| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: bsdf2klems.c,v 2.35 2023/07/26 15:50:03 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Load measured BSDF interpolant and write out as XML file with Klems matrix.
| 6 |
| 7 |
* G. Ward
| 8 |
| 9 |
| 10 |
#define _USE_MATH_DEFINES
| 11 |
#include <stdlib.h>
| 12 |
#include <math.h>
| 13 |
#include <ctype.h>
| 14 |
#include "random.h"
| 15 |
#include "platform.h"
| 16 |
#include "paths.h"
| 17 |
#include "rtio.h"
| 18 |
#include "calcomp.h"
| 19 |
#include "bsdfrep.h"
| 20 |
#include "bsdf_m.h"
| 21 |
/* tristimulus components */
| 22 |
enum {CIE_X, CIE_Y, CIE_Z};
| 23 |
/* assumed maximum # Klems patches */
| 24 |
#define MAXPATCHES 145
| 25 |
/* global argv[0] */
| 26 |
char *progname;
| 27 |
/* selected basis function name */
| 28 |
static const char klems_full[] = "LBNL/Klems Full";
| 29 |
static const char klems_half[] = "LBNL/Klems Half";
| 30 |
static const char klems_quarter[] = "LBNL/Klems Quarter";
| 31 |
static const char *kbasis = klems_full;
| 32 |
/* number of BSDF samples per patch */
| 33 |
static int npsamps = 1024;
| 34 |
/* limit on number of RBF lobes */
| 35 |
static int lobe_lim = 15000;
| 36 |
/* progress bar length */
| 37 |
static int do_prog = 79;
| 38 |
| 39 |
#define MAXCARG 512 /* wrapBSDF command */
| 40 |
static char *wrapBSDF[MAXCARG] = {"wrapBSDF", "-W", "-UU"};
| 41 |
static int wbsdfac = 3;
| 42 |
| 43 |
/* Add argument to wrapBSDF, allocating space if !isstatic */
| 44 |
static void
| 45 |
add_wbsdf(const char *arg, int isstatic)
| 46 |
| 47 |
if (arg == NULL)
| 48 |
return;
| 49 |
if (wbsdfac >= MAXCARG-1) {
| 50 |
fputs(progname, stderr);
| 51 |
fputs(": too many command arguments to wrapBSDF\n", stderr);
| 52 |
exit(1);
| 53 |
| 54 |
if (!*arg)
| 55 |
arg = "";
| 56 |
else if (!isstatic)
| 57 |
arg = savqstr((char *)arg);
| 58 |
| 59 |
wrapBSDF[wbsdfac++] = (char *)arg;
| 60 |
| 61 |
| 62 |
/* Start new progress bar */
| 63 |
#define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else
| 64 |
| 65 |
/* Draw progress bar of the appropriate length */
| 66 |
static void
| 67 |
prog_show(double frac)
| 68 |
| 69 |
static unsigned call_cnt = 0;
| 70 |
static char lastc[] = "-\\|/";
| 71 |
char pbar[256];
| 72 |
int nchars;
| 73 |
| 74 |
if (do_prog <= 1) return;
| 75 |
if (do_prog > sizeof(pbar)-2)
| 76 |
do_prog = sizeof(pbar)-2;
| 77 |
if (frac < 0) frac = 0;
| 78 |
else if (frac >= 1) frac = .9999;
| 79 |
nchars = do_prog*frac;
| 80 |
pbar[0] = '\r';
| 81 |
memset(pbar+1, '*', nchars);
| 82 |
pbar[nchars+1] = lastc[call_cnt++ & 3];
| 83 |
memset(pbar+2+nchars, '-', do_prog-nchars-1);
| 84 |
pbar[do_prog+1] = '\0';
| 85 |
fputs(pbar, stderr);
| 86 |
| 87 |
| 88 |
/* Finish progress bar */
| 89 |
static void
| 90 |
prog_done(void)
| 91 |
| 92 |
int n = do_prog;
| 93 |
| 94 |
if (n <= 1) return;
| 95 |
fputc('\r', stderr);
| 96 |
while (n--)
| 97 |
fputc(' ', stderr);
| 98 |
| 99 |
| 100 |
| 101 |
/* Return angle basis corresponding to the given name */
| 102 |
static ANGLE_BASIS *
| 103 |
get_basis(const char *bn)
| 104 |
| 105 |
int n = nabases;
| 106 |
| 107 |
while (n-- > 0)
| 108 |
if (!strcasecmp(bn, abase_list[n].name))
| 109 |
return &abase_list[n];
| 110 |
return NULL;
| 111 |
| 112 |
| 113 |
/* Copy geometry string to file for wrapBSDF */
| 114 |
static char *
| 115 |
save_geom(const char *mgf)
| 116 |
| 117 |
char *tfname = mktemp(savqstr(TEMPLATE));
| 118 |
int fd = open(tfname, O_CREAT|O_WRONLY, 0600);
| 119 |
| 120 |
if (fd < 0)
| 121 |
return(NULL);
| 122 |
write(fd, mgf, strlen(mgf));
| 123 |
close(fd);
| 124 |
add_wbsdf("-g", 1);
| 125 |
add_wbsdf(tfname, 1);
| 126 |
return(tfname);
| 127 |
| 128 |
| 129 |
/* Open XYZ component file for output and add appropriate arguments */
| 130 |
static FILE *
| 131 |
open_component_file(int c)
| 132 |
| 133 |
static const char sname[3][6] = {"CIE-X", "CIE-Y", "CIE-Z"};
| 134 |
static const char cname[4][4] = {"-rf", "-tf", "-tb", "-rb"};
| 135 |
| 136 |
FILE *fp = fopen(tfname, "w");
| 137 |
| 138 |
if (fp == NULL) {
| 139 |
fprintf(stderr, "%s: cannot open '%s' for writing\n",
| 140 |
progname, tfname);
| 141 |
exit(1);
| 142 |
| 143 |
add_wbsdf("-s", 1); add_wbsdf(sname[c], 1);
| 144 |
add_wbsdf(cname[(input_orient>0)<<1 | (output_orient>0)], 1);
| 145 |
| 146 |
return(fp);
| 147 |
| 148 |
| 149 |
/* Load and resample XML BSDF description using Klems basis */
| 150 |
static void
| 151 |
eval_bsdf(const char *fname)
| 152 |
| 153 |
ANGLE_BASIS *abp = get_basis(kbasis);
| 154 |
FILE *cfp[3];
| 155 |
SDData bsd;
| 156 |
SDError ec;
| 157 |
FVECT vin, vout;
| 158 |
SDValue sdv;
| 159 |
double sum, xsum, ysum;
| 160 |
int i, j, n;
| 161 |
| 162 |
initurand(npsamps);
| 163 |
SDclearBSDF(&bsd, fname); /* load BSDF file */
| 164 |
if ((ec = SDloadFile(&bsd, fname)) != SDEnone)
| 165 |
goto err;
| 166 |
if (bsd.mgf != NULL) /* save geometry */
| 167 |
save_geom(bsd.mgf);
| 168 |
if (bsd.matn[0]) /* save identifier(s) */
| 169 |
strcpy(bsdf_name, bsd.matn);
| 170 |
if (bsd.makr[0])
| 171 |
strcpy(bsdf_manuf, bsd.makr);
| 172 |
if (bsd.dim[2] > 0) { /* save dimension(s) */
| 173 |
char buf[64];
| 174 |
if ((bsd.dim[0] > 0) & (bsd.dim[1] > 0))
| 175 |
sprintf(buf, "w=%g;h=%g;t=%g",
| 176 |
bsd.dim[0], bsd.dim[1], bsd.dim[2]);
| 177 |
else
| 178 |
sprintf(buf, "t=%g", bsd.dim[2]);
| 179 |
add_wbsdf("-f", 1);
| 180 |
add_wbsdf(buf, 0);
| 181 |
| 182 |
/* front reflection */
| 183 |
if (bsd.rf != NULL || bsd.rLambFront.cieY > .002) {
| 184 |
input_orient = 1; output_orient = 1;
| 185 |
cfp[CIE_Y] = open_component_file(CIE_Y);
| 186 |
if (bsd.rf != NULL && bsd.rf->comp[0].cspec[2].flags) {
| 187 |
rbf_colorimetry = RBCtristimulus;
| 188 |
cfp[CIE_X] = open_component_file(CIE_X);
| 189 |
cfp[CIE_Z] = open_component_file(CIE_Z);
| 190 |
} else
| 191 |
rbf_colorimetry = RBCphotopic;
| 192 |
for (j = 0; j < abp->nangles; j++) {
| 193 |
for (i = 0; i < abp->nangles; i++) {
| 194 |
sum = 0; /* average over patches */
| 195 |
xsum = ysum = 0;
| 196 |
for (n = npsamps; n-- > 0; ) {
| 197 |
fo_getvec(vout, j+(n+frandom())/npsamps, abp);
| 198 |
fi_getvec(vin, i+urand(n), abp);
| 199 |
ec = SDevalBSDF(&sdv, vin, vout, &bsd);
| 200 |
if (ec != SDEnone)
| 201 |
goto err;
| 202 |
sum += sdv.cieY;
| 203 |
if (rbf_colorimetry == RBCtristimulus) {
| 204 |
xsum += sdv.cieY * sdv.spec.cx;
| 205 |
ysum += sdv.cieY * sdv.spec.cy;
| 206 |
| 207 |
| 208 |
fprintf(cfp[CIE_Y], "\t%.3e\n", sum/npsamps);
| 209 |
| 210 |
fprintf(cfp[CIE_X], "\t%.3e\n", xsum*sum/(npsamps*ysum));
| 211 |
fprintf(cfp[CIE_Z], "\t%.3e\n",
| 212 |
(sum - xsum - ysum)*sum/(npsamps*ysum));
| 213 |
| 214 |
| 215 |
fputc('\n', cfp[CIE_Y]); /* extra space between rows */
| 216 |
| 217 |
fputc('\n', cfp[CIE_X]);
| 218 |
fputc('\n', cfp[CIE_Z]);
| 219 |
| 220 |
| 221 |
if (fclose(cfp[CIE_Y])) {
| 222 |
fprintf(stderr, "%s: error writing Y output\n", progname);
| 223 |
exit(1);
| 224 |
| 225 |
if (rbf_colorimetry == RBCtristimulus &&
| 226 |
(fclose(cfp[CIE_X]) || fclose(cfp[CIE_Z]))) {
| 227 |
fprintf(stderr, "%s: error writing X/Z output\n", progname);
| 228 |
exit(1);
| 229 |
| 230 |
| 231 |
/* back reflection */
| 232 |
if (bsd.rb != NULL || bsd.rLambBack.cieY > .002) {
| 233 |
input_orient = -1; output_orient = -1;
| 234 |
| 235 |
if (bsd.rb != NULL && bsd.rb->comp[0].cspec[2].flags) {
| 236 |
| 237 |
| 238 |
| 239 |
} else
| 240 |
| 241 |
| 242 |
| 243 |
| 244 |
xsum = ysum = 0;
| 245 |
| 246 |
bo_getvec(vout, j+(n+frandom())/npsamps, abp);
| 247 |
bi_getvec(vin, i+urand(n), abp);
| 248 |
| 249 |
if (ec != SDEnone)
| 250 |
goto err;
| 251 |
sum += sdv.cieY;
| 252 |
| 253 |
| 254 |
| 255 |
| 256 |
| 257 |
| 258 |
| 259 |
| 260 |
| 261 |
| 262 |
| 263 |
| 264 |
| 265 |
| 266 |
| 267 |
| 268 |
| 269 |
| 270 |
| 271 |
exit(1);
| 272 |
| 273 |
| 274 |
| 275 |
| 276 |
exit(1);
| 277 |
| 278 |
| 279 |
/* front transmission */
| 280 |
if (bsd.tf != NULL || bsd.tLambFront.cieY > .002) {
| 281 |
input_orient = 1; output_orient = -1;
| 282 |
| 283 |
if (bsd.tf != NULL && bsd.tf->comp[0].cspec[2].flags) {
| 284 |
| 285 |
| 286 |
| 287 |
} else
| 288 |
| 289 |
| 290 |
| 291 |
| 292 |
xsum = ysum = 0;
| 293 |
| 294 |
| 295 |
| 296 |
| 297 |
if (ec != SDEnone)
| 298 |
goto err;
| 299 |
sum += sdv.cieY;
| 300 |
| 301 |
| 302 |
| 303 |
| 304 |
| 305 |
| 306 |
| 307 |
| 308 |
| 309 |
| 310 |
| 311 |
| 312 |
| 313 |
| 314 |
| 315 |
| 316 |
| 317 |
| 318 |
| 319 |
exit(1);
| 320 |
| 321 |
| 322 |
| 323 |
| 324 |
exit(1);
| 325 |
| 326 |
| 327 |
/* back transmission */
| 328 |
if ((bsd.tb != NULL) | (bsd.tf != NULL)) {
| 329 |
input_orient = -1; output_orient = 1;
| 330 |
| 331 |
if (bsd.tb != NULL)
| 332 |
rbf_colorimetry = bsd.tb->comp[0].cspec[2].flags
| 333 |
? RBCtristimulus : RBCphotopic ;
| 334 |
| 335 |
| 336 |
| 337 |
| 338 |
| 339 |
| 340 |
| 341 |
xsum = ysum = 0;
| 342 |
| 343 |
| 344 |
| 345 |
| 346 |
if (ec != SDEnone)
| 347 |
goto err;
| 348 |
sum += sdv.cieY;
| 349 |
| 350 |
| 351 |
| 352 |
| 353 |
| 354 |
| 355 |
| 356 |
| 357 |
| 358 |
| 359 |
| 360 |
| 361 |
| 362 |
| 363 |
| 364 |
| 365 |
| 366 |
| 367 |
| 368 |
exit(1);
| 369 |
| 370 |
| 371 |
| 372 |
| 373 |
exit(1);
| 374 |
| 375 |
| 376 |
SDfreeBSDF(&bsd); /* all done */
| 377 |
return;
| 378 |
err:
| 379 |
SDreportError(ec, stderr);
| 380 |
exit(1);
| 381 |
| 382 |
| 383 |
/* Interpolate and output a BSDF function using Klems basis */
| 384 |
static void
| 385 |
eval_function(char *funame)
| 386 |
| 387 |
| 388 |
int assignD = (fundefined(funame) < 6);
| 389 |
FILE *ofp = open_component_file(CIE_Y);
| 390 |
double iovec[6];
| 391 |
double sum;
| 392 |
int i, j, n;
| 393 |
| 394 |
initurand(npsamps);
| 395 |
for (j = 0; j < abp->nangles; j++) { /* run through directions */
| 396 |
| 397 |
sum = 0;
| 398 |
for (n = npsamps; n--; ) { /* average over patches */
| 399 |
if (output_orient > 0)
| 400 |
fo_getvec(iovec+3, j+(n+frandom())/npsamps, abp);
| 401 |
else
| 402 |
bo_getvec(iovec+3, j+(n+frandom())/npsamps, abp);
| 403 |
| 404 |
if (input_orient > 0)
| 405 |
fi_getvec(iovec, i+urand(n), abp);
| 406 |
else
| 407 |
bi_getvec(iovec, i+urand(n), abp);
| 408 |
| 409 |
if (assignD) {
| 410 |
varset("Dx", '=', -iovec[3]);
| 411 |
varset("Dy", '=', -iovec[4]);
| 412 |
varset("Dz", '=', -iovec[5]);
| 413 |
++eclock;
| 414 |
| 415 |
sum += funvalue(funame, 6, iovec);
| 416 |
| 417 |
fprintf(ofp, "\t%.3e\n", sum/npsamps);
| 418 |
| 419 |
fputc('\n', ofp);
| 420 |
prog_show((j+1.)/abp->nangles);
| 421 |
| 422 |
prog_done();
| 423 |
if (fclose(ofp)) {
| 424 |
| 425 |
exit(1);
| 426 |
| 427 |
| 428 |
| 429 |
/* Interpolate and output a radial basis function BSDF representation */
| 430 |
static void
| 431 |
eval_rbf(void)
| 432 |
| 433 |
| 434 |
float (*XZarr)[2] = NULL;
| 435 |
float bsdfarr[MAXPATCHES*MAXPATCHES];
| 436 |
FILE *cfp[3];
| 437 |
FVECT vin, vout;
| 438 |
double sum, xsum, ysum, normf;
| 439 |
int i, j, ni, no, nisamps, nosamps;
| 440 |
/* sanity check */
| 441 |
if (abp->nangles > MAXPATCHES) {
| 442 |
fprintf(stderr, "%s: too many patches!\n", progname);
| 443 |
exit(1);
| 444 |
| 445 |
memset(bsdfarr, 0, sizeof(bsdfarr));
| 446 |
| 447 |
XZarr = (float (*)[2])calloc(abp->nangles*abp->nangles, 2*sizeof(float));
| 448 |
nosamps = (int)(pow((double)npsamps, 0.67) + .5);
| 449 |
nisamps = (npsamps + (nosamps>>1)) / nosamps;
| 450 |
normf = 1./(double)(nisamps*nosamps);
| 451 |
| 452 |
for (ni = nisamps; ni--; ) { /* sample over incident patch */
| 453 |
RBFNODE *rbf;
| 454 |
if (input_orient > 0) /* vary incident patch loc. */
| 455 |
fi_getvec(vin, i+urand(ni), abp);
| 456 |
else
| 457 |
bi_getvec(vin, i+urand(ni), abp);
| 458 |
| 459 |
rbf = advect_rbf(vin, lobe_lim); /* compute radial basis func */
| 460 |
| 461 |
| 462 |
sum = 0; /* sample over exiting patch */
| 463 |
xsum = ysum = 0;
| 464 |
for (no = nosamps; no--; ) {
| 465 |
SDValue sdv;
| 466 |
| 467 |
fo_getvec(vout, j+(no+frandom())/nosamps, abp);
| 468 |
else
| 469 |
bo_getvec(vout, j+(no+frandom())/nosamps, abp);
| 470 |
| 471 |
eval_rbfcol(&sdv, rbf, vout);
| 472 |
sum += sdv.cieY;
| 473 |
| 474 |
| 475 |
| 476 |
| 477 |
| 478 |
no = j*abp->nangles + i;
| 479 |
bsdfarr[no] += sum * normf;
| 480 |
| 481 |
XZarr[no][0] += xsum*sum*normf/ysum;
| 482 |
XZarr[no][1] += (sum - xsum - ysum)*sum*normf/ysum;
| 483 |
| 484 |
| 485 |
if (rbf != NULL)
| 486 |
free(rbf);
| 487 |
| 488 |
prog_show((i+1.)/abp->nangles);
| 489 |
| 490 |
/* write out our matrix */
| 491 |
| 492 |
no = 0;
| 493 |
| 494 |
for (i = 0; i < abp->nangles; i++, no++)
| 495 |
fprintf(cfp[CIE_Y], "\t%.3e\n", bsdfarr[no]);
| 496 |
| 497 |
| 498 |
prog_done();
| 499 |
| 500 |
| 501 |
exit(1);
| 502 |
| 503 |
if (XZarr == NULL) /* no color? */
| 504 |
return;
| 505 |
| 506 |
| 507 |
no = 0;
| 508 |
| 509 |
for (i = 0; i < abp->nangles; i++, no++) {
| 510 |
fprintf(cfp[CIE_X], "\t%.3e\n", XZarr[no][0]);
| 511 |
fprintf(cfp[CIE_Z], "\t%.3e\n", XZarr[no][1]);
| 512 |
| 513 |
| 514 |
| 515 |
| 516 |
free(XZarr);
| 517 |
if (fclose(cfp[CIE_X]) || fclose(cfp[CIE_Z])) {
| 518 |
| 519 |
exit(1);
| 520 |
| 521 |
| 522 |
| 523 |
#if defined(_WIN32) || defined(_WIN64)
| 524 |
/* Execute wrapBSDF command (may never return) */
| 525 |
static int
| 526 |
wrap_up(void)
| 527 |
| 528 |
char cmd[32700];
| 529 |
| 530 |
if (bsdf_manuf[0]) {
| 531 |
add_wbsdf("-f", 1);
| 532 |
strcpy(cmd, "m=");
| 533 |
strcpy(cmd+2, bsdf_manuf);
| 534 |
add_wbsdf(cmd, 0);
| 535 |
| 536 |
if (bsdf_name[0]) {
| 537 |
add_wbsdf("-f", 1);
| 538 |
strcpy(cmd, "n=");
| 539 |
strcpy(cmd+2, bsdf_name);
| 540 |
add_wbsdf(cmd, 0);
| 541 |
| 542 |
if (!convert_commandline(cmd, sizeof(cmd), wrapBSDF)) {
| 543 |
| 544 |
fputs(": command line too long in wrap_up()\n", stderr);
| 545 |
return(1);
| 546 |
| 547 |
return(system(cmd));
| 548 |
| 549 |
#else
| 550 |
| 551 |
static int
| 552 |
wrap_up(void)
| 553 |
| 554 |
char buf[256];
| 555 |
char *compath = getpath((char *)wrapBSDF[0], getenv("PATH"), X_OK);
| 556 |
| 557 |
if (compath == NULL) {
| 558 |
fprintf(stderr, "%s: cannot locate %s\n", progname, wrapBSDF[0]);
| 559 |
return(1);
| 560 |
| 561 |
| 562 |
add_wbsdf("-f", 1);
| 563 |
strcpy(buf, "m=");
| 564 |
strcpy(buf+2, bsdf_manuf);
| 565 |
add_wbsdf(buf, 0);
| 566 |
| 567 |
if (bsdf_name[0]) {
| 568 |
add_wbsdf("-f", 1);
| 569 |
strcpy(buf, "n=");
| 570 |
strcpy(buf+2, bsdf_name);
| 571 |
add_wbsdf(buf, 0);
| 572 |
| 573 |
execv(compath, wrapBSDF); /* successful call never returns */
| 574 |
perror(compath);
| 575 |
return(1);
| 576 |
| 577 |
#endif
| 578 |
| 579 |
#define HEAD_BUFLEN 10240
| 580 |
static char head_buf[HEAD_BUFLEN];
| 581 |
static int cur_headlen = 0;
| 582 |
| 583 |
/* Record header line as comment associated with this SIR input */
| 584 |
static int
| 585 |
record2header(char *s)
| 586 |
| 587 |
int len = strlen(s);
| 588 |
| 589 |
if (cur_headlen+len >= HEAD_BUFLEN-6)
| 590 |
return(0);
| 591 |
/* includes EOL */
| 592 |
strcpy(head_buf+cur_headlen, s);
| 593 |
cur_headlen += len;
| 594 |
| 595 |
| 596 |
if (head_buf[cur_headlen-1] == '\n')
| 597 |
head_buf[cur_headlen-1] = '\t';
| 598 |
#endif
| 599 |
return(1);
| 600 |
| 601 |
| 602 |
/* Finish off header for this file */
| 603 |
static void
| 604 |
done_header(void)
| 605 |
| 606 |
while (cur_headlen > 0 && isspace(head_buf[cur_headlen-1]))
| 607 |
--cur_headlen;
| 608 |
head_buf[cur_headlen] = '\0';
| 609 |
if (!cur_headlen)
| 610 |
return;
| 611 |
add_wbsdf("-C", 1);
| 612 |
add_wbsdf(head_buf, 0);
| 613 |
head_buf[cur_headlen=0] = '\0';
| 614 |
| 615 |
| 616 |
/* Read in BSDF and interpolate as Klems matrix representation */
| 617 |
int
| 618 |
main(int argc, char *argv[])
| 619 |
| 620 |
int dofwd = 0, dobwd = 1;
| 621 |
char buf[1024];
| 622 |
char *cp;
| 623 |
int i, na;
| 624 |
| 625 |
progname = argv[0];
| 626 |
esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
| 627 |
esupport &= ~(E_INCHAN|E_OUTCHAN);
| 628 |
scompile("PI:3.14159265358979323846", NULL, 0);
| 629 |
biggerlib();
| 630 |
for (i = 1; i < argc && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
| 631 |
switch (argv[i][1]) { /* get options */
| 632 |
case 'n':
| 633 |
npsamps = atoi(argv[++i]);
| 634 |
if (npsamps <= 0)
| 635 |
goto userr;
| 636 |
break;
| 637 |
case 'e':
| 638 |
scompile(argv[++i], NULL, 0);
| 639 |
single_plane_incident = 0;
| 640 |
break;
| 641 |
case 'f':
| 642 |
if ((argv[i][0] == '-') & !argv[i][2]) {
| 643 |
if (strchr(argv[++i], '=') != NULL) {
| 644 |
add_wbsdf("-f", 1);
| 645 |
add_wbsdf(argv[i], 1);
| 646 |
} else {
| 647 |
char *fpath = getpath(argv[i],
| 648 |
getrlibpath(), 0);
| 649 |
if (fpath == NULL) {
| 650 |
fprintf(stderr,
| 651 |
"%s: cannot find file '%s'\n",
| 652 |
argv[0], argv[i]);
| 653 |
return(1);
| 654 |
| 655 |
fcompile(fpath);
| 656 |
| 657 |
| 658 |
} else
| 659 |
dofwd = (argv[i][0] == '+');
| 660 |
break;
| 661 |
case 'b':
| 662 |
dobwd = (argv[i][0] == '+');
| 663 |
break;
| 664 |
case 'h':
| 665 |
kbasis = klems_half;
| 666 |
add_wbsdf("-a", 1);
| 667 |
add_wbsdf("kh", 1);
| 668 |
break;
| 669 |
case 'q':
| 670 |
kbasis = klems_quarter;
| 671 |
add_wbsdf("-a", 1);
| 672 |
add_wbsdf("kq", 1);
| 673 |
break;
| 674 |
case 'l':
| 675 |
lobe_lim = atoi(argv[++i]);
| 676 |
break;
| 677 |
case 'p':
| 678 |
do_prog = atoi(argv[i]+2);
| 679 |
break;
| 680 |
case 'C':
| 681 |
| 682 |
add_wbsdf(argv[++i], 1);
| 683 |
break;
| 684 |
default:
| 685 |
goto userr;
| 686 |
| 687 |
if (kbasis == klems_full) { /* default (full) basis? */
| 688 |
add_wbsdf("-a", 1);
| 689 |
add_wbsdf("kf", 1);
| 690 |
| 691 |
strcpy(buf, "File produced by: ");
| 692 |
if (convert_commandline(buf+18, sizeof(buf)-18, argv) != NULL) {
| 693 |
add_wbsdf("-C", 1); add_wbsdf(buf, 0);
| 694 |
| 695 |
if (single_plane_incident >= 0) { /* function-based BSDF? */
| 696 |
if (i != argc-1 || fundefined(argv[i]) < 3) {
| 697 |
fprintf(stderr,
| 698 |
"%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
| 699 |
progname);
| 700 |
fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n");
| 701 |
goto userr;
| 702 |
| 703 |
doptimize(1); /* optimize definitions */
| 704 |
++eclock;
| 705 |
if (dofwd) {
| 706 |
input_orient = -1;
| 707 |
output_orient = -1;
| 708 |
prog_start("Evaluating outside reflectance");
| 709 |
eval_function(argv[i]);
| 710 |
output_orient = 1;
| 711 |
prog_start("Evaluating outside->inside transmission");
| 712 |
| 713 |
| 714 |
if (dobwd) {
| 715 |
input_orient = 1;
| 716 |
output_orient = 1;
| 717 |
prog_start("Evaluating inside reflectance");
| 718 |
| 719 |
output_orient = -1;
| 720 |
prog_start("Evaluating inside->outside transmission");
| 721 |
| 722 |
| 723 |
return(wrap_up());
| 724 |
| 725 |
/* XML input? */
| 726 |
if (i == argc-1 && (cp = argv[i]+strlen(argv[i])-4) > argv[i] &&
| 727 |
!strcasecmp(cp, ".xml")) {
| 728 |
eval_bsdf(argv[i]); /* load & resample BSDF */
| 729 |
return(wrap_up());
| 730 |
| 731 |
if (i < argc) { /* open input files if given */
| 732 |
int nbsdf = 0;
| 733 |
for ( ; i < argc; i++) { /* interpolate each component */
| 734 |
FILE *fpin = fopen(argv[i], "rb");
| 735 |
if (fpin == NULL) {
| 736 |
fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
| 737 |
progname, argv[i]);
| 738 |
return(1);
| 739 |
| 740 |
sprintf(buf, "%s:\n", argv[i]);
| 741 |
record2header(buf);
| 742 |
sir_headshare = &record2header;
| 743 |
if (!load_bsdf_rep(fpin))
| 744 |
return(1);
| 745 |
fclose(fpin);
| 746 |
done_header();
| 747 |
sprintf(buf, "Interpolating component '%s'", argv[i]);
| 748 |
prog_start(buf);
| 749 |
eval_rbf();
| 750 |
| 751 |
return(wrap_up());
| 752 |
| 753 |
SET_FILE_BINARY(stdin); /* load from stdin */
| 754 |
record2header("<stdin>:\n");
| 755 |
| 756 |
if (!load_bsdf_rep(stdin))
| 757 |
return(1);
| 758 |
done_header();
| 759 |
prog_start("Interpolating from standard input");
| 760 |
eval_rbf(); /* resample dist. */
| 761 |
return(wrap_up());
| 762 |
userr:
| 763 |
fprintf(stderr,
| 764 |
"Usage: %s [-n spp][-h|-q][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n", progname);
| 765 |
fprintf(stderr,
| 766 |
" or: %s [-n spp][-h|-q] bsdf_in.xml > bsdf_out.xml\n", progname);
| 767 |
fprintf(stderr,
| 768 |
" or: %s [-n spp][-h|-q][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
| 769 |
progname);
| 770 |
return(1);
| 771 |
