root/radiance/ray/src/cv/bsdf2klems.c
Revision: 2.7
Committed: Thu Aug 1 16:10:13 2013 UTC (11 years, 9 months ago) by greg
Changes since 2.6: +39 -12 lines
Added code to emit front/back transmission if missing on XML input
2 static const char RCSid[] = "$Id: bsdf2klems.c,v 2.6 2013/06/29 21:03:25 greg Exp $";
5 * Load measured BSDF interpolant and write out as XML file with Klems matrix.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdio.h>
12 #include <stdlib.h>
13 #include <string.h>
14 #include <math.h>
15 #include "random.h"
16 #include "platform.h"
17 #include "calcomp.h"
18 #include "bsdfrep.h"
19 #include "bsdf_m.h"
20 /* assumed maximum # Klems patches */
21 #define MAXPATCHES 145
22 /* global argv[0] */
23 char *progname;
24 /* selected basis function name */
25 static const char *kbasis = "LBNL/Klems Full";
26 /* number of BSDF samples per patch */
27 static int npsamps = 256;
28
29 /* Return angle basis corresponding to the given name */
30 ANGLE_BASIS *
31 get_basis(const char *bn)
32 {
33 int n = nabases;
34
35 while (n-- > 0)
36 if (!strcasecmp(bn, abase_list[n].name))
37 return &abase_list[n];
38 return NULL;
39 }
40
41 /* Output XML header to stdout */
42 static void
43 xml_header(int ac, char *av[])
44 {
45 puts("<?xml version=\"1.0\" encoding=\"UTF-8\"?>");
46 puts("<WindowElement xmlns=\"http://windows.lbl.gov\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:schemaLocation=\"http://windows.lbl.gov/BSDF-v1.4.xsd\">");
47 fputs("<!-- File produced by:", stdout);
48 while (ac-- > 0) {
49 fputc(' ', stdout);
50 fputs(*av++, stdout);
51 }
52 puts(" -->");
53 }
54
55 /* Output XML prologue to stdout */
56 static void
57 xml_prologue(const SDData *sd)
58 {
59 const char *matn = (sd && sd->matn[0]) ? sd->matn : "Name";
60 const char *makr = (sd && sd->makr[0]) ? sd->makr : "Manufacturer";
61 ANGLE_BASIS *abp = get_basis(kbasis);
62 int i;
63
64 if (abp == NULL) {
65 fprintf(stderr, "%s: unknown angle basis '%s'\n", progname, kbasis);
66 exit(1);
67 }
68 puts("<WindowElementType>System</WindowElementType>");
69 puts("<FileType>BSDF</FileType>");
70 puts("<Optical>");
71 puts("<Layer>");
72 puts("\t<Material>");
73 printf("\t\t<Name>%s</Name>\n", matn);
74 printf("\t\t<Manufacturer>%s</Manufacturer>\n", makr);
75 if (sd && sd->dim[2] > .001) {
76 printf("\t\t<Thickness unit=\"meter\">%.3f</Thickness>\n", sd->dim[2]);
77 printf("\t\t<Width unit=\"meter\">%.3f</Width>\n", sd->dim[0]);
78 printf("\t\t<Height unit=\"meter\">%.3f</Height>\n", sd->dim[1]);
79 }
80 puts("\t\t<DeviceType>Other</DeviceType>");
81 puts("\t</Material>");
82 if (sd && sd->mgf != NULL) {
83 puts("\t<Geometry format=\"MGF\">");
84 puts("\t\t<MGFblock unit=\"meter\">");
85 fputs(sd->mgf, stdout);
86 puts("</MGFblock>");
87 puts("\t</Geometry>");
88 }
89 puts("\t<DataDefinition>");
90 puts("\t\t<IncidentDataStructure>Columns</IncidentDataStructure>");
91 puts("\t\t<AngleBasis>");
92 printf("\t\t\t<AngleBasisName>%s</AngleBasisName>\n", kbasis);
93 for (i = 0; abp->lat[i].nphis; i++) {
94 puts("\t\t\t<AngleBasisBlock>");
95 printf("\t\t\t<Theta>%g</Theta>\n", i ?
96 .5*(abp->lat[i].tmin + abp->lat[i+1].tmin) :
97 .0 );
98 printf("\t\t\t<nPhis>%d</nPhis>\n", abp->lat[i].nphis);
99 puts("\t\t\t<ThetaBounds>");
100 printf("\t\t\t\t<LowerTheta>%g</LowerTheta>\n", abp->lat[i].tmin);
101 printf("\t\t\t\t<UpperTheta>%g</UpperTheta>\n", abp->lat[i+1].tmin);
102 puts("\t\t\t</ThetaBounds>");
103 puts("\t\t\t</AngleBasisBlock>");
104 }
105 puts("\t\t</AngleBasis>");
106 puts("\t</DataDefinition>");
107 }
108
109 /* Output XML data prologue to stdout */
110 static void
111 data_prologue()
112 {
113 static const char *bsdf_type[4] = {
114 "Reflection Front",
115 "Transmission Front",
116 "Transmission Back",
117 "Reflection Back"
118 };
119
120 puts("\t<WavelengthData>");
121 puts("\t\t<LayerNumber>System</LayerNumber>");
122 puts("\t\t<Wavelength unit=\"Integral\">Visible</Wavelength>");
123 puts("\t\t<SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>");
124 puts("\t\t<DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>");
125 puts("\t\t<WavelengthDataBlock>");
126 printf("\t\t\t<WavelengthDataDirection>%s</WavelengthDataDirection>\n",
127 bsdf_type[(input_orient>0)<<1 | (output_orient>0)]);
128 printf("\t\t\t<ColumnAngleBasis>%s</ColumnAngleBasis>\n", kbasis);
129 printf("\t\t\t<RowAngleBasis>%s</RowAngleBasis>\n", kbasis);
130 puts("\t\t\t<ScatteringDataType>BTDF</ScatteringDataType>");
131 puts("\t\t\t<ScatteringData>");
132 }
133
134 /* Output XML data epilogue to stdout */
135 static void
136 data_epilogue(void)
137 {
138 puts("\t\t\t</ScatteringData>");
139 puts("\t\t</WavelengthDataBlock>");
140 puts("\t</WavelengthData>");
141 }
142
143 /* Output XML epilogue to stdout */
144 static void
145 xml_epilogue(void)
146 {
147 puts("</Layer>");
148 puts("</Optical>");
149 puts("</WindowElement>");
150 }
151
152 /* Load and resample XML BSDF description using Klems basis */
153 static void
154 eval_bsdf(const char *fname)
155 {
156 ANGLE_BASIS *abp = get_basis(kbasis);
157 float *trans_mtx = NULL;
158 SDData bsd;
159 SDError ec;
160 FVECT vin, vout;
161 SDValue sv;
162 double sum;
163 int i, j, n;
164
165 SDclearBSDF(&bsd, fname); /* load BSDF file */
166 if ((ec = SDloadFile(&bsd, fname)) != SDEnone)
167 goto err;
168 xml_prologue(&bsd); /* pass geometry */
169 /* front reflection */
170 if (bsd.rf != NULL || bsd.rLambFront.cieY > .002) {
171 input_orient = 1; output_orient = 1;
172 data_prologue();
173 for (j = 0; j < abp->nangles; j++) {
174 for (i = 0; i < abp->nangles; i++) {
175 sum = 0; /* average over patches */
176 for (n = npsamps; n-- > 0; ) {
177 fo_getvec(vout, j+(n+frandom())/npsamps, abp);
178 fi_getvec(vin, i+urand(n), abp);
179 ec = SDevalBSDF(&sv, vout, vin, &bsd);
180 if (ec != SDEnone)
181 goto err;
182 sum += sv.cieY;
183 }
184 printf("\t%.3e\n", sum/npsamps);
185 }
186 putchar('\n'); /* extra space between rows */
187 }
188 data_epilogue();
189 }
190 /* back reflection */
191 if (bsd.rb != NULL || bsd.rLambBack.cieY > .002) {
192 input_orient = -1; output_orient = -1;
193 data_prologue();
194 for (j = 0; j < abp->nangles; j++) {
195 for (i = 0; i < abp->nangles; i++) {
196 sum = 0; /* average over patches */
197 for (n = npsamps; n-- > 0; ) {
198 bo_getvec(vout, j+(n+frandom())/npsamps, abp);
199 bi_getvec(vin, i+urand(n), abp);
200 ec = SDevalBSDF(&sv, vout, vin, &bsd);
201 if (ec != SDEnone)
202 goto err;
203 sum += sv.cieY;
204 }
205 printf("\t%.3e\n", sum/npsamps);
206 }
207 putchar('\n'); /* extra space between rows */
208 }
209 data_epilogue();
210 }
211 /* front transmission */
212 if (bsd.tf != NULL || bsd.tLamb.cieY > .002) {
213 if (bsd.tb == NULL)
214 trans_mtx = (float *)malloc(sizeof(float) *
215 abp->nangles*abp->nangles);
216 input_orient = 1; output_orient = -1;
217 data_prologue();
218 for (j = 0; j < abp->nangles; j++) {
219 for (i = 0; i < abp->nangles; i++) {
220 sum = 0; /* average over patches */
221 for (n = npsamps; n-- > 0; ) {
222 bo_getvec(vout, j+(n+frandom())/npsamps, abp);
223 fi_getvec(vin, i+urand(n), abp);
224 ec = SDevalBSDF(&sv, vout, vin, &bsd);
225 if (ec != SDEnone)
226 goto err;
227 sum += sv.cieY;
228 }
229 printf("\t%.3e\n", sum/npsamps);
230 if (trans_mtx != NULL)
231 trans_mtx[j*abp->nangles + i] = sum/npsamps;
232 }
233 putchar('\n'); /* extra space between rows */
234 }
235 data_epilogue();
236 }
237 /* back transmission */
238 if (bsd.tb != NULL || trans_mtx != NULL) {
239 if (bsd.tf == NULL)
240 trans_mtx = (float *)malloc(sizeof(float) *
241 abp->nangles*abp->nangles);
242 input_orient = -1; output_orient = 1;
243 data_prologue();
244 for (j = 0; j < abp->nangles; j++) {
245 for (i = 0; i < abp->nangles; i++)
246 if (bsd.tb != NULL) { /* use tb if we have it */
247 sum = 0; /* average over patches */
248 for (n = npsamps; n-- > 0; ) {
249 fo_getvec(vout, j+(n+frandom())/npsamps, abp);
250 bi_getvec(vin, i+urand(n), abp);
251 ec = SDevalBSDF(&sv, vout, vin, &bsd);
252 if (ec != SDEnone)
253 goto err;
254 sum += sv.cieY;
255 }
256 printf("\t%.3e\n", sum/npsamps);
257 if (trans_mtx != NULL)
258 trans_mtx[i*abp->nangles + j] = sum/npsamps;
259 } else { /* else transpose tf */
260 printf("\t%.3e\n", trans_mtx[i*abp->nangles + j]);
261 }
262 putchar('\n'); /* extra space between rows */
263 }
264 data_epilogue();
265 }
266 /* derived front transmission */
267 if (bsd.tf == NULL && trans_mtx != NULL) {
268 input_orient = 1; output_orient = -1;
269 data_prologue();
270 for (j = 0; j < abp->nangles; j++) {
271 for (i = 0; i < abp->nangles; i++)
272 printf("\t%.3e\n", trans_mtx[j*abp->nangles + i]);
273 putchar('\n'); /* extra space between rows */
274 }
275 data_epilogue();
276 }
277 SDfreeBSDF(&bsd); /* all done */
278 if (trans_mtx != NULL)
279 free(trans_mtx);
280 return;
281 err:
282 SDreportError(ec, stderr);
283 exit(1);
284 }
285
286 /* Interpolate and output a BSDF function using Klems basis */
287 static void
288 eval_function(char *funame)
289 {
290 ANGLE_BASIS *abp = get_basis(kbasis);
291 double iovec[6];
292 double sum;
293 int i, j, n;
294
295 initurand(npsamps);
296 data_prologue(); /* begin output */
297 for (j = 0; j < abp->nangles; j++) { /* run through directions */
298 for (i = 0; i < abp->nangles; i++) {
299 sum = 0;
300 for (n = npsamps; n--; ) { /* average over patches */
301 if (output_orient > 0)
302 fo_getvec(iovec+3, j+(n+frandom())/npsamps, abp);
303 else
304 bo_getvec(iovec+3, j+(n+frandom())/npsamps, abp);
305
306 if (input_orient > 0)
307 fi_getvec(iovec, i+urand(n), abp);
308 else
309 bi_getvec(iovec, i+urand(n), abp);
310
311 sum += funvalue(funame, 6, iovec);
312 }
313 printf("\t%.3e\n", sum/npsamps);
314 }
315 putchar('\n');
316 }
317 data_epilogue(); /* finish output */
318 }
319
320 /* Interpolate and output a radial basis function BSDF representation */
321 static void
322 eval_rbf(void)
323 {
324 ANGLE_BASIS *abp = get_basis(kbasis);
325 float bsdfarr[MAXPATCHES*MAXPATCHES];
326 FVECT vin, vout;
327 RBFNODE *rbf;
328 double sum;
329 int i, j, n;
330 /* sanity check */
331 if (abp->nangles > MAXPATCHES) {
332 fprintf(stderr, "%s: too many patches!\n", progname);
333 exit(1);
334 }
335 data_prologue(); /* begin output */
336 for (i = 0; i < abp->nangles; i++) {
337 if (input_orient > 0) /* use incident patch center */
338 fi_getvec(vin, i+.5*(i>0), abp);
339 else
340 bi_getvec(vin, i+.5*(i>0), abp);
341
342 rbf = advect_rbf(vin); /* compute radial basis func */
343
344 for (j = 0; j < abp->nangles; j++) {
345 sum = 0; /* sample over exiting patch */
346 for (n = npsamps; n--; ) {
347 if (output_orient > 0)
348 fo_getvec(vout, j+(n+frandom())/npsamps, abp);
349 else
350 bo_getvec(vout, j+(n+frandom())/npsamps, abp);
351
352 sum += eval_rbfrep(rbf, vout) / vout[2];
353 }
354 bsdfarr[j*abp->nangles + i] = sum*output_orient/npsamps;
355 }
356 if (rbf != NULL)
357 free(rbf);
358 }
359 n = 0; /* write out our matrix */
360 for (j = 0; j < abp->nangles; j++) {
361 for (i = 0; i < abp->nangles; i++)
362 printf("\t%.3e\n", bsdfarr[n++]);
363 putchar('\n');
364 }
365 data_epilogue(); /* finish output */
366 }
367
368 /* Read in BSDF and interpolate as Klems matrix representation */
369 int
370 main(int argc, char *argv[])
371 {
372 int dofwd = 0, dobwd = 1;
373 char *cp;
374 int i, na;
375
376 progname = argv[0];
377 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
378 esupport &= ~(E_INCHAN|E_OUTCHAN);
379 scompile("PI:3.14159265358979323846", NULL, 0);
380 biggerlib();
381 for (i = 1; i < argc && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
382 switch (argv[i][1]) { /* get options */
383 case 'n':
384 npsamps = atoi(argv[++i]);
385 if (npsamps <= 0)
386 goto userr;
387 break;
388 case 'e':
389 scompile(argv[++i], NULL, 0);
390 single_plane_incident = 0;
391 break;
392 case 'f':
393 if (!argv[i][2]) {
394 fcompile(argv[++i]);
395 single_plane_incident = 0;
396 } else
397 dofwd = (argv[i][0] == '+');
398 break;
399 case 'b':
400 dobwd = (argv[i][0] == '+');
401 break;
402 case 'h':
403 kbasis = "LBNL/Klems Half";
404 break;
405 case 'q':
406 kbasis = "LBNL/Klems Quarter";
407 break;
408 default:
409 goto userr;
410 }
411 if (single_plane_incident >= 0) { /* function-based BSDF? */
412 if (i != argc-1 || fundefined(argv[i]) != 6) {
413 fprintf(stderr,
414 "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
415 progname);
416 goto userr;
417 }
418 xml_header(argc, argv); /* start XML output */
419 xml_prologue(NULL);
420 if (dofwd) {
421 input_orient = -1;
422 output_orient = -1;
423 eval_function(argv[i]); /* outside reflectance */
424 output_orient = 1;
425 eval_function(argv[i]); /* outside -> inside */
426 }
427 if (dobwd) {
428 input_orient = 1;
429 output_orient = 1;
430 eval_function(argv[i]); /* inside reflectance */
431 output_orient = -1;
432 eval_function(argv[i]); /* inside -> outside */
433 }
434 xml_epilogue(); /* finish XML output & exit */
435 return(0);
436 }
437 /* XML input? */
438 if (i == argc-1 && (cp = argv[i]+strlen(argv[i])-4) > argv[i] &&
439 !strcasecmp(cp, ".xml")) {
440 xml_header(argc, argv); /* start XML output */
441 eval_bsdf(argv[i]); /* load & resample BSDF */
442 xml_epilogue(); /* finish XML output & exit */
443 return(0);
444 }
445 if (i < argc) { /* open input files if given */
446 int nbsdf = 0;
447 for ( ; i < argc; i++) { /* interpolate each component */
448 FILE *fpin = fopen(argv[i], "rb");
449 if (fpin == NULL) {
450 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
451 progname, argv[i]);
452 return(1);
453 }
454 if (!load_bsdf_rep(fpin))
455 return(1);
456 fclose(fpin);
457 if (!nbsdf++) { /* start XML on first dist. */
458 xml_header(argc, argv);
459 xml_prologue(NULL);
460 }
461 eval_rbf();
462 }
463 xml_epilogue(); /* finish XML output & exit */
464 return(0);
465 }
466 SET_FILE_BINARY(stdin); /* load from stdin */
467 if (!load_bsdf_rep(stdin))
468 return(1);
469 xml_header(argc, argv); /* start XML output */
470 xml_prologue(NULL);
471 eval_rbf(); /* resample dist. */
472 xml_epilogue(); /* finish XML output & exit */
473 return(0);
474 userr:
475 fprintf(stderr,
476 "Usage: %s [-n spp][-h|-q][bsdf.sir ..] > bsdf.xml\n", progname);
477 fprintf(stderr,
478 " or: %s [-n spp][-h|-q] bsdf_in.xml > bsdf_out.xml\n", progname);
479 fprintf(stderr,
480 " or: %s [-n spp][-h|-q][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
481 progname);
482 return(1);
483 }
