| 1 |
/* Copyright (c) 1990 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Convert Architrion file to Radiance
| 9 |
| 10 |
* Greg Ward
| 11 |
| 12 |
| 13 |
#include <stdio.h>
| 14 |
| 15 |
#include "trans.h"
| 16 |
| 17 |
#define DEFMAPFILE "/usr/local/lib/ray/lib/arch.map"
| 18 |
| 19 |
/* qualifiers */
| 20 |
#define Q_COL 0
| 21 |
#define Q_FAC 1
| 22 |
#define Q_LAY 2
| 23 |
#define Q_REF 3
| 24 |
#define NQUALS 4
| 25 |
| 26 |
char *qname[NQUALS] = {
| 27 |
"Color",
| 28 |
"Face",
| 29 |
"Layer",
| 30 |
"RefId",
| 31 |
| 32 |
| 33 |
QLIST qlist = {NQUALS, qname};
| 34 |
/* face ids */
| 35 |
#define F_BOT 0
| 36 |
#define F_END 1
| 37 |
#define F_OPP 2
| 38 |
#define F_REF 3
| 39 |
#define F_SIL 4
| 40 |
#define F_TOP 5
| 41 |
#define NFACES 6
| 42 |
ID faceId[NFACES] = {
| 43 |
{"bottom"},{"end"},{"opposite"},{"reference"},{"sill"},{"top"}
| 44 |
| 45 |
/* valid qualifier ids */
| 46 |
IDLIST qual[NQUALS] = {
| 47 |
{ 0, NULL },
| 48 |
{ NFACES, faceId },
| 49 |
{ 0, NULL },
| 50 |
{ 0, NULL },
| 51 |
| 52 |
/* mapping rules */
| 53 |
RULEHD *ourmap = NULL;
| 54 |
/* file header */
| 55 |
struct header {
| 56 |
char *filename;
| 57 |
char *layer[9];
| 58 |
char length_u[16], area_u[16];
| 59 |
double length_f, area_f;
| 60 |
int nblocks, nopenings;
| 61 |
} fhead;
| 62 |
/* block or opening geometry */
| 63 |
typedef struct {
| 64 |
int x[4], y[4], z[4], h[4];
| 65 |
} PRISM;
| 66 |
/* macros for x,y,z */
| 67 |
#define p_x(p,i) ((p)->x[(i)&3])
| 68 |
#define p_y(p,i) ((p)->y[(i)&3])
| 69 |
#define p_z(p,i) ((i)&4 ? (p)->h[(i)&3] : (p)->z[i])
| 70 |
/* opening */
| 71 |
typedef struct {
| 72 |
PRISM p;
| 73 |
int corner;
| 74 |
int depth;
| 75 |
ID frame;
| 76 |
} OPNG;
| 77 |
/* block */
| 78 |
typedef struct {
| 79 |
short layer;
| 80 |
short color;
| 81 |
ID refid;
| 82 |
PRISM p;
| 83 |
int nopenings;
| 84 |
OPNG *opening;
| 85 |
} BLOCK;
| 86 |
/* point format */
| 87 |
char ptfmt[] = "\t%12.9g %12.9g %12.9g\n";
| 88 |
/* antimatter modifier id for openings */
| 89 |
char openmod[] = "opening";
| 90 |
/* return flags for checkface() */
| 91 |
#define T1_OK 1
| 92 |
#define T2_OK 2
| 93 |
#define QL_OK 4
| 94 |
| 95 |
char *progname; /* argv[0] */
| 96 |
| 97 |
| 98 |
main(argc, argv) /* translate Architrion file */
| 99 |
int argc;
| 100 |
char *argv[];
| 101 |
| 102 |
int donames = 0; /* -n flag, produce namelist */
| 103 |
int i;
| 104 |
| 105 |
progname = argv[0];
| 106 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 107 |
switch (argv[i][1]) {
| 108 |
case 'n': /* just produce name list */
| 109 |
donames++;
| 110 |
break;
| 111 |
case 'm': /* use custom mapfile */
| 112 |
ourmap = getmapping(argv[++i], &qlist);
| 113 |
break;
| 114 |
default:
| 115 |
goto userr;
| 116 |
| 117 |
if (i < argc-1)
| 118 |
goto userr;
| 119 |
if (i == argc-1)
| 120 |
if (freopen(argv[i], "r", stdin) == NULL) {
| 121 |
fprintf(stderr, "%s: cannot open\n", argv[i]);
| 122 |
exit(1);
| 123 |
| 124 |
getfhead(stdin); /* get Architrion header */
| 125 |
if (donames) { /* scan for ids */
| 126 |
arch2names(stdin);
| 127 |
printf("filename \"%s\"\n", fhead.filename);
| 128 |
printf("filetype \"Architrion\"\n");
| 129 |
write_quals(&qlist, qual, stdout);
| 130 |
} else { /* translate file */
| 131 |
if (ourmap == NULL)
| 132 |
ourmap = getmapping(DEFMAPFILE, &qlist);
| 133 |
arch2rad(stdin, stdout);
| 134 |
| 135 |
return(0);
| 136 |
userr:
| 137 |
fprintf(stderr, "Usage: %s [-n][-m mapfile] [input]\n", argv[0]);
| 138 |
exit(1);
| 139 |
| 140 |
| 141 |
| 142 |
arch2rad(inp, out) /* translate Architrion file to Radiance */
| 143 |
FILE *inp, *out;
| 144 |
| 145 |
int nbs, nos;
| 146 |
BLOCK blk;
| 147 |
| 148 |
puthead(out);
| 149 |
nbs = nos = 0;
| 150 |
while (getblock(&blk, inp) != EOF) {
| 151 |
putblock(&blk, out);
| 152 |
nbs++;
| 153 |
nos += blk.nopenings;
| 154 |
doneblock(&blk);
| 155 |
| 156 |
if (nbs != fhead.nblocks)
| 157 |
fprintf(stderr,
| 158 |
"%s: warning -- block count incorrect (%d != %d)\n",
| 159 |
progname, nbs, fhead.nblocks);
| 160 |
if (nos != fhead.nopenings)
| 161 |
fprintf(stderr,
| 162 |
"%s: warning -- opening count incorrect (%d != %d)\n",
| 163 |
progname, nos, fhead.nopenings);
| 164 |
| 165 |
| 166 |
| 167 |
arch2names(inp) /* get name list from an Architrion file */
| 168 |
FILE *inp;
| 169 |
| 170 |
BLOCK blk;
| 171 |
| 172 |
| 173 |
if (ourmap == NULL || hasmatch(&blk, ourmap))
| 174 |
add2quals(&blk);
| 175 |
doneblock(&blk);
| 176 |
| 177 |
| 178 |
| 179 |
| 180 |
hasmatch(bp, mp) /* check for any match in rule list */
| 181 |
BLOCK *bp;
| 182 |
RULEHD *mp;
| 183 |
| 184 |
if (mp == NULL)
| 185 |
return(0);
| 186 |
if (hasmatch(bp, mp->next)) /* check in order -- more likely */
| 187 |
return(1);
| 188 |
return(matchrule(bp, mp));
| 189 |
| 190 |
| 191 |
| 192 |
getfhead(fp) /* get file header */
| 193 |
FILE *fp;
| 194 |
| 195 |
char buf[MAXSTR];
| 196 |
int i, n;
| 197 |
register int c;
| 198 |
/* get file name */
| 199 |
if (fgets(buf, MAXSTR, fp) == NULL)
| 200 |
goto readerr;
| 201 |
buf[strlen(buf)-1] = '\0';
| 202 |
fhead.filename = savestr(buf);
| 203 |
/* get layers */
| 204 |
fhead.layer[0] = "Worksheet";
| 205 |
for (i = 1; i <= 8; i++) {
| 206 |
if (fscanf(fp, "L%*[^0-8]%d", &n) != 1 || n != i)
| 207 |
goto readerr;
| 208 |
while ((c = getc(fp)) != EOF && (c == ' ' || c == '\t'))
| 209 |
| 210 |
if (c == EOF)
| 211 |
goto readerr;
| 212 |
ungetc(c, fp);
| 213 |
| 214 |
goto readerr;
| 215 |
| 216 |
if (buf[0])
| 217 |
fhead.layer[i] = savestr(buf);
| 218 |
else
| 219 |
fhead.layer[i] = NULL;
| 220 |
| 221 |
/* get units */
| 222 |
| 223 |
goto readerr;
| 224 |
if (sscanf(buf, "0 %*f %s %*f %s\n",
| 225 |
fhead.length_u, fhead.area_u) != 2) {
| 226 |
fhead.length_u[0] = '\0';
| 227 |
fhead.area_u[0] = '\0';
| 228 |
| 229 |
if (fgets(buf, MAXSTR, fp) == NULL ||
| 230 |
sscanf(buf, "0 %lf\n", &fhead.length_f) != 1)
| 231 |
goto readerr;
| 232 |
| 233 |
sscanf(buf, "0 %lf\n", &fhead.area_f) != 1)
| 234 |
goto readerr;
| 235 |
/* get number of blocks and openings */
| 236 |
| 237 |
sscanf(buf, "0 %d %d\n", &fhead.nblocks,
| 238 |
&fhead.nopenings) != 2)
| 239 |
goto readerr;
| 240 |
return;
| 241 |
readerr:
| 242 |
fprintf(stderr, "%s: error reading Architrion header\n", progname);
| 243 |
exit(1);
| 244 |
| 245 |
| 246 |
| 247 |
puthead(fp) /* put out header information */
| 248 |
FILE *fp;
| 249 |
| 250 |
register int i;
| 251 |
| 252 |
fprintf(fp, "# File created by: %s\n", progname);
| 253 |
fprintf(fp, "# Input file: %s\n", fhead.filename);
| 254 |
fprintf(fp, "# Input units: %s\n", fhead.length_u);
| 255 |
fprintf(fp, "# Output units: meters\n");
| 256 |
fprintf(fp, "# Named layers:\n");
| 257 |
for (i = 0; i < 8; i++)
| 258 |
if (fhead.layer[i] != NULL)
| 259 |
fprintf(fp, "#\tLayer No. %d\t%s\n", i, fhead.layer[i]);
| 260 |
| 261 |
| 262 |
| 263 |
getblock(bp, fp) /* get an Architrion block */
| 264 |
register BLOCK *bp;
| 265 |
FILE *fp;
| 266 |
| 267 |
char word[32];
| 268 |
int i;
| 269 |
| 270 |
if (fgets(word, sizeof(word), fp) == NULL)
| 271 |
return(EOF);
| 272 |
if (strncmp(word, "Block", 5))
| 273 |
return(EOF);
| 274 |
if (fscanf(fp, "1 %hd %hd %d", &bp->layer,
| 275 |
&bp->color, &bp->nopenings) != 3)
| 276 |
return(EOF);
| 277 |
if (fgetid(&bp->refid, "\n", fp) == EOF)
| 278 |
return(EOF);
| 279 |
if (fscanf(fp, "1 %d %d %d %d %d %d %d %d\n",
| 280 |
&bp->p.x[0], &bp->p.y[0], &bp->p.z[0], &bp->p.h[0],
| 281 |
&bp->p.x[1], &bp->p.y[1], &bp->p.z[1], &bp->p.h[1]) != 8)
| 282 |
return(EOF);
| 283 |
| 284 |
&bp->p.x[2], &bp->p.y[2], &bp->p.z[2], &bp->p.h[2],
| 285 |
&bp->p.x[3], &bp->p.y[3], &bp->p.z[3], &bp->p.h[3]) != 8)
| 286 |
return(EOF);
| 287 |
if (bp->nopenings == 0) {
| 288 |
bp->opening = NULL;
| 289 |
return(0);
| 290 |
| 291 |
bp->opening = (OPNG *)malloc(bp->nopenings*sizeof(OPNG));
| 292 |
if (bp->opening == NULL)
| 293 |
goto memerr;
| 294 |
for (i = 0; i < bp->nopenings; i++)
| 295 |
if (getopening(&bp->opening[i], fp) < 0)
| 296 |
return(EOF);
| 297 |
return(0);
| 298 |
memerr:
| 299 |
fprintf(stderr, "%s: out of memory in getblock\n", progname);
| 300 |
exit(1);
| 301 |
| 302 |
| 303 |
| 304 |
getopening(op, fp) /* read in opening from fp */
| 305 |
register OPNG *op;
| 306 |
FILE *fp;
| 307 |
| 308 |
register int c;
| 309 |
char word[32];
| 310 |
| 311 |
| 312 |
return(EOF);
| 313 |
if (strncmp(word, "Opening", 7))
| 314 |
return(EOF);
| 315 |
if (fscanf(fp, "2 %d %d %d %d %d %d %d %d\n",
| 316 |
&op->p.x[0], &op->p.y[0],
| 317 |
&op->p.z[0], &op->p.h[0],
| 318 |
&op->p.x[1], &op->p.y[1],
| 319 |
&op->p.z[1], &op->p.h[1]) != 8)
| 320 |
return(EOF);
| 321 |
| 322 |
&op->p.x[2], &op->p.y[2],
| 323 |
&op->p.z[2], &op->p.h[2],
| 324 |
&op->p.x[3], &op->p.y[3],
| 325 |
&op->p.z[3], &op->p.h[3]) != 8)
| 326 |
return(EOF);
| 327 |
c = getc(fp);
| 328 |
if (c == '3') {
| 329 |
if (fscanf(fp, "%d %d", &op->corner, &op->depth) != 2)
| 330 |
return(EOF);
| 331 |
if (fgetid(&op->frame, "\n", fp) == EOF)
| 332 |
return(EOF);
| 333 |
} else {
| 334 |
op->corner = -1;
| 335 |
op->frame.name = NULL;
| 336 |
if (c != EOF)
| 337 |
ungetc(c, fp);
| 338 |
| 339 |
return(0);
| 340 |
| 341 |
| 342 |
| 343 |
doneblock(bp) /* free data associated with bp */
| 344 |
register BLOCK *bp;
| 345 |
| 346 |
register int i;
| 347 |
| 348 |
if (bp->nopenings > 0) {
| 349 |
| 350 |
doneid(&bp->opening[i].frame);
| 351 |
free((char *)bp->opening);
| 352 |
| 353 |
doneid(&bp->refid);
| 354 |
| 355 |
| 356 |
| 357 |
add2quals(bp) /* add to qualifier lists */
| 358 |
register BLOCK *bp;
| 359 |
| 360 |
ID tmpid;
| 361 |
| 362 |
if (fhead.layer[bp->layer] == NULL) {
| 363 |
tmpid.name = NULL;
| 364 |
tmpid.number = bp->layer;
| 365 |
} else {
| 366 |
tmpid.name = fhead.layer[bp->layer];
| 367 |
tmpid.number = 0;
| 368 |
| 369 |
findid(&qual[Q_LAY], &tmpid, 1);
| 370 |
tmpid.name = NULL;
| 371 |
tmpid.number = bp->color;
| 372 |
findid(&qual[Q_COL], &tmpid, 1);
| 373 |
findid(&qual[Q_REF], &bp->refid, 1);
| 374 |
| 375 |
| 376 |
| 377 |
putblock(bp, fp) /* put out a block */
| 378 |
BLOCK *bp;
| 379 |
FILE *fp;
| 380 |
| 381 |
RULEHD *rp;
| 382 |
char *mod[NFACES], *sillmod;
| 383 |
int nmods, i;
| 384 |
int donematch, newmatch;
| 385 |
| 386 |
nmods = 0; sillmod = NULL;
| 387 |
donematch = 0;
| 388 |
for (rp = ourmap; rp != NULL; rp = rp->next) {
| 389 |
newmatch = matchrule(bp, rp); /* test this rule */
| 390 |
newmatch &= ~donematch; /* don't repeat */
| 391 |
if (newmatch == 0)
| 392 |
continue;
| 393 |
mod[nmods++] = rp->mnam;
| 394 |
if (sillmod == NULL && newmatch&F_SIL)
| 395 |
sillmod = rp->mnam;
| 396 |
putfaces(rp->mnam, bp, newmatch, fp); /* put out new faces */
| 397 |
donematch |= newmatch;
| 398 |
if (donematch == (1<<NFACES)-1)
| 399 |
break; /* done all faces */
| 400 |
| 401 |
/* put out openings */
| 402 |
if (donematch && bp->nopenings > 0) {
| 403 |
putopenmod(sillmod, mod, nmods, fp);
| 404 |
| 405 |
putopening(&bp->opening[i], fp);
| 406 |
| 407 |
if (ferror(fp)) {
| 408 |
fprintf(stderr, "%s: write error in putblock\n", progname);
| 409 |
exit(1);
| 410 |
| 411 |
| 412 |
| 413 |
| 414 |
putopenmod(sm, ml, nm, fp) /* put out opening modifier */
| 415 |
char *sm, *ml[];
| 416 |
int nm;
| 417 |
FILE *fp;
| 418 |
| 419 |
int rept, nrepts;
| 420 |
register int i, j;
| 421 |
| 422 |
if (sm == NULL) { /* if no sill modifier, use list */
| 423 |
sm = *ml++;
| 424 |
nm--;
| 425 |
| 426 |
/* check for repeats */
| 427 |
rept = 0; nrepts = 0;
| 428 |
for (i = 0; i < nm; i++) {
| 429 |
if (ml[i] == sm || !strcmp(ml[i], VOIDID)) {
| 430 |
rept |= 1<<i;
| 431 |
nrepts++;
| 432 |
continue;
| 433 |
| 434 |
for (j = 0; j < i; j++)
| 435 |
if (!(rept & 1<<j) && ml[j] == ml[i]) {
| 436 |
rept |= 1<<j;
| 437 |
nrepts++;
| 438 |
| 439 |
| 440 |
/* print antimatter and modlist */
| 441 |
fprintf(fp, "\n%s antimatter %s\n", VOIDID, openmod);
| 442 |
fprintf(fp, "%d %s", 1+nm-nrepts, sm);
| 443 |
| 444 |
if (!(rept & 1<<i))
| 445 |
fprintf(fp, " %s", ml[i]);
| 446 |
fprintf(fp, "\n0\n0\n");
| 447 |
| 448 |
| 449 |
| 450 |
putopening(op, fp) /* put out an opening */
| 451 |
OPNG *op;
| 452 |
FILE *fp;
| 453 |
| 454 |
static int nopens = 0;
| 455 |
char buf[32];
| 456 |
register PRISM *p = &op->p;
| 457 |
PRISM newp;
| 458 |
register int i;
| 459 |
/* copy original prism */
| 460 |
for (i = 0; i < 4; i++) {
| 461 |
newp.x[i] = p->x[i];
| 462 |
newp.y[i] = p->y[i];
| 463 |
newp.z[i] = p->z[i];
| 464 |
newp.h[i] = p->h[i];
| 465 |
| 466 |
/* spread reference and opposite */
| 467 |
if (p->x[2] > p->x[0]) {
| 468 |
newp.x[0] -= 2;
| 469 |
newp.x[1] -= 2;
| 470 |
newp.x[2] += 2;
| 471 |
newp.x[3] += 2;
| 472 |
} else if (p->x[0] > p->x[2]) {
| 473 |
newp.x[0] += 2;
| 474 |
newp.x[1] += 2;
| 475 |
newp.x[2] -= 2;
| 476 |
newp.x[3] -= 2;
| 477 |
| 478 |
if (p->y[2] > p->y[0]) {
| 479 |
newp.y[0] -= 2;
| 480 |
newp.y[1] -= 2;
| 481 |
newp.y[2] += 2;
| 482 |
newp.y[3] += 2;
| 483 |
} else if (p->y[0] > p->y[2]) {
| 484 |
newp.y[0] += 2;
| 485 |
newp.y[1] += 2;
| 486 |
newp.y[2] -= 2;
| 487 |
newp.y[3] -= 2;
| 488 |
| 489 |
/* put out faces */
| 490 |
sprintf(buf, "op%d", ++nopens);
| 491 |
putface(openmod, buf, "ref", &newp, 4, 5, 1, 0, fp);
| 492 |
putface(openmod, buf, "opp", &newp, 2, 6, 7, 3, fp);
| 493 |
putface(openmod, buf, "end1", &newp, 5, 6, 2, 1, fp);
| 494 |
putface(openmod, buf, "end2", &newp, 3, 7, 4, 0, fp);
| 495 |
putface(openmod, buf, "bot", &newp, 1, 2, 3, 0, fp);
| 496 |
putface(openmod, buf, "top", &newp, 7, 6, 5, 4, fp);
| 497 |
| 498 |
| 499 |
| 500 |
int
| 501 |
matchrule(bp, rp) /* see if block matches this rule */
| 502 |
register BLOCK *bp;
| 503 |
register RULEHD *rp;
| 504 |
| 505 |
register int i;
| 506 |
ID tmpid;
| 507 |
| 508 |
if (rp->qflg & FL(Q_LAY)) { /* check layer */
| 509 |
| 510 |
| 511 |
if (!matchid(&tmpid, &idm(rp)[Q_LAY]))
| 512 |
return(0);
| 513 |
| 514 |
if (rp->qflg & FL(Q_COL)) { /* check color */
| 515 |
tmpid.name = NULL;
| 516 |
| 517 |
if (!matchid(&tmpid, &idm(rp)[Q_COL]))
| 518 |
return(0);
| 519 |
| 520 |
if (rp->qflg & FL(Q_REF)) { /* check reference id */
| 521 |
if (!matchid(&bp->refid, &idm(rp)[Q_REF]))
| 522 |
return(0);
| 523 |
| 524 |
if (rp->qflg & FL(Q_FAC)) { /* check faces */
| 525 |
for (i = 0; i < NFACES; i++)
| 526 |
if (matchid(&faceId[i], &idm(rp)[Q_FAC]))
| 527 |
return(1<<i); /* match single face */
| 528 |
return(0);
| 529 |
| 530 |
return((1<<NFACES)-1); /* matched all faces */
| 531 |
| 532 |
| 533 |
| 534 |
putfaces(m, bp, ff, fp) /* put out faces */
| 535 |
char *m;
| 536 |
BLOCK *bp;
| 537 |
register int ff;
| 538 |
FILE *fp;
| 539 |
| 540 |
char *blkname(), *bn;
| 541 |
| 542 |
if (!strcmp(m, VOIDID))
| 543 |
return;
| 544 |
bn = blkname(bp);
| 545 |
if (ff & 1<<F_REF)
| 546 |
putface(m, bn, "ref", &bp->p, 4, 5, 1, 0, fp);
| 547 |
if (ff & 1<<F_OPP)
| 548 |
putface(m, bn, "opp", &bp->p, 2, 6, 7, 3, fp);
| 549 |
if (ff & 1<<F_END) {
| 550 |
putface(m, bn, "end1", &bp->p, 5, 6, 2, 1, fp);
| 551 |
putface(m, bn, "end2", &bp->p, 3, 7, 4, 0, fp);
| 552 |
| 553 |
if (ff & 1<<F_BOT)
| 554 |
putface(m, bn, "bot", &bp->p, 1, 2, 3, 0, fp);
| 555 |
if (ff & 1<<F_TOP)
| 556 |
putface(m, bn, "top", &bp->p, 7, 6, 5, 4, fp);
| 557 |
| 558 |
| 559 |
| 560 |
char *
| 561 |
blkname(bp) /* think up a good name for this block */
| 562 |
register BLOCK *bp;
| 563 |
| 564 |
static char nambuf[32];
| 565 |
static int blkcnt = 0;
| 566 |
register char *nam;
| 567 |
register int i, j;
| 568 |
| 569 |
sprintf(nambuf, "l%d.", bp->layer);
| 570 |
i = strlen(nambuf);
| 571 |
nam = bp->refid.name;
| 572 |
if (nam == NULL) {
| 573 |
nam = fhead.layer[bp->layer];
| 574 |
if (nam != NULL)
| 575 |
i = 0;
| 576 |
| 577 |
if (nam != NULL) {
| 578 |
for (j = 0; j < 12 && nam[j]; j++) {
| 579 |
if (nam[j] == ' ' || nam[j] == '\t')
| 580 |
nambuf[i++] = '_';
| 581 |
else
| 582 |
nambuf[i++] = nam[j];
| 583 |
| 584 |
nambuf[i++] = '.';
| 585 |
| 586 |
if (bp->refid.number != 0) {
| 587 |
sprintf(nambuf+i, "r%d.", bp->refid.number);
| 588 |
i = strlen(nambuf);
| 589 |
| 590 |
sprintf(nambuf+i, "b%d", ++blkcnt);
| 591 |
return(nambuf);
| 592 |
| 593 |
| 594 |
| 595 |
putface(m, bn, fn, p, a, b, c, d, fp) /* put out a face */
| 596 |
char *m;
| 597 |
char *bn, *fn;
| 598 |
PRISM *p;
| 599 |
int a, b, c, d;
| 600 |
FILE *fp;
| 601 |
| 602 |
int cf;
| 603 |
| 604 |
cf = checkface(p, a, b, c, d);
| 605 |
if (cf & QL_OK) {
| 606 |
fprintf(fp, "\n%s polygon %s.%s\n", m, bn, fn);
| 607 |
fprintf(fp, "0\n0\n12\n");
| 608 |
putpoint(p, a, fp);
| 609 |
putpoint(p, b, fp);
| 610 |
putpoint(p, c, fp);
| 611 |
putpoint(p, d, fp);
| 612 |
return;
| 613 |
| 614 |
if (cf & T1_OK) {
| 615 |
fprintf(fp, "\n%s polygon %s.%sA\n", m, bn, fn);
| 616 |
fprintf(fp, "0\n0\n9\n");
| 617 |
putpoint(p, d, fp);
| 618 |
putpoint(p, a, fp);
| 619 |
putpoint(p, b, fp);
| 620 |
| 621 |
if (cf & T2_OK) {
| 622 |
fprintf(fp, "\n%s polygon %s.%sB\n", m, bn, fn);
| 623 |
| 624 |
putpoint(p, b, fp);
| 625 |
putpoint(p, c, fp);
| 626 |
putpoint(p, d, fp);
| 627 |
| 628 |
| 629 |
| 630 |
| 631 |
#define ldot(v1,v2) (v1[0]*v2[0]+v1[1]*v2[1]+v1[2]*v2[2])
| 632 |
| 633 |
| 634 |
long
| 635 |
lcross(vr, v1, v2) /* compute cross product */
| 636 |
register long vr[3], v1[3], v2[3];
| 637 |
| 638 |
vr[0] = v1[1]*v2[2] - v1[2]*v2[1];
| 639 |
vr[1] = v1[2]*v2[0] - v1[0]*v2[2];
| 640 |
vr[2] = v1[0]*v2[1] - v1[1]*v2[0];
| 641 |
| 642 |
| 643 |
| 644 |
#define labs(a) ((a)>0 ? (a) : -(a))
| 645 |
| 646 |
| 647 |
checkface(p, a, b, c, d) /* check a face for validity */
| 648 |
register PRISM *p;
| 649 |
int a, b, c, d;
| 650 |
| 651 |
int rval = 0;
| 652 |
long lt;
| 653 |
long vc1[3], vc2[3], vt1[3], vt2[3];
| 654 |
long vc1l, vc2l, vc1vc2;
| 655 |
/* check first triangle */
| 656 |
vt1[0] = p_x(p,b) - p_x(p,a);
| 657 |
vt1[1] = p_y(p,b) - p_y(p,a);
| 658 |
vt1[2] = p_z(p,b) - p_z(p,a);
| 659 |
vt2[0] = p_x(p,d) - p_x(p,a);
| 660 |
vt2[1] = p_y(p,d) - p_y(p,a);
| 661 |
vt2[2] = p_z(p,d) - p_z(p,a);
| 662 |
lcross(vc1, vt1, vt2);
| 663 |
lt = labs(vc1[0]) + labs(vc1[1]) + labs(vc1[2]);
| 664 |
if (lt > 1L<<18) lt = 16;
| 665 |
else if (lt > 1L<<12) lt = 8;
| 666 |
else lt = 0;
| 667 |
if (lt) { vc1[0] >>= lt; vc1[1] >>= lt; vc1[2] >>= lt; }
| 668 |
vc1l = ldot(vc1,vc1);
| 669 |
if (vc1l > 4)
| 670 |
rval |= T1_OK;
| 671 |
/* check second triangle */
| 672 |
vt1[0] = p_x(p,d) - p_x(p,c);
| 673 |
vt1[1] = p_y(p,d) - p_y(p,c);
| 674 |
vt1[2] = p_z(p,d) - p_z(p,c);
| 675 |
vt2[0] = p_x(p,b) - p_x(p,c);
| 676 |
vt2[1] = p_y(p,b) - p_y(p,c);
| 677 |
vt2[2] = p_z(p,b) - p_z(p,c);
| 678 |
lcross(vc2, vt1, vt2);
| 679 |
lt = labs(vc2[0]) + labs(vc2[1]) + labs(vc2[2]);
| 680 |
| 681 |
| 682 |
else lt = 0;
| 683 |
if (lt) { vc2[0] >>= lt; vc2[1] >>= lt; vc2[2] >>= lt; }
| 684 |
vc2l = ldot(vc2,vc2);
| 685 |
if (vc2l > 4)
| 686 |
rval |= T2_OK;
| 687 |
/* check quadrilateral */
| 688 |
if (rval == (T1_OK|T2_OK)) {
| 689 |
vc1vc2 = ldot(vc1,vc2);
| 690 |
if (vc1vc2*vc1vc2 >= vc1l*vc2l-8)
| 691 |
rval |= QL_OK;
| 692 |
| 693 |
return(rval);
| 694 |
| 695 |
| 696 |
| 697 |
putpoint(p, n, fp) /* put out a point */
| 698 |
register PRISM *p;
| 699 |
int n;
| 700 |
FILE *fp;
| 701 |
| 702 |
register int i = n&3;
| 703 |
| 704 |
fprintf(fp, ptfmt, p->x[i]*fhead.length_f, p->y[i]*fhead.length_f,
| 705 |
(n&4 ? p->h[i] : p->z[i])*fhead.length_f);
| 706 |
| 707 |
| 708 |
| 709 |
eputs(s)
| 710 |
char *s;
| 711 |
| 712 |
fputs(s, stderr);
| 713 |
| 714 |
| 715 |
| 716 |
quit(code)
| 717 |
int code;
| 718 |
| 719 |
exit(code);
| 720 |
