--- ray/src/cv/bsdf2klems.c 2013/09/26 17:05:00 2.10 +++ ray/src/cv/bsdf2klems.c 2015/05/05 22:16:49 2.17 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf2klems.c,v 2.10 2013/09/26 17:05:00 greg Exp $"; +static const char RCSid[] = "$Id: bsdf2klems.c,v 2.17 2015/05/05 22:16:49 greg Exp $"; #endif /* * Load measured BSDF interpolant and write out as XML file with Klems matrix. @@ -27,9 +27,51 @@ static const char *kbasis = "LBNL/Klems Full"; static int npsamps = 256; /* limit on number of RBF lobes */ static int lobe_lim = 15000; + /* progress bar length */ +static int do_prog = 79; + +/* Start new progress bar */ +#define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else + +/* Draw progress bar of the appropriate length */ +static void +prog_show(double frac) +{ + static unsigned call_cnt = 0; + static char lastc[] = "-\\|/"; + char pbar[256]; + int nchars; + + if (do_prog <= 1) return; + if (do_prog > sizeof(pbar)-2) + do_prog = sizeof(pbar)-2; + if (frac < 0) frac = 0; + else if (frac >= 1) frac = .9999; + nchars = do_prog*frac; + pbar[0] = '\r'; + memset(pbar+1, '*', nchars); + pbar[nchars+1] = lastc[call_cnt++ & 3]; + memset(pbar+2+nchars, '-', do_prog-nchars-1); + pbar[do_prog+1] = '\0'; + fputs(pbar, stderr); +} + +/* Finish progress bar */ +static void +prog_done(void) +{ + int n = do_prog; + + if (n <= 1) return; + fputc('\r', stderr); + while (n--) + fputc(' ', stderr); + fputc('\r', stderr); +} + /* Return angle basis corresponding to the given name */ -ANGLE_BASIS * +static ANGLE_BASIS * get_basis(const char *bn) { int n = nabases; @@ -58,8 +100,10 @@ xml_header(int ac, char *av[]) static void xml_prologue(const SDData *sd) { - const char *matn = (sd && sd->matn[0]) ? sd->matn : "Name"; - const char *makr = (sd && sd->makr[0]) ? sd->makr : "Manufacturer"; + const char *matn = (sd && sd->matn[0]) ? sd->matn : + bsdf_name[0] ? bsdf_name : "Unknown"; + const char *makr = (sd && sd->makr[0]) ? sd->makr : + bsdf_manuf[0] ? bsdf_manuf : "Unknown"; ANGLE_BASIS *abp = get_basis(kbasis); int i; @@ -295,8 +339,10 @@ eval_function(char *funame) printf("\t%.3e\n", sum/npsamps); } putchar('\n'); + prog_show((j+1.)/abp->nangles); } data_epilogue(); /* finish output */ + prog_done(); } /* Interpolate and output a radial basis function BSDF representation */ @@ -331,12 +377,13 @@ eval_rbf(void) else bo_getvec(vout, j+(n+frandom())/npsamps, abp); - sum += eval_rbfrep(rbf, vout) / vout[2]; + sum += eval_rbfrep(rbf, vout); } - bsdfarr[j*abp->nangles + i] = sum*output_orient/npsamps; + bsdfarr[j*abp->nangles + i] = sum / (double)npsamps; } if (rbf != NULL) free(rbf); + prog_show((i+1.)/abp->nangles); } n = 0; /* write out our matrix */ for (j = 0; j < abp->nangles; j++) { @@ -345,6 +392,7 @@ eval_rbf(void) putchar('\n'); } data_epilogue(); /* finish output */ + prog_done(); } /* Read in BSDF and interpolate as Klems matrix representation */ @@ -390,6 +438,9 @@ main(int argc, char *argv[]) case 'l': lobe_lim = atoi(argv[++i]); break; + case 'p': + do_prog = atoi(argv[i]+2); + break; default: goto userr; } @@ -398,8 +449,7 @@ main(int argc, char *argv[]) fprintf(stderr, "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n", progname); - fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n", - progname); + fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n"); goto userr; } ++eclock; @@ -408,16 +458,20 @@ main(int argc, char *argv[]) if (dofwd) { input_orient = -1; output_orient = -1; - eval_function(argv[i]); /* outside reflectance */ + prog_start("Evaluating outside reflectance"); + eval_function(argv[i]); output_orient = 1; - eval_function(argv[i]); /* outside -> inside */ + prog_start("Evaluating outside->inside transmission"); + eval_function(argv[i]); } if (dobwd) { input_orient = 1; output_orient = 1; - eval_function(argv[i]); /* inside reflectance */ + prog_start("Evaluating inside reflectance"); + eval_function(argv[i]); output_orient = -1; - eval_function(argv[i]); /* inside -> outside */ + prog_start("Evaluating inside->outside transmission"); + eval_function(argv[i]); } xml_epilogue(); /* finish XML output & exit */ return(0); @@ -433,6 +487,7 @@ main(int argc, char *argv[]) if (i < argc) { /* open input files if given */ int nbsdf = 0; for ( ; i < argc; i++) { /* interpolate each component */ + char pbuf[256]; FILE *fpin = fopen(argv[i], "rb"); if (fpin == NULL) { fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n", @@ -446,6 +501,8 @@ main(int argc, char *argv[]) xml_header(argc, argv); xml_prologue(NULL); } + sprintf(pbuf, "Interpolating component '%s'", argv[i]); + prog_start(pbuf); eval_rbf(); } xml_epilogue(); /* finish XML output & exit */ @@ -456,6 +513,7 @@ main(int argc, char *argv[]) return(1); xml_header(argc, argv); /* start XML output */ xml_prologue(NULL); + prog_start("Interpolating from standard input"); eval_rbf(); /* resample dist. */ xml_epilogue(); /* finish XML output & exit */ return(0);
