--- ray/src/cv/bsdf2klems.c 2013/11/21 20:09:06 2.12 +++ ray/src/cv/bsdf2klems.c 2014/03/12 21:15:31 2.13 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf2klems.c,v 2.12 2013/11/21 20:09:06 greg Exp $"; +static const char RCSid[] = "$Id: bsdf2klems.c,v 2.13 2014/03/12 21:15:31 greg Exp $"; #endif /* * Load measured BSDF interpolant and write out as XML file with Klems matrix. @@ -27,9 +27,38 @@ static const char *kbasis = "LBNL/Klems Full"; static int npsamps = 256; /* limit on number of RBF lobes */ static int lobe_lim = 15000; + /* progress bar length */ +static int do_prog = 79; + +/* Start new progress bar */ +#define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else + +/* Draw progress bar of the appropriate length */ +static void +prog_show(double frac) +{ + char pbar[256]; + int nchars; + + if (do_prog <= 0) return; + if (do_prog > sizeof(pbar)-2) + do_prog = sizeof(pbar)-2; + if (frac < 0) frac = 0; + else if (frac > 1) frac = 1; + nchars = do_prog*frac + .5; + pbar[0] = '\r'; + memset(pbar+1, '*', nchars); + memset(pbar+1+nchars, '-', do_prog-nchars); + pbar[do_prog+1] = '\0'; + fputs(pbar, stderr); +} + +/* Finish progress bar */ +#define prog_done() if (do_prog) fputc('\n',stderr); else + /* Return angle basis corresponding to the given name */ -ANGLE_BASIS * +static ANGLE_BASIS * get_basis(const char *bn) { int n = nabases; @@ -297,8 +326,10 @@ eval_function(char *funame) printf("\t%.3e\n", sum/npsamps); } putchar('\n'); + prog_show((j+1.)/abp->nangles); } data_epilogue(); /* finish output */ + prog_done(); } /* Interpolate and output a radial basis function BSDF representation */ @@ -340,6 +371,7 @@ eval_rbf(void) } if (rbf != NULL) free(rbf); + prog_show((i+1.)/abp->nangles); } n = 0; /* write out our matrix */ for (j = 0; j < abp->nangles; j++) { @@ -348,6 +380,7 @@ eval_rbf(void) putchar('\n'); } data_epilogue(); /* finish output */ + prog_done(); } /* Read in BSDF and interpolate as Klems matrix representation */ @@ -393,6 +426,9 @@ main(int argc, char *argv[]) case 'l': lobe_lim = atoi(argv[++i]); break; + case 'p': + do_prog = atoi(argv[i]+2); + break; default: goto userr; } @@ -401,8 +437,7 @@ main(int argc, char *argv[]) fprintf(stderr, "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n", progname); - fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n", - progname); + fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n"); goto userr; } ++eclock; @@ -411,16 +446,20 @@ main(int argc, char *argv[]) if (dofwd) { input_orient = -1; output_orient = -1; - eval_function(argv[i]); /* outside reflectance */ + prog_start("Evaluating outside reflectance"); + eval_function(argv[i]); output_orient = 1; - eval_function(argv[i]); /* outside -> inside */ + prog_start("Evaluating outside->inside transmission"); + eval_function(argv[i]); } if (dobwd) { input_orient = 1; output_orient = 1; - eval_function(argv[i]); /* inside reflectance */ + prog_start("Evaluating inside reflectance"); + eval_function(argv[i]); output_orient = -1; - eval_function(argv[i]); /* inside -> outside */ + prog_start("Evaluating inside->outside transmission"); + eval_function(argv[i]); } xml_epilogue(); /* finish XML output & exit */ return(0); @@ -436,6 +475,7 @@ main(int argc, char *argv[]) if (i < argc) { /* open input files if given */ int nbsdf = 0; for ( ; i < argc; i++) { /* interpolate each component */ + char pbuf[256]; FILE *fpin = fopen(argv[i], "rb"); if (fpin == NULL) { fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n", @@ -449,6 +489,8 @@ main(int argc, char *argv[]) xml_header(argc, argv); xml_prologue(NULL); } + sprintf(pbuf, "Interpolating component '%s'", argv[i]); + prog_start(pbuf); eval_rbf(); } xml_epilogue(); /* finish XML output & exit */ @@ -459,6 +501,7 @@ main(int argc, char *argv[]) return(1); xml_header(argc, argv); /* start XML output */ xml_prologue(NULL); + prog_start("Interpolating from standard input"); eval_rbf(); /* resample dist. */ xml_epilogue(); /* finish XML output & exit */ return(0);
