| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: bsdf2klems.c,v 2.10 2013/09/26 17:05:00 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Load measured BSDF interpolant and write out as XML file with Klems matrix.
| 6 |
| 7 |
* G. Ward
| 8 |
| 9 |
| 10 |
#define _USE_MATH_DEFINES
| 11 |
#include <stdio.h>
| 12 |
#include <stdlib.h>
| 13 |
#include <string.h>
| 14 |
#include <math.h>
| 15 |
#include "random.h"
| 16 |
#include "platform.h"
| 17 |
#include "calcomp.h"
| 18 |
#include "bsdfrep.h"
| 19 |
#include "bsdf_m.h"
| 20 |
/* assumed maximum # Klems patches */
| 21 |
#define MAXPATCHES 145
| 22 |
/* global argv[0] */
| 23 |
char *progname;
| 24 |
/* selected basis function name */
| 25 |
static const char *kbasis = "LBNL/Klems Full";
| 26 |
/* number of BSDF samples per patch */
| 27 |
static int npsamps = 256;
| 28 |
/* limit on number of RBF lobes */
| 29 |
static int lobe_lim = 15000;
| 30 |
| 31 |
/* Return angle basis corresponding to the given name */
| 32 |
ANGLE_BASIS *
| 33 |
get_basis(const char *bn)
| 34 |
| 35 |
int n = nabases;
| 36 |
| 37 |
while (n-- > 0)
| 38 |
if (!strcasecmp(bn, abase_list[n].name))
| 39 |
return &abase_list[n];
| 40 |
return NULL;
| 41 |
| 42 |
| 43 |
/* Output XML header to stdout */
| 44 |
static void
| 45 |
xml_header(int ac, char *av[])
| 46 |
| 47 |
puts("<?xml version=\"1.0\" encoding=\"UTF-8\"?>");
| 48 |
puts("<WindowElement xmlns=\"http://windows.lbl.gov\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:schemaLocation=\"http://windows.lbl.gov/BSDF-v1.4.xsd\">");
| 49 |
fputs("<!-- File produced by:", stdout);
| 50 |
while (ac-- > 0) {
| 51 |
fputc(' ', stdout);
| 52 |
fputs(*av++, stdout);
| 53 |
| 54 |
puts(" -->");
| 55 |
| 56 |
| 57 |
/* Output XML prologue to stdout */
| 58 |
static void
| 59 |
xml_prologue(const SDData *sd)
| 60 |
| 61 |
const char *matn = (sd && sd->matn[0]) ? sd->matn :
| 62 |
bsdf_name[0] ? bsdf_name : "Unknown";
| 63 |
const char *makr = (sd && sd->makr[0]) ? sd->makr :
| 64 |
bsdf_manuf[0] ? bsdf_manuf : "Unknown";
| 65 |
ANGLE_BASIS *abp = get_basis(kbasis);
| 66 |
int i;
| 67 |
| 68 |
if (abp == NULL) {
| 69 |
fprintf(stderr, "%s: unknown angle basis '%s'\n", progname, kbasis);
| 70 |
exit(1);
| 71 |
| 72 |
puts("<WindowElementType>System</WindowElementType>");
| 73 |
puts("<FileType>BSDF</FileType>");
| 74 |
puts("<Optical>");
| 75 |
puts("<Layer>");
| 76 |
puts("\t<Material>");
| 77 |
printf("\t\t<Name>%s</Name>\n", matn);
| 78 |
printf("\t\t<Manufacturer>%s</Manufacturer>\n", makr);
| 79 |
if (sd && sd->dim[2] > .001) {
| 80 |
printf("\t\t<Thickness unit=\"meter\">%.3f</Thickness>\n", sd->dim[2]);
| 81 |
printf("\t\t<Width unit=\"meter\">%.3f</Width>\n", sd->dim[0]);
| 82 |
printf("\t\t<Height unit=\"meter\">%.3f</Height>\n", sd->dim[1]);
| 83 |
| 84 |
puts("\t\t<DeviceType>Other</DeviceType>");
| 85 |
puts("\t</Material>");
| 86 |
if (sd && sd->mgf != NULL) {
| 87 |
puts("\t<Geometry format=\"MGF\">");
| 88 |
puts("\t\t<MGFblock unit=\"meter\">");
| 89 |
fputs(sd->mgf, stdout);
| 90 |
puts("</MGFblock>");
| 91 |
puts("\t</Geometry>");
| 92 |
| 93 |
puts("\t<DataDefinition>");
| 94 |
puts("\t\t<IncidentDataStructure>Columns</IncidentDataStructure>");
| 95 |
puts("\t\t<AngleBasis>");
| 96 |
printf("\t\t\t<AngleBasisName>%s</AngleBasisName>\n", kbasis);
| 97 |
for (i = 0; abp->lat[i].nphis; i++) {
| 98 |
puts("\t\t\t<AngleBasisBlock>");
| 99 |
printf("\t\t\t<Theta>%g</Theta>\n", i ?
| 100 |
.5*(abp->lat[i].tmin + abp->lat[i+1].tmin) :
| 101 |
.0 );
| 102 |
printf("\t\t\t<nPhis>%d</nPhis>\n", abp->lat[i].nphis);
| 103 |
puts("\t\t\t<ThetaBounds>");
| 104 |
printf("\t\t\t\t<LowerTheta>%g</LowerTheta>\n", abp->lat[i].tmin);
| 105 |
printf("\t\t\t\t<UpperTheta>%g</UpperTheta>\n", abp->lat[i+1].tmin);
| 106 |
puts("\t\t\t</ThetaBounds>");
| 107 |
puts("\t\t\t</AngleBasisBlock>");
| 108 |
| 109 |
puts("\t\t</AngleBasis>");
| 110 |
puts("\t</DataDefinition>");
| 111 |
| 112 |
| 113 |
/* Output XML data prologue to stdout */
| 114 |
static void
| 115 |
data_prologue()
| 116 |
| 117 |
static const char *bsdf_type[4] = {
| 118 |
"Reflection Front",
| 119 |
"Transmission Front",
| 120 |
"Transmission Back",
| 121 |
"Reflection Back"
| 122 |
| 123 |
| 124 |
puts("\t<WavelengthData>");
| 125 |
puts("\t\t<LayerNumber>System</LayerNumber>");
| 126 |
puts("\t\t<Wavelength unit=\"Integral\">Visible</Wavelength>");
| 127 |
puts("\t\t<SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>");
| 128 |
puts("\t\t<DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>");
| 129 |
puts("\t\t<WavelengthDataBlock>");
| 130 |
printf("\t\t\t<WavelengthDataDirection>%s</WavelengthDataDirection>\n",
| 131 |
bsdf_type[(input_orient>0)<<1 | (output_orient>0)]);
| 132 |
printf("\t\t\t<ColumnAngleBasis>%s</ColumnAngleBasis>\n", kbasis);
| 133 |
printf("\t\t\t<RowAngleBasis>%s</RowAngleBasis>\n", kbasis);
| 134 |
puts("\t\t\t<ScatteringDataType>BTDF</ScatteringDataType>");
| 135 |
puts("\t\t\t<ScatteringData>");
| 136 |
| 137 |
| 138 |
/* Output XML data epilogue to stdout */
| 139 |
static void
| 140 |
data_epilogue(void)
| 141 |
| 142 |
puts("\t\t\t</ScatteringData>");
| 143 |
puts("\t\t</WavelengthDataBlock>");
| 144 |
puts("\t</WavelengthData>");
| 145 |
| 146 |
| 147 |
/* Output XML epilogue to stdout */
| 148 |
static void
| 149 |
xml_epilogue(void)
| 150 |
| 151 |
puts("</Layer>");
| 152 |
puts("</Optical>");
| 153 |
puts("</WindowElement>");
| 154 |
| 155 |
| 156 |
/* Load and resample XML BSDF description using Klems basis */
| 157 |
static void
| 158 |
eval_bsdf(const char *fname)
| 159 |
| 160 |
| 161 |
SDData bsd;
| 162 |
SDError ec;
| 163 |
FVECT vin, vout;
| 164 |
SDValue sv;
| 165 |
double sum;
| 166 |
int i, j, n;
| 167 |
| 168 |
SDclearBSDF(&bsd, fname); /* load BSDF file */
| 169 |
if ((ec = SDloadFile(&bsd, fname)) != SDEnone)
| 170 |
goto err;
| 171 |
xml_prologue(&bsd); /* pass geometry */
| 172 |
/* front reflection */
| 173 |
if (bsd.rf != NULL || bsd.rLambFront.cieY > .002) {
| 174 |
input_orient = 1; output_orient = 1;
| 175 |
data_prologue();
| 176 |
for (j = 0; j < abp->nangles; j++) {
| 177 |
for (i = 0; i < abp->nangles; i++) {
| 178 |
sum = 0; /* average over patches */
| 179 |
for (n = npsamps; n-- > 0; ) {
| 180 |
fo_getvec(vout, j+(n+frandom())/npsamps, abp);
| 181 |
fi_getvec(vin, i+urand(n), abp);
| 182 |
ec = SDevalBSDF(&sv, vout, vin, &bsd);
| 183 |
if (ec != SDEnone)
| 184 |
goto err;
| 185 |
sum += sv.cieY;
| 186 |
| 187 |
printf("\t%.3e\n", sum/npsamps);
| 188 |
| 189 |
putchar('\n'); /* extra space between rows */
| 190 |
| 191 |
data_epilogue();
| 192 |
| 193 |
/* back reflection */
| 194 |
if (bsd.rb != NULL || bsd.rLambBack.cieY > .002) {
| 195 |
input_orient = -1; output_orient = -1;
| 196 |
data_prologue();
| 197 |
| 198 |
| 199 |
| 200 |
| 201 |
bo_getvec(vout, j+(n+frandom())/npsamps, abp);
| 202 |
bi_getvec(vin, i+urand(n), abp);
| 203 |
| 204 |
if (ec != SDEnone)
| 205 |
goto err;
| 206 |
sum += sv.cieY;
| 207 |
| 208 |
| 209 |
| 210 |
| 211 |
| 212 |
data_epilogue();
| 213 |
| 214 |
/* front transmission */
| 215 |
if (bsd.tf != NULL || bsd.tLamb.cieY > .002) {
| 216 |
input_orient = 1; output_orient = -1;
| 217 |
data_prologue();
| 218 |
| 219 |
| 220 |
| 221 |
| 222 |
| 223 |
| 224 |
| 225 |
if (ec != SDEnone)
| 226 |
goto err;
| 227 |
sum += sv.cieY;
| 228 |
| 229 |
| 230 |
| 231 |
| 232 |
| 233 |
data_epilogue();
| 234 |
| 235 |
/* back transmission */
| 236 |
if ((bsd.tb != NULL) | (bsd.tf != NULL)) {
| 237 |
input_orient = -1; output_orient = 1;
| 238 |
data_prologue();
| 239 |
| 240 |
| 241 |
| 242 |
| 243 |
| 244 |
| 245 |
| 246 |
if (ec != SDEnone)
| 247 |
goto err;
| 248 |
sum += sv.cieY;
| 249 |
| 250 |
| 251 |
| 252 |
| 253 |
| 254 |
data_epilogue();
| 255 |
| 256 |
SDfreeBSDF(&bsd); /* all done */
| 257 |
return;
| 258 |
err:
| 259 |
SDreportError(ec, stderr);
| 260 |
exit(1);
| 261 |
| 262 |
| 263 |
/* Interpolate and output a BSDF function using Klems basis */
| 264 |
static void
| 265 |
eval_function(char *funame)
| 266 |
| 267 |
| 268 |
int assignD = (fundefined(funame) < 6);
| 269 |
double iovec[6];
| 270 |
double sum;
| 271 |
int i, j, n;
| 272 |
| 273 |
initurand(npsamps);
| 274 |
data_prologue(); /* begin output */
| 275 |
for (j = 0; j < abp->nangles; j++) { /* run through directions */
| 276 |
| 277 |
sum = 0;
| 278 |
for (n = npsamps; n--; ) { /* average over patches */
| 279 |
if (output_orient > 0)
| 280 |
fo_getvec(iovec+3, j+(n+frandom())/npsamps, abp);
| 281 |
else
| 282 |
bo_getvec(iovec+3, j+(n+frandom())/npsamps, abp);
| 283 |
| 284 |
if (input_orient > 0)
| 285 |
fi_getvec(iovec, i+urand(n), abp);
| 286 |
else
| 287 |
bi_getvec(iovec, i+urand(n), abp);
| 288 |
| 289 |
if (assignD) {
| 290 |
varset("Dx", '=', -iovec[3]);
| 291 |
varset("Dy", '=', -iovec[4]);
| 292 |
varset("Dz", '=', -iovec[5]);
| 293 |
++eclock;
| 294 |
| 295 |
sum += funvalue(funame, 6, iovec);
| 296 |
| 297 |
| 298 |
| 299 |
putchar('\n');
| 300 |
| 301 |
data_epilogue(); /* finish output */
| 302 |
| 303 |
| 304 |
/* Interpolate and output a radial basis function BSDF representation */
| 305 |
static void
| 306 |
eval_rbf(void)
| 307 |
| 308 |
| 309 |
float bsdfarr[MAXPATCHES*MAXPATCHES];
| 310 |
FVECT vin, vout;
| 311 |
RBFNODE *rbf;
| 312 |
double sum;
| 313 |
int i, j, n;
| 314 |
/* sanity check */
| 315 |
if (abp->nangles > MAXPATCHES) {
| 316 |
fprintf(stderr, "%s: too many patches!\n", progname);
| 317 |
exit(1);
| 318 |
| 319 |
| 320 |
| 321 |
if (input_orient > 0) /* use incident patch center */
| 322 |
fi_getvec(vin, i+.5*(i>0), abp);
| 323 |
else
| 324 |
bi_getvec(vin, i+.5*(i>0), abp);
| 325 |
| 326 |
rbf = advect_rbf(vin, lobe_lim); /* compute radial basis func */
| 327 |
| 328 |
| 329 |
sum = 0; /* sample over exiting patch */
| 330 |
| 331 |
| 332 |
| 333 |
else
| 334 |
| 335 |
| 336 |
sum += eval_rbfrep(rbf, vout) / vout[2];
| 337 |
| 338 |
bsdfarr[j*abp->nangles + i] = sum*output_orient/npsamps;
| 339 |
| 340 |
if (rbf != NULL)
| 341 |
free(rbf);
| 342 |
| 343 |
n = 0; /* write out our matrix */
| 344 |
| 345 |
| 346 |
printf("\t%.3e\n", bsdfarr[n++]);
| 347 |
putchar('\n');
| 348 |
| 349 |
| 350 |
| 351 |
| 352 |
/* Read in BSDF and interpolate as Klems matrix representation */
| 353 |
int
| 354 |
main(int argc, char *argv[])
| 355 |
| 356 |
int dofwd = 0, dobwd = 1;
| 357 |
char *cp;
| 358 |
int i, na;
| 359 |
| 360 |
progname = argv[0];
| 361 |
esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
| 362 |
esupport &= ~(E_INCHAN|E_OUTCHAN);
| 363 |
scompile("PI:3.14159265358979323846", NULL, 0);
| 364 |
biggerlib();
| 365 |
for (i = 1; i < argc && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
| 366 |
switch (argv[i][1]) { /* get options */
| 367 |
case 'n':
| 368 |
npsamps = atoi(argv[++i]);
| 369 |
if (npsamps <= 0)
| 370 |
goto userr;
| 371 |
break;
| 372 |
case 'e':
| 373 |
scompile(argv[++i], NULL, 0);
| 374 |
single_plane_incident = 0;
| 375 |
break;
| 376 |
case 'f':
| 377 |
if (!argv[i][2]) {
| 378 |
fcompile(argv[++i]);
| 379 |
| 380 |
} else
| 381 |
dofwd = (argv[i][0] == '+');
| 382 |
break;
| 383 |
case 'b':
| 384 |
dobwd = (argv[i][0] == '+');
| 385 |
break;
| 386 |
case 'h':
| 387 |
kbasis = "LBNL/Klems Half";
| 388 |
break;
| 389 |
case 'q':
| 390 |
kbasis = "LBNL/Klems Quarter";
| 391 |
break;
| 392 |
case 'l':
| 393 |
lobe_lim = atoi(argv[++i]);
| 394 |
break;
| 395 |
default:
| 396 |
goto userr;
| 397 |
| 398 |
if (single_plane_incident >= 0) { /* function-based BSDF? */
| 399 |
if (i != argc-1 || fundefined(argv[i]) != 6) {
| 400 |
fprintf(stderr,
| 401 |
"%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
| 402 |
progname);
| 403 |
fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n",
| 404 |
progname);
| 405 |
goto userr;
| 406 |
| 407 |
++eclock;
| 408 |
xml_header(argc, argv); /* start XML output */
| 409 |
xml_prologue(NULL);
| 410 |
if (dofwd) {
| 411 |
input_orient = -1;
| 412 |
output_orient = -1;
| 413 |
eval_function(argv[i]); /* outside reflectance */
| 414 |
output_orient = 1;
| 415 |
eval_function(argv[i]); /* outside -> inside */
| 416 |
| 417 |
if (dobwd) {
| 418 |
input_orient = 1;
| 419 |
output_orient = 1;
| 420 |
eval_function(argv[i]); /* inside reflectance */
| 421 |
output_orient = -1;
| 422 |
eval_function(argv[i]); /* inside -> outside */
| 423 |
| 424 |
xml_epilogue(); /* finish XML output & exit */
| 425 |
return(0);
| 426 |
| 427 |
/* XML input? */
| 428 |
if (i == argc-1 && (cp = argv[i]+strlen(argv[i])-4) > argv[i] &&
| 429 |
!strcasecmp(cp, ".xml")) {
| 430 |
| 431 |
eval_bsdf(argv[i]); /* load & resample BSDF */
| 432 |
| 433 |
return(0);
| 434 |
| 435 |
if (i < argc) { /* open input files if given */
| 436 |
int nbsdf = 0;
| 437 |
for ( ; i < argc; i++) { /* interpolate each component */
| 438 |
FILE *fpin = fopen(argv[i], "rb");
| 439 |
if (fpin == NULL) {
| 440 |
fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
| 441 |
progname, argv[i]);
| 442 |
return(1);
| 443 |
| 444 |
if (!load_bsdf_rep(fpin))
| 445 |
return(1);
| 446 |
fclose(fpin);
| 447 |
if (!nbsdf++) { /* start XML on first dist. */
| 448 |
| 449 |
xml_prologue(NULL);
| 450 |
| 451 |
eval_rbf();
| 452 |
| 453 |
| 454 |
return(0);
| 455 |
| 456 |
SET_FILE_BINARY(stdin); /* load from stdin */
| 457 |
if (!load_bsdf_rep(stdin))
| 458 |
return(1);
| 459 |
| 460 |
xml_prologue(NULL);
| 461 |
eval_rbf(); /* resample dist. */
| 462 |
| 463 |
return(0);
| 464 |
userr:
| 465 |
fprintf(stderr,
| 466 |
"Usage: %s [-n spp][-h|-q][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n", progname);
| 467 |
fprintf(stderr,
| 468 |
" or: %s [-n spp][-h|-q] bsdf_in.xml > bsdf_out.xml\n", progname);
| 469 |
fprintf(stderr,
| 470 |
" or: %s [-n spp][-h|-q][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
| 471 |
progname);
| 472 |
return(1);
| 473 |
