |
| 197 |
| 198 |
| 199 |
if (!plotBSDF(tfile_name(btpref, dsuffix, i),
| 200 |
ivec, SDsampT, sd))
| 201 |
return(0);
| 202 |
| 203 |
return(1);
| 204 |
| 205 |
| 206 |
/* Plot surface points using radial basis function */
| 207 |
static int
| 208 |
plotRBF(const char *fname, const RBFNODE *rbf)
| 209 |
| 210 |
| 211 |
int i, j;
| 212 |
| 213 |
if (fp == NULL) {
| 214 |
| 215 |
progname, fname);
| 216 |
return(0);
| 217 |
| 218 |
| 219 |
| 220 |
FVECT ovec;
| 221 |
double bsdf;
| 222 |
| 223 |
bsdf = eval_rbfrep(rbf, ovec);
| 224 |
if (bsdf > overall_max)
| 225 |
overall_max = bsdf;
| 226 |
else if (bsdf < overall_min)
| 227 |
bsdf = overall_min;
| 228 |
| 229 |
| 230 |
| 231 |
| 232 |
| 233 |
| 234 |
progname, fname);
| 235 |
return(0);
| 236 |
| 237 |
return(1);
| 238 |
| 239 |
| 240 |
/* Build BSDF values from scattering interpolant representation */
| 241 |
static int
| 242 |
build_wRBF(void)
| 243 |
| 244 |
const char *pref;
| 245 |
int i;
| 246 |
| 247 |
if (input_orient > 0) {
| 248 |
if (output_orient > 0)
| 249 |
pref = frpref;
| 250 |
else
| 251 |
pref = ftpref;
| 252 |
} else if (output_orient < 0)
| 253 |
pref = brpref;
| 254 |
else
| 255 |
pref = btpref;
| 256 |
| 257 |
| 258 |
FVECT ivec;
| 259 |
RBFNODE *rbf;
| 260 |
| 261 |
if (input_orient < 0) {
| 262 |
| 263 |
| 264 |
rbf = advect_rbf(ivec, 15000);
| 265 |
if (!plotRBF(tfile_name(pref, dsuffix, i), rbf))
| 266 |
return(0);
| 267 |
if (rbf) free(rbf);
| 268 |
| 269 |
return(1); /* next call frees */
| 270 |
| 271 |
| 272 |
/* Put out mirror arrow for the given incident vector */
| 273 |
static void
| 274 |
put_mirror_arrow(const FVECT ivec, int inc_side)
| 275 |
| 276 |
const double arrow_len = 1.2*bsdf_rad;
| 277 |
const double tip_len = 0.2*bsdf_rad;
| 278 |
FVECT origin, refl;
| 279 |
int i;
| 280 |
| 281 |
cvt_sposition(origin, ivec, inc_side);
| 282 |
| 283 |
refl[0] = -2.*ivec[2]*ivec[0];
| 284 |
refl[1] = -2.*ivec[2]*ivec[1];
| 285 |
refl[2] = 2.*ivec[2]*ivec[2] - 1.;
| 286 |
| 287 |
printf("\n# Mirror arrow\n");
| 288 |
printf("\narrow_mat cylinder inc_dir\n0\n0\n7");
| 289 |
printf("\n\t%f %f %f\n\t%f %f %f\n\t%f\n",
| 290 |
origin[0], origin[1], origin[2]+arrow_len,
| 291 |
origin[0], origin[1], origin[2],
| 292 |
arrow_rad);
| 293 |
printf("\narrow_mat cylinder mir_dir\n0\n0\n7");
| 294 |
| 295 |
| 296 |
origin[0] + arrow_len*refl[0],
| 297 |
origin[1] + arrow_len*refl[1],
| 298 |
origin[2] + arrow_len*refl[2],
| 299 |
arrow_rad);
| 300 |
printf("\narrow_mat cone mir_tip\n0\n0\n8");
| 301 |
printf("\n\t%f %f %f\n\t%f %f %f\n\t%f 0\n",
| 302 |
origin[0] + (arrow_len-.5*tip_len)*refl[0],
| 303 |
origin[1] + (arrow_len-.5*tip_len)*refl[1],
| 304 |
origin[2] + (arrow_len-.5*tip_len)*refl[2],
| 305 |
origin[0] + (arrow_len+.5*tip_len)*refl[0],
| 306 |
origin[1] + (arrow_len+.5*tip_len)*refl[1],
| 307 |
origin[2] + (arrow_len+.5*tip_len)*refl[2],
| 308 |
2.*arrow_rad);
| 309 |
| 310 |
| 311 |
/* Put out transmitted direction arrow for the given incident vector */
| 312 |
static void
| 313 |
put_trans_arrow(const FVECT ivec, int inc_side)
| 314 |
| 315 |
| 316 |
| 317 |
FVECT origin;
| 318 |
int i;
| 319 |
| 320 |
| 321 |
| 322 |
printf("\n# Transmission arrow\n");
| 323 |
printf("\narrow_mat cylinder trans_dir\n0\n0\n7");
| 324 |
| 325 |
| 326 |
origin[0], origin[1], origin[2]-arrow_len,
| 327 |
arrow_rad);
| 328 |
printf("\narrow_mat cone trans_tip\n0\n0\n8");
| 329 |
| 330 |
origin[0], origin[1], origin[2]-arrow_len+.5*tip_len,
| 331 |
origin[0], origin[1], origin[2]-arrow_len-.5*tip_len,
| 332 |
2.*arrow_rad);
| 333 |
| 334 |
| 335 |
/* Compute rotation (x,y,z) => (xp,yp,zp) */
| 336 |
static int
| 337 |
addrot(char *xf, const FVECT xp, const FVECT yp, const FVECT zp)
| 338 |
| 339 |
int n = 0;
| 340 |
double theta;
| 341 |
| 342 |
if (yp[2]*yp[2] + zp[2]*zp[2] < 2.*FTINY*FTINY) {
| 343 |
/* Special case for X' along Z-axis */
| 344 |
theta = -atan2(yp[0], yp[1]);
| 345 |
sprintf(xf, " -ry %f -rz %f",
| 346 |
xp[2] < 0.0 ? 90.0 : -90.0,
| 347 |
theta*(180./PI));
| 348 |
return(4);
| 349 |
| 350 |
theta = atan2(yp[2], zp[2]);
| 351 |
if (!FEQ(theta,0.0)) {
| 352 |
sprintf(xf, " -rx %f", theta*(180./PI));
| 353 |
while (*xf) ++xf;
| 354 |
n += 2;
| 355 |
| 356 |
theta = Asin(-xp[2]);
| 357 |
| 358 |
sprintf(xf, " -ry %f", theta*(180./PI));
| 359 |
while (*xf) ++xf;
| 360 |
n += 2;
| 361 |
| 362 |
theta = atan2(xp[1], xp[0]);
| 363 |
| 364 |
sprintf(xf, " -rz %f", theta*(180./PI));
| 365 |
/* while (*xf) ++xf; */
| 366 |
n += 2;
| 367 |
| 368 |
return(n);
| 369 |
| 370 |
| 371 |
/* Put out BSDF surfaces */
| 372 |
static int
| 373 |
put_BSDFs(void)
| 374 |
| 375 |
const double scalef = bsdf_rad/(log10(overall_max) - min_log10);
| 376 |
FVECT ivec, sorg;
| 377 |
RREAL vMtx[3][3];
| 378 |
char *fname;
| 379 |
char cmdbuf[256];
| 380 |
char xfargs[128];
| 381 |
int nxfa;
| 382 |
int i;
| 383 |
| 384 |
printf("\n# Gensurf output corresponding to %d incident directions\n",
| 385 |
NINCIDENT);
| 386 |
| 387 |
printf("\nvoid glow arrow_glow\n0\n0\n4 1 0 1 0\n");
| 388 |
printf("\nvoid mixfunc arrow_mat\n4 arrow_glow void 0.5 .\n0\n0\n");
| 389 |
| 390 |
if (front_comp & SDsampR) /* front reflection */
| 391 |
| 392 |
| 393 |
put_mirror_arrow(ivec, 1);
| 394 |
cvt_sposition(sorg, ivec, 1);
| 395 |
ivec[0] = -ivec[0]; ivec[1] = -ivec[1]; /* normal */
| 396 |
sprintf(xfargs, "-s %f -t %f %f %f", bsdf_rad,
| 397 |
sorg[0], sorg[1], sorg[2]);
| 398 |
nxfa = 6;
| 399 |
printf("\nvoid colorfunc scale_pat\n");
| 400 |
printf("%d bsdf_red bsdf_grn bsdf_blu bsdf2rad.cal\n\t%s\n0\n0\n",
| 401 |
4+nxfa, xfargs);
| 402 |
printf("\nscale_pat glow scale_mat\n0\n0\n4 1 1 1 0\n");
| 403 |
SDcompXform(vMtx, ivec, Yaxis);
| 404 |
nxfa = addrot(xfargs, vMtx[0], vMtx[1], vMtx[2]);
| 405 |
sprintf(xfargs+strlen(xfargs), " -s %f -t %f %f %f",
| 406 |
scalef, sorg[0], sorg[1], sorg[2]);
| 407 |
nxfa += 6;
| 408 |
fname = tfile_name(frpref, dsuffix, i);
| 409 |
sprintf(cmdbuf, "gensurf scale_mat %s%d %s %s %s %d %d | xform %s",
| 410 |
frpref, i, fname, fname, fname, SAMPRES-1, SAMPRES-1,
| 411 |
xfargs);
| 412 |
if (!run_cmd(cmdbuf))
| 413 |
return(0);
| 414 |
| 415 |
if (front_comp & SDsampT) /* front transmission */
| 416 |
| 417 |
| 418 |
put_trans_arrow(ivec, 1);
| 419 |
| 420 |
| 421 |
| 422 |
| 423 |
nxfa = 6;
| 424 |
| 425 |
| 426 |
4+nxfa, xfargs);
| 427 |
| 428 |
| 429 |
| 430 |
| 431 |
| 432 |
nxfa += 6;
| 433 |
fname = tfile_name(ftpref, dsuffix, i);
| 434 |
sprintf(cmdbuf, "gensurf scale_mat %s%d %s %s %s %d %d | xform -I %s",
| 435 |
ftpref, i, fname, fname, fname, SAMPRES-1, SAMPRES-1,
| 436 |
xfargs);
| 437 |
| 438 |
return(0);
| 439 |
| 440 |
if (back_comp & SDsampR) /* rear reflection */
| 441 |
| 442 |
| 443 |
put_mirror_arrow(ivec, -1);
| 444 |
cvt_sposition(sorg, ivec, -1);
| 445 |
| 446 |
| 447 |
| 448 |
nxfa = 6;
| 449 |
| 450 |
| 451 |
4+nxfa, xfargs);
| 452 |
| 453 |
| 454 |
| 455 |
| 456 |
| 457 |
nxfa += 6;
| 458 |
fname = tfile_name(brpref, dsuffix, i);
| 459 |
sprintf(cmdbuf, "gensurf scale_mat %s%d %s %s %s %d %d | xform -I -ry 180 %s",
| 460 |
brpref, i, fname, fname, fname, SAMPRES-1, SAMPRES-1,
| 461 |
xfargs);
| 462 |
| 463 |
return(0);
| 464 |
| 465 |
if (back_comp & SDsampT) /* rear transmission */
| 466 |
| 467 |
| 468 |
put_trans_arrow(ivec, -1);
| 469 |
| 470 |
| 471 |
| 472 |
| 473 |
nxfa = 6;
| 474 |
| 475 |
| 476 |
4+nxfa, xfargs);
| 477 |
| 478 |
| 479 |
| 480 |
| 481 |
| 482 |
nxfa += 6;
| 483 |
fname = tfile_name(btpref, dsuffix, i);
| 484 |
sprintf(cmdbuf, "gensurf scale_mat %s%d %s %s %s %d %d | xform -ry 180 %s",
| 485 |
btpref, i, fname, fname, fname, SAMPRES-1, SAMPRES-1,
| 486 |
xfargs);
| 487 |
| 488 |
return(0);
| 489 |
| 490 |
return(1);
| 491 |
| 492 |
| 493 |
/* Put our hemisphere material */
| 494 |
static void
| 495 |
put_matBSDF(const char *XMLfile)
| 496 |
| 497 |
const char *curdir = "./";
| 498 |
| 499 |
if (!XMLfile) { /* simple material */
| 500 |
printf("\n# Simplified material because we have no XML input\n");
| 501 |
printf("\nvoid brightfunc latlong\n2 latlong bsdf2rad.cal\n0\n0\n");
| 502 |
if ((front_comp|back_comp) & SDsampT)
| 503 |
printf("\nlatlong trans %s\n0\n0\n7 .75 .75 .75 0 .04 .5 .8\n",
| 504 |
sph_mat);
| 505 |
else
| 506 |
printf("\nlatlong plastic %s\n0\n0\n5 .5 .5 .5 0 0\n",
| 507 |
sph_mat);
| 508 |
return;
| 509 |
| 510 |
switch (XMLfile[0]) { /* avoid RAYPATH search */
| 511 |
case '.':
| 512 |
CASEDIRSEP:
| 513 |
curdir = "";
| 514 |
break;
| 515 |
case '\0':
| 516 |
fprintf(stderr, "%s: empty file name in put_matBSDF\n", progname);
| 517 |
exit(1);
| 518 |
break;
| 519 |
| 520 |
printf("\n# Actual BSDF material for rendering the hemispheres\n");
| 521 |
printf("\nvoid BSDF BSDFmat\n6 0 \"%s%s\" 0 1 0 .\n0\n0\n",
| 522 |
curdir, XMLfile);
| 523 |
printf("\nvoid plastic black\n0\n0\n5 0 0 0 0 0\n");
| 524 |
printf("\nvoid mixfunc %s\n4 BSDFmat black latlong bsdf2rad.cal\n0\n0\n",
| 525 |
sph_mat);
| 526 |
| 527 |
| 528 |
/* Put out overhead parallel light source */
| 529 |
static void
| 530 |
put_source(void)
| 531 |
| 532 |
printf("\n# Overhead parallel light source\n");
| 533 |
printf("\nvoid light bright\n0\n0\n3 2500 2500 2500\n");
| 534 |
printf("\nbright source light\n0\n0\n4 0 0 1 2\n");
| 535 |
printf("\n# Material used for labels\n");
| 536 |
printf("\nvoid trans vellum\n0\n0\n7 1 1 1 0 0 .5 0\n");
| 537 |
| 538 |
| 539 |
/* Put out hemisphere(s) */
| 540 |
static void
| 541 |
put_hemispheres(void)
| 542 |
| 543 |
const int nsegs = 131;
| 544 |
| 545 |
printf("\n# Hemisphere(s) for showing BSDF appearance (if XML file)\n");
| 546 |
if (front_comp) {
| 547 |
printf(
| 548 |
"\n!genrev %s Front \"R*sin(A*t)\" \"R*cos(A*t)\" %d -e \"R:%g;A:%f\" -s | xform -t %g 0 0\n",
| 549 |
sph_mat, nsegs, sph_rad, 0.495*PI, sph_xoffset);
| 550 |
printf("\nvoid brighttext front_text\n3 helvet.fnt . FRONT\n0\n");
| 551 |
printf("12\n\t%f %f 0\n\t%f 0 0\n\t0 %f 0\n\t.01 1 -.1\n",
| 552 |
-.22*sph_rad + sph_xoffset, -1.4*sph_rad,
| 553 |
.35/5.*sph_rad, -1.6*.35/5.*sph_rad);
| 554 |
printf("\nfront_text alias front_label_mat vellum\n");
| 555 |
printf("\nfront_label_mat polygon front_label\n0\n0\n12");
| 556 |
printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
| 557 |
-.25*sph_rad + sph_xoffset, -1.3*sph_rad,
| 558 |
-.25*sph_rad + sph_xoffset, (-1.4-1.6*.35/5.-.1)*sph_rad,
| 559 |
| 560 |
.25*sph_rad + sph_xoffset, -1.3*sph_rad );
| 561 |
| 562 |
if (back_comp) {
| 563 |
printf(
| 564 |
"\n!genrev %s Back \"R*cos(A*t)\" \"R*sin(A*t)\" %d -e \"R:%g;A:%f\" -s | xform -t %g 0 0\n",
| 565 |
sph_mat, nsegs, sph_rad, 0.495*PI, -sph_xoffset);
| 566 |
printf("\nvoid brighttext back_text\n3 helvet.fnt . BACK\n0\n");
| 567 |
| 568 |
-.22*sph_rad - sph_xoffset, -1.4*sph_rad,
| 569 |
.35/4.*sph_rad, -1.6*.35/4.*sph_rad);
| 570 |
printf("\nback_text alias back_label_mat vellum\n");
| 571 |
printf("\nback_label_mat polygon back_label\n0\n0\n12");
| 572 |
| 573 |
-.25*sph_rad - sph_xoffset, -1.3*sph_rad,
| 574 |
-.25*sph_rad - sph_xoffset, (-1.4-1.6*.35/4.-.1)*sph_rad,
| 575 |
| 576 |
.25*sph_rad - sph_xoffset, -1.3*sph_rad );
| 577 |
| 578 |
| 579 |
| 580 |
/* Put out falsecolor scale and name label */
| 581 |
static void
| 582 |
put_scale(void)
| 583 |
| 584 |
const double max_log10 = log10(overall_max);
| 585 |
const double leg_width = 2.*.75*(fabs(sph_xoffset) - sph_rad);
| 586 |
const double leg_height = 2.*sph_rad;
| 587 |
const int text_lines = 6;
| 588 |
const int text_digits = 8;
| 589 |
char fmt[16];
| 590 |
int i;
| 591 |
| 592 |
printf("\n# BSDF legend with falsecolor scale\n");
| 593 |
printf("\nvoid colorfunc lscale\n10 sca_red(Py) sca_grn(Py) sca_blu(Py)");
| 594 |
printf("\n\tbsdf2rad.cal -s %f -t 0 %f 0\n0\n0\n", leg_height, -.5*leg_height);
| 595 |
sprintf(fmt, "%%.%df", text_digits-3);
| 596 |
for (i = 0; i < text_lines; i++) {
| 597 |
char vbuf[16];
| 598 |
sprintf(vbuf, fmt, pow(10., (i+.5)/text_lines*(max_log10-min_log10)+min_log10));
| 599 |
printf("\nlscale brighttext lscale\n");
| 600 |
printf("3 helvet.fnt . %s\n0\n12\n", vbuf);
| 601 |
printf("\t%f %f 0\n", -.45*leg_width, ((i+.9)/text_lines-.5)*leg_height);
| 602 |
printf("\t%f 0 0\n", .8*leg_width/strlen(vbuf));
| 603 |
printf("\t0 %f 0\n", -.9/text_lines*leg_height);
| 604 |
printf("\t.01 1 -.1\n");
| 605 |
| 606 |
printf("\nlscale alias legend_mat vellum\n");
| 607 |
printf("\nlegend_mat polygon legend\n0\n0\n12");
| 608 |
| 609 |
-.5*leg_width, .5*leg_height,
| 610 |
-.5*leg_width, -.5*leg_height,
| 611 |
| 612 |
.5*leg_width, .5*leg_height);
| 613 |
printf("\nvoid brighttext BSDFtitle\n3 helvet.fnt . BSDF\n0\n12\n");
| 614 |
printf("\t%f %f 0\n", -.25*leg_width, .7*leg_height);
| 615 |
printf("\t%f 0 0\n", .4/4.*leg_width);
| 616 |
printf("\t0 %f 0\n", -.1*leg_height);
| 617 |
| 618 |
printf("\nBSDFtitle alias title_mat vellum\n");
| 619 |
printf("\ntitle_mat polygon title\n0\n0\n12");
| 620 |
| 621 |
-.3*leg_width, .75*leg_height,
| 622 |
-.3*leg_width, .55*leg_height,
| 623 |
| 624 |
.3*leg_width, .75*leg_height);
| 625 |
if (!bsdf_name[0])
| 626 |
return;
| 627 |
printf("\nvoid brighttext BSDFname\n3 helvet.fnt . \"%s\"\n0\n12\n", bsdf_name);
| 628 |
printf("\t%f %f 0\n", -.95*leg_width, -.6*leg_height);
| 629 |
printf("\t%f 0 0\n", 1.8/strlen(bsdf_name)*leg_width);
| 630 |
| 631 |
| 632 |
printf("\nBSDFname alias name_mat vellum\n");
| 633 |
printf("\nname_mat polygon name\n0\n0\n12");
| 634 |
| 635 |
-leg_width, -.55*leg_height,
| 636 |
-leg_width, -.75*leg_height,
| 637 |
| 638 |
leg_width, -.55*leg_height);
| 639 |
| 640 |
| 641 |
/* Convert MGF to Radiance in output */
| 642 |
static void
| 643 |
convert_mgf(const char *mgfdata)
| 644 |
| 645 |
int len = strlen(mgfdata);
| 646 |
char mgfn[128];
| 647 |
char radfn[128];
| 648 |
char cmdbuf[256];
| 649 |
float xmin, xmax, ymin, ymax, zmin, zmax;
| 650 |
double max_dim;
| 651 |
int fd;
| 652 |
FILE *fp;
| 653 |
| 654 |
if (!len) return;
| 655 |
strcpy(mgfn, tfile_name("geom", ".mgf", 0));
| 656 |
fd = open(mgfn, O_WRONLY|O_CREAT, 0666);
| 657 |
if (fd < 0 || write(fd, mgfdata, len) != len) {
| 658 |
fprintf(stderr, "%s: cannot write file '%s'\n",
| 659 |
progname, mgfn);
| 660 |
return;
| 661 |
| 662 |
close(fd);
| 663 |
strcpy(radfn, tfile_name("geom", ".rad", 0));
| 664 |
sprintf(cmdbuf, "mgf2rad %s > %s", mgfn, radfn);
| 665 |
| 666 |
return;
| 667 |
sprintf(cmdbuf, "getbbox -w -h %s", radfn);
| 668 |
if ((fp = popen(cmdbuf, "r")) == NULL ||
| 669 |
fscanf(fp, "%f %f %f %f %f %f",
| 670 |
&xmin, &xmax, &ymin, &ymax, &zmin, &zmax) != 6
| 671 |
|| pclose(fp) < 0) {
| 672 |
fprintf(stderr, "%s: error reading from command: %s\n",
| 673 |
progname, cmdbuf);
| 674 |
return;
| 675 |
| 676 |
max_dim = ymax - ymin;
| 677 |
if (xmax - xmin > max_dim)
| 678 |
max_dim = xmax - xmin;
| 679 |
if (front_comp) {
| 680 |
printf("\n# BSDF system geometry (front view)\n");
| 681 |
sprintf(cmdbuf, "xform -t %f %f %f -s %f -t %f %f 0 %s",
| 682 |
-.5*(xmin+xmax), -.5*(ymin+ymax), -zmax,
| 683 |
1.5*sph_rad/max_dim,
| 684 |
sph_xoffset, -2.5*sph_rad,
| 685 |
radfn);
| 686 |
| 687 |
return;
| 688 |
| 689 |
if (back_comp) {
| 690 |
printf("\n# BSDF system geometry (back view)\n");
| 691 |
sprintf(cmdbuf, "xform -t %f %f %f -s %f -ry 180 -t %f %f 0 %s",
| 692 |
-.5*(xmin+xmax), -.5*(ymin+ymax), -zmin,
| 693 |
| 694 |
-sph_xoffset, -2.5*sph_rad,
| 695 |
radfn);
| 696 |
| 697 |
return;
| 698 |
| 699 |
| 700 |
| 701 |
/* Check RBF input header line & get minimum BSDF value */
| 702 |
static int
| 703 |
rbf_headline(char *s, void *p)
| 704 |
| 705 |
char fmt[64];
| 706 |
| 707 |
if (formatval(fmt, s)) {
| 708 |
if (strcmp(fmt, BSDFREP_FMT))
| 709 |
return(-1);
| 710 |
return(0);
| 711 |
| 712 |
if (!strncmp(s, "IO_SIDES=", 9)) {
| 713 |
sscanf(s+9, "%d %d", &input_orient, &output_orient);
| 714 |
if (input_orient == output_orient) {
| 715 |
| 716 |
front_comp |= SDsampR;
| 717 |
else
| 718 |
back_comp |= SDsampR;
| 719 |
} else if (input_orient > 0)
| 720 |
front_comp |= SDsampT;
| 721 |
else
| 722 |
back_comp |= SDsampT;
| 723 |
return(0);
| 724 |
| 725 |
if (!strncmp(s, "BSDFMIN=", 8)) {
| 726 |
sscanf(s+8, "%lf", &bsdf_min);
| 727 |
if (bsdf_min < overall_min)
| 728 |
overall_min = bsdf_min;
| 729 |
return(0);
| 730 |
| 731 |
return(0);
| 732 |
| 733 |
| 734 |
/* Produce a Radiance model plotting the given BSDF representation */
| 735 |
int
| 736 |
main(int argc, char *argv[])
| 737 |
| 738 |
int inpXML = -1;
| 739 |
SDData myBSDF;
| 740 |
int n;
| 741 |
/* check arguments */
| 742 |
progname = argv[0];
| 743 |
if (argc > 1 && (n = strlen(argv[1])-4) > 0) {
| 744 |
if (!strcasecmp(argv[1]+n, ".xml"))
| 745 |
inpXML = 1;
| 746 |
else if (!strcasecmp(argv[1]+n, ".sir"))
| 747 |
inpXML = 0;
| 748 |
| 749 |
if (inpXML < 0 || inpXML & (argc > 2)) {
| 750 |
fprintf(stderr, "Usage: %s bsdf.xml > output.rad\n", progname);
| 751 |
fprintf(stderr, " Or: %s hemi1.sir hemi2.sir .. > output.rad\n", progname);
| 752 |
return(1);
| 753 |
| 754 |
fputs("# ", stdout); /* copy our command */
| 755 |
printargs(argc, argv, stdout);
| 756 |
/* evaluate BSDF */
| 757 |
if (inpXML) {
| 758 |
SDclearBSDF(&myBSDF, argv[1]);
| 759 |
if (SDreportError(SDloadFile(&myBSDF, argv[1]), stderr))
| 760 |
return(1);
| 761 |
if (myBSDF.rf != NULL) front_comp |= SDsampR;
| 762 |
if (myBSDF.tf != NULL) front_comp |= SDsampT;
| 763 |
if (myBSDF.rb != NULL) back_comp |= SDsampR;
| 764 |
if (myBSDF.tb != NULL) back_comp |= SDsampT;
| 765 |
if (!front_comp & !back_comp) {
| 766 |
fprintf(stderr, "%s: nothing to plot in '%s'\n",
| 767 |
progname, argv[1]);
| 768 |
return(1);
| 769 |
| 770 |
if (front_comp & SDsampR && myBSDF.rLambFront.cieY < overall_min*PI)
| 771 |
overall_min = myBSDF.rLambFront.cieY/PI;
| 772 |
if (back_comp & SDsampR && myBSDF.rLambBack.cieY < overall_min*PI)
| 773 |
overall_min = myBSDF.rLambBack.cieY/PI;
| 774 |
if ((front_comp|back_comp) & SDsampT &&
| 775 |
myBSDF.tLamb.cieY < overall_min*PI)
| 776 |
overall_min = myBSDF.tLamb.cieY/PI;
| 777 |
set_minlog();
| 778 |
if (!build_wBSDF(&myBSDF))
| 779 |
return(1);
| 780 |
if (myBSDF.matn[0])
| 781 |
strcpy(bsdf_name, myBSDF.matn);
| 782 |
else
| 783 |
strcpy(bsdf_name, myBSDF.name);
| 784 |
strcpy(bsdf_manuf, myBSDF.makr);
| 785 |
put_matBSDF(argv[1]);
| 786 |
} else {
| 787 |
FILE *fp;
| 788 |
for (n = 1; n < argc; n++) {
| 789 |
fp = fopen(argv[n], "rb");
| 790 |
if (fp == NULL) {
| 791 |
fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
| 792 |
progname, argv[n]);
| 793 |
return(1);
| 794 |
| 795 |
if (getheader(fp, rbf_headline, NULL) < 0) {
| 796 |
fprintf(stderr, "%s: bad BSDF interpolant '%s'\n",
| 797 |
progname, argv[n]);
| 798 |
return(1);
| 799 |
| 800 |
fclose(fp);
| 801 |
| 802 |
set_minlog();
| 803 |
| 804 |
| 805 |
if (!load_bsdf_rep(fp))
| 806 |
return(1);
| 807 |
fclose(fp);
| 808 |
if (!build_wRBF())
| 809 |
return(1);
| 810 |
| 811 |
put_matBSDF(NULL);
| 812 |
| 813 |
put_source(); /* before hemispheres & labels */
| 814 |
put_hemispheres();
| 815 |
put_scale();
| 816 |
if (inpXML && myBSDF.mgf)
| 817 |
convert_mgf(myBSDF.mgf);
| 818 |
if (!put_BSDFs())
| 819 |
return(1);
| 820 |
cleanup_tmp();
| 821 |
return(0);
| 822 |
