root/radiance/ray/src/cv/bsdf2klems.c
Revision: 2.38
Committed: Sat Jun 7 05:09:45 2025 UTC (3 weeks, 1 day ago) by greg
Changes since 2.37: +1 -3 lines
2 static const char RCSid[] = "$Id: bsdf2klems.c,v 2.37 2025/06/03 21:31:51 greg Exp $";
5 * Load measured BSDF interpolant and write out as XML file with Klems matrix.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdlib.h>
12 #include <math.h>
13 #include <ctype.h>
14 #include "random.h"
15 #include "rtio.h"
16 #include "calcomp.h"
17 #include "bsdfrep.h"
18 #include "bsdf_m.h"
19 /* tristimulus components */
20 enum {CIE_X, CIE_Y, CIE_Z};
21 /* assumed maximum # Klems patches */
22 #define MAXPATCHES 145
23 /* selected basis function name */
24 static const char klems_full[] = "LBNL/Klems Full";
25 static const char klems_half[] = "LBNL/Klems Half";
26 static const char klems_quarter[] = "LBNL/Klems Quarter";
27 static const char *kbasis = klems_full;
28 /* number of BSDF samples per patch */
29 static int npsamps = 1024;
30 /* limit on number of RBF lobes */
31 static int lobe_lim = 15000;
32 /* progress bar length */
33 static int do_prog = 79;
34
35 #define MAXCARG 512 /* wrapBSDF command */
36 static char *wrapBSDF[MAXCARG] = {"wrapBSDF", "-W", "-UU"};
37 static int wbsdfac = 3;
38
39 /* Add argument to wrapBSDF, allocating space if !isstatic */
40 static void
41 add_wbsdf(const char *arg, int isstatic)
42 {
43 if (arg == NULL)
44 return;
45 if (wbsdfac >= MAXCARG-1) {
46 fputs(progname, stderr);
47 fputs(": too many command arguments to wrapBSDF\n", stderr);
48 exit(1);
49 }
50 if (!*arg)
51 arg = "";
52 else if (!isstatic)
53 arg = savqstr((char *)arg);
54
55 wrapBSDF[wbsdfac++] = (char *)arg;
56 }
57
58 /* Start new progress bar */
59 #define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else
60
61 /* Draw progress bar of the appropriate length */
62 static void
63 prog_show(double frac)
64 {
65 static unsigned call_cnt = 0;
66 static char lastc[] = "-\\|/";
67 char pbar[256];
68 int nchars;
69
70 if (do_prog <= 1) return;
71 if (do_prog > sizeof(pbar)-2)
72 do_prog = sizeof(pbar)-2;
73 if (frac < 0) frac = 0;
74 else if (frac >= 1) frac = .9999;
75 nchars = do_prog*frac;
76 pbar[0] = '\r';
77 memset(pbar+1, '*', nchars);
78 pbar[nchars+1] = lastc[call_cnt++ & 3];
79 memset(pbar+2+nchars, '-', do_prog-nchars-1);
80 pbar[do_prog+1] = '\0';
81 fputs(pbar, stderr);
82 }
83
84 /* Finish progress bar */
85 static void
86 prog_done(void)
87 {
88 int n = do_prog;
89
90 if (n <= 1) return;
91 fputc('\r', stderr);
92 while (n--)
93 fputc(' ', stderr);
94 fputc('\r', stderr);
95 }
96
97 /* Return angle basis corresponding to the given name */
98 static ANGLE_BASIS *
99 get_basis(const char *bn)
100 {
101 int n = nabases;
102
103 while (n-- > 0)
104 if (!strcasecmp(bn, abase_list[n].name))
105 return &abase_list[n];
106 return NULL;
107 }
108
109 /* Copy geometry string to file for wrapBSDF */
110 static char *
111 save_geom(const char *mgf)
112 {
113 char *tfname = mktemp(savqstr(TEMPLATE));
114 int fd = open(tfname, O_CREAT|O_WRONLY, 0600);
115
116 if (fd < 0)
117 return(NULL);
118 write(fd, mgf, strlen(mgf));
119 close(fd);
120 add_wbsdf("-g", 1);
121 add_wbsdf(tfname, 1);
122 return(tfname);
123 }
124
125 /* Open XYZ component file for output and add appropriate arguments */
126 static FILE *
127 open_component_file(int c)
128 {
129 static const char sname[3][6] = {"CIE-X", "CIE-Y", "CIE-Z"};
130 static const char cname[4][4] = {"-rf", "-tf", "-tb", "-rb"};
131 char *tfname = mktemp(savqstr(TEMPLATE));
132 FILE *fp = fopen(tfname, "w");
133
134 if (fp == NULL) {
135 fprintf(stderr, "%s: cannot open '%s' for writing\n",
136 progname, tfname);
137 exit(1);
138 }
139 add_wbsdf("-s", 1); add_wbsdf(sname[c], 1);
140 add_wbsdf(cname[(input_orient>0)<<1 | (output_orient>0)], 1);
141 add_wbsdf(tfname, 1);
142 return(fp);
143 }
144
145 /* Load and resample XML BSDF description using Klems basis */
146 static void
147 eval_bsdf(const char *fname)
148 {
149 ANGLE_BASIS *abp = get_basis(kbasis);
150 FILE *cfp[3];
151 SDData bsd;
152 SDError ec;
153 FVECT vin, vout;
154 SDValue sdv;
155 double sum, xsum, ysum;
156 int i, j, n;
157
158 initurand(npsamps);
159 SDclearBSDF(&bsd, fname); /* load BSDF file */
160 if ((ec = SDloadFile(&bsd, fname)) != SDEnone)
161 goto err;
162 if (bsd.mgf != NULL) /* save geometry */
163 save_geom(bsd.mgf);
164 if (bsd.matn[0]) /* save identifier(s) */
165 strcpy(bsdf_name, bsd.matn);
166 if (bsd.makr[0])
167 strcpy(bsdf_manuf, bsd.makr);
168 if (bsd.dim[2] > 0) { /* save dimension(s) */
169 char buf[64];
170 if ((bsd.dim[0] > 0) & (bsd.dim[1] > 0))
171 sprintf(buf, "w=%g;h=%g;t=%g",
172 bsd.dim[0], bsd.dim[1], bsd.dim[2]);
173 else
174 sprintf(buf, "t=%g", bsd.dim[2]);
175 add_wbsdf("-f", 1);
176 add_wbsdf(buf, 0);
177 }
178 /* front reflection */
179 if (bsd.rf != NULL || bsd.rLambFront.cieY > .002) {
180 input_orient = 1; output_orient = 1;
181 cfp[CIE_Y] = open_component_file(CIE_Y);
182 if (bsd.rf != NULL && bsd.rf->comp[0].cspec[2].flags) {
183 rbf_colorimetry = RBCtristimulus;
184 cfp[CIE_X] = open_component_file(CIE_X);
185 cfp[CIE_Z] = open_component_file(CIE_Z);
186 } else
187 rbf_colorimetry = RBCphotopic;
188 for (j = 0; j < abp->nangles; j++) {
189 for (i = 0; i < abp->nangles; i++) {
190 sum = 0; /* average over patches */
191 xsum = ysum = 0;
192 for (n = npsamps; n-- > 0; ) {
193 fo_getvec(vout, j+(n+frandom())/npsamps, abp);
194 fi_getvec(vin, i+urand(n), abp);
195 ec = SDevalBSDF(&sdv, vin, vout, &bsd);
196 if (ec != SDEnone)
197 goto err;
198 sum += sdv.cieY;
199 if (rbf_colorimetry == RBCtristimulus) {
200 xsum += sdv.cieY * sdv.spec.cx;
201 ysum += sdv.cieY * sdv.spec.cy;
202 }
203 }
204 fprintf(cfp[CIE_Y], "\t%.3e\n", sum/npsamps);
205 if (rbf_colorimetry == RBCtristimulus) {
206 fprintf(cfp[CIE_X], "\t%.3e\n", xsum*sum/(npsamps*ysum));
207 fprintf(cfp[CIE_Z], "\t%.3e\n",
208 (sum - xsum - ysum)*sum/(npsamps*ysum));
209 }
210 }
211 fputc('\n', cfp[CIE_Y]); /* extra space between rows */
212 if (rbf_colorimetry == RBCtristimulus) {
213 fputc('\n', cfp[CIE_X]);
214 fputc('\n', cfp[CIE_Z]);
215 }
216 }
217 if (fclose(cfp[CIE_Y])) {
218 fprintf(stderr, "%s: error writing Y output\n", progname);
219 exit(1);
220 }
221 if (rbf_colorimetry == RBCtristimulus &&
222 (fclose(cfp[CIE_X]) || fclose(cfp[CIE_Z]))) {
223 fprintf(stderr, "%s: error writing X/Z output\n", progname);
224 exit(1);
225 }
226 }
227 /* back reflection */
228 if (bsd.rb != NULL || bsd.rLambBack.cieY > .002) {
229 input_orient = -1; output_orient = -1;
230 cfp[CIE_Y] = open_component_file(CIE_Y);
231 if (bsd.rb != NULL && bsd.rb->comp[0].cspec[2].flags) {
232 rbf_colorimetry = RBCtristimulus;
233 cfp[CIE_X] = open_component_file(CIE_X);
234 cfp[CIE_Z] = open_component_file(CIE_Z);
235 } else
236 rbf_colorimetry = RBCphotopic;
237 for (j = 0; j < abp->nangles; j++) {
238 for (i = 0; i < abp->nangles; i++) {
239 sum = 0; /* average over patches */
240 xsum = ysum = 0;
241 for (n = npsamps; n-- > 0; ) {
242 bo_getvec(vout, j+(n+frandom())/npsamps, abp);
243 bi_getvec(vin, i+urand(n), abp);
244 ec = SDevalBSDF(&sdv, vin, vout, &bsd);
245 if (ec != SDEnone)
246 goto err;
247 sum += sdv.cieY;
248 if (rbf_colorimetry == RBCtristimulus) {
249 xsum += sdv.cieY * sdv.spec.cx;
250 ysum += sdv.cieY * sdv.spec.cy;
251 }
252 }
253 fprintf(cfp[CIE_Y], "\t%.3e\n", sum/npsamps);
254 if (rbf_colorimetry == RBCtristimulus) {
255 fprintf(cfp[CIE_X], "\t%.3e\n", xsum*sum/(npsamps*ysum));
256 fprintf(cfp[CIE_Z], "\t%.3e\n",
257 (sum - xsum - ysum)*sum/(npsamps*ysum));
258 }
259 }
260 if (rbf_colorimetry == RBCtristimulus) {
261 fputc('\n', cfp[CIE_X]);
262 fputc('\n', cfp[CIE_Z]);
263 }
264 }
265 if (fclose(cfp[CIE_Y])) {
266 fprintf(stderr, "%s: error writing Y output\n", progname);
267 exit(1);
268 }
269 if (rbf_colorimetry == RBCtristimulus &&
270 (fclose(cfp[CIE_X]) || fclose(cfp[CIE_Z]))) {
271 fprintf(stderr, "%s: error writing X/Z output\n", progname);
272 exit(1);
273 }
274 }
275 /* front transmission */
276 if (bsd.tf != NULL || bsd.tLambFront.cieY > .002) {
277 input_orient = 1; output_orient = -1;
278 cfp[CIE_Y] = open_component_file(CIE_Y);
279 if (bsd.tf != NULL && bsd.tf->comp[0].cspec[2].flags) {
280 rbf_colorimetry = RBCtristimulus;
281 cfp[CIE_X] = open_component_file(CIE_X);
282 cfp[CIE_Z] = open_component_file(CIE_Z);
283 } else
284 rbf_colorimetry = RBCphotopic;
285 for (j = 0; j < abp->nangles; j++) {
286 for (i = 0; i < abp->nangles; i++) {
287 sum = 0; /* average over patches */
288 xsum = ysum = 0;
289 for (n = npsamps; n-- > 0; ) {
290 bo_getvec(vout, j+(n+frandom())/npsamps, abp);
291 fi_getvec(vin, i+urand(n), abp);
292 ec = SDevalBSDF(&sdv, vin, vout, &bsd);
293 if (ec != SDEnone)
294 goto err;
295 sum += sdv.cieY;
296 if (rbf_colorimetry == RBCtristimulus) {
297 xsum += sdv.cieY * sdv.spec.cx;
298 ysum += sdv.cieY * sdv.spec.cy;
299 }
300 }
301 fprintf(cfp[CIE_Y], "\t%.3e\n", sum/npsamps);
302 if (rbf_colorimetry == RBCtristimulus) {
303 fprintf(cfp[CIE_X], "\t%.3e\n", xsum*sum/(npsamps*ysum));
304 fprintf(cfp[CIE_Z], "\t%.3e\n",
305 (sum - xsum - ysum)*sum/(npsamps*ysum));
306 }
307 }
308 if (rbf_colorimetry == RBCtristimulus) {
309 fputc('\n', cfp[CIE_X]);
310 fputc('\n', cfp[CIE_Z]);
311 }
312 }
313 if (fclose(cfp[CIE_Y])) {
314 fprintf(stderr, "%s: error writing Y output\n", progname);
315 exit(1);
316 }
317 if (rbf_colorimetry == RBCtristimulus &&
318 (fclose(cfp[CIE_X]) || fclose(cfp[CIE_Z]))) {
319 fprintf(stderr, "%s: error writing X/Z output\n", progname);
320 exit(1);
321 }
322 }
323 /* back transmission */
324 if ((bsd.tb != NULL) | (bsd.tf != NULL)) {
325 input_orient = -1; output_orient = 1;
326 cfp[CIE_Y] = open_component_file(CIE_Y);
327 if (bsd.tb != NULL)
328 rbf_colorimetry = bsd.tb->comp[0].cspec[2].flags
329 ? RBCtristimulus : RBCphotopic ;
330 if (rbf_colorimetry == RBCtristimulus) {
331 cfp[CIE_X] = open_component_file(CIE_X);
332 cfp[CIE_Z] = open_component_file(CIE_Z);
333 }
334 for (j = 0; j < abp->nangles; j++) {
335 for (i = 0; i < abp->nangles; i++) {
336 sum = 0; /* average over patches */
337 xsum = ysum = 0;
338 for (n = npsamps; n-- > 0; ) {
339 fo_getvec(vout, j+(n+frandom())/npsamps, abp);
340 bi_getvec(vin, i+urand(n), abp);
341 ec = SDevalBSDF(&sdv, vin, vout, &bsd);
342 if (ec != SDEnone)
343 goto err;
344 sum += sdv.cieY;
345 if (rbf_colorimetry == RBCtristimulus) {
346 xsum += sdv.cieY * sdv.spec.cx;
347 ysum += sdv.cieY * sdv.spec.cy;
348 }
349 }
350 fprintf(cfp[CIE_Y], "\t%.3e\n", sum/npsamps);
351 if (rbf_colorimetry == RBCtristimulus) {
352 fprintf(cfp[CIE_X], "\t%.3e\n", xsum*sum/(npsamps*ysum));
353 fprintf(cfp[CIE_Z], "\t%.3e\n",
354 (sum - xsum - ysum)*sum/(npsamps*ysum));
355 }
356 }
357 if (rbf_colorimetry == RBCtristimulus) {
358 fputc('\n', cfp[CIE_X]);
359 fputc('\n', cfp[CIE_Z]);
360 }
361 }
362 if (fclose(cfp[CIE_Y])) {
363 fprintf(stderr, "%s: error writing Y output\n", progname);
364 exit(1);
365 }
366 if (rbf_colorimetry == RBCtristimulus &&
367 (fclose(cfp[CIE_X]) || fclose(cfp[CIE_Z]))) {
368 fprintf(stderr, "%s: error writing X/Z output\n", progname);
369 exit(1);
370 }
371 }
372 SDfreeBSDF(&bsd); /* all done */
373 return;
374 err:
375 SDreportError(ec, stderr);
376 exit(1);
377 }
378
379 /* Interpolate and output a BSDF function using Klems basis */
380 static void
381 eval_function(char *funame)
382 {
383 ANGLE_BASIS *abp = get_basis(kbasis);
384 int assignD = (fundefined(funame) < 6);
385 FILE *ofp = open_component_file(CIE_Y);
386 double iovec[6];
387 double sum;
388 int i, j, n;
389
390 initurand(npsamps);
391 for (j = 0; j < abp->nangles; j++) { /* run through directions */
392 for (i = 0; i < abp->nangles; i++) {
393 sum = 0;
394 for (n = npsamps; n--; ) { /* average over patches */
395 if (output_orient > 0)
396 fo_getvec(iovec+3, j+(n+frandom())/npsamps, abp);
397 else
398 bo_getvec(iovec+3, j+(n+frandom())/npsamps, abp);
399
400 if (input_orient > 0)
401 fi_getvec(iovec, i+urand(n), abp);
402 else
403 bi_getvec(iovec, i+urand(n), abp);
404
405 if (assignD) {
406 varset("Dx", '=', -iovec[3]);
407 varset("Dy", '=', -iovec[4]);
408 varset("Dz", '=', -iovec[5]);
409 ++eclock;
410 }
411 sum += funvalue(funame, 6, iovec);
412 }
413 fprintf(ofp, "\t%.3e\n", sum/npsamps);
414 }
415 fputc('\n', ofp);
416 prog_show((j+1.)/abp->nangles);
417 }
418 prog_done();
419 if (fclose(ofp)) {
420 fprintf(stderr, "%s: error writing Y output\n", progname);
421 exit(1);
422 }
423 }
424
425 /* Interpolate and output a radial basis function BSDF representation */
426 static void
427 eval_rbf(void)
428 {
429 ANGLE_BASIS *abp = get_basis(kbasis);
430 float (*XZarr)[2] = NULL;
431 float bsdfarr[MAXPATCHES*MAXPATCHES];
432 FILE *cfp[3];
433 FVECT vin, vout;
434 double sum, xsum, ysum, normf;
435 int i, j, ni, no, nisamps, nosamps;
436 /* sanity check */
437 if (abp->nangles > MAXPATCHES) {
438 fprintf(stderr, "%s: too many patches!\n", progname);
439 exit(1);
440 }
441 memset(bsdfarr, 0, sizeof(bsdfarr));
442 if (rbf_colorimetry == RBCtristimulus)
443 XZarr = (float (*)[2])calloc(abp->nangles*abp->nangles, 2*sizeof(float));
444 nosamps = (int)(pow((double)npsamps, 0.67) + .5);
445 nisamps = (npsamps + (nosamps>>1)) / nosamps;
446 normf = 1./(double)(nisamps*nosamps);
447 for (i = 0; i < abp->nangles; i++) {
448 for (ni = nisamps; ni--; ) { /* sample over incident patch */
449 RBFNODE *rbf;
450 if (input_orient > 0) /* vary incident patch loc. */
451 fi_getvec(vin, i+urand(ni), abp);
452 else
453 bi_getvec(vin, i+urand(ni), abp);
454
455 rbf = advect_rbf(vin, lobe_lim); /* compute radial basis func */
456
457 for (j = 0; j < abp->nangles; j++) {
458 sum = 0; /* sample over exiting patch */
459 xsum = ysum = 0;
460 for (no = nosamps; no--; ) {
461 SDValue sdv;
462 if (output_orient > 0)
463 fo_getvec(vout, j+(no+frandom())/nosamps, abp);
464 else
465 bo_getvec(vout, j+(no+frandom())/nosamps, abp);
466
467 eval_rbfcol(&sdv, rbf, vout);
468 sum += sdv.cieY;
469 if (rbf_colorimetry == RBCtristimulus) {
470 xsum += sdv.cieY * sdv.spec.cx;
471 ysum += sdv.cieY * sdv.spec.cy;
472 }
473 }
474 no = j*abp->nangles + i;
475 bsdfarr[no] += sum * normf;
476 if (rbf_colorimetry == RBCtristimulus) {
477 XZarr[no][0] += xsum*sum*normf/ysum;
478 XZarr[no][1] += (sum - xsum - ysum)*sum*normf/ysum;
479 }
480 }
481 if (rbf != NULL)
482 free(rbf);
483 }
484 prog_show((i+1.)/abp->nangles);
485 }
486 /* write out our matrix */
487 cfp[CIE_Y] = open_component_file(CIE_Y);
488 no = 0;
489 for (j = 0; j < abp->nangles; j++) {
490 for (i = 0; i < abp->nangles; i++, no++)
491 fprintf(cfp[CIE_Y], "\t%.3e\n", bsdfarr[no]);
492 fputc('\n', cfp[CIE_Y]);
493 }
494 prog_done();
495 if (fclose(cfp[CIE_Y])) {
496 fprintf(stderr, "%s: error writing Y output\n", progname);
497 exit(1);
498 }
499 if (XZarr == NULL) /* no color? */
500 return;
501 cfp[CIE_X] = open_component_file(CIE_X);
502 cfp[CIE_Z] = open_component_file(CIE_Z);
503 no = 0;
504 for (j = 0; j < abp->nangles; j++) {
505 for (i = 0; i < abp->nangles; i++, no++) {
506 fprintf(cfp[CIE_X], "\t%.3e\n", XZarr[no][0]);
507 fprintf(cfp[CIE_Z], "\t%.3e\n", XZarr[no][1]);
508 }
509 fputc('\n', cfp[CIE_X]);
510 fputc('\n', cfp[CIE_Z]);
511 }
512 free(XZarr);
513 if (fclose(cfp[CIE_X]) || fclose(cfp[CIE_Z])) {
514 fprintf(stderr, "%s: error writing X/Z output\n", progname);
515 exit(1);
516 }
517 }
518
519 #if defined(_WIN32) || defined(_WIN64)
520 /* Execute wrapBSDF command (may never return) */
521 static int
522 wrap_up(void)
523 {
524 char cmd[32700];
525
526 if (bsdf_manuf[0]) {
527 add_wbsdf("-f", 1);
528 strcpy(cmd, "m=");
529 strcpy(cmd+2, bsdf_manuf);
530 add_wbsdf(cmd, 0);
531 }
532 if (bsdf_name[0]) {
533 add_wbsdf("-f", 1);
534 strcpy(cmd, "n=");
535 strcpy(cmd+2, bsdf_name);
536 add_wbsdf(cmd, 0);
537 }
538 if (!convert_commandline(cmd, sizeof(cmd), wrapBSDF)) {
539 fputs(progname, stderr);
540 fputs(": command line too long in wrap_up()\n", stderr);
541 return(1);
542 }
543 return(system(cmd));
544 }
545 #else
546 /* Execute wrapBSDF command (may never return) */
547 static int
548 wrap_up(void)
549 {
550 char buf[256];
551 char *compath = getpath((char *)wrapBSDF[0], getenv("PATH"), X_OK);
552
553 if (compath == NULL) {
554 fprintf(stderr, "%s: cannot locate %s\n", progname, wrapBSDF[0]);
555 return(1);
556 }
557 if (bsdf_manuf[0]) {
558 add_wbsdf("-f", 1);
559 strcpy(buf, "m=");
560 strcpy(buf+2, bsdf_manuf);
561 add_wbsdf(buf, 0);
562 }
563 if (bsdf_name[0]) {
564 add_wbsdf("-f", 1);
565 strcpy(buf, "n=");
566 strcpy(buf+2, bsdf_name);
567 add_wbsdf(buf, 0);
568 }
569 execv(compath, wrapBSDF); /* successful call never returns */
570 perror(compath);
571 return(1);
572 }
573 #endif
574
575 #define HEAD_BUFLEN 10240
576 static char head_buf[HEAD_BUFLEN];
577 static int cur_headlen = 0;
578
579 /* Record header line as comment associated with this SIR input */
580 static int
581 record2header(char *s)
582 {
583 int len = strlen(s);
584
585 if (cur_headlen+len >= HEAD_BUFLEN-6)
586 return(0);
587 /* includes EOL */
588 strcpy(head_buf+cur_headlen, s);
589 cur_headlen += len;
590
591 #if defined(_WIN32) || defined(_WIN64)
592 if (head_buf[cur_headlen-1] == '\n')
593 head_buf[cur_headlen-1] = '\t';
594 #endif
595 return(1);
596 }
597
598 /* Finish off header for this file */
599 static void
600 done_header(void)
601 {
602 while (cur_headlen > 0 && isspace(head_buf[cur_headlen-1]))
603 --cur_headlen;
604 head_buf[cur_headlen] = '\0';
605 if (!cur_headlen)
606 return;
607 add_wbsdf("-C", 1);
608 add_wbsdf(head_buf, 0);
609 head_buf[cur_headlen=0] = '\0';
610 }
611
612 /* Read in BSDF and interpolate as Klems matrix representation */
613 int
614 main(int argc, char *argv[])
615 {
616 int dofwd = 0, dobwd = 1;
617 char buf[1024];
618 char *cp;
619 int i, na;
620 /* set global progname */
621 fixargv0(argv[0]);
622 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
623 esupport &= ~(E_INCHAN|E_OUTCHAN);
624 scompile("PI:3.14159265358979323846", NULL, 0);
625 biggerlib();
626 for (i = 1; i < argc && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
627 switch (argv[i][1]) { /* get options */
628 case 'n':
629 npsamps = atoi(argv[++i]);
630 if (npsamps <= 0)
631 goto userr;
632 break;
633 case 'e':
634 scompile(argv[++i], NULL, 0);
635 single_plane_incident = 0;
636 break;
637 case 'f':
638 if ((argv[i][0] == '-') & !argv[i][2]) {
639 if (strchr(argv[++i], '=') != NULL) {
640 add_wbsdf("-f", 1);
641 add_wbsdf(argv[i], 1);
642 } else {
643 char *fpath = getpath(argv[i],
644 getrlibpath(), 0);
645 if (fpath == NULL) {
646 fprintf(stderr,
647 "%s: cannot find file '%s'\n",
648 argv[0], argv[i]);
649 return(1);
650 }
651 fcompile(fpath);
652 single_plane_incident = 0;
653 }
654 } else
655 dofwd = (argv[i][0] == '+');
656 break;
657 case 'b':
658 dobwd = (argv[i][0] == '+');
659 break;
660 case 'h':
661 kbasis = klems_half;
662 add_wbsdf("-a", 1);
663 add_wbsdf("kh", 1);
664 break;
665 case 'q':
666 kbasis = klems_quarter;
667 add_wbsdf("-a", 1);
668 add_wbsdf("kq", 1);
669 break;
670 case 'l':
671 lobe_lim = atoi(argv[++i]);
672 break;
673 case 'p':
674 do_prog = atoi(argv[i]+2);
675 break;
676 case 'C':
677 add_wbsdf(argv[i], 1);
678 add_wbsdf(argv[++i], 1);
679 break;
680 default:
681 goto userr;
682 }
683 if (kbasis == klems_full) { /* default (full) basis? */
684 add_wbsdf("-a", 1);
685 add_wbsdf("kf", 1);
686 }
687 strcpy(buf, "File produced by: ");
688 if (convert_commandline(buf+18, sizeof(buf)-18, argv) != NULL) {
689 add_wbsdf("-C", 1); add_wbsdf(buf, 0);
690 }
691 if (single_plane_incident >= 0) { /* function-based BSDF? */
692 if (i != argc-1 || fundefined(argv[i]) < 3) {
693 fprintf(stderr,
694 "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
695 progname);
696 fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n");
697 goto userr;
698 }
699 doptimize(1); /* optimize definitions */
700 ++eclock;
701 if (dofwd) {
702 input_orient = -1;
703 output_orient = -1;
704 prog_start("Evaluating outside reflectance");
705 eval_function(argv[i]);
706 output_orient = 1;
707 prog_start("Evaluating outside->inside transmission");
708 eval_function(argv[i]);
709 }
710 if (dobwd) {
711 input_orient = 1;
712 output_orient = 1;
713 prog_start("Evaluating inside reflectance");
714 eval_function(argv[i]);
715 output_orient = -1;
716 prog_start("Evaluating inside->outside transmission");
717 eval_function(argv[i]);
718 }
719 return(wrap_up());
720 }
721 /* XML input? */
722 if (i == argc-1 && (cp = argv[i]+strlen(argv[i])-4) > argv[i] &&
723 !strcasecmp(cp, ".xml")) {
724 eval_bsdf(argv[i]); /* load & resample BSDF */
725 return(wrap_up());
726 }
727 if (i < argc) { /* open input files if given */
728 int nbsdf = 0;
729 for ( ; i < argc; i++) { /* interpolate each component */
730 FILE *fpin = fopen(argv[i], "rb");
731 if (fpin == NULL) {
732 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
733 progname, argv[i]);
734 return(1);
735 }
736 sprintf(buf, "%s:\n", argv[i]);
737 record2header(buf);
738 sir_headshare = &record2header;
739 if (!load_bsdf_rep(fpin))
740 return(1);
741 fclose(fpin);
742 done_header();
743 sprintf(buf, "Interpolating component '%s'", argv[i]);
744 prog_start(buf);
745 eval_rbf();
746 }
747 return(wrap_up());
748 }
749 SET_FILE_BINARY(stdin); /* load from stdin */
750 record2header("<stdin>:\n");
751 sir_headshare = &record2header;
752 if (!load_bsdf_rep(stdin))
753 return(1);
754 done_header();
755 prog_start("Interpolating from standard input");
756 eval_rbf(); /* resample dist. */
757 return(wrap_up());
758 userr:
759 fprintf(stderr,
760 "Usage: %s [-n spp][-h|-q][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n", progname);
761 fprintf(stderr,
762 " or: %s [-n spp][-h|-q] bsdf_in.xml > bsdf_out.xml\n", progname);
763 fprintf(stderr,
764 " or: %s [-n spp][-h|-q][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
765 progname);
766 return(1);
767 }
