root/radiance/ray/src/cv/bsdf2rad.c
Revision: 2.41
Committed: Tue Jun 3 21:31:51 2025 UTC (2 weeks, 6 days ago) by greg
Changes since 2.40: +3 -4 lines
2 static const char RCSid[] = "$Id: bsdf2rad.c,v 2.40 2025/04/22 04:45:25 greg Exp $";
5 * Plot 3-D BSDF output based on scattering interpolant or XML representation
6 */
7
8 #include <stdlib.h>
9 #include "rtio.h"
10 #include "paths.h"
11 #include "rtmath.h"
12 #include "bsdfrep.h"
13
14 #ifndef NINCIDENT
15 #define NINCIDENT 37 /* number of samples/hemisphere */
16 #endif
17 #ifndef GRIDSTEP
18 #define GRIDSTEP 2 /* our grid step size */
19 #endif
20 #define SAMPRES (GRIDRES/GRIDSTEP)
21
22 int front_comp = 0; /* front component flags (SDsamp*) */
23 int back_comp = 0; /* back component flags */
24 double overall_min = 1./PI; /* overall minimum BSDF value */
25 double min_log10; /* smallest log10 value for plotting */
26 double overall_max = .0; /* overall maximum BSDF value */
27
28 char ourTempDir[TEMPLEN+1] = ""; /* our temporary directory */
29
30 const char frpref[] = "rf";
31 const char ftpref[] = "tf";
32 const char brpref[] = "rb";
33 const char btpref[] = "tb";
34 const char dsuffix[] = ".txt";
35
36 const char sph_fmat[] = "fBSDFmat";
37 const char sph_bmat[] = "bBSDFmat";
38 const double sph_rad = 10.;
39 const double sph_xoffset = 15.;
40
41 #define bsdf_rad (sph_rad*.25)
42 #define arrow_rad (bsdf_rad*.015)
43
44 #define set_minlog() overall_min = (overall_min < 1e-5) ? 1e-5 : overall_min; \
45 min_log10 = log10(overall_min) - .1
46
47 /* Get Fibonacci sphere vector (0 to NINCIDENT-1) */
48 static RREAL *
49 get_ivector(FVECT iv, int i)
50 {
51 const double phistep = PI*(3. - 2.236067978);
52 double r;
53
54 iv[2] = 1. - (i+.5)*(1./NINCIDENT);
55 r = sqrt(1. - iv[2]*iv[2]);
56 iv[0] = r * cos((i+1.)*phistep);
57 iv[1] = r * sin((i+1.)*phistep);
58
59 return(iv);
60 }
61
62 /* Convert incident vector into sphere position */
63 static RREAL *
64 cvt_sposition(FVECT sp, const FVECT iv, int inc_side)
65 {
66 sp[0] = -iv[0]*sph_rad + inc_side*sph_xoffset;
67 sp[1] = -iv[1]*sph_rad;
68 sp[2] = iv[2]*sph_rad;
69
70 return(sp);
71 }
72
73 /* Get temporary file name */
74 static char *
75 tfile_name(const char *prefix, const char *suffix, int i)
76 {
77 static char buf[256];
78
79 if (!ourTempDir[0]) { /* create temporary directory */
80 mktemp(strcpy(ourTempDir,TEMPLATE));
81 if (mkdir(ourTempDir, 0777) < 0) {
82 perror("mkdir");
83 exit(1);
84 }
85 }
86 if (!prefix) prefix = "T";
87 if (!suffix) suffix = "";
88 sprintf(buf, "%s/%s%03d%s", ourTempDir, prefix, i, suffix);
89 return(buf);
90 }
91
92 /* Remove temporary directory & contents */
93 static void
94 cleanup_tmp(void)
95 {
96 char buf[128];
97
98 if (!ourTempDir[0])
99 return;
100 #if defined(_WIN32) || defined(_WIN64)
101 sprintf(buf, "RMDIR %s /S /Q", ourTempDir);
102 #else
103 sprintf(buf, "rm -rf %s", ourTempDir);
104 #endif
105 system(buf);
106 }
107
108 /* Run the specified command, returning 1 if OK */
109 static int
110 run_cmd(const char *cmd)
111 {
112 fflush(stdout);
113 if (system(cmd)) {
114 fprintf(stderr, "%s: error running: %s\n", progname, cmd);
115 return(0);
116 }
117 return(1);
118 }
119
120 /* Plot surface points for the given BSDF incident angle */
121 static int
122 plotBSDF(const char *fname, const FVECT ivec, int dfl, const SDData *sd)
123 {
124 FILE *fp = fopen(fname, "w");
125 int i, j;
126
127 if (fp == NULL) {
128 fprintf(stderr, "%s: cannot open '%s' for writing\n",
129 progname, fname);
130 return(0);
131 }
132 if (ivec[2] > 0) {
133 input_orient = 1;
134 output_orient = dfl&SDsampR ? 1 : -1;
135 } else {
136 input_orient = -1;
137 output_orient = dfl&SDsampR ? -1 : 1;
138 }
139 for (i = SAMPRES; i--; )
140 for (j = 0; j < SAMPRES; j++) {
141 FVECT ovec;
142 SDValue sval;
143 double bsdf;
144 ovec_from_pos(ovec, i*GRIDSTEP, j*GRIDSTEP);
145 if (SDreportError(SDevalBSDF(&sval, ivec,
146 ovec, sd), stderr))
147 return(0);
148 if (sval.cieY > overall_max)
149 overall_max = sval.cieY;
150 bsdf = (sval.cieY < overall_min) ? overall_min : sval.cieY;
151 bsdf = log10(bsdf) - min_log10;
152 fprintf(fp, "%.5f %.5f %.5f\n",
153 ovec[0]*bsdf, ovec[1]*bsdf, ovec[2]*bsdf);
154 }
155 if (fclose(fp) == EOF) {
156 fprintf(stderr, "%s: error writing data to '%s'\n",
157 progname, fname);
158 return(0);
159 }
160 return(1);
161 }
162
163 /* Build BSDF values from loaded XML file */
164 static int
165 build_wBSDF(const SDData *sd)
166 {
167 FVECT ivec;
168 int i;
169
170 if (front_comp & SDsampR)
171 for (i = 0; i < NINCIDENT; i++) {
172 get_ivector(ivec, i);
173 if (!plotBSDF(tfile_name(frpref, dsuffix, i),
174 ivec, SDsampR, sd))
175 return(0);
176 }
177 if (front_comp & SDsampT)
178 for (i = 0; i < NINCIDENT; i++) {
179 get_ivector(ivec, i);
180 if (!plotBSDF(tfile_name(ftpref, dsuffix, i),
181 ivec, SDsampT, sd))
182 return(0);
183 }
184 if (back_comp & SDsampR)
185 for (i = 0; i < NINCIDENT; i++) {
186 get_ivector(ivec, i);
187 ivec[0] = -ivec[0]; ivec[2] = -ivec[2];
188 if (!plotBSDF(tfile_name(brpref, dsuffix, i),
189 ivec, SDsampR, sd))
190 return(0);
191 }
192 if (back_comp & SDsampT)
193 for (i = 0; i < NINCIDENT; i++) {
194 get_ivector(ivec, i);
195 ivec[0] = -ivec[0]; ivec[2] = -ivec[2];
196 if (!plotBSDF(tfile_name(btpref, dsuffix, i),
197 ivec, SDsampT, sd))
198 return(0);
199 }
200 return(1);
201 }
202
203 /* Plot surface points using radial basis function */
204 static int
205 plotRBF(const char *fname, const RBFNODE *rbf)
206 {
207 FILE *fp = fopen(fname, "w");
208 int i, j;
209
210 if (fp == NULL) {
211 fprintf(stderr, "%s: cannot open '%s' for writing\n",
212 progname, fname);
213 return(0);
214 }
215 for (i = SAMPRES; i--; )
216 for (j = 0; j < SAMPRES; j++) {
217 FVECT ovec;
218 double bsdf;
219 ovec_from_pos(ovec, i*GRIDSTEP, j*GRIDSTEP);
220 bsdf = eval_rbfrep(rbf, ovec);
221 if (bsdf > overall_max)
222 overall_max = bsdf;
223 else if (bsdf < overall_min)
224 bsdf = overall_min;
225 bsdf = log10(bsdf) - min_log10;
226 fprintf(fp, "%.5f %.5f %.5f\n",
227 ovec[0]*bsdf, ovec[1]*bsdf, ovec[2]*bsdf);
228 }
229 if (fclose(fp) == EOF) {
230 fprintf(stderr, "%s: error writing data to '%s'\n",
231 progname, fname);
232 return(0);
233 }
234 return(1);
235 }
236
237 /* Build BSDF values from scattering interpolant representation */
238 static int
239 build_wRBF(void)
240 {
241 const char *pref;
242 int i;
243
244 if (input_orient > 0) {
245 if (output_orient > 0)
246 pref = frpref;
247 else
248 pref = ftpref;
249 } else if (output_orient < 0)
250 pref = brpref;
251 else
252 pref = btpref;
253
254 for (i = 0; i < NINCIDENT; i++) {
255 FVECT ivec;
256 RBFNODE *rbf;
257 get_ivector(ivec, i);
258 if (input_orient < 0) {
259 ivec[0] = -ivec[0]; ivec[2] = -ivec[2];
260 }
261 rbf = advect_rbf(ivec, 15000);
262 if (!plotRBF(tfile_name(pref, dsuffix, i), rbf))
263 return(0);
264 if (rbf) free(rbf);
265 }
266 return(1); /* next call frees */
267 }
268
269 /* Put out mirror arrow for the given incident vector */
270 static void
271 put_mirror_arrow(const FVECT origin, const FVECT nrm)
272 {
273 const double arrow_len = 1.2*bsdf_rad;
274 const double tip_len = 0.2*bsdf_rad;
275 static int cnt = 1;
276 FVECT refl;
277 int i;
278
279 refl[0] = 2.*nrm[2]*nrm[0];
280 refl[1] = 2.*nrm[2]*nrm[1];
281 refl[2] = 2.*nrm[2]*nrm[2] - 1.;
282
283 printf("\n# Mirror arrow #%d\n", cnt);
284 printf("\nshaft_mat cylinder inc_dir%d\n0\n0\n7", cnt);
285 printf("\n\t%f %f %f\n\t%f %f %f\n\t%f\n",
286 origin[0], origin[1], origin[2]+arrow_len,
287 origin[0], origin[1], origin[2],
288 arrow_rad);
289 printf("\nshaft_mat cylinder mir_dir%d\n0\n0\n7", cnt);
290 printf("\n\t%f %f %f\n\t%f %f %f\n\t%f\n",
291 origin[0], origin[1], origin[2],
292 origin[0] + arrow_len*refl[0],
293 origin[1] + arrow_len*refl[1],
294 origin[2] + arrow_len*refl[2],
295 arrow_rad);
296 printf("\ntip_mat cone mir_tip%d\n0\n0\n8", cnt);
297 printf("\n\t%f %f %f\n\t%f %f %f\n\t%f 0\n",
298 origin[0] + (arrow_len-.5*tip_len)*refl[0],
299 origin[1] + (arrow_len-.5*tip_len)*refl[1],
300 origin[2] + (arrow_len-.5*tip_len)*refl[2],
301 origin[0] + (arrow_len+.5*tip_len)*refl[0],
302 origin[1] + (arrow_len+.5*tip_len)*refl[1],
303 origin[2] + (arrow_len+.5*tip_len)*refl[2],
304 2.*arrow_rad);
305 ++cnt;
306 }
307
308 /* Put out transmitted direction arrow for the given incident vector */
309 static void
310 put_trans_arrow(const FVECT origin)
311 {
312 const double arrow_len = 1.2*bsdf_rad;
313 const double tip_len = 0.2*bsdf_rad;
314 static int cnt = 1;
315 int i;
316
317 printf("\n# Transmission arrow #%d\n", cnt);
318 printf("\nshaft_mat cylinder trans_dir%d\n0\n0\n7", cnt);
319 printf("\n\t%f %f %f\n\t%f %f %f\n\t%f\n",
320 origin[0], origin[1], origin[2],
321 origin[0], origin[1], origin[2]-arrow_len,
322 arrow_rad);
323 printf("\ntip_mat cone trans_tip%d\n0\n0\n8", cnt);
324 printf("\n\t%f %f %f\n\t%f %f %f\n\t%f 0\n",
325 origin[0], origin[1], origin[2]-arrow_len+.5*tip_len,
326 origin[0], origin[1], origin[2]-arrow_len-.5*tip_len,
327 2.*arrow_rad);
328 ++cnt;
329 }
330
331 /* Compute rotation (x,y,z) => (xp,yp,zp) */
332 static int
333 addrot(char *xf, const FVECT xp, const FVECT yp, const FVECT zp)
334 {
335 int n = 0;
336 double theta;
337
338 if (yp[2]*yp[2] + zp[2]*zp[2] < 2.*FTINY*FTINY) {
339 /* Special case for X' along Z-axis */
340 theta = -atan2(yp[0], yp[1]);
341 sprintf(xf, " -ry %f -rz %f",
342 xp[2] < 0.0 ? 90.0 : -90.0,
343 theta*(180./PI));
344 return(4);
345 }
346 theta = atan2(yp[2], zp[2]);
347 if (!FABSEQ(theta,0.0)) {
348 sprintf(xf, " -rx %f", theta*(180./PI));
349 while (*xf) ++xf;
350 n += 2;
351 }
352 theta = Asin(-xp[2]);
353 if (!FABSEQ(theta,0.0)) {
354 sprintf(xf, " -ry %f", theta*(180./PI));
355 while (*xf) ++xf;
356 n += 2;
357 }
358 theta = atan2(xp[1], xp[0]);
359 if (!FABSEQ(theta,0.0)) {
360 sprintf(xf, " -rz %f", theta*(180./PI));
361 /* while (*xf) ++xf; */
362 n += 2;
363 }
364 return(n);
365 }
366
367 /* Put out BSDF surfaces */
368 static int
369 put_BSDFs(void)
370 {
371 const double scalef = bsdf_rad/(log10(overall_max) - min_log10);
372 FVECT ivec, sorg, nrm, upv;
373 RREAL vMtx[3][3];
374 char *fname;
375 char cmdbuf[256];
376 char rotargs[64];
377 int nrota;
378 int i;
379
380 printf("\n# Gensurf output corresponding to %d incident directions\n",
381 NINCIDENT);
382
383 printf("\nvoid glow tip_mat\n0\n0\n4 1 0 1 0\n");
384 printf("\nvoid mixfunc shaft_mat\n4 tip_mat void 0.25 .\n0\n0\n");
385
386 for (i = 0; i < NINCIDENT; i++) {
387 get_ivector(ivec, i);
388 nrm[0] = -ivec[0]; nrm[1] = -ivec[1]; nrm[2] = ivec[2];
389 upv[0] = nrm[0]*nrm[1]*(nrm[2] - 1.);
390 upv[1] = nrm[0]*nrm[0] + nrm[1]*nrm[1]*nrm[2];
391 upv[2] = -nrm[1]*(nrm[0]*nrm[0] + nrm[1]*nrm[1]);
392 if (SDcompXform(vMtx, nrm, upv) != SDEnone)
393 continue;
394 nrota = addrot(rotargs, vMtx[0], vMtx[1], vMtx[2]);
395 if (front_comp) {
396 cvt_sposition(sorg, ivec, 1);
397 printf("\nvoid colorfunc scale_pat\n");
398 printf("10 bsdf_red bsdf_grn bsdf_blu bsdf2rad.cal\n");
399 printf("\t-s %f -t %f %f %f\n0\n0\n",
400 bsdf_rad, sorg[0], sorg[1], sorg[2]);
401 printf("\nscale_pat glow scale_mat\n0\n0\n4 1 1 1 0\n");
402 }
403 if (front_comp & SDsampR) {
404 put_mirror_arrow(sorg, nrm);
405 fname = tfile_name(frpref, dsuffix, i);
406 sprintf(cmdbuf,
407 "gensurf scale_mat %s%d %s %s %s %d %d | xform %s -s %f -t %f %f %f",
408 frpref, i, fname, fname, fname, SAMPRES-1, SAMPRES-1,
409 rotargs, scalef, sorg[0], sorg[1], sorg[2]);
410 if (!run_cmd(cmdbuf))
411 return(0);
412 }
413 if (front_comp & SDsampT) {
414 put_trans_arrow(sorg);
415 fname = tfile_name(ftpref, dsuffix, i);
416 sprintf(cmdbuf,
417 "gensurf scale_mat %s%d %s %s %s %d %d | xform -I %s -s %f -t %f %f %f",
418 ftpref, i, fname, fname, fname, SAMPRES-1, SAMPRES-1,
419 rotargs, scalef, sorg[0], sorg[1], sorg[2]);
420 if (!run_cmd(cmdbuf))
421 return(0);
422 }
423 if (back_comp) {
424 cvt_sposition(sorg, ivec, -1);
425 printf("\nvoid colorfunc scale_pat\n");
426 printf("10 bsdf_red bsdf_grn bsdf_blu bsdf2rad.cal\n");
427 printf("\t-s %f -t %f %f %f\n0\n0\n",
428 bsdf_rad, sorg[0], sorg[1], sorg[2]);
429 printf("\nscale_pat glow scale_mat\n0\n0\n4 1 1 1 0\n");
430 }
431 if (back_comp & SDsampR) {
432 put_mirror_arrow(sorg, nrm);
433 fname = tfile_name(brpref, dsuffix, i);
434 sprintf(cmdbuf,
435 "gensurf scale_mat %s%d %s %s %s %d %d | xform -I -ry 180 %s -s %f -t %f %f %f",
436 brpref, i, fname, fname, fname, SAMPRES-1, SAMPRES-1,
437 rotargs, scalef, sorg[0], sorg[1], sorg[2]);
438 if (!run_cmd(cmdbuf))
439 return(0);
440 }
441 if (back_comp & SDsampT) {
442 put_trans_arrow(sorg);
443 fname = tfile_name(btpref, dsuffix, i);
444 sprintf(cmdbuf,
445 "gensurf scale_mat %s%d %s %s %s %d %d | xform -ry 180 %s -s %f -t %f %f %f",
446 btpref, i, fname, fname, fname, SAMPRES-1, SAMPRES-1,
447 rotargs, scalef, sorg[0], sorg[1], sorg[2]);
448 if (!run_cmd(cmdbuf))
449 return(0);
450 }
451 }
452 return(1);
453 }
454
455 /* Put our hemisphere material */
456 static void
457 put_matBSDF(const char *XMLfile)
458 {
459 const char *curdir = "./";
460
461 if (!XMLfile) { /* simple material */
462 printf("\n# Simplified material because we have no XML input\n");
463 printf("\nvoid brightfunc latlong\n2 latlong bsdf2rad.cal\n0\n0\n");
464 if ((front_comp|back_comp) & SDsampT)
465 printf("\nlatlong trans %s\n0\n0\n7 .75 .75 .75 0 .04 .5 .8\n",
466 sph_fmat);
467 else
468 printf("\nlatlong plastic %s\n0\n0\n5 .5 .5 .5 0 0\n",
469 sph_fmat);
470 printf("\ninherit alias %s %s\n", sph_bmat, sph_fmat);
471 return;
472 }
473 switch (XMLfile[0]) { /* avoid RAYPATH search */
474 case '.':
475 case '~':
476 CASEDIRSEP:
477 curdir = "";
478 break;
479 case '\0':
480 fprintf(stderr, "%s: empty file name in put_matBSDF\n", progname);
481 exit(1);
482 break;
483 }
484 printf("\n# Actual BSDF materials for rendering the hemispheres\n");
485 printf("\nvoid BSDF BSDF_f\n6 0 \"%s%s\" upx upy upz bsdf2rad.cal\n0\n0\n",
486 curdir, XMLfile);
487 printf("\nvoid plastic black\n0\n0\n5 0 0 0 0 0\n");
488 printf("\nvoid mixfunc %s\n4 BSDF_f black latlong bsdf2rad.cal\n0\n0\n",
489 sph_fmat);
490 printf("\nvoid BSDF BSDF_b\n8 0 \"%s%s\" upx upy upz bsdf2rad.cal -ry 180\n0\n0\n",
491 curdir, XMLfile);
492 printf("\nvoid mixfunc %s\n4 BSDF_b black latlong bsdf2rad.cal\n0\n0\n",
493 sph_bmat);
494 }
495
496 /* Put out overhead parallel light source */
497 static void
498 put_source(void)
499 {
500 printf("\n# Overhead parallel light source\n");
501 printf("\nvoid light bright\n0\n0\n3 2500 2500 2500\n");
502 printf("\nbright source light\n0\n0\n4 0 0 1 2\n");
503 printf("\n# Material used for labels\n");
504 printf("\nvoid trans vellum\n0\n0\n7 1 1 1 0 0 .5 0\n");
505 }
506
507 /* Put out hemisphere(s) */
508 static void
509 put_hemispheres(void)
510 {
511 const int nsegs = 131;
512
513 printf("\n# Hemisphere(s) for showing BSDF appearance (if XML file)\n");
514 if (front_comp) {
515 printf(
516 "\n!genrev %s Front \"R*sin(A*t)\" \"R*cos(A*t)\" %d -e \"R:%g;A:%f\" -s | xform -t %g 0 0\n",
517 sph_fmat, nsegs, sph_rad, 0.5*PI, sph_xoffset);
518 printf("\nvoid brighttext front_text\n3 helvet.fnt . FRONT\n0\n");
519 printf("12\n\t%f %f 0\n\t%f 0 0\n\t0 %f 0\n\t.01 1 -.1\n",
520 -.22*sph_rad + sph_xoffset, -1.4*sph_rad,
521 .35/5.*sph_rad, -1.6*.35/5.*sph_rad);
522 printf("\nfront_text alias front_label_mat vellum\n");
523 printf("\nfront_label_mat polygon front_label\n0\n0\n12");
524 printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
525 -.25*sph_rad + sph_xoffset, -1.3*sph_rad,
526 -.25*sph_rad + sph_xoffset, (-1.4-1.6*.35/5.-.1)*sph_rad,
527 .25*sph_rad + sph_xoffset, (-1.4-1.6*.35/5.-.1)*sph_rad,
528 .25*sph_rad + sph_xoffset, -1.3*sph_rad );
529 }
530 if (back_comp) {
531 printf(
532 "\n!genrev %s Back \"R*cos(A*t)\" \"R*sin(A*t)\" %d -e \"R:%g;A:%f\" -s | xform -t %g 0 0\n",
533 sph_bmat, nsegs, sph_rad, 0.5*PI, -sph_xoffset);
534 printf("\nvoid brighttext back_text\n3 helvet.fnt . BACK\n0\n");
535 printf("12\n\t%f %f 0\n\t%f 0 0\n\t0 %f 0\n\t.01 1 -.1\n",
536 -.22*sph_rad - sph_xoffset, -1.4*sph_rad,
537 .35/4.*sph_rad, -1.6*.35/4.*sph_rad);
538 printf("\nback_text alias back_label_mat vellum\n");
539 printf("\nback_label_mat polygon back_label\n0\n0\n12");
540 printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
541 -.25*sph_rad - sph_xoffset, -1.3*sph_rad,
542 -.25*sph_rad - sph_xoffset, (-1.4-1.6*.35/4.-.1)*sph_rad,
543 .25*sph_rad - sph_xoffset, (-1.4-1.6*.35/4.-.1)*sph_rad,
544 .25*sph_rad - sph_xoffset, -1.3*sph_rad );
545 }
546 }
547
548 /* Put out falsecolor scale and name label */
549 static void
550 put_scale(void)
551 {
552 const double max_log10 = log10(overall_max);
553 const double leg_width = 2.*.75*(fabs(sph_xoffset) - sph_rad);
554 const double leg_height = 2.*sph_rad;
555 const int text_lines = 6;
556 const int text_digits = 8;
557 char fmt[16];
558 int i;
559
560 printf("\n# BSDF legend with falsecolor scale\n");
561 printf("\nvoid colorfunc lscale\n10 sca_red(Py) sca_grn(Py) sca_blu(Py)");
562 printf("\n\tbsdf2rad.cal -s %f -t 0 %f 0\n0\n0\n", leg_height, -.5*leg_height);
563 sprintf(fmt, "%%.%df", text_digits-3);
564 for (i = 0; i < text_lines; i++) {
565 char vbuf[16];
566 sprintf(vbuf, fmt, pow(10., (i+.5)/text_lines*(max_log10-min_log10)+min_log10));
567 printf("\nlscale brighttext lscale\n");
568 printf("3 helvet.fnt . %s\n0\n12\n", vbuf);
569 printf("\t%f %f 0\n", -.45*leg_width, ((i+.9)/text_lines-.5)*leg_height);
570 printf("\t%f 0 0\n", .8*leg_width/strlen(vbuf));
571 printf("\t0 %f 0\n", -.9/text_lines*leg_height);
572 printf("\t.01 1 -.1\n");
573 }
574 printf("\nlscale alias legend_mat vellum\n");
575 printf("\nlegend_mat polygon legend\n0\n0\n12");
576 printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
577 -.5*leg_width, .5*leg_height,
578 -.5*leg_width, -.5*leg_height,
579 .5*leg_width, -.5*leg_height,
580 .5*leg_width, .5*leg_height);
581 printf("\nvoid brighttext BSDFtitle\n3 helvet.fnt . BSDF\n0\n12\n");
582 printf("\t%f %f 0\n", -.25*leg_width, .7*leg_height);
583 printf("\t%f 0 0\n", .4/4.*leg_width);
584 printf("\t0 %f 0\n", -.1*leg_height);
585 printf("\t.01 1 -.1\n");
586 printf("\nBSDFtitle alias title_mat vellum\n");
587 printf("\ntitle_mat polygon title\n0\n0\n12");
588 printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
589 -.3*leg_width, .75*leg_height,
590 -.3*leg_width, .55*leg_height,
591 .3*leg_width, .55*leg_height,
592 .3*leg_width, .75*leg_height);
593 if (!bsdf_name[0])
594 return;
595 printf("\nvoid brighttext BSDFname\n3 helvet.fnt . \"%s\"\n0\n12\n", bsdf_name);
596 printf("\t%f %f 0\n", -.95*leg_width, -.6*leg_height);
597 printf("\t%f 0 0\n", 1.8/strlen(bsdf_name)*leg_width);
598 printf("\t0 %f 0\n", -.1*leg_height);
599 printf("\t.01 1 -.1\n");
600 printf("\nBSDFname alias name_mat vellum\n");
601 printf("\nname_mat polygon name\n0\n0\n12");
602 printf("\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n\t%f %f 0\n",
603 -leg_width, -.55*leg_height,
604 -leg_width, -.75*leg_height,
605 leg_width, -.75*leg_height,
606 leg_width, -.55*leg_height);
607 }
608
609 /* Convert MGF to Radiance in output */
610 static void
611 convert_mgf(const char *mgfdata)
612 {
613 int len = strlen(mgfdata);
614 char mgfn[128];
615 char radfn[128];
616 char cmdbuf[256];
617 float xmin, xmax, ymin, ymax, zmin, zmax;
618 double max_dim;
619 int fd;
620 FILE *fp;
621
622 if (!len) return;
623 strcpy(mgfn, tfile_name("geom", ".mgf", 0));
624 fd = open(mgfn, O_WRONLY|O_CREAT, 0666);
625 if (fd < 0 || write(fd, mgfdata, len) != len) {
626 fprintf(stderr, "%s: cannot write file '%s'\n",
627 progname, mgfn);
628 return;
629 }
630 close(fd);
631 strcpy(radfn, tfile_name("geom", ".rad", 0));
632 sprintf(cmdbuf, "mgf2rad %s > %s", mgfn, radfn);
633 if (!run_cmd(cmdbuf))
634 return;
635 sprintf(cmdbuf, "getbbox -w -h %s", radfn);
636 if ((fp = popen(cmdbuf, "r")) == NULL ||
637 fscanf(fp, "%f %f %f %f %f %f",
638 &xmin, &xmax, &ymin, &ymax, &zmin, &zmax) != 6
639 || pclose(fp) != 0) {
640 fprintf(stderr, "%s: error reading from command: %s\n",
641 progname, cmdbuf);
642 return;
643 }
644 max_dim = ymax - ymin;
645 if (xmax - xmin > max_dim)
646 max_dim = xmax - xmin;
647 if (front_comp) {
648 printf("\n# BSDF system geometry (front view)\n");
649 sprintf(cmdbuf, "xform -t %f %f %f -s %f -t %f %f 0 %s",
650 -.5*(xmin+xmax), -.5*(ymin+ymax), -zmax,
651 1.5*sph_rad/max_dim,
652 sph_xoffset, -2.5*sph_rad,
653 radfn);
654 if (!run_cmd(cmdbuf))
655 return;
656 }
657 if (back_comp) {
658 printf("\n# BSDF system geometry (back view)\n");
659 sprintf(cmdbuf, "xform -t %f %f %f -s %f -ry 180 -t %f %f 0 %s",
660 -.5*(xmin+xmax), -.5*(ymin+ymax), -zmin,
661 1.5*sph_rad/max_dim,
662 -sph_xoffset, -2.5*sph_rad,
663 radfn);
664 if (!run_cmd(cmdbuf))
665 return;
666 }
667 }
668
669 /* Check RBF input header line & get minimum BSDF value */
670 static int
671 rbf_headline(char *s, void *p)
672 {
673 char fmt[MAXFMTLEN];
674
675 if (formatval(fmt, s)) {
676 if (strcmp(fmt, BSDFREP_FMT))
677 return(-1);
678 return(0);
679 }
680 if (!strncmp(s, "IO_SIDES=", 9)) {
681 sscanf(s+9, "%d %d", &input_orient, &output_orient);
682 if (input_orient == output_orient) {
683 if (input_orient > 0)
684 front_comp |= SDsampR;
685 else
686 back_comp |= SDsampR;
687 } else if (input_orient > 0)
688 front_comp |= SDsampT;
689 else
690 back_comp |= SDsampT;
691 return(0);
692 }
693 if (!strncmp(s, "BSDFMIN=", 8)) {
694 sscanf(s+8, "%lf", &bsdf_min);
695 if (bsdf_min < overall_min)
696 overall_min = bsdf_min;
697 return(0);
698 }
699 return(0);
700 }
701
702 /* Produce a Radiance model plotting the given BSDF representation */
703 int
704 main(int argc, char *argv[])
705 {
706 int inpXML = -1;
707 double myLim[2];
708 SDData myBSDF;
709 int a, n;
710 /* set global progname */
711 fixargv0(argv[0]);
712 /* check arguments */
713 a = 1;
714 myLim[0] = -1; myLim[1] = -2; /* specified BSDF range? */
715 if (argc > a+3 && argv[a][0] == '-' && argv[a][1] == 'r') {
716 myLim[0] = atof(argv[++a]);
717 myLim[1] = atof(argv[++a]);
718 ++a;
719 }
720 if (argc > a && (n = strlen(argv[a])-4) > 0) {
721 if (!strcasecmp(argv[a]+n, ".xml"))
722 inpXML = 1;
723 else if (!strcasecmp(argv[a]+n, ".sir"))
724 inpXML = 0;
725 }
726 if (inpXML < 0 || inpXML & (argc > a+1)) {
727 fprintf(stderr, "Usage: %s [-r min max] bsdf.xml > output.rad\n", progname);
728 fprintf(stderr, " Or: %s [-r min max] hemi1.sir hemi2.sir .. > output.rad\n", progname);
729 return(1);
730 }
731 fputs("# ", stdout); /* copy our command */
732 printargs(argc, argv, stdout);
733 /* evaluate BSDF */
734 if (inpXML) {
735 SDclearBSDF(&myBSDF, argv[a]);
736 if (SDreportError(SDloadFile(&myBSDF, argv[a]), stderr))
737 return(1);
738 if (myBSDF.rf != NULL) front_comp |= SDsampR;
739 if (myBSDF.tf != NULL) front_comp |= SDsampT;
740 if (myBSDF.rb != NULL) back_comp |= SDsampR;
741 if (myBSDF.tb != NULL) back_comp |= SDsampT;
742 if (!front_comp & !back_comp) {
743 fprintf(stderr, "%s: nothing to plot in '%s'\n",
744 progname, argv[a]);
745 return(1);
746 }
747 if (myLim[0] >= 0)
748 overall_min = myLim[0];
749 else {
750 if (front_comp & SDsampR && myBSDF.rLambFront.cieY < overall_min*PI)
751 overall_min = myBSDF.rLambFront.cieY/PI;
752 if (back_comp & SDsampR && myBSDF.rLambBack.cieY < overall_min*PI)
753 overall_min = myBSDF.rLambBack.cieY/PI;
754 if (front_comp & SDsampT && myBSDF.tLambFront.cieY < overall_min*PI)
755 overall_min = myBSDF.tLambFront.cieY/PI;
756 if (back_comp & SDsampT && myBSDF.tLambBack.cieY < overall_min*PI)
757 overall_min = myBSDF.tLambBack.cieY/PI;
758 }
759 set_minlog();
760 if (!build_wBSDF(&myBSDF))
761 return(1);
762 if (myBSDF.matn[0])
763 strcpy(bsdf_name, myBSDF.matn);
764 else
765 strcpy(bsdf_name, myBSDF.name);
766 strcpy(bsdf_manuf, myBSDF.makr);
767 put_matBSDF(argv[a]);
768 } else {
769 FILE *fp[4];
770 if (argc > a+4) {
771 fprintf(stderr, "%s: more than 4 hemispheres!\n", progname);
772 return(1);
773 }
774 for (n = a; n < argc; n++) {
775 fp[n-a] = fopen(argv[n], "rb");
776 if (fp[n-a] == NULL) {
777 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
778 progname, argv[n]);
779 return(1);
780 }
781 if (getheader(fp[n-a], rbf_headline, NULL) < 0) {
782 fprintf(stderr, "%s: bad BSDF interpolant '%s'\n",
783 progname, argv[n]);
784 return(1);
785 }
786 }
787 if (myLim[0] >= 0)
788 overall_min = myLim[0];
789 set_minlog();
790 for (n = a; n < argc; n++) {
791 if (fseek(fp[n-a], 0L, SEEK_SET) < 0) {
792 fprintf(stderr, "%s: cannot seek on '%s'\n",
793 progname, argv[n]);
794 return(1);
795 }
796 if (!load_bsdf_rep(fp[n-a]))
797 return(1);
798 fclose(fp[n-a]);
799 if (!build_wRBF())
800 return(1);
801 }
802 put_matBSDF(NULL);
803 }
804 if (myLim[1] > myLim[0]) /* override maximum BSDF? */
805 overall_max = myLim[1];
806 put_source(); /* before hemispheres & labels */
807 put_hemispheres();
808 put_scale();
809 if (inpXML && myBSDF.mgf)
810 convert_mgf(myBSDF.mgf);
811 if (!put_BSDFs()) /* most of the output happens here */
812 return(1);
813 cleanup_tmp();
814 return(0);
815 }
