root/radiance/ray/src/cv/bsdf2rad.c
Tue Dec 7 23:55:02 2021 UTC (2 years, 5 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.38: +3 -3 lines
Diff to previous 2.38 , to selected 2.11
Sat Mar 27 17:50:18 2021 UTC (3 years, 1 month ago) by greg
Changes since 2.37: +5 -4 lines
Diff to previous 2.37 , to selected 2.11
Fri Feb 12 00:53:56 2021 UTC (3 years, 3 months ago) by greg
Changes since 2.36: +4 -6 lines
Diff to previous 2.36 , to selected 2.11
refactor: Created comparison macros for RREAL and FVECT types
Fri Jul 19 17:37:56 2019 UTC (4 years, 9 months ago) by greg
Diff to previous 2.35 , to selected 2.11
Thu Aug 2 18:33:42 2018 UTC (5 years, 9 months ago) by greg
Diff to previous 2.34 , to selected 2.11
Fri Jul 20 00:50:40 2018 UTC (5 years, 9 months ago) by greg
Changes since 2.33: +44 -28 lines
Diff to previous 2.33 , to selected 2.11
Added "-r" option to bsdf2rad and bsdfview to fix plotting range
Mon Oct 2 22:11:32 2017 UTC (6 years, 7 months ago) by greg
Changes since 2.32: +7 -4 lines
Diff to previous 2.32 , to selected 2.11
Fixed bug caused by too-short char array
Thu Aug 3 19:50:12 2017 UTC (6 years, 9 months ago) by greg
Changes since 2.31: +13 -9 lines
Diff to previous 2.31 , to selected 2.11
Added numbering to arrows
Wed May 31 02:41:52 2017 UTC (6 years, 11 months ago) by greg
Diff to previous 2.30 , to selected 2.11
Fixed issue with polar region
Mon May 15 19:17:27 2017 UTC (7 years ago) by greg
Changes since 2.29: +3 -2 lines
Diff to previous 2.29 , to selected 2.11
Fixed issue with zero minimum BSDF values
Wed Apr 12 05:01:45 2017 UTC (7 years, 1 month ago) by greg
Changes since 2.28: +8 -8 lines
Diff to previous 2.28 , to selected 2.11
Switched to brighter arrow tips
Wed Apr 12 04:27:04 2017 UTC (7 years, 1 month ago) by greg
Changes since 2.27: +4 -3 lines
Diff to previous 2.27 , to selected 2.11
Added missing case in BSDF file name
Wed Apr 12 04:15:08 2017 UTC (7 years, 1 month ago) by greg
Changes since 2.26: +16 -9 lines
Diff to previous 2.26 , to selected 2.11
Keep file open until done with it
Wed Apr 12 03:35:01 2017 UTC (7 years, 1 month ago) by greg
Diff to previous 2.25 , to selected 2.11
Removed stray line of code
Wed Apr 12 00:31:40 2017 UTC (7 years, 1 month ago) by greg
Changes since 2.24: +50 -104 lines
Diff to previous 2.24 , to selected 2.11
Simplified code a bit
Tue Apr 11 18:26:55 2017 UTC (7 years, 1 month ago) by greg
Changes since 2.23: +16 -10 lines
Diff to previous 2.23 , to selected 2.11
Fixed BSDF material orientation for back side
Tue Apr 11 03:47:23 2017 UTC (7 years, 1 month ago) by greg
Changes since 2.22: +10 -6 lines
Diff to previous 2.22 , to selected 2.11
Made directional arrows more transparent
Tue Apr 11 02:21:37 2017 UTC (7 years, 1 month ago) by greg
Changes since 2.21: +19 -9 lines
Diff to previous 2.21 , to selected 2.11
Fixed issue with up vector that was misorienting 3-D plots
Mon Apr 10 15:44:19 2017 UTC (7 years, 1 month ago) by greg
Changes since 2.20: +9 -12 lines
Diff to previous 2.20 , to selected 2.11
Eliminated use of antimatter in favor of genrev
Mon Apr 10 06:09:14 2017 UTC (7 years, 1 month ago) by greg
Changes since 2.19: +26 -28 lines
Diff to previous 2.19 , to selected 2.11
Swapped Front & Back hemisphere placement and additional tweaks
Mon Apr 10 01:31:37 2017 UTC (7 years, 1 month ago) by greg
Changes since 2.18: +45 -36 lines
Corrected angles (I hope)
Sun Apr 9 22:51:19 2017 UTC (7 years, 1 month ago) by greg
Changes since 2.17: +14 -15 lines
More tweaks and bug fixes
Sun Apr 9 22:06:07 2017 UTC (7 years, 1 month ago) by greg
Changes since 2.16: +5 -5 lines
Made a couple of minor tweaks to improve output
Sun Apr 9 21:39:26 2017 UTC (7 years, 1 month ago) by greg
Changes since 2.15: +773 -139 lines
Sun Mar 6 01:13:17 2016 UTC (8 years, 2 months ago) by schorsch
Thu Nov 20 19:10:48 2014 UTC (9 years, 5 months ago) by greg
Added indication of incident direction in output
Mon Sep 15 00:54:03 2014 UTC (9 years, 8 months ago) by greg
CVS Tags: rad4R2P1, rad4R2P2
Changes since 2.12: +7 -5 lines
Fixed issue with debug reporting of hemispherical reflection/transmission
Thu Aug 21 10:33:48 2014 UTC (9 years, 8 months ago) by greg
Changes since 2.11: +3 -4 lines
Sun Mar 30 17:28:04 2014 UTC (10 years, 1 month ago) by greg
CVS Tags: rad4R2
Changes since 2.10: +5 -1 lines
Fix for Windows and Unix
Sun Mar 30 17:23:28 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.9: +5 -3 lines
Fixed handling of zero BSDF function evaluations
Mon Mar 24 06:07:46 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.8: +12 -6 lines
Minor fixes
Mon Mar 24 05:36:40 2014 UTC (10 years, 1 month ago) by greg
Added numbering to surface name
Thu Feb 20 09:21:32 2014 UTC (10 years, 2 months ago) by greg
Mon Feb 17 21:56:22 2014 UTC (10 years, 3 months ago) by greg
Tue Nov 26 17:33:55 2013 UTC (10 years, 5 months ago) by greg
Thu Nov 21 20:09:26 2013 UTC (10 years, 5 months ago) by greg
Changes since 2.3: +90 -30 lines
Added ability to create models from XML files
Thu Oct 31 18:19:18 2013 UTC (10 years, 6 months ago) by greg
Made debug statements optional
Thu Oct 31 18:03:13 2013 UTC (10 years, 6 months ago) by greg
Changes since 2.1: +30 -13 lines
Added -p option to output peak positions as spheres
Tue Oct 22 04:29:27 2013 UTC (10 years, 6 months ago) by greg
Diff to selected 2.11
