root/radiance/ray/src/cv/bsdf2klems.c
Revision: 2.28
Committed: Sat Dec 28 18:05:14 2019 UTC (4 years, 4 months ago) by greg
Changes since 2.27: +1 -3 lines
2 static const char RCSid[] = "$Id: bsdf2klems.c,v 2.27 2019/06/17 23:58:32 greg Exp $";
5 * Load measured BSDF interpolant and write out as XML file with Klems matrix.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdlib.h>
12 #include <math.h>
13 #include "random.h"
14 #include "platform.h"
15 #include "paths.h"
16 #include "rtio.h"
17 #include "calcomp.h"
18 #include "bsdfrep.h"
19 #include "bsdf_m.h"
20 /* tristimulus components */
21 enum {CIE_X, CIE_Y, CIE_Z};
22 /* assumed maximum # Klems patches */
23 #define MAXPATCHES 145
24 /* global argv[0] */
25 char *progname;
26 /* selected basis function name */
27 static const char klems_full[] = "LBNL/Klems Full";
28 static const char klems_half[] = "LBNL/Klems Half";
29 static const char klems_quarter[] = "LBNL/Klems Quarter";
30 static const char *kbasis = klems_full;
31 /* number of BSDF samples per patch */
32 static int npsamps = 1024;
33 /* limit on number of RBF lobes */
34 static int lobe_lim = 15000;
35 /* progress bar length */
36 static int do_prog = 79;
37
38 #define MAXCARG 512 /* wrapBSDF command */
39 static char *wrapBSDF[MAXCARG] = {"wrapBSDF", "-W", "-UU"};
40 static int wbsdfac = 3;
41
42 /* Add argument to wrapBSDF, allocating space if !isstatic */
43 static void
44 add_wbsdf(const char *arg, int isstatic)
45 {
46 if (arg == NULL)
47 return;
48 if (wbsdfac >= MAXCARG-1) {
49 fputs(progname, stderr);
50 fputs(": too many command arguments to wrapBSDF\n", stderr);
51 exit(1);
52 }
53 if (!*arg)
54 arg = "";
55 else if (!isstatic)
56 arg = savqstr((char *)arg);
57
58 wrapBSDF[wbsdfac++] = (char *)arg;
59 }
60
61 /* Start new progress bar */
62 #define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else
63
64 /* Draw progress bar of the appropriate length */
65 static void
66 prog_show(double frac)
67 {
68 static unsigned call_cnt = 0;
69 static char lastc[] = "-\\|/";
70 char pbar[256];
71 int nchars;
72
73 if (do_prog <= 1) return;
74 if (do_prog > sizeof(pbar)-2)
75 do_prog = sizeof(pbar)-2;
76 if (frac < 0) frac = 0;
77 else if (frac >= 1) frac = .9999;
78 nchars = do_prog*frac;
79 pbar[0] = '\r';
80 memset(pbar+1, '*', nchars);
81 pbar[nchars+1] = lastc[call_cnt++ & 3];
82 memset(pbar+2+nchars, '-', do_prog-nchars-1);
83 pbar[do_prog+1] = '\0';
84 fputs(pbar, stderr);
85 }
86
87 /* Finish progress bar */
88 static void
89 prog_done(void)
90 {
91 int n = do_prog;
92
93 if (n <= 1) return;
94 fputc('\r', stderr);
95 while (n--)
96 fputc(' ', stderr);
97 fputc('\r', stderr);
98 }
99
100 /* Return angle basis corresponding to the given name */
101 static ANGLE_BASIS *
102 get_basis(const char *bn)
103 {
104 int n = nabases;
105
106 while (n-- > 0)
107 if (!strcasecmp(bn, abase_list[n].name))
108 return &abase_list[n];
109 return NULL;
110 }
111
112 /* Copy geometry string to file for wrapBSDF */
113 static char *
114 save_geom(const char *mgf)
115 {
116 char *tfname = mktemp(savqstr(TEMPLATE));
117 int fd = open(tfname, O_CREAT|O_WRONLY, 0600);
118
119 if (fd < 0)
120 return(NULL);
121 write(fd, mgf, strlen(mgf));
122 close(fd);
123 add_wbsdf("-g", 1);
124 add_wbsdf(tfname, 1);
125 return(tfname);
126 }
127
128 /* Open XYZ component file for output and add appropriate arguments */
129 static FILE *
130 open_component_file(int c)
131 {
132 static const char sname[3][6] = {"CIE-X", "CIE-Y", "CIE-Z"};
133 static const char cname[4][4] = {"-rf", "-tf", "-tb", "-rb"};
134 char *tfname = mktemp(savqstr(TEMPLATE));
135 FILE *fp = fopen(tfname, "w");
136
137 if (fp == NULL) {
138 fprintf(stderr, "%s: cannot open '%s' for writing\n",
139 progname, tfname);
140 exit(1);
141 }
142 add_wbsdf("-s", 1); add_wbsdf(sname[c], 1);
143 add_wbsdf(cname[(input_orient>0)<<1 | (output_orient>0)], 1);
144 add_wbsdf(tfname, 1);
145 return(fp);
146 }
147
148 /* Load and resample XML BSDF description using Klems basis */
149 static void
150 eval_bsdf(const char *fname)
151 {
152 ANGLE_BASIS *abp = get_basis(kbasis);
153 FILE *cfp[3];
154 SDData bsd;
155 SDError ec;
156 FVECT vin, vout;
157 SDValue sdv;
158 double sum, xsum, ysum;
159 int i, j, n;
160
161 initurand(npsamps);
162 SDclearBSDF(&bsd, fname); /* load BSDF file */
163 if ((ec = SDloadFile(&bsd, fname)) != SDEnone)
164 goto err;
165 if (bsd.mgf != NULL) /* save geometry */
166 save_geom(bsd.mgf);
167 if (bsd.matn[0]) /* save identifier(s) */
168 strcpy(bsdf_name, bsd.matn);
169 if (bsd.makr[0])
170 strcpy(bsdf_manuf, bsd.makr);
171 if (bsd.dim[2] > 0) { /* save dimension(s) */
172 char buf[64];
173 if ((bsd.dim[0] > 0) & (bsd.dim[1] > 0))
174 sprintf(buf, "w=%g;h=%g;t=%g",
175 bsd.dim[0], bsd.dim[1], bsd.dim[2]);
176 else
177 sprintf(buf, "t=%g", bsd.dim[2]);
178 add_wbsdf("-f", 1);
179 add_wbsdf(buf, 0);
180 }
181 /* front reflection */
182 if (bsd.rf != NULL || bsd.rLambFront.cieY > .002) {
183 input_orient = 1; output_orient = 1;
184 cfp[CIE_Y] = open_component_file(CIE_Y);
185 if (bsd.rf != NULL && bsd.rf->comp[0].cspec[2].flags) {
186 rbf_colorimetry = RBCtristimulus;
187 cfp[CIE_X] = open_component_file(CIE_X);
188 cfp[CIE_Z] = open_component_file(CIE_Z);
189 } else
190 rbf_colorimetry = RBCphotopic;
191 for (j = 0; j < abp->nangles; j++) {
192 for (i = 0; i < abp->nangles; i++) {
193 sum = 0; /* average over patches */
194 xsum = ysum = 0;
195 for (n = npsamps; n-- > 0; ) {
196 fo_getvec(vout, j+(n+frandom())/npsamps, abp);
197 fi_getvec(vin, i+urand(n), abp);
198 ec = SDevalBSDF(&sdv, vout, vin, &bsd);
199 if (ec != SDEnone)
200 goto err;
201 sum += sdv.cieY;
202 if (rbf_colorimetry == RBCtristimulus) {
203 xsum += sdv.cieY * sdv.spec.cx;
204 ysum += sdv.cieY * sdv.spec.cy;
205 }
206 }
207 fprintf(cfp[CIE_Y], "\t%.3e\n", sum/npsamps);
208 if (rbf_colorimetry == RBCtristimulus) {
209 fprintf(cfp[CIE_X], "\t%.3e\n", xsum*sum/(npsamps*ysum));
210 fprintf(cfp[CIE_Z], "\t%.3e\n",
211 (sum - xsum - ysum)*sum/(npsamps*ysum));
212 }
213 }
214 fputc('\n', cfp[CIE_Y]); /* extra space between rows */
215 if (rbf_colorimetry == RBCtristimulus) {
216 fputc('\n', cfp[CIE_X]);
217 fputc('\n', cfp[CIE_Z]);
218 }
219 }
220 if (fclose(cfp[CIE_Y])) {
221 fprintf(stderr, "%s: error writing Y output\n", progname);
222 exit(1);
223 }
224 if (rbf_colorimetry == RBCtristimulus &&
225 (fclose(cfp[CIE_X]) || fclose(cfp[CIE_Z]))) {
226 fprintf(stderr, "%s: error writing X/Z output\n", progname);
227 exit(1);
228 }
229 }
230 /* back reflection */
231 if (bsd.rb != NULL || bsd.rLambBack.cieY > .002) {
232 input_orient = -1; output_orient = -1;
233 cfp[CIE_Y] = open_component_file(CIE_Y);
234 if (bsd.rb != NULL && bsd.rb->comp[0].cspec[2].flags) {
235 rbf_colorimetry = RBCtristimulus;
236 cfp[CIE_X] = open_component_file(CIE_X);
237 cfp[CIE_Z] = open_component_file(CIE_Z);
238 } else
239 rbf_colorimetry = RBCphotopic;
240 for (j = 0; j < abp->nangles; j++) {
241 for (i = 0; i < abp->nangles; i++) {
242 sum = 0; /* average over patches */
243 xsum = ysum = 0;
244 for (n = npsamps; n-- > 0; ) {
245 bo_getvec(vout, j+(n+frandom())/npsamps, abp);
246 bi_getvec(vin, i+urand(n), abp);
247 ec = SDevalBSDF(&sdv, vout, vin, &bsd);
248 if (ec != SDEnone)
249 goto err;
250 sum += sdv.cieY;
251 if (rbf_colorimetry == RBCtristimulus) {
252 xsum += sdv.cieY * sdv.spec.cx;
253 ysum += sdv.cieY * sdv.spec.cy;
254 }
255 }
256 fprintf(cfp[CIE_Y], "\t%.3e\n", sum/npsamps);
257 if (rbf_colorimetry == RBCtristimulus) {
258 fprintf(cfp[CIE_X], "\t%.3e\n", xsum*sum/(npsamps*ysum));
259 fprintf(cfp[CIE_Z], "\t%.3e\n",
260 (sum - xsum - ysum)*sum/(npsamps*ysum));
261 }
262 }
263 if (rbf_colorimetry == RBCtristimulus) {
264 fputc('\n', cfp[CIE_X]);
265 fputc('\n', cfp[CIE_Z]);
266 }
267 }
268 if (fclose(cfp[CIE_Y])) {
269 fprintf(stderr, "%s: error writing Y output\n", progname);
270 exit(1);
271 }
272 if (rbf_colorimetry == RBCtristimulus &&
273 (fclose(cfp[CIE_X]) || fclose(cfp[CIE_Z]))) {
274 fprintf(stderr, "%s: error writing X/Z output\n", progname);
275 exit(1);
276 }
277 }
278 /* front transmission */
279 if (bsd.tf != NULL || bsd.tLamb.cieY > .002) {
280 input_orient = 1; output_orient = -1;
281 cfp[CIE_Y] = open_component_file(CIE_Y);
282 if (bsd.tf != NULL && bsd.tf->comp[0].cspec[2].flags) {
283 rbf_colorimetry = RBCtristimulus;
284 cfp[CIE_X] = open_component_file(CIE_X);
285 cfp[CIE_Z] = open_component_file(CIE_Z);
286 } else
287 rbf_colorimetry = RBCphotopic;
288 for (j = 0; j < abp->nangles; j++) {
289 for (i = 0; i < abp->nangles; i++) {
290 sum = 0; /* average over patches */
291 xsum = ysum = 0;
292 for (n = npsamps; n-- > 0; ) {
293 bo_getvec(vout, j+(n+frandom())/npsamps, abp);
294 fi_getvec(vin, i+urand(n), abp);
295 ec = SDevalBSDF(&sdv, vout, vin, &bsd);
296 if (ec != SDEnone)
297 goto err;
298 sum += sdv.cieY;
299 if (rbf_colorimetry == RBCtristimulus) {
300 xsum += sdv.cieY * sdv.spec.cx;
301 ysum += sdv.cieY * sdv.spec.cy;
302 }
303 }
304 fprintf(cfp[CIE_Y], "\t%.3e\n", sum/npsamps);
305 if (rbf_colorimetry == RBCtristimulus) {
306 fprintf(cfp[CIE_X], "\t%.3e\n", xsum*sum/(npsamps*ysum));
307 fprintf(cfp[CIE_Z], "\t%.3e\n",
308 (sum - xsum - ysum)*sum/(npsamps*ysum));
309 }
310 }
311 if (rbf_colorimetry == RBCtristimulus) {
312 fputc('\n', cfp[CIE_X]);
313 fputc('\n', cfp[CIE_Z]);
314 }
315 }
316 if (fclose(cfp[CIE_Y])) {
317 fprintf(stderr, "%s: error writing Y output\n", progname);
318 exit(1);
319 }
320 if (rbf_colorimetry == RBCtristimulus &&
321 (fclose(cfp[CIE_X]) || fclose(cfp[CIE_Z]))) {
322 fprintf(stderr, "%s: error writing X/Z output\n", progname);
323 exit(1);
324 }
325 }
326 /* back transmission */
327 if ((bsd.tb != NULL) | (bsd.tf != NULL)) {
328 input_orient = -1; output_orient = 1;
329 cfp[CIE_Y] = open_component_file(CIE_Y);
330 if (bsd.tb != NULL)
331 rbf_colorimetry = bsd.tb->comp[0].cspec[2].flags
332 ? RBCtristimulus : RBCphotopic ;
333 if (rbf_colorimetry == RBCtristimulus) {
334 cfp[CIE_X] = open_component_file(CIE_X);
335 cfp[CIE_Z] = open_component_file(CIE_Z);
336 }
337 for (j = 0; j < abp->nangles; j++) {
338 for (i = 0; i < abp->nangles; i++) {
339 sum = 0; /* average over patches */
340 xsum = ysum = 0;
341 for (n = npsamps; n-- > 0; ) {
342 fo_getvec(vout, j+(n+frandom())/npsamps, abp);
343 bi_getvec(vin, i+urand(n), abp);
344 ec = SDevalBSDF(&sdv, vout, vin, &bsd);
345 if (ec != SDEnone)
346 goto err;
347 sum += sdv.cieY;
348 if (rbf_colorimetry == RBCtristimulus) {
349 xsum += sdv.cieY * sdv.spec.cx;
350 ysum += sdv.cieY * sdv.spec.cy;
351 }
352 }
353 fprintf(cfp[CIE_Y], "\t%.3e\n", sum/npsamps);
354 if (rbf_colorimetry == RBCtristimulus) {
355 fprintf(cfp[CIE_X], "\t%.3e\n", xsum*sum/(npsamps*ysum));
356 fprintf(cfp[CIE_Z], "\t%.3e\n",
357 (sum - xsum - ysum)*sum/(npsamps*ysum));
358 }
359 }
360 if (rbf_colorimetry == RBCtristimulus) {
361 fputc('\n', cfp[CIE_X]);
362 fputc('\n', cfp[CIE_Z]);
363 }
364 }
365 if (fclose(cfp[CIE_Y])) {
366 fprintf(stderr, "%s: error writing Y output\n", progname);
367 exit(1);
368 }
369 if (rbf_colorimetry == RBCtristimulus &&
370 (fclose(cfp[CIE_X]) || fclose(cfp[CIE_Z]))) {
371 fprintf(stderr, "%s: error writing X/Z output\n", progname);
372 exit(1);
373 }
374 }
375 SDfreeBSDF(&bsd); /* all done */
376 return;
377 err:
378 SDreportError(ec, stderr);
379 exit(1);
380 }
381
382 /* Interpolate and output a BSDF function using Klems basis */
383 static void
384 eval_function(char *funame)
385 {
386 ANGLE_BASIS *abp = get_basis(kbasis);
387 int assignD = (fundefined(funame) < 6);
388 FILE *ofp = open_component_file(CIE_Y);
389 double iovec[6];
390 double sum;
391 int i, j, n;
392
393 initurand(npsamps);
394 for (j = 0; j < abp->nangles; j++) { /* run through directions */
395 for (i = 0; i < abp->nangles; i++) {
396 sum = 0;
397 for (n = npsamps; n--; ) { /* average over patches */
398 if (output_orient > 0)
399 fo_getvec(iovec+3, j+(n+frandom())/npsamps, abp);
400 else
401 bo_getvec(iovec+3, j+(n+frandom())/npsamps, abp);
402
403 if (input_orient > 0)
404 fi_getvec(iovec, i+urand(n), abp);
405 else
406 bi_getvec(iovec, i+urand(n), abp);
407
408 if (assignD) {
409 varset("Dx", '=', -iovec[3]);
410 varset("Dy", '=', -iovec[4]);
411 varset("Dz", '=', -iovec[5]);
412 ++eclock;
413 }
414 sum += funvalue(funame, 6, iovec);
415 }
416 fprintf(ofp, "\t%.3e\n", sum/npsamps);
417 }
418 fputc('\n', ofp);
419 prog_show((j+1.)/abp->nangles);
420 }
421 prog_done();
422 if (fclose(ofp)) {
423 fprintf(stderr, "%s: error writing Y output\n", progname);
424 exit(1);
425 }
426 }
427
428 /* Interpolate and output a radial basis function BSDF representation */
429 static void
430 eval_rbf(void)
431 {
432 ANGLE_BASIS *abp = get_basis(kbasis);
433 float (*XZarr)[2] = NULL;
434 float bsdfarr[MAXPATCHES*MAXPATCHES];
435 FILE *cfp[3];
436 FVECT vin, vout;
437 double sum, xsum, ysum, normf;
438 int i, j, ni, no, nisamps, nosamps;
439 /* sanity check */
440 if (abp->nangles > MAXPATCHES) {
441 fprintf(stderr, "%s: too many patches!\n", progname);
442 exit(1);
443 }
444 memset(bsdfarr, 0, sizeof(bsdfarr));
445 if (rbf_colorimetry == RBCtristimulus)
446 XZarr = (float (*)[2])calloc(abp->nangles*abp->nangles, 2*sizeof(float));
447 nosamps = (int)(pow((double)npsamps, 0.67) + .5);
448 nisamps = (npsamps + (nosamps>>1)) / nosamps;
449 normf = 1./(double)(nisamps*nosamps);
450 for (i = 0; i < abp->nangles; i++) {
451 for (ni = nisamps; ni--; ) { /* sample over incident patch */
452 RBFNODE *rbf;
453 if (input_orient > 0) /* vary incident patch loc. */
454 fi_getvec(vin, i+urand(ni), abp);
455 else
456 bi_getvec(vin, i+urand(ni), abp);
457
458 rbf = advect_rbf(vin, lobe_lim); /* compute radial basis func */
459
460 for (j = 0; j < abp->nangles; j++) {
461 sum = 0; /* sample over exiting patch */
462 xsum = ysum = 0;
463 for (no = nosamps; no--; ) {
464 SDValue sdv;
465 if (output_orient > 0)
466 fo_getvec(vout, j+(no+frandom())/nosamps, abp);
467 else
468 bo_getvec(vout, j+(no+frandom())/nosamps, abp);
469
470 eval_rbfcol(&sdv, rbf, vout);
471 sum += sdv.cieY;
472 if (rbf_colorimetry == RBCtristimulus) {
473 xsum += sdv.cieY * sdv.spec.cx;
474 ysum += sdv.cieY * sdv.spec.cy;
475 }
476 }
477 no = j*abp->nangles + i;
478 bsdfarr[no] += sum * normf;
479 if (rbf_colorimetry == RBCtristimulus) {
480 XZarr[no][0] += xsum*sum*normf/ysum;
481 XZarr[no][1] += (sum - xsum - ysum)*sum*normf/ysum;
482 }
483 }
484 if (rbf != NULL)
485 free(rbf);
486 }
487 prog_show((i+1.)/abp->nangles);
488 }
489 /* write out our matrix */
490 cfp[CIE_Y] = open_component_file(CIE_Y);
491 no = 0;
492 for (j = 0; j < abp->nangles; j++) {
493 for (i = 0; i < abp->nangles; i++, no++)
494 fprintf(cfp[CIE_Y], "\t%.3e\n", bsdfarr[no]);
495 fputc('\n', cfp[CIE_Y]);
496 }
497 prog_done();
498 if (fclose(cfp[CIE_Y])) {
499 fprintf(stderr, "%s: error writing Y output\n", progname);
500 exit(1);
501 }
502 if (XZarr == NULL) /* no color? */
503 return;
504 cfp[CIE_X] = open_component_file(CIE_X);
505 cfp[CIE_Z] = open_component_file(CIE_Z);
506 no = 0;
507 for (j = 0; j < abp->nangles; j++) {
508 for (i = 0; i < abp->nangles; i++, no++) {
509 fprintf(cfp[CIE_X], "\t%.3e\n", XZarr[no][0]);
510 fprintf(cfp[CIE_Z], "\t%.3e\n", XZarr[no][1]);
511 }
512 fputc('\n', cfp[CIE_X]);
513 fputc('\n', cfp[CIE_Z]);
514 }
515 free(XZarr);
516 if (fclose(cfp[CIE_X]) || fclose(cfp[CIE_Z])) {
517 fprintf(stderr, "%s: error writing X/Z output\n", progname);
518 exit(1);
519 }
520 }
521
522 #if defined(_WIN32) || defined(_WIN64)
523 /* Execute wrapBSDF command (may never return) */
524 static int
525 wrap_up(void)
526 {
527 char cmd[8192];
528
529 if (bsdf_manuf[0]) {
530 add_wbsdf("-f", 1);
531 strcpy(cmd, "m=");
532 strcpy(cmd+2, bsdf_manuf);
533 add_wbsdf(cmd, 0);
534 }
535 if (bsdf_name[0]) {
536 add_wbsdf("-f", 1);
537 strcpy(cmd, "n=");
538 strcpy(cmd+2, bsdf_name);
539 add_wbsdf(cmd, 0);
540 }
541 if (!convert_commandline(cmd, sizeof(cmd), wrapBSDF)) {
542 fputs(progname, stderr);
543 fputs(": command line too long in wrap_up()\n", stderr);
544 return(1);
545 }
546 return(system(cmd));
547 }
548 #else
549 /* Execute wrapBSDF command (may never return) */
550 static int
551 wrap_up(void)
552 {
553 char buf[256];
554 char *compath = getpath((char *)wrapBSDF[0], getenv("PATH"), X_OK);
555
556 if (compath == NULL) {
557 fprintf(stderr, "%s: cannot locate %s\n", progname, wrapBSDF[0]);
558 return(1);
559 }
560 if (bsdf_manuf[0]) {
561 add_wbsdf("-f", 1);
562 strcpy(buf, "m=");
563 strcpy(buf+2, bsdf_manuf);
564 add_wbsdf(buf, 0);
565 }
566 if (bsdf_name[0]) {
567 add_wbsdf("-f", 1);
568 strcpy(buf, "n=");
569 strcpy(buf+2, bsdf_name);
570 add_wbsdf(buf, 0);
571 }
572 execv(compath, wrapBSDF); /* successful call never returns */
573 perror(compath);
574 return(1);
575 }
576 #endif
577
578 /* Read in BSDF and interpolate as Klems matrix representation */
579 int
580 main(int argc, char *argv[])
581 {
582 int dofwd = 0, dobwd = 1;
583 char buf[2048];
584 char *cp;
585 int i, na;
586
587 progname = argv[0];
588 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
589 esupport &= ~(E_INCHAN|E_OUTCHAN);
590 scompile("PI:3.14159265358979323846", NULL, 0);
591 biggerlib();
592 for (i = 1; i < argc && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
593 switch (argv[i][1]) { /* get options */
594 case 'n':
595 npsamps = atoi(argv[++i]);
596 if (npsamps <= 0)
597 goto userr;
598 break;
599 case 'e':
600 scompile(argv[++i], NULL, 0);
601 single_plane_incident = 0;
602 break;
603 case 'f':
604 if (!argv[i][2]) {
605 if (strchr(argv[++i], '=') != NULL) {
606 add_wbsdf("-f", 1);
607 add_wbsdf(argv[i], 1);
608 } else {
609 char *fpath = getpath(argv[i],
610 getrlibpath(), 0);
611 if (fpath == NULL) {
612 fprintf(stderr,
613 "%s: cannot find file '%s'\n",
614 argv[0], argv[i]);
615 return(1);
616 }
617 fcompile(fpath);
618 single_plane_incident = 0;
619 }
620 } else
621 dofwd = (argv[i][0] == '+');
622 break;
623 case 'b':
624 dobwd = (argv[i][0] == '+');
625 break;
626 case 'h':
627 kbasis = klems_half;
628 add_wbsdf("-a", 1);
629 add_wbsdf("kh", 1);
630 break;
631 case 'q':
632 kbasis = klems_quarter;
633 add_wbsdf("-a", 1);
634 add_wbsdf("kq", 1);
635 break;
636 case 'l':
637 lobe_lim = atoi(argv[++i]);
638 break;
639 case 'p':
640 do_prog = atoi(argv[i]+2);
641 break;
642 case 'C':
643 add_wbsdf(argv[i], 1);
644 add_wbsdf(argv[++i], 1);
645 break;
646 default:
647 goto userr;
648 }
649 if (kbasis == klems_full) { /* default (full) basis? */
650 add_wbsdf("-a", 1);
651 add_wbsdf("kf", 1);
652 }
653 strcpy(buf, "File produced by: ");
654 if (convert_commandline(buf+18, sizeof(buf)-18, argv) != NULL) {
655 add_wbsdf("-C", 1); add_wbsdf(buf, 0);
656 }
657 if (single_plane_incident >= 0) { /* function-based BSDF? */
658 if (i != argc-1 || fundefined(argv[i]) < 3) {
659 fprintf(stderr,
660 "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
661 progname);
662 fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n");
663 goto userr;
664 }
665 ++eclock;
666 if (dofwd) {
667 input_orient = -1;
668 output_orient = -1;
669 prog_start("Evaluating outside reflectance");
670 eval_function(argv[i]);
671 output_orient = 1;
672 prog_start("Evaluating outside->inside transmission");
673 eval_function(argv[i]);
674 }
675 if (dobwd) {
676 input_orient = 1;
677 output_orient = 1;
678 prog_start("Evaluating inside reflectance");
679 eval_function(argv[i]);
680 output_orient = -1;
681 prog_start("Evaluating inside->outside transmission");
682 eval_function(argv[i]);
683 }
684 return(wrap_up());
685 }
686 /* XML input? */
687 if (i == argc-1 && (cp = argv[i]+strlen(argv[i])-4) > argv[i] &&
688 !strcasecmp(cp, ".xml")) {
689 eval_bsdf(argv[i]); /* load & resample BSDF */
690 return(wrap_up());
691 }
692 if (i < argc) { /* open input files if given */
693 int nbsdf = 0;
694 for ( ; i < argc; i++) { /* interpolate each component */
695 char pbuf[256];
696 FILE *fpin = fopen(argv[i], "rb");
697 if (fpin == NULL) {
698 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
699 progname, argv[i]);
700 return(1);
701 }
702 if (!load_bsdf_rep(fpin))
703 return(1);
704 fclose(fpin);
705 sprintf(pbuf, "Interpolating component '%s'", argv[i]);
706 prog_start(pbuf);
707 eval_rbf();
708 }
709 return(wrap_up());
710 }
711 SET_FILE_BINARY(stdin); /* load from stdin */
712 if (!load_bsdf_rep(stdin))
713 return(1);
714 prog_start("Interpolating from standard input");
715 eval_rbf(); /* resample dist. */
716 return(wrap_up());
717 userr:
718 fprintf(stderr,
719 "Usage: %s [-n spp][-h|-q][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n", progname);
720 fprintf(stderr,
721 " or: %s [-n spp][-h|-q] bsdf_in.xml > bsdf_out.xml\n", progname);
722 fprintf(stderr,
723 " or: %s [-n spp][-h|-q][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
724 progname);
725 return(1);
726 }
