root/radiance/ray/src/cv/bsdf2klems.c
Wed Oct 1 23:32:42 2014 UTC (9 years, 5 months ago) by greg
CVS Tags: rad4R2P2
Changes since 2.15: +1 -2 lines
Diff to previous 2.15
Eliminated unnecessary calculation (remnant from previous change)
Thu Aug 21 10:33:48 2014 UTC (9 years, 7 months ago) by greg
CVS Tags: rad4R2P1
Diff to previous 2.14
Wed Mar 12 22:24:59 2014 UTC (10 years ago) by greg
CVS Tags: rad4R2
Changes since 2.13: +13 -3 lines
Diff to previous 2.13
Changed progress bar to erase itself when done
Wed Mar 12 21:15:31 2014 UTC (10 years ago) by greg
Changes since 2.12: +51 -8 lines
Diff to previous 2.12
Disabled DEBUG statements in BSDF programs and added progress bars
Thu Nov 21 20:09:06 2013 UTC (10 years, 4 months ago) by greg
Changes since 2.11: +4 -3 lines
Changed secant correction to patch centers for better normalization
Sat Nov 9 05:47:49 2013 UTC (10 years, 4 months ago) by greg
Thu Sep 26 17:05:00 2013 UTC (10 years, 6 months ago) by greg
Changes since 2.9: +8 -3 lines
Added -l option to limit maximum number of RBF lobes for interpolation
Sun Aug 11 14:32:34 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.8: +12 -39 lines
Eliminated matrix transpose, which wasn't working anyway
Fri Aug 2 20:56:19 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.7: +11 -1 lines
Added ability to use Dx, Dy and Dz instead of last 3 function parameters
Thu Aug 1 16:10:13 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.6: +39 -12 lines
Added code to emit front/back transmission if missing on XML input
Sat Jun 29 21:03:25 2013 UTC (10 years, 9 months ago) by greg
Thu Apr 25 03:14:52 2013 UTC (10 years, 11 months ago) by greg
Changes since 2.4: +5 -5 lines
Fixed same correlated sampling problem for XML input
Thu Apr 25 03:12:08 2013 UTC (10 years, 11 months ago) by greg
Changes since 2.3: +6 -5 lines
Fixed correlated sampling problem for functional BSDFs
Tue Apr 23 23:19:09 2013 UTC (10 years, 11 months ago) by greg
Changes since 2.2: +45 -22 lines
Tue Apr 23 04:40:23 2013 UTC (10 years, 11 months ago) by greg
Changes since 2.1: +47 -11 lines
Untested implementation of Klems conversion from radial basis function
Sun Apr 21 23:01:14 2013 UTC (10 years, 11 months ago) by greg
