root/Development/ray/src/cv/bsdf2klems.c
Sat Jun 7 05:09:45 2025 UTC (6 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.37: +1 -3 lines
Diff to previous 2.37 , to selected 2.23
Tue Jun 3 21:31:51 2025 UTC (6 months, 4 weeks ago) by greg
Changes since 2.36: +3 -5 lines
Diff to previous 2.36 , to selected 2.23
Fri Feb 23 03:47:57 2024 UTC (22 months, 1 week ago) by greg
Changes since 2.35: +2 -1 lines
Diff to previous 2.35 , to selected 2.23
Wed Jul 26 15:50:03 2023 UTC (2 years, 5 months ago) by greg
Diff to previous 2.34 , to selected 2.23
fix: made it so '+f' works as '+forward' instead of trying to load file
Tue Dec 7 23:55:02 2021 UTC (4 years ago) by greg
Changes since 2.33: +5 -5 lines
Diff to previous 2.33 , to selected 2.23
Sat Mar 27 17:50:18 2021 UTC (4 years, 9 months ago) by greg
Diff to previous 2.32 , to selected 2.23
Fri Nov 13 19:21:11 2020 UTC (5 years, 1 month ago) by greg
Changes since 2.31: +10 -8 lines
Diff to previous 2.31 , to selected 2.23
feat(bsdf2ttree): made it so options/parameters may differ per input SIR
Wed Oct 28 18:54:21 2020 UTC (5 years, 2 months ago) by greg
Diff to previous 2.30 , to selected 2.23
fix(bsdf2klems, bsdf2ttree): increased command-line buffer to accommodate comments in Windows
Mon Oct 26 21:28:18 2020 UTC (5 years, 2 months ago) by greg
Changes since 2.29: +5 -1 lines
Diff to previous 2.29 , to selected 2.23
fix(bsdf2klems, bsdf2ttree): preventing issues on Windows with newlines in commands
Mon Oct 26 21:12:20 2020 UTC (5 years, 2 months ago) by greg
Changes since 2.28: +39 -1 lines
Diff to previous 2.28 , to selected 2.23
feat(bsdf2klems, bsdf2ttree): added XML header comments copying useful information from SIR inputs
Sat Dec 28 18:05:14 2019 UTC (6 years ago) by greg
Changes since 2.27: +1 -3 lines
Diff to previous 2.27 , to selected 2.23
Mon Jun 17 23:58:32 2019 UTC (6 years, 6 months ago) by greg
Changes since 2.26: +71 -65 lines
Diff to previous 2.26 , to selected 2.23
Added incident patch sampling for more accurate result
Tue Mar 19 22:03:24 2019 UTC (6 years, 9 months ago) by greg
Diff to previous 2.25 , to selected 2.23
Increased default -n option to 1024 (was 256)
Fri May 4 23:56:49 2018 UTC (7 years, 8 months ago) by greg
Changes since 2.24: +10 -2 lines
Diff to previous 2.24 , to selected 2.23
Fri Feb 17 22:31:49 2017 UTC (8 years, 10 months ago) by greg
Changes since 2.23: +1 -6 lines
Diff to previous 2.23
Removed unnecessary calls to c_ccvt()
Thu Oct 13 16:59:29 2016 UTC (9 years, 2 months ago) by greg
Changes since 2.22: +4 -4 lines
Diff to previous 2.22
Minor cosmetic fixes
Sun Mar 6 01:13:17 2016 UTC (9 years, 10 months ago) by schorsch
Thu Feb 4 00:45:47 2016 UTC (9 years, 11 months ago) by greg
Changes since 2.20: +25 -24 lines
Minor cleanup and fixes
Wed Feb 3 01:57:06 2016 UTC (9 years, 11 months ago) by greg
Changes since 2.19: +361 -173 lines
Added tristimulus color support for RBF and XML input
Sun Jan 24 14:28:51 2016 UTC (9 years, 11 months ago) by greg
Fixed check for number of arguments to allow 3-argument BSDFs
Wed May 27 11:39:37 2015 UTC (10 years, 7 months ago) by greg
Added missing initialization call
Tue May 5 22:16:49 2015 UTC (10 years, 8 months ago) by greg
Changes since 2.16: +9 -6 lines
Improved progress bar feedback
Wed Oct 1 23:32:42 2014 UTC (11 years, 3 months ago) by greg
CVS Tags: rad4R2P2
Changes since 2.15: +1 -2 lines
Eliminated unnecessary calculation (remnant from previous change)
Thu Aug 21 10:33:48 2014 UTC (11 years, 4 months ago) by greg
CVS Tags: rad4R2P1
Wed Mar 12 22:24:59 2014 UTC (11 years, 9 months ago) by greg
CVS Tags: rad4R2
Changes since 2.13: +13 -3 lines
Changed progress bar to erase itself when done
Wed Mar 12 21:15:31 2014 UTC (11 years, 9 months ago) by greg
Changes since 2.12: +51 -8 lines
Disabled DEBUG statements in BSDF programs and added progress bars
Thu Nov 21 20:09:06 2013 UTC (12 years, 1 month ago) by greg
Changes since 2.11: +4 -3 lines
Changed secant correction to patch centers for better normalization
Sat Nov 9 05:47:49 2013 UTC (12 years, 1 month ago) by greg
Thu Sep 26 17:05:00 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.9: +8 -3 lines
Added -l option to limit maximum number of RBF lobes for interpolation
Sun Aug 11 14:32:34 2013 UTC (12 years, 4 months ago) by greg
Changes since 2.8: +12 -39 lines
Eliminated matrix transpose, which wasn't working anyway
Fri Aug 2 20:56:19 2013 UTC (12 years, 5 months ago) by greg
Changes since 2.7: +11 -1 lines
Added ability to use Dx, Dy and Dz instead of last 3 function parameters
Thu Aug 1 16:10:13 2013 UTC (12 years, 5 months ago) by greg
Changes since 2.6: +39 -12 lines
Added code to emit front/back transmission if missing on XML input
Sat Jun 29 21:03:25 2013 UTC (12 years, 6 months ago) by greg
Thu Apr 25 03:14:52 2013 UTC (12 years, 8 months ago) by greg
Changes since 2.4: +5 -5 lines
Fixed same correlated sampling problem for XML input
Thu Apr 25 03:12:08 2013 UTC (12 years, 8 months ago) by greg
Changes since 2.3: +6 -5 lines
Fixed correlated sampling problem for functional BSDFs
Tue Apr 23 23:19:09 2013 UTC (12 years, 8 months ago) by greg
Changes since 2.2: +45 -22 lines
Tue Apr 23 04:40:23 2013 UTC (12 years, 8 months ago) by greg
Changes since 2.1: +47 -11 lines
Untested implementation of Klems conversion from radial basis function
Sun Apr 21 23:01:14 2013 UTC (12 years, 8 months ago) by greg
Diff to selected 2.23
