root/Development/ray/src/cv/bsdf2rad.c
Revision: 2.16
Committed: Sun Apr 9 21:39:26 2017 UTC (8 years, 7 months ago) by greg
Changes since 2.15: +773 -139 lines
2 static const char RCSid[] = "$Id: bsdf2rad.c,v 2.15 2016/03/06 01:13:17 schorsch Exp $";
5 * Plot 3-D BSDF output based on scattering interpolant or XML representation
6 */
7
8 #include <stdio.h>
9 #include <string.h>
10 #include <stdlib.h>
11 #include "paths.h"
12 #include "rtmath.h"
13 #include "resolu.h"
14 #include "bsdfrep.h"
15
16 #define NINCIDENT 25 /* number of samples/hemisphere */
17
18 #define GRIDSTEP 2 /* our grid step size */
19 #define SAMPRES (GRIDRES/GRIDSTEP)
20
21 int front_comp = 0; /* front component flags (SDsamp*) */
22 int back_comp = 0; /* back component flags */
23 double overall_min = 1./PI; /* overall minimum BSDF value */
24 double min_log10; /* smallest log10 value for plotting */
25 double overall_max = .0; /* overall maximum BSDF value */
26
27 char ourTempDir[TEMPLEN] = ""; /* our temporary directory */
28
29 const FVECT Xaxis = {1., 0., 0.};
30 const FVECT Yaxis = {0., 1., 0.};
31 const FVECT Zaxis = {0., 0., 1.};
32
33 const char frpref[] = "frefl";
34 const char ftpref[] = "ftrans";
35 const char brpref[] = "brefl";
36 const char btpref[] = "btrans";
37 const char dsuffix[] = ".txt";
38
39 const char sph_mat[] = "BSDFmat";
40 const double sph_rad = 10.;
41 const double sph_xoffset = 15.;
42
43 #define bsdf_rad (sph_rad*.25)
44 #define arrow_rad (bsdf_rad*.015)
45
46 #define FEQ(a,b) ((a)-(b) <= 1e-7 && (b)-(a) <= 1e-7)
47
48 #define set_minlog() (min_log10 = log10(overall_min + 1e-5) - .1)
49
50 char *progname;
51
52 /* Get Fibonacci sphere vector (0 to NINCIDENT-1) */
53 static void
54 get_ivector(FVECT iv, int i)
55 {
56 const double zstep = 1./(2*NINCIDENT-1);
57 const double phistep = PI*(3. - 2.236067978);
58 double r;
59
60 iv[2] = 1. - (i+.5)*zstep;
61 r = sqrt(1. - iv[2]*iv[2]);
62 iv[0] = r * cos((i+1.)*phistep);
63 iv[1] = r * sin((i+1.)*phistep);
64 }
65
66 /* Get temporary file name */
67 static char *
68 tfile_name(const char *prefix, const char *suffix, int i)
69 {
70 static char buf[128];
71
72 if (!ourTempDir[0]) { /* create temporary directory */
73 mktemp(strcpy(ourTempDir,TEMPLATE));
74 if (mkdir(ourTempDir, 0777) < 0) {
75 perror("mkdir");
76 exit(1);
77 }
78 }
79 if (!prefix) prefix = "T";
80 if (!suffix) suffix = "";
81 sprintf(buf, "%s/%s%03d%s", ourTempDir, prefix, i, suffix);
82 return(buf);
83 }
84
85 /* Remove temporary directory & contents */
86 static void
87 cleanup_tmp(void)
88 {
89 char buf[128];
90
91 if (!ourTempDir[0])
92 return;
93 #if defined(_WIN32) || defined(_WIN64)
94 sprintf(buf, "RMDIR %s /S /Q", ourTempDir);
95 #else
96 sprintf(buf, "rm -rf %s", ourTempDir);
97 #endif
98 system(buf);
99 }
100
101 /* Run the specified command, returning 1 if OK */
102 static int
103 run_cmd(const char *cmd)
104 {
105 fflush(stdout);
106 if (system(cmd)) {
107 fprintf(stderr, "%s: error running: %s\n", progname, cmd);
108 return(0);
109 }
110 return(1);
111 }
112
113 /* Plot surface points for the given BSDF incident angle */
114 static int
115 plotBSDF(const char *fname, const FVECT ivec, int dfl, const SDData *sd)
116 {
117 FILE *fp = fopen(fname, "w");
118 int i, j;
119
120 if (fp == NULL) {
121 fprintf(stderr, "%s: cannot open '%s' for writing\n",
122 progname, fname);
123 return(0);
124 }
125 if (ivec[2] > 0) {
126 input_orient = 1;
127 output_orient = dfl&SDsampR ? 1 : -1;
128 } else {
129 input_orient = -1;
130 output_orient = dfl&SDsampR ? -1 : 1;
131 }
132 for (i = SAMPRES; i--; )
133 for (j = 0; j < SAMPRES; j++) {
134 FVECT ovec;
135 SDValue sval;
136 double bsdf;
137 ovec_from_pos(ovec, i*GRIDSTEP, j*GRIDSTEP);
138 if (SDreportError(SDevalBSDF(&sval, ovec,
139 ivec, sd), stderr))
140 return(0);
141 if (sval.cieY > overall_max)
142 overall_max = sval.cieY;
143 bsdf = (sval.cieY < overall_min) ? overall_min : sval.cieY;
144 bsdf = log10(bsdf) - min_log10;
145 fprintf(fp, "%.5f %.5f %.5f\n",
146 ovec[0]*bsdf, ovec[1]*bsdf, ovec[2]*bsdf);
147 }
148 if (fclose(fp) == EOF) {
149 fprintf(stderr, "%s: error writing data to '%s'\n",
150 progname, fname);
151 return(0);
152 }
153 return(1);
154 }
155
156 /* Build BSDF values from loaded XML file */
157 static int
158 build_wBSDF(const SDData *sd)
159 {
160 FVECT ivec;
161 int i;
162
163 if (front_comp & SDsampR)
164 for (i = 0; i < NINCIDENT; i++) {
165 get_ivector(ivec, i);
166 if (!plotBSDF(tfile_name(frpref, dsuffix, i),
167 ivec, SDsampR, sd))
168 return(0);
169 }
170 if (front_comp & SDsampT)
171 for (i = 0; i < NINCIDENT; i++) {
172 get_ivector(ivec, i);
173 if (!plotBSDF(tfile_name(ftpref, dsuffix, i),
174 ivec, SDsampT, sd))
175 return(0);
176 }
177 if (back_comp & SDsampR)
178 for (i = 0; i < NINCIDENT; i++) {
179 get_ivector(ivec, i);
180 ivec[0] = -ivec[0]; ivec[2] = -ivec[2];
181 if (!plotBSDF(tfile_name(brpref, dsuffix, i),
182 ivec, SDsampR, sd))
183 return(0);
184 }
185 if (back_comp & SDsampT)
186 for (i = 0; i < NINCIDENT; i++) {
187 get_ivector(ivec, i);
188 ivec[0] = -ivec[0]; ivec[2] = -ivec[2];
189 if (!plotBSDF(tfile_name(btpref, dsuffix, i),
190 ivec, SDsampT, sd))
191 return(0);
192 }
193 return(1);
194 }
195
196 /* Plot surface points using radial basis function */
197 static int
198 plotRBF(const char *fname, const RBFNODE *rbf)
199 {
200 FILE *fp = fopen(fname, "w");
201 int i, j;
202
203 if (fp == NULL) {
204 fprintf(stderr, "%s: cannot open '%s' for writing\n",
205 progname, fname);
206 return(0);
207 }
208 for (i = SAMPRES; i--; )
209 for (j = 0; j < SAMPRES; j++) {
210 FVECT ovec;
211 double bsdf;
212 ovec_from_pos(ovec, i*GRIDSTEP, j*GRIDSTEP);
213 bsdf = eval_rbfrep(rbf, ovec);
214 if (bsdf > overall_max)
215 overall_max = bsdf;
216 else if (bsdf < overall_min)
217 bsdf = overall_min;
218 bsdf = log10(bsdf) - min_log10;
219 fprintf(fp, "%.5f %.5f %.5f\n",
220 ovec[0]*bsdf, ovec[1]*bsdf, ovec[2]*bsdf);
221 }
222 if (fclose(fp) == EOF) {
223 fprintf(stderr, "%s: error writing data to '%s'\n",
224 progname, fname);
225 return(0);
226 }
227 return(1);
228 }
229
230 /* Build BSDF values from scattering interpolant representation */
231 static int
232 build_wRBF(void)
233 {
234 const char *pref;
235 int i;
236
237 if (input_orient > 0) {
238 if (output_orient > 0)
239 pref = frpref;
240 else
241 pref = ftpref;
242 } else if (output_orient < 0)
243 pref = brpref;
244 else
245 pref = btpref;
246
247 for (i = 0; i < NINCIDENT; i++) {
248 FVECT ivec;
249 RBFNODE *rbf;
250 get_ivector(ivec, i);
251 if (input_orient < 0) {
252 ivec[0] = -ivec[0]; ivec[1] = -ivec[1]; ivec[2] = -ivec[2];
253 }
254 rbf = advect_rbf(ivec, 15000);
255 if (!plotRBF(tfile_name(pref, dsuffix, i), rbf))
256 return(0);
257 if (rbf) free(rbf);
258 }
259 return(1); /* next call frees */
260 }
261
262 /* Put out mirror arrow for the given incident vector */
263 static void
264 put_mirror_arrow(const FVECT ivec, int inc_side)
265 {
266 const double arrow_len = 1.2*bsdf_rad;
267 const double tip_len = 0.2*bsdf_rad;
268 FVECT origin, refl;
269 int i;
270
271 for (i = 3; i--; ) origin[i] = ivec[i]*sph_rad;
272 origin[0] -= inc_side*sph_xoffset;
273
274 refl[0] = 2.*ivec[2]*ivec[0];
275 refl[1] = 2.*ivec[2]*ivec[1];
276 refl[2] = 2.*ivec[2]*ivec[2] - 1.;
277
278 printf("\n# Mirror arrow\n");
279 printf("\narrow_mat cylinder inc_dir\n0\n0\n7");
280 printf("\n\t%f %f %f\n\t%f %f %f\n\t%f\n",
281 origin[0], origin[1], origin[2]+arrow_len,
282 origin[0], origin[1], origin[2],
283 arrow_rad);
284 printf("\narrow_mat cylinder mir_dir\n0\n0\n7");
285 printf("\n\t%f %f %f\n\t%f %f %f\n\t%f\n",
286 origin[0], origin[1], origin[2],
287 origin[0] + arrow_len*refl[0],
288 origin[1] + arrow_len*refl[1],
289 origin[2] + arrow_len*refl[2],
290 arrow_rad);
291 printf("\narrow_mat cone mir_tip\n0\n0\n8");
292 printf("\n\t%f %f %f\n\t%f %f %f\n\t%f 0\n",
293 origin[0] + (arrow_len-.5*tip_len)*refl[0],
294 origin[1] + (arrow_len-.5*tip_len)*refl[1],
295 origin[2] + (arrow_len-.5*tip_len)*refl[2],
296 origin[0] + (arrow_len+.5*tip_len)*refl[0],
297 origin[1] + (arrow_len+.5*tip_len)*refl[1],
298 origin[2] + (arrow_len+.5*tip_len)*refl[2],
299 2.*arrow_rad);
300 }
301
302 /* Put out transmitted direction arrow for the given incident vector */
303 static void
304 put_trans_arrow(const FVECT ivec, int inc_side)
305 {
306 const double arrow_len = 1.2*bsdf_rad;
307 const double tip_len = 0.2*bsdf_rad;
308 FVECT origin;
309 int i;
310
311 for (i = 3; i--; ) origin[i] = ivec[i]*sph_rad;
312 origin[0] -= inc_side*sph_xoffset;
313
314 printf("\n# Transmission arrow\n");
315 printf("\narrow_mat cylinder trans_dir\n0\n0\n7");
316 printf("\n\t%f %f %f\n\t%f %f %f\n\t%f\n",
317 origin[0], origin[1], origin[2],
318 origin[0], origin[1], origin[2]-arrow_len,
319 arrow_rad);
320 printf("\narrow_mat cone trans_tip\n0\n0\n8");
321 printf("\n\t%f %f %f\n\t%f %f %f\n\t%f 0\n",
322 origin[0], origin[1], origin[2]-arrow_len+.5*tip_len,
323 origin[0], origin[1], origin[2]-arrow_len-.5*tip_len,
324 2.*arrow_rad);
325 }
326
327 /* Compute rotation (x,y,z) => (xp,yp,zp) */
328 static int
329 addrot(char *xf, const FVECT xp, const FVECT yp, const FVECT zp)
330 {
331 int n = 0;
332 double theta;
333
334 if (yp[2]*yp[2] + zp[2]*zp[2] < 2.*FTINY*FTINY) {
335 /* Special case for X' along Z-axis */
336 theta = -atan2(yp[0], yp[1]);
337 sprintf(xf, " -ry %f -rz %f",
338 xp[2] < 0.0 ? 90.0 : -90.0,
339 theta*(180./PI));
340 return(4);
341 }
342 theta = atan2(yp[2], zp[2]);
343 if (!FEQ(theta,0.0)) {
344 sprintf(xf, " -rx %f", theta*(180./PI));
345 while (*xf) ++xf;
346 n += 2;
347 }
348 theta = Asin(-xp[2]);
349 if (!FEQ(theta,0.0)) {
350 sprintf(xf, " -ry %f", theta*(180./PI));
351 while (*xf) ++xf;
352 n += 2;
353 }
354 theta = atan2(xp[1], xp[0]);
355 if (!FEQ(theta,0.0)) {
356 sprintf(xf, " -rz %f", theta*(180./PI));
357 /* while (*xf) ++xf; */
358 n += 2;
359 }
360 return(n);
361 }
362
363 /* Put out BSDF surfaces */
364 static int
365 put_BSDFs(void)
366 {
367 const double scalef = bsdf_rad/(log10(overall_max) - min_log10);
368 FVECT ivec;
369 RREAL vMtx[3][3];
370 char *fname;
371 char cmdbuf[256];
372 char xfargs[128];
373 int nxfa;
374 int i;
375
376 printf("\n# Gensurf output corresponding to %d incident directions\n",
377 NINCIDENT);
378
379 printf("\nvoid glow arrow_glow\n0\n0\n4 1 0 1 0\n");
380 printf("\nvoid mixfunc arrow_mat\n4 arrow_glow void .5 .\n0\n0\n");
381
382 if (front_comp & SDsampR)
383 for (i = 0; i < NINCIDENT; i++) {
384 get_ivector(ivec, i);
385 put_mirror_arrow(ivec, 1);
386 sprintf(xfargs, "-s %f -t %f %f %f", bsdf_rad,
387 ivec[0]*sph_rad - sph_xoffset,
388 ivec[1]*sph_rad, ivec[2]*sph_rad);
389 nxfa = 6;
390 printf("\nvoid colorfunc scale_pat\n");
391 printf("%d bsdf_red bsdf_grn bsdf_blu bsdf2rad.cal\n\t%s\n0\n0\n",
392 4+nxfa, xfargs);
393 printf("\nscale_pat glow scale_mat\n0\n0\n4 1 1 1 0\n");
394 SDcompXform(vMtx, ivec, Yaxis);
395 nxfa = addrot(xfargs, vMtx[0], vMtx[1], vMtx[2]);
396 sprintf(xfargs+strlen(xfargs), " -s %f -t %f %f %f",
397 scalef, ivec[0]*sph_rad - sph_xoffset,
398 ivec[1]*sph_rad, ivec[2]*sph_rad);
399 nxfa += 6;
400 fname = tfile_name(frpref, dsuffix, i);
401 sprintf(cmdbuf, "gensurf scale_mat %s%d %s %s %s %d %d | xform -mx -my %s",
402 frpref, i+1, fname, fname, fname, SAMPRES-1, SAMPRES-1,
403 xfargs);
404 if (!run_cmd(cmdbuf))
405 return(0);
406 }
407 if (front_comp & SDsampT)
408 for (i = 0; i < NINCIDENT; i++) {
409 get_ivector(ivec, i);
410 put_trans_arrow(ivec, 1);
411 sprintf(xfargs, "-s %f -t %f %f %f", bsdf_rad,
412 ivec[0]*sph_rad - sph_xoffset,
413 ivec[1]*sph_rad, ivec[2]*sph_rad);
414 nxfa = 6;
415 printf("\nvoid colorfunc scale_pat\n");
416 printf("%d bsdf_red bsdf_grn bsdf_blu bsdf2rad.cal\n\t%s\n0\n0\n",
417 4+nxfa, xfargs);
418 printf("\nscale_pat glow scale_mat\n0\n0\n4 1 1 1 0\n");
419 SDcompXform(vMtx, ivec, Yaxis);
420 nxfa = addrot(xfargs, vMtx[0], vMtx[1], vMtx[2]);
421 sprintf(xfargs+strlen(xfargs), " -s %f -t %f %f %f",
422 scalef, ivec[0]*sph_rad - sph_xoffset,
423 ivec[1]*sph_rad, ivec[2]*sph_rad);
424 nxfa += 6;
425 fname = tfile_name(ftpref, dsuffix, i);
426 sprintf(cmdbuf, "gensurf scale_mat %s%d %s %s %s %d %d | xform -I -mx -my %s",
427 ftpref, i+1, fname, fname, fname, SAMPRES-1, SAMPRES-1,
428 xfargs);
429 if (!run_cmd(cmdbuf))
430 return(0);
431 }
432 if (back_comp & SDsampR)
433 for (i = 0; i < NINCIDENT; i++) {
434 get_ivector(ivec, i);
435 put_mirror_arrow(ivec, -1);
436 fname = tfile_name(brpref, dsuffix, i);
437 sprintf(xfargs, "-s %f -t %f %f %f", bsdf_rad,
438 ivec[0]*sph_rad + sph_xoffset,
439 ivec[1]*sph_rad, ivec[2]*sph_rad);
440 nxfa = 6;
441 printf("\nvoid colorfunc scale_pat\n");
442 printf("%d bsdf_red bsdf_grn bsdf_blu bsdf2rad.cal\n\t%s\n0\n0\n",
443 4+nxfa, xfargs);
444 printf("\nscale_pat glow scale_mat\n0\n0\n4 1 1 1 0\n");
445 SDcompXform(vMtx, ivec, Yaxis);
446 nxfa = addrot(xfargs, vMtx[0], vMtx[1], vMtx[2]);
447 sprintf(xfargs+strlen(xfargs), " -s %f -t %f %f %f",
448 scalef, ivec[0]*sph_rad + sph_xoffset,
449 ivec[1]*sph_rad, ivec[2]*sph_rad);
450 nxfa += 6;
451 fname = tfile_name(brpref, dsuffix, i);
452 sprintf(cmdbuf, "gensurf scale_mat %s%d %s %s %s %d %d | xform -I -ry 180 -mx -my %s",
453 brpref, i+1, fname, fname, fname, SAMPRES-1, SAMPRES-1,
454 xfargs);
455 if (!run_cmd(cmdbuf))
456 return(0);
457 }
458 if (back_comp & SDsampT)
459 for (i = 0; i < NINCIDENT; i++) {
460 get_ivector(ivec, i);
461 put_trans_arrow(ivec, -1);
462 fname = tfile_name(btpref, dsuffix, i);
463 sprintf(xfargs, "-s %f -t %f %f %f", bsdf_rad,
464 ivec[0]*sph_rad + sph_xoffset,
465 ivec[1]*sph_rad, ivec[2]*sph_rad);
466 nxfa = 6;
467 printf("\nvoid colorfunc scale_pat\n");
468 printf("%d bsdf_red bsdf_grn bsdf_blu bsdf2rad.cal\n\t%s\n0\n0\n",
469 4+nxfa, xfargs);
470 printf("\nscale_pat glow scale_mat\n0\n0\n4 1 1 1 0\n");
471 SDcompXform(vMtx, ivec, Yaxis);
472 nxfa = addrot(xfargs, vMtx[0], vMtx[1], vMtx[2]);
473 sprintf(xfargs+strlen(xfargs), " -s %f -t %f %f %f",
474 scalef, ivec[0]*sph_rad + sph_xoffset,
475 ivec[1]*sph_rad, ivec[2]*sph_rad);
476 nxfa += 6;
477 fname = tfile_name(btpref, dsuffix, i);
478 sprintf(cmdbuf, "gensurf scale_mat %s%d %s %s %s %d %d | xform -ry 180 -mx -my %s",
479 btpref, i+1, fname, fname, fname, SAMPRES-1, SAMPRES-1,
480 xfargs);
481 if (!run_cmd(cmdbuf))
482 return(0);
483 }
484 return(1);
485 }
486
487 /* Put our hemisphere material */
488 static void
489 put_matBSDF(const char *XMLfile)
490 {
491 const char *curdir = "./";
492
493 if (!XMLfile) { /* simple material */
494 printf("\n# Simplified material because we have no XML input\n");
495 printf("\nvoid brightfunc latlong\n2 latlong bsdf2rad.cal\n0\n0\n");
496 if ((front_comp|back_comp) & SDsampT)
497 printf("\nlatlong trans %s\n0\n0\n7 .75 .75 .75 0 0 .5 .8\n",
498 sph_mat);
499 else
500 printf("\nlatlong plastic %s\n0\n0\n5 .5 .5 .5 0 0\n",
501 sph_mat);
502 return;
503 }
504 switch (XMLfile[0]) { /* avoid RAYPATH search */
505 case '.':
506 CASEDIRSEP:
507 curdir = "";
508 break;
509 case '\0':
510 fprintf(stderr, "%s: empty file name in put_matBSDF\n", progname);
511 exit(1);
512 break;
513 }
514 printf("\n# Actual BSDF material for rendering the hemispheres\n");
515 printf("\nvoid BSDF BSDFmat\n6 0 \"%s%s\" 0 1 0 .\n0\n0\n",
516 curdir, XMLfile);
517 printf("\nvoid plastic black\n0\n0\n5 0 0 0 0 0\n");
518 printf("\nvoid mixfunc %s\n4 BSDFmat black latlong bsdf2rad.cal\n0\n0\n",
519 sph_mat);
520 }
521
522 /* Put out overhead parallel light source */
523 static void
524 put_source(void)
525 {
526 printf("\n# Overhead parallel light source\n");
527 printf("\nvoid light bright\n0\n0\n3 1000 1000 1000\n");
528 printf("\nbright source light\n0\n0\n4 0 0 1 2\n");
529 printf("\n# Material used for labels\n");
530 printf("\nvoid trans vellum\n0\n0\n7 1 1 1 0 0 .5 0\n");
531 }
532
533 /* Put out hemisphere(s) */
534 static void
535 put_hemispheres(void)
536 {
537 printf("\n# Hemisphere(s) for showing BSDF appearance (if XML file)\n");
538 printf("\nvoid antimatter anti_sph\n2 void %s\n0\n0\n", sph_mat);
539 if (front_comp) {
540 printf("\n%s sphere Front\n0\n0\n4 %f 0 0 %f\n",
541 sph_mat, -sph_xoffset, sph_rad);
542 printf("\n!genbox anti_sph sph_eraser %f %f %f | xform -t %f %f %f\n",
543 2.02*sph_rad, 2.02*sph_rad, 1.02*sph_rad,
544 -1.01*sph_rad - sph_xoffset, -1.01*sph_rad, -1.01*sph_rad);
545 printf("\nvoid brighttext front_text\n3 helvet.fnt . FRONT\n0\n");
546 printf("12\n\t%f %f 0\n\t%f 0 0\n\t0 %f 0\n\t.01 1 -.1\n",
547 -.22*sph_rad - sph_xoffset, -1.2*sph_rad,
548 .35/5.*sph_rad, -1.6*.35/5.*sph_rad);
549 printf("\nfront_text alias front_label_mat vellum\n");
550 printf("\nfront_label_mat polygon front_label\n0\n0\n12");
551 printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
552 -.25*sph_rad - sph_xoffset, -1.1*sph_rad,
553 -.25*sph_rad - sph_xoffset, (-1.2-1.6*.35/5.-.1)*sph_rad,
554 .25*sph_rad - sph_xoffset, (-1.2-1.6*.35/5.-.1)*sph_rad,
555 .25*sph_rad - sph_xoffset, -1.1*sph_rad );
556 }
557 if (back_comp) {
558 printf("\n%s bubble Back\n0\n0\n4 %f 0 0 %f\n",
559 sph_mat, sph_xoffset, sph_rad);
560 printf("\n!genbox anti_sph sph_eraser %f %f %f | xform -t %f %f %f\n",
561 2.02*sph_rad, 2.02*sph_rad, 1.02*sph_rad,
562 -1.01*sph_rad + sph_xoffset, -1.01*sph_rad, -1.01*sph_rad);
563 printf("\nvoid brighttext back_text\n3 helvet.fnt . BACK\n0\n");
564 printf("12\n\t%f %f 0\n\t%f 0 0\n\t0 %f 0\n\t.01 1 -.1\n",
565 -.22*sph_rad + sph_xoffset, -1.2*sph_rad,
566 .35/4.*sph_rad, -1.6*.35/4.*sph_rad);
567 printf("\nback_text alias back_label_mat vellum\n");
568 printf("\nback_label_mat polygon back_label\n0\n0\n12");
569 printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
570 -.25*sph_rad + sph_xoffset, -1.1*sph_rad,
571 -.25*sph_rad + sph_xoffset, (-1.2-1.6*.35/4.-.1)*sph_rad,
572 .25*sph_rad + sph_xoffset, (-1.2-1.6*.35/4.-.1)*sph_rad,
573 .25*sph_rad + sph_xoffset, -1.1*sph_rad );
574 }
575 }
576
577 /* Put out falsecolor scale and name label */
578 static void
579 put_scale(void)
580 {
581 const double max_log10 = log10(overall_max);
582 const double leg_width = 2.*.75*(sph_xoffset - sph_rad);
583 const double leg_height = 2.*sph_rad;
584 const int text_lines = 6;
585 const int text_digits = 7;
586 char fmt[16];
587 int i;
588
589 printf("\n# BSDF legend with falsecolor scale\n");
590 printf("\nvoid colorfunc lscale\n10 sca_red(Py) sca_grn(Py) sca_blu(Py)");
591 printf("\n\tbsdf2rad.cal -s %f -t 0 %f 0\n0\n0\n", leg_height, -.5*leg_height);
592 sprintf(fmt, "%%%dg", text_digits-2);
593 for (i = 0; i < text_lines; i++) {
594 char vbuf[16];
595 sprintf(vbuf, fmt, pow(10., (i+.5)/text_lines*(max_log10-min_log10)+min_log10));
596 printf("\nlscale brighttext lscale\n");
597 printf("3 helvet.fnt . %s\n0\n12\n", vbuf);
598 printf("\t%f %f 0\n", -.45*leg_width, ((i+.9)/text_lines-.5)*leg_height);
599 printf("\t%f 0 0\n", .9*leg_width/strlen(vbuf));
600 printf("\t0 %f 0\n", -.9/text_lines*leg_height);
601 printf("\t.01 1 -.1\n");
602 }
603 printf("\nlscale alias legend_mat vellum\n");
604 printf("\nlegend_mat polygon legend\n0\n0\n12");
605 printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
606 -.5*leg_width, .5*leg_height,
607 -.5*leg_width, -.5*leg_height,
608 .5*leg_width, -.5*leg_height,
609 .5*leg_width, .5*leg_height);
610 printf("\nvoid brighttext BSDFtitle\n3 helvet.fnt . BSDF\n0\n12\n");
611 printf("\t%f %f 0\n", -.25*leg_width, .7*leg_height);
612 printf("\t%f 0 0\n", .4/4.*leg_width);
613 printf("\t0 %f 0\n", -.1*leg_height);
614 printf("\t.01 1 -.1\n");
615 printf("\nBSDFtitle alias title_mat vellum\n");
616 printf("\ntitle_mat polygon title\n0\n0\n12");
617 printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
618 -.3*leg_width, .75*leg_height,
619 -.3*leg_width, .55*leg_height,
620 .3*leg_width, .55*leg_height,
621 .3*leg_width, .75*leg_height);
622 if (!bsdf_name[0])
623 return;
624 printf("\nvoid brighttext BSDFname\n3 helvet.fnt . \"%s\"\n0\n12\n", bsdf_name);
625 printf("\t%f %f 0\n", -.95*leg_width, -.6*leg_height);
626 printf("\t%f 0 0\n", .4/strlen(bsdf_name)*leg_width);
627 printf("\t0 %f 0\n", -.1*leg_height);
628 printf("\t.01 1 -.1\n");
629 printf("\nBSDFname alias name_mat vellum\n");
630 printf("\nname_mat polygon name\n0\n0\n12");
631 printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
632 -leg_width, -.55*leg_height,
633 -leg_width, -.75*leg_height,
634 leg_width, -.75*leg_height,
635 leg_width, -.55*leg_height);
636 }
637
638 /* Convert MGF to Radiance in output */
639 static void
640 convert_mgf(const char *mgfdata)
641 {
642 int len = strlen(mgfdata);
643 char mgfn[128];
644 char radfn[128];
645 char cmdbuf[256];
646 float xmin, xmax, ymin, ymax, zmin, zmax;
647 double max_dim;
648 int fd;
649 FILE *fp;
650
651 if (!len) return;
652 strcpy(mgfn, tfile_name("geom", ".mgf", 0));
653 fd = open(mgfn, O_WRONLY|O_CREAT, 0666);
654 if (fd < 0 || write(fd, mgfdata, len) != len) {
655 fprintf(stderr, "%s: cannot write file '%s'\n",
656 progname, mgfn);
657 return;
658 }
659 close(fd);
660 strcpy(radfn, tfile_name("geom", ".rad", 0));
661 sprintf(cmdbuf, "mgf2rad %s > %s", mgfn, radfn);
662 if (!run_cmd(cmdbuf))
663 return;
664 sprintf(cmdbuf, "getbbox -w -h %s", radfn);
665 if ((fp = popen(cmdbuf, "r")) == NULL ||
666 fscanf(fp, "%f %f %f %f %f %f",
667 &xmin, &xmax, &ymin, &ymax, &zmin, &zmax) != 6
668 || pclose(fp) < 0) {
669 fprintf(stderr, "%s: error reading from command: %s\n",
670 progname, cmdbuf);
671 return;
672 }
673 max_dim = ymax - ymin;
674 if (xmax - xmin > max_dim)
675 max_dim = xmax - xmin;
676 if (front_comp) {
677 printf("\n# BSDF system geometry (front view)\n");
678 sprintf(cmdbuf, "xform -t %f %f %f -s %f -t %f %f 0 %s",
679 -.5*(xmin+xmax), -.5*(ymin+ymax), -zmax,
680 1.5*sph_rad/max_dim,
681 -sph_xoffset, -2.5*sph_rad,
682 radfn);
683 if (!run_cmd(cmdbuf))
684 return;
685 }
686 if (back_comp) {
687 printf("\n# BSDF system geometry (back view)\n");
688 sprintf(cmdbuf, "xform -t %f %f %f -s %f -ry 180 -t %f %f 0 %s",
689 -.5*(xmin+xmax), -.5*(ymin+ymax), -zmin,
690 1.5*sph_rad/max_dim,
691 sph_xoffset, -2.5*sph_rad,
692 radfn);
693 if (!run_cmd(cmdbuf))
694 return;
695 }
696 }
697
698 /* Check RBF input header line & get minimum BSDF value */
699 static int
700 rbf_headline(char *s, void *p)
701 {
702 char fmt[64];
703
704 if (formatval(fmt, s)) {
705 if (strcmp(fmt, BSDFREP_FMT))
706 return(-1);
707 return(0);
708 }
709 if (!strncmp(s, "IO_SIDES=", 9)) {
710 sscanf(s+9, "%d %d", &input_orient, &output_orient);
711 if (input_orient == output_orient) {
712 if (input_orient > 0)
713 front_comp |= SDsampR;
714 else
715 back_comp |= SDsampR;
716 } else if (input_orient > 0)
717 front_comp |= SDsampT;
718 else
719 back_comp |= SDsampT;
720 return(0);
721 }
722 if (!strncmp(s, "BSDFMIN=", 8)) {
723 sscanf(s+8, "%lf", &bsdf_min);
724 if (bsdf_min < overall_min)
725 overall_min = bsdf_min;
726 return(0);
727 }
728 return(0);
729 }
730
731 /* Produce a Radiance model plotting the given BSDF representation */
732 int
733 main(int argc, char *argv[])
734 {
735 int inpXML = -1;
736 SDData myBSDF;
737 int n;
738 /* check arguments */
739 progname = argv[0];
740 if (argc > 1 && (n = strlen(argv[1])-4) > 0) {
741 if (!strcasecmp(argv[1]+n, ".xml"))
742 inpXML = 1;
743 else if (!strcasecmp(argv[1]+n, ".sir"))
744 inpXML = 0;
745 }
746 if (inpXML < 0 || inpXML & (argc > 2)) {
747 fprintf(stderr, "Usage: %s bsdf.xml > output.rad\n", progname);
748 fprintf(stderr, " Or: %s hemi1.sir hemi2.sir .. > output.rad\n", progname);
749 return(1);
750 }
751 fputs("# ", stdout); /* copy our command */
752 printargs(argc, argv, stdout);
753 /* evaluate BSDF */
754 if (inpXML) {
755 SDclearBSDF(&myBSDF, argv[1]);
756 if (SDreportError(SDloadFile(&myBSDF, argv[1]), stderr))
757 return(1);
758 if (myBSDF.rf != NULL) front_comp |= SDsampR;
759 if (myBSDF.tf != NULL) front_comp |= SDsampT;
760 if (myBSDF.rb != NULL) back_comp |= SDsampR;
761 if (myBSDF.tb != NULL) back_comp |= SDsampT;
762 if (!front_comp & !back_comp) {
763 fprintf(stderr, "%s: nothing to plot in '%s'\n",
764 progname, argv[1]);
765 return(1);
766 }
767 if (front_comp & SDsampR && myBSDF.rLambFront.cieY < overall_min*PI)
768 overall_min = myBSDF.rLambFront.cieY/PI;
769 if (back_comp & SDsampR && myBSDF.rLambBack.cieY < overall_min*PI)
770 overall_min = myBSDF.rLambBack.cieY/PI;
771 if ((front_comp|back_comp) & SDsampT &&
772 myBSDF.tLamb.cieY < overall_min*PI)
773 overall_min = myBSDF.tLamb.cieY/PI;
774 set_minlog();
775 if (!build_wBSDF(&myBSDF))
776 return(1);
777 if (myBSDF.matn[0])
778 strcpy(bsdf_name, myBSDF.matn);
779 else
780 strcpy(bsdf_name, myBSDF.name);
781 strcpy(bsdf_manuf, myBSDF.makr);
782 put_matBSDF(argv[1]);
783 } else {
784 FILE *fp;
785 for (n = 1; n < argc; n++) {
786 fp = fopen(argv[n], "rb");
787 if (fp == NULL) {
788 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
789 progname, argv[n]);
790 return(1);
791 }
792 if (getheader(fp, rbf_headline, NULL) < 0) {
793 fprintf(stderr, "%s: bad BSDF interpolant '%s'\n",
794 progname, argv[n]);
795 return(1);
796 }
797 fclose(fp);
798 }
799 set_minlog();
800 for (n = 1; n < argc; n++) {
801 fp = fopen(argv[n], "rb");
802 if (!load_bsdf_rep(fp))
803 return(1);
804 fclose(fp);
805 if (!build_wRBF())
806 return(1);
807 }
808 put_matBSDF(NULL);
809 }
810 put_source(); /* before hemispheres & labels */
811 put_hemispheres();
812 put_scale();
813 if (inpXML && myBSDF.mgf)
814 convert_mgf(myBSDF.mgf);
815 if (!put_BSDFs())
816 return(1);
817 cleanup_tmp();
818 return(0);
819 }
