root/radiance/ray/src/cv/bsdf2rad.c
Revision: 2.35
Committed: Thu Aug 2 18:33:42 2018 UTC (6 years, 11 months ago) by greg
2 static const char RCSid[] = "$Id: bsdf2rad.c,v 2.34 2018/07/20 00:50:40 greg Exp $";
5 * Plot 3-D BSDF output based on scattering interpolant or XML representation
6 */
7
8 #include <stdio.h>
9 #include <string.h>
10 #include <stdlib.h>
11 #include "paths.h"
12 #include "rtmath.h"
13 #include "resolu.h"
14 #include "bsdfrep.h"
15
16 #ifndef NINCIDENT
17 #define NINCIDENT 37 /* number of samples/hemisphere */
18 #endif
19 #ifndef GRIDSTEP
20 #define GRIDSTEP 2 /* our grid step size */
21 #endif
22 #define SAMPRES (GRIDRES/GRIDSTEP)
23
24 int front_comp = 0; /* front component flags (SDsamp*) */
25 int back_comp = 0; /* back component flags */
26 double overall_min = 1./PI; /* overall minimum BSDF value */
27 double min_log10; /* smallest log10 value for plotting */
28 double overall_max = .0; /* overall maximum BSDF value */
29
30 char ourTempDir[TEMPLEN+1] = ""; /* our temporary directory */
31
32 const char frpref[] = "rf";
33 const char ftpref[] = "tf";
34 const char brpref[] = "rb";
35 const char btpref[] = "tb";
36 const char dsuffix[] = ".txt";
37
38 const char sph_fmat[] = "fBSDFmat";
39 const char sph_bmat[] = "bBSDFmat";
40 const double sph_rad = 10.;
41 const double sph_xoffset = 15.;
42
43 #define bsdf_rad (sph_rad*.25)
44 #define arrow_rad (bsdf_rad*.015)
45
46 #define FEQ(a,b) ((a)-(b) <= 1e-7 && (b)-(a) <= 1e-7)
47
48 #define set_minlog() overall_min = (overall_min < 1e-5) ? 1e-5 : overall_min; \
49 min_log10 = log10(overall_min) - .1
50
51 char *progname;
52
53 /* Get Fibonacci sphere vector (0 to NINCIDENT-1) */
54 static RREAL *
55 get_ivector(FVECT iv, int i)
56 {
57 const double phistep = PI*(3. - 2.236067978);
58 double r;
59
60 iv[2] = 1. - (i+.5)*(1./NINCIDENT);
61 r = sqrt(1. - iv[2]*iv[2]);
62 iv[0] = r * cos((i+1.)*phistep);
63 iv[1] = r * sin((i+1.)*phistep);
64
65 return(iv);
66 }
67
68 /* Convert incident vector into sphere position */
69 static RREAL *
70 cvt_sposition(FVECT sp, const FVECT iv, int inc_side)
71 {
72 sp[0] = -iv[0]*sph_rad + inc_side*sph_xoffset;
73 sp[1] = -iv[1]*sph_rad;
74 sp[2] = iv[2]*sph_rad;
75
76 return(sp);
77 }
78
79 /* Get temporary file name */
80 static char *
81 tfile_name(const char *prefix, const char *suffix, int i)
82 {
83 static char buf[256];
84
85 if (!ourTempDir[0]) { /* create temporary directory */
86 mktemp(strcpy(ourTempDir,TEMPLATE));
87 if (mkdir(ourTempDir, 0777) < 0) {
88 perror("mkdir");
89 exit(1);
90 }
91 }
92 if (!prefix) prefix = "T";
93 if (!suffix) suffix = "";
94 sprintf(buf, "%s/%s%03d%s", ourTempDir, prefix, i, suffix);
95 return(buf);
96 }
97
98 /* Remove temporary directory & contents */
99 static void
100 cleanup_tmp(void)
101 {
102 char buf[128];
103
104 if (!ourTempDir[0])
105 return;
106 #if defined(_WIN32) || defined(_WIN64)
107 sprintf(buf, "RMDIR %s /S /Q", ourTempDir);
108 #else
109 sprintf(buf, "rm -rf %s", ourTempDir);
110 #endif
111 system(buf);
112 }
113
114 /* Run the specified command, returning 1 if OK */
115 static int
116 run_cmd(const char *cmd)
117 {
118 fflush(stdout);
119 if (system(cmd)) {
120 fprintf(stderr, "%s: error running: %s\n", progname, cmd);
121 return(0);
122 }
123 return(1);
124 }
125
126 /* Plot surface points for the given BSDF incident angle */
127 static int
128 plotBSDF(const char *fname, const FVECT ivec, int dfl, const SDData *sd)
129 {
130 FILE *fp = fopen(fname, "w");
131 int i, j;
132
133 if (fp == NULL) {
134 fprintf(stderr, "%s: cannot open '%s' for writing\n",
135 progname, fname);
136 return(0);
137 }
138 if (ivec[2] > 0) {
139 input_orient = 1;
140 output_orient = dfl&SDsampR ? 1 : -1;
141 } else {
142 input_orient = -1;
143 output_orient = dfl&SDsampR ? -1 : 1;
144 }
145 for (i = SAMPRES; i--; )
146 for (j = 0; j < SAMPRES; j++) {
147 FVECT ovec;
148 SDValue sval;
149 double bsdf;
150 ovec_from_pos(ovec, i*GRIDSTEP, j*GRIDSTEP);
151 if (SDreportError(SDevalBSDF(&sval, ovec,
152 ivec, sd), stderr))
153 return(0);
154 if (sval.cieY > overall_max)
155 overall_max = sval.cieY;
156 bsdf = (sval.cieY < overall_min) ? overall_min : sval.cieY;
157 bsdf = log10(bsdf) - min_log10;
158 fprintf(fp, "%.5f %.5f %.5f\n",
159 ovec[0]*bsdf, ovec[1]*bsdf, ovec[2]*bsdf);
160 }
161 if (fclose(fp) == EOF) {
162 fprintf(stderr, "%s: error writing data to '%s'\n",
163 progname, fname);
164 return(0);
165 }
166 return(1);
167 }
168
169 /* Build BSDF values from loaded XML file */
170 static int
171 build_wBSDF(const SDData *sd)
172 {
173 FVECT ivec;
174 int i;
175
176 if (front_comp & SDsampR)
177 for (i = 0; i < NINCIDENT; i++) {
178 get_ivector(ivec, i);
179 if (!plotBSDF(tfile_name(frpref, dsuffix, i),
180 ivec, SDsampR, sd))
181 return(0);
182 }
183 if (front_comp & SDsampT)
184 for (i = 0; i < NINCIDENT; i++) {
185 get_ivector(ivec, i);
186 if (!plotBSDF(tfile_name(ftpref, dsuffix, i),
187 ivec, SDsampT, sd))
188 return(0);
189 }
190 if (back_comp & SDsampR)
191 for (i = 0; i < NINCIDENT; i++) {
192 get_ivector(ivec, i);
193 ivec[0] = -ivec[0]; ivec[2] = -ivec[2];
194 if (!plotBSDF(tfile_name(brpref, dsuffix, i),
195 ivec, SDsampR, sd))
196 return(0);
197 }
198 if (back_comp & SDsampT)
199 for (i = 0; i < NINCIDENT; i++) {
200 get_ivector(ivec, i);
201 ivec[0] = -ivec[0]; ivec[2] = -ivec[2];
202 if (!plotBSDF(tfile_name(btpref, dsuffix, i),
203 ivec, SDsampT, sd))
204 return(0);
205 }
206 return(1);
207 }
208
209 /* Plot surface points using radial basis function */
210 static int
211 plotRBF(const char *fname, const RBFNODE *rbf)
212 {
213 FILE *fp = fopen(fname, "w");
214 int i, j;
215
216 if (fp == NULL) {
217 fprintf(stderr, "%s: cannot open '%s' for writing\n",
218 progname, fname);
219 return(0);
220 }
221 for (i = SAMPRES; i--; )
222 for (j = 0; j < SAMPRES; j++) {
223 FVECT ovec;
224 double bsdf;
225 ovec_from_pos(ovec, i*GRIDSTEP, j*GRIDSTEP);
226 bsdf = eval_rbfrep(rbf, ovec);
227 if (bsdf > overall_max)
228 overall_max = bsdf;
229 else if (bsdf < overall_min)
230 bsdf = overall_min;
231 bsdf = log10(bsdf) - min_log10;
232 fprintf(fp, "%.5f %.5f %.5f\n",
233 ovec[0]*bsdf, ovec[1]*bsdf, ovec[2]*bsdf);
234 }
235 if (fclose(fp) == EOF) {
236 fprintf(stderr, "%s: error writing data to '%s'\n",
237 progname, fname);
238 return(0);
239 }
240 return(1);
241 }
242
243 /* Build BSDF values from scattering interpolant representation */
244 static int
245 build_wRBF(void)
246 {
247 const char *pref;
248 int i;
249
250 if (input_orient > 0) {
251 if (output_orient > 0)
252 pref = frpref;
253 else
254 pref = ftpref;
255 } else if (output_orient < 0)
256 pref = brpref;
257 else
258 pref = btpref;
259
260 for (i = 0; i < NINCIDENT; i++) {
261 FVECT ivec;
262 RBFNODE *rbf;
263 get_ivector(ivec, i);
264 if (input_orient < 0) {
265 ivec[0] = -ivec[0]; ivec[2] = -ivec[2];
266 }
267 rbf = advect_rbf(ivec, 15000);
268 if (!plotRBF(tfile_name(pref, dsuffix, i), rbf))
269 return(0);
270 if (rbf) free(rbf);
271 }
272 return(1); /* next call frees */
273 }
274
275 /* Put out mirror arrow for the given incident vector */
276 static void
277 put_mirror_arrow(const FVECT origin, const FVECT nrm)
278 {
279 const double arrow_len = 1.2*bsdf_rad;
280 const double tip_len = 0.2*bsdf_rad;
281 static int cnt = 1;
282 FVECT refl;
283 int i;
284
285 refl[0] = 2.*nrm[2]*nrm[0];
286 refl[1] = 2.*nrm[2]*nrm[1];
287 refl[2] = 2.*nrm[2]*nrm[2] - 1.;
288
289 printf("\n# Mirror arrow #%d\n", cnt);
290 printf("\nshaft_mat cylinder inc_dir%d\n0\n0\n7", cnt);
291 printf("\n\t%f %f %f\n\t%f %f %f\n\t%f\n",
292 origin[0], origin[1], origin[2]+arrow_len,
293 origin[0], origin[1], origin[2],
294 arrow_rad);
295 printf("\nshaft_mat cylinder mir_dir%d\n0\n0\n7", cnt);
296 printf("\n\t%f %f %f\n\t%f %f %f\n\t%f\n",
297 origin[0], origin[1], origin[2],
298 origin[0] + arrow_len*refl[0],
299 origin[1] + arrow_len*refl[1],
300 origin[2] + arrow_len*refl[2],
301 arrow_rad);
302 printf("\ntip_mat cone mir_tip%d\n0\n0\n8", cnt);
303 printf("\n\t%f %f %f\n\t%f %f %f\n\t%f 0\n",
304 origin[0] + (arrow_len-.5*tip_len)*refl[0],
305 origin[1] + (arrow_len-.5*tip_len)*refl[1],
306 origin[2] + (arrow_len-.5*tip_len)*refl[2],
307 origin[0] + (arrow_len+.5*tip_len)*refl[0],
308 origin[1] + (arrow_len+.5*tip_len)*refl[1],
309 origin[2] + (arrow_len+.5*tip_len)*refl[2],
310 2.*arrow_rad);
311 ++cnt;
312 }
313
314 /* Put out transmitted direction arrow for the given incident vector */
315 static void
316 put_trans_arrow(const FVECT origin)
317 {
318 const double arrow_len = 1.2*bsdf_rad;
319 const double tip_len = 0.2*bsdf_rad;
320 static int cnt = 1;
321 int i;
322
323 printf("\n# Transmission arrow #%d\n", cnt);
324 printf("\nshaft_mat cylinder trans_dir%d\n0\n0\n7", cnt);
325 printf("\n\t%f %f %f\n\t%f %f %f\n\t%f\n",
326 origin[0], origin[1], origin[2],
327 origin[0], origin[1], origin[2]-arrow_len,
328 arrow_rad);
329 printf("\ntip_mat cone trans_tip%d\n0\n0\n8", cnt);
330 printf("\n\t%f %f %f\n\t%f %f %f\n\t%f 0\n",
331 origin[0], origin[1], origin[2]-arrow_len+.5*tip_len,
332 origin[0], origin[1], origin[2]-arrow_len-.5*tip_len,
333 2.*arrow_rad);
334 ++cnt;
335 }
336
337 /* Compute rotation (x,y,z) => (xp,yp,zp) */
338 static int
339 addrot(char *xf, const FVECT xp, const FVECT yp, const FVECT zp)
340 {
341 int n = 0;
342 double theta;
343
344 if (yp[2]*yp[2] + zp[2]*zp[2] < 2.*FTINY*FTINY) {
345 /* Special case for X' along Z-axis */
346 theta = -atan2(yp[0], yp[1]);
347 sprintf(xf, " -ry %f -rz %f",
348 xp[2] < 0.0 ? 90.0 : -90.0,
349 theta*(180./PI));
350 return(4);
351 }
352 theta = atan2(yp[2], zp[2]);
353 if (!FEQ(theta,0.0)) {
354 sprintf(xf, " -rx %f", theta*(180./PI));
355 while (*xf) ++xf;
356 n += 2;
357 }
358 theta = Asin(-xp[2]);
359 if (!FEQ(theta,0.0)) {
360 sprintf(xf, " -ry %f", theta*(180./PI));
361 while (*xf) ++xf;
362 n += 2;
363 }
364 theta = atan2(xp[1], xp[0]);
365 if (!FEQ(theta,0.0)) {
366 sprintf(xf, " -rz %f", theta*(180./PI));
367 /* while (*xf) ++xf; */
368 n += 2;
369 }
370 return(n);
371 }
372
373 /* Put out BSDF surfaces */
374 static int
375 put_BSDFs(void)
376 {
377 const double scalef = bsdf_rad/(log10(overall_max) - min_log10);
378 FVECT ivec, sorg, nrm, upv;
379 RREAL vMtx[3][3];
380 char *fname;
381 char cmdbuf[256];
382 char rotargs[64];
383 int nrota;
384 int i;
385
386 printf("\n# Gensurf output corresponding to %d incident directions\n",
387 NINCIDENT);
388
389 printf("\nvoid glow tip_mat\n0\n0\n4 1 0 1 0\n");
390 printf("\nvoid mixfunc shaft_mat\n4 tip_mat void 0.25 .\n0\n0\n");
391
392 for (i = 0; i < NINCIDENT; i++) {
393 get_ivector(ivec, i);
394 nrm[0] = -ivec[0]; nrm[1] = -ivec[1]; nrm[2] = ivec[2];
395 upv[0] = nrm[0]*nrm[1]*(nrm[2] - 1.);
396 upv[1] = nrm[0]*nrm[0] + nrm[1]*nrm[1]*nrm[2];
397 upv[2] = -nrm[1]*(nrm[0]*nrm[0] + nrm[1]*nrm[1]);
398 if (SDcompXform(vMtx, nrm, upv) != SDEnone)
399 continue;
400 nrota = addrot(rotargs, vMtx[0], vMtx[1], vMtx[2]);
401 if (front_comp) {
402 cvt_sposition(sorg, ivec, 1);
403 printf("\nvoid colorfunc scale_pat\n");
404 printf("10 bsdf_red bsdf_grn bsdf_blu bsdf2rad.cal\n");
405 printf("\t-s %f -t %f %f %f\n0\n0\n",
406 bsdf_rad, sorg[0], sorg[1], sorg[2]);
407 printf("\nscale_pat glow scale_mat\n0\n0\n4 1 1 1 0\n");
408 }
409 if (front_comp & SDsampR) {
410 put_mirror_arrow(sorg, nrm);
411 fname = tfile_name(frpref, dsuffix, i);
412 sprintf(cmdbuf,
413 "gensurf scale_mat %s%d %s %s %s %d %d | xform %s -s %f -t %f %f %f",
414 frpref, i, fname, fname, fname, SAMPRES-1, SAMPRES-1,
415 rotargs, scalef, sorg[0], sorg[1], sorg[2]);
416 if (!run_cmd(cmdbuf))
417 return(0);
418 }
419 if (front_comp & SDsampT) {
420 put_trans_arrow(sorg);
421 fname = tfile_name(ftpref, dsuffix, i);
422 sprintf(cmdbuf,
423 "gensurf scale_mat %s%d %s %s %s %d %d | xform -I %s -s %f -t %f %f %f",
424 ftpref, i, fname, fname, fname, SAMPRES-1, SAMPRES-1,
425 rotargs, scalef, sorg[0], sorg[1], sorg[2]);
426 if (!run_cmd(cmdbuf))
427 return(0);
428 }
429 if (back_comp) {
430 cvt_sposition(sorg, ivec, -1);
431 printf("\nvoid colorfunc scale_pat\n");
432 printf("10 bsdf_red bsdf_grn bsdf_blu bsdf2rad.cal\n");
433 printf("\t-s %f -t %f %f %f\n0\n0\n",
434 bsdf_rad, sorg[0], sorg[1], sorg[2]);
435 printf("\nscale_pat glow scale_mat\n0\n0\n4 1 1 1 0\n");
436 }
437 if (back_comp & SDsampR) {
438 put_mirror_arrow(sorg, nrm);
439 fname = tfile_name(brpref, dsuffix, i);
440 sprintf(cmdbuf,
441 "gensurf scale_mat %s%d %s %s %s %d %d | xform -I -ry 180 %s -s %f -t %f %f %f",
442 brpref, i, fname, fname, fname, SAMPRES-1, SAMPRES-1,
443 rotargs, scalef, sorg[0], sorg[1], sorg[2]);
444 if (!run_cmd(cmdbuf))
445 return(0);
446 }
447 if (back_comp & SDsampT) {
448 put_trans_arrow(sorg);
449 fname = tfile_name(btpref, dsuffix, i);
450 sprintf(cmdbuf,
451 "gensurf scale_mat %s%d %s %s %s %d %d | xform -ry 180 %s -s %f -t %f %f %f",
452 btpref, i, fname, fname, fname, SAMPRES-1, SAMPRES-1,
453 rotargs, scalef, sorg[0], sorg[1], sorg[2]);
454 if (!run_cmd(cmdbuf))
455 return(0);
456 }
457 }
458 return(1);
459 }
460
461 /* Put our hemisphere material */
462 static void
463 put_matBSDF(const char *XMLfile)
464 {
465 const char *curdir = "./";
466
467 if (!XMLfile) { /* simple material */
468 printf("\n# Simplified material because we have no XML input\n");
469 printf("\nvoid brightfunc latlong\n2 latlong bsdf2rad.cal\n0\n0\n");
470 if ((front_comp|back_comp) & SDsampT)
471 printf("\nlatlong trans %s\n0\n0\n7 .75 .75 .75 0 .04 .5 .8\n",
472 sph_fmat);
473 else
474 printf("\nlatlong plastic %s\n0\n0\n5 .5 .5 .5 0 0\n",
475 sph_fmat);
476 printf("\ninherit alias %s %s\n", sph_bmat, sph_fmat);
477 return;
478 }
479 switch (XMLfile[0]) { /* avoid RAYPATH search */
480 case '.':
481 case '~':
482 CASEDIRSEP:
483 curdir = "";
484 break;
485 case '\0':
486 fprintf(stderr, "%s: empty file name in put_matBSDF\n", progname);
487 exit(1);
488 break;
489 }
490 printf("\n# Actual BSDF materials for rendering the hemispheres\n");
491 printf("\nvoid BSDF BSDF_f\n6 0 \"%s%s\" upx upy upz bsdf2rad.cal\n0\n0\n",
492 curdir, XMLfile);
493 printf("\nvoid plastic black\n0\n0\n5 0 0 0 0 0\n");
494 printf("\nvoid mixfunc %s\n4 BSDF_f black latlong bsdf2rad.cal\n0\n0\n",
495 sph_fmat);
496 printf("\nvoid BSDF BSDF_b\n8 0 \"%s%s\" upx upy upz bsdf2rad.cal -ry 180\n0\n0\n",
497 curdir, XMLfile);
498 printf("\nvoid mixfunc %s\n4 BSDF_b black latlong bsdf2rad.cal\n0\n0\n",
499 sph_bmat);
500 }
501
502 /* Put out overhead parallel light source */
503 static void
504 put_source(void)
505 {
506 printf("\n# Overhead parallel light source\n");
507 printf("\nvoid light bright\n0\n0\n3 2500 2500 2500\n");
508 printf("\nbright source light\n0\n0\n4 0 0 1 2\n");
509 printf("\n# Material used for labels\n");
510 printf("\nvoid trans vellum\n0\n0\n7 1 1 1 0 0 .5 0\n");
511 }
512
513 /* Put out hemisphere(s) */
514 static void
515 put_hemispheres(void)
516 {
517 const int nsegs = 131;
518
519 printf("\n# Hemisphere(s) for showing BSDF appearance (if XML file)\n");
520 if (front_comp) {
521 printf(
522 "\n!genrev %s Front \"R*sin(A*t)\" \"R*cos(A*t)\" %d -e \"R:%g;A:%f\" -s | xform -t %g 0 0\n",
523 sph_fmat, nsegs, sph_rad, 0.5*PI, sph_xoffset);
524 printf("\nvoid brighttext front_text\n3 helvet.fnt . FRONT\n0\n");
525 printf("12\n\t%f %f 0\n\t%f 0 0\n\t0 %f 0\n\t.01 1 -.1\n",
526 -.22*sph_rad + sph_xoffset, -1.4*sph_rad,
527 .35/5.*sph_rad, -1.6*.35/5.*sph_rad);
528 printf("\nfront_text alias front_label_mat vellum\n");
529 printf("\nfront_label_mat polygon front_label\n0\n0\n12");
530 printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
531 -.25*sph_rad + sph_xoffset, -1.3*sph_rad,
532 -.25*sph_rad + sph_xoffset, (-1.4-1.6*.35/5.-.1)*sph_rad,
533 .25*sph_rad + sph_xoffset, (-1.4-1.6*.35/5.-.1)*sph_rad,
534 .25*sph_rad + sph_xoffset, -1.3*sph_rad );
535 }
536 if (back_comp) {
537 printf(
538 "\n!genrev %s Back \"R*cos(A*t)\" \"R*sin(A*t)\" %d -e \"R:%g;A:%f\" -s | xform -t %g 0 0\n",
539 sph_bmat, nsegs, sph_rad, 0.5*PI, -sph_xoffset);
540 printf("\nvoid brighttext back_text\n3 helvet.fnt . BACK\n0\n");
541 printf("12\n\t%f %f 0\n\t%f 0 0\n\t0 %f 0\n\t.01 1 -.1\n",
542 -.22*sph_rad - sph_xoffset, -1.4*sph_rad,
543 .35/4.*sph_rad, -1.6*.35/4.*sph_rad);
544 printf("\nback_text alias back_label_mat vellum\n");
545 printf("\nback_label_mat polygon back_label\n0\n0\n12");
546 printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
547 -.25*sph_rad - sph_xoffset, -1.3*sph_rad,
548 -.25*sph_rad - sph_xoffset, (-1.4-1.6*.35/4.-.1)*sph_rad,
549 .25*sph_rad - sph_xoffset, (-1.4-1.6*.35/4.-.1)*sph_rad,
550 .25*sph_rad - sph_xoffset, -1.3*sph_rad );
551 }
552 }
553
554 /* Put out falsecolor scale and name label */
555 static void
556 put_scale(void)
557 {
558 const double max_log10 = log10(overall_max);
559 const double leg_width = 2.*.75*(fabs(sph_xoffset) - sph_rad);
560 const double leg_height = 2.*sph_rad;
561 const int text_lines = 6;
562 const int text_digits = 8;
563 char fmt[16];
564 int i;
565
566 printf("\n# BSDF legend with falsecolor scale\n");
567 printf("\nvoid colorfunc lscale\n10 sca_red(Py) sca_grn(Py) sca_blu(Py)");
568 printf("\n\tbsdf2rad.cal -s %f -t 0 %f 0\n0\n0\n", leg_height, -.5*leg_height);
569 sprintf(fmt, "%%.%df", text_digits-3);
570 for (i = 0; i < text_lines; i++) {
571 char vbuf[16];
572 sprintf(vbuf, fmt, pow(10., (i+.5)/text_lines*(max_log10-min_log10)+min_log10));
573 printf("\nlscale brighttext lscale\n");
574 printf("3 helvet.fnt . %s\n0\n12\n", vbuf);
575 printf("\t%f %f 0\n", -.45*leg_width, ((i+.9)/text_lines-.5)*leg_height);
576 printf("\t%f 0 0\n", .8*leg_width/strlen(vbuf));
577 printf("\t0 %f 0\n", -.9/text_lines*leg_height);
578 printf("\t.01 1 -.1\n");
579 }
580 printf("\nlscale alias legend_mat vellum\n");
581 printf("\nlegend_mat polygon legend\n0\n0\n12");
582 printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
583 -.5*leg_width, .5*leg_height,
584 -.5*leg_width, -.5*leg_height,
585 .5*leg_width, -.5*leg_height,
586 .5*leg_width, .5*leg_height);
587 printf("\nvoid brighttext BSDFtitle\n3 helvet.fnt . BSDF\n0\n12\n");
588 printf("\t%f %f 0\n", -.25*leg_width, .7*leg_height);
589 printf("\t%f 0 0\n", .4/4.*leg_width);
590 printf("\t0 %f 0\n", -.1*leg_height);
591 printf("\t.01 1 -.1\n");
592 printf("\nBSDFtitle alias title_mat vellum\n");
593 printf("\ntitle_mat polygon title\n0\n0\n12");
594 printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
595 -.3*leg_width, .75*leg_height,
596 -.3*leg_width, .55*leg_height,
597 .3*leg_width, .55*leg_height,
598 .3*leg_width, .75*leg_height);
599 if (!bsdf_name[0])
600 return;
601 printf("\nvoid brighttext BSDFname\n3 helvet.fnt . \"%s\"\n0\n12\n", bsdf_name);
602 printf("\t%f %f 0\n", -.95*leg_width, -.6*leg_height);
603 printf("\t%f 0 0\n", 1.8/strlen(bsdf_name)*leg_width);
604 printf("\t0 %f 0\n", -.1*leg_height);
605 printf("\t.01 1 -.1\n");
606 printf("\nBSDFname alias name_mat vellum\n");
607 printf("\nname_mat polygon name\n0\n0\n12");
608 printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
609 -leg_width, -.55*leg_height,
610 -leg_width, -.75*leg_height,
611 leg_width, -.75*leg_height,
612 leg_width, -.55*leg_height);
613 }
614
615 /* Convert MGF to Radiance in output */
616 static void
617 convert_mgf(const char *mgfdata)
618 {
619 int len = strlen(mgfdata);
620 char mgfn[128];
621 char radfn[128];
622 char cmdbuf[256];
623 float xmin, xmax, ymin, ymax, zmin, zmax;
624 double max_dim;
625 int fd;
626 FILE *fp;
627
628 if (!len) return;
629 strcpy(mgfn, tfile_name("geom", ".mgf", 0));
630 fd = open(mgfn, O_WRONLY|O_CREAT, 0666);
631 if (fd < 0 || write(fd, mgfdata, len) != len) {
632 fprintf(stderr, "%s: cannot write file '%s'\n",
633 progname, mgfn);
634 return;
635 }
636 close(fd);
637 strcpy(radfn, tfile_name("geom", ".rad", 0));
638 sprintf(cmdbuf, "mgf2rad %s > %s", mgfn, radfn);
639 if (!run_cmd(cmdbuf))
640 return;
641 sprintf(cmdbuf, "getbbox -w -h %s", radfn);
642 if ((fp = popen(cmdbuf, "r")) == NULL ||
643 fscanf(fp, "%f %f %f %f %f %f",
644 &xmin, &xmax, &ymin, &ymax, &zmin, &zmax) != 6
645 || pclose(fp) < 0) {
646 fprintf(stderr, "%s: error reading from command: %s\n",
647 progname, cmdbuf);
648 return;
649 }
650 max_dim = ymax - ymin;
651 if (xmax - xmin > max_dim)
652 max_dim = xmax - xmin;
653 if (front_comp) {
654 printf("\n# BSDF system geometry (front view)\n");
655 sprintf(cmdbuf, "xform -t %f %f %f -s %f -t %f %f 0 %s",
656 -.5*(xmin+xmax), -.5*(ymin+ymax), -zmax,
657 1.5*sph_rad/max_dim,
658 sph_xoffset, -2.5*sph_rad,
659 radfn);
660 if (!run_cmd(cmdbuf))
661 return;
662 }
663 if (back_comp) {
664 printf("\n# BSDF system geometry (back view)\n");
665 sprintf(cmdbuf, "xform -t %f %f %f -s %f -ry 180 -t %f %f 0 %s",
666 -.5*(xmin+xmax), -.5*(ymin+ymax), -zmin,
667 1.5*sph_rad/max_dim,
668 -sph_xoffset, -2.5*sph_rad,
669 radfn);
670 if (!run_cmd(cmdbuf))
671 return;
672 }
673 }
674
675 /* Check RBF input header line & get minimum BSDF value */
676 static int
677 rbf_headline(char *s, void *p)
678 {
679 char fmt[MAXFMTLEN];
680
681 if (formatval(fmt, s)) {
682 if (strcmp(fmt, BSDFREP_FMT))
683 return(-1);
684 return(0);
685 }
686 if (!strncmp(s, "IO_SIDES=", 9)) {
687 sscanf(s+9, "%d %d", &input_orient, &output_orient);
688 if (input_orient == output_orient) {
689 if (input_orient > 0)
690 front_comp |= SDsampR;
691 else
692 back_comp |= SDsampR;
693 } else if (input_orient > 0)
694 front_comp |= SDsampT;
695 else
696 back_comp |= SDsampT;
697 return(0);
698 }
699 if (!strncmp(s, "BSDFMIN=", 8)) {
700 sscanf(s+8, "%lf", &bsdf_min);
701 if (bsdf_min < overall_min)
702 overall_min = bsdf_min;
703 return(0);
704 }
705 return(0);
706 }
707
708 /* Produce a Radiance model plotting the given BSDF representation */
709 int
710 main(int argc, char *argv[])
711 {
712 int inpXML = -1;
713 double myLim[2];
714 SDData myBSDF;
715 int a, n;
716 /* check arguments */
717 progname = argv[0];
718 a = 1;
719 myLim[0] = -1; myLim[1] = -2; /* specified BSDF range? */
720 if (argc > a+3 && argv[a][0] == '-' && argv[a][1] == 'r') {
721 myLim[0] = atof(argv[++a]);
722 myLim[1] = atof(argv[++a]);
723 ++a;
724 }
725 if (argc > a && (n = strlen(argv[a])-4) > 0) {
726 if (!strcasecmp(argv[a]+n, ".xml"))
727 inpXML = 1;
728 else if (!strcasecmp(argv[a]+n, ".sir"))
729 inpXML = 0;
730 }
731 if (inpXML < 0 || inpXML & (argc > a+1)) {
732 fprintf(stderr, "Usage: %s [-r min max] bsdf.xml > output.rad\n", progname);
733 fprintf(stderr, " Or: %s [-r min max] hemi1.sir hemi2.sir .. > output.rad\n", progname);
734 return(1);
735 }
736 fputs("# ", stdout); /* copy our command */
737 printargs(argc, argv, stdout);
738 /* evaluate BSDF */
739 if (inpXML) {
740 SDclearBSDF(&myBSDF, argv[a]);
741 if (SDreportError(SDloadFile(&myBSDF, argv[a]), stderr))
742 return(1);
743 if (myBSDF.rf != NULL) front_comp |= SDsampR;
744 if (myBSDF.tf != NULL) front_comp |= SDsampT;
745 if (myBSDF.rb != NULL) back_comp |= SDsampR;
746 if (myBSDF.tb != NULL) back_comp |= SDsampT;
747 if (!front_comp & !back_comp) {
748 fprintf(stderr, "%s: nothing to plot in '%s'\n",
749 progname, argv[a]);
750 return(1);
751 }
752 if (myLim[0] >= 0)
753 overall_min = myLim[0];
754 else {
755 if (front_comp & SDsampR && myBSDF.rLambFront.cieY < overall_min*PI)
756 overall_min = myBSDF.rLambFront.cieY/PI;
757 if (back_comp & SDsampR && myBSDF.rLambBack.cieY < overall_min*PI)
758 overall_min = myBSDF.rLambBack.cieY/PI;
759 if ((front_comp|back_comp) & SDsampT &&
760 myBSDF.tLamb.cieY < overall_min*PI)
761 overall_min = myBSDF.tLamb.cieY/PI;
762 }
763 set_minlog();
764 if (!build_wBSDF(&myBSDF))
765 return(1);
766 if (myBSDF.matn[0])
767 strcpy(bsdf_name, myBSDF.matn);
768 else
769 strcpy(bsdf_name, myBSDF.name);
770 strcpy(bsdf_manuf, myBSDF.makr);
771 put_matBSDF(argv[a]);
772 } else {
773 FILE *fp[4];
774 if (argc > a+4) {
775 fprintf(stderr, "%s: more than 4 hemispheres!\n", progname);
776 return(1);
777 }
778 for (n = a; n < argc; n++) {
779 fp[n-a] = fopen(argv[n], "rb");
780 if (fp[n-a] == NULL) {
781 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
782 progname, argv[n]);
783 return(1);
784 }
785 if (getheader(fp[n-a], rbf_headline, NULL) < 0) {
786 fprintf(stderr, "%s: bad BSDF interpolant '%s'\n",
787 progname, argv[n]);
788 return(1);
789 }
790 }
791 if (myLim[0] >= 0)
792 overall_min = myLim[0];
793 set_minlog();
794 for (n = a; n < argc; n++) {
795 if (fseek(fp[n-a], 0L, SEEK_SET) < 0) {
796 fprintf(stderr, "%s: cannot seek on '%s'\n",
797 progname, argv[n]);
798 return(1);
799 }
800 if (!load_bsdf_rep(fp[n-a]))
801 return(1);
802 fclose(fp[n-a]);
803 if (!build_wRBF())
804 return(1);
805 }
806 put_matBSDF(NULL);
807 }
808 if (myLim[1] > myLim[0]) /* override maximum BSDF? */
809 overall_max = myLim[1];
810 put_source(); /* before hemispheres & labels */
811 put_hemispheres();
812 put_scale();
813 if (inpXML && myBSDF.mgf)
814 convert_mgf(myBSDF.mgf);
815 if (!put_BSDFs()) /* most of the output happens here */
816 return(1);
817 cleanup_tmp();
818 return(0);
819 }
