root/radiance/ray/src/cv/arch2rad.c
Revision: 1.3
Committed: Mon Dec 17 14:43:08 1990 UTC (33 years, 5 months ago) by greg
Changes since 1.2: +6 -7 lines
made reading headers a little more flexible
1 /* Copyright (c) 1990 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Convert Architrion file to Radiance
9 *
10 * Greg Ward
11 */
12
13 #include <stdio.h>
14
15 #include "trans.h"
16
17 #define DEFMAPFILE "/usr/local/lib/ray/lib/arch.map"
18
19 /* qualifiers */
20 #define Q_COL 0
21 #define Q_FAC 1
22 #define Q_LAY 2
23 #define Q_REF 3
24 #define NQUALS 4
25
26 char *qname[NQUALS] = {
27 "Color",
28 "Face",
29 "Layer",
30 "RefId",
31 };
32
33 QLIST qlist = {NQUALS, qname};
34 /* face ids */
35 #define F_BOT 0
36 #define F_END 1
37 #define F_OPP 2
38 #define F_REF 3
39 #define F_SIL 4
40 #define F_TOP 5
41 #define NFACES 6
42 ID faceId[NFACES] = {
43 {"bottom"},{"end"},{"opposite"},{"reference"},{"sill"},{"top"}
44 };
45 /* valid qualifier ids */
46 IDLIST qual[NQUALS] = {
47 { 0, NULL },
48 { NFACES, faceId },
49 { 0, NULL },
50 { 0, NULL },
51 };
52 /* mapping rules */
53 RULEHD *ourmap = NULL;
54 /* file header */
55 struct header {
56 char *filename;
57 char *layer[9];
58 char length_u[16], area_u[16];
59 double length_f, area_f;
60 int nblocks, nopenings;
61 } fhead;
62 /* block or opening geometry */
63 typedef struct {
64 int x[4], y[4], z[4], h[4];
65 } PRISM;
66 /* macros for x,y,z */
67 #define p_x(p,i) ((p)->x[(i)&3])
68 #define p_y(p,i) ((p)->y[(i)&3])
69 #define p_z(p,i) ((i)&4 ? (p)->h[(i)&3] : (p)->z[i])
70 /* opening */
71 typedef struct {
72 PRISM p;
73 int corner;
74 int depth;
75 ID frame;
76 } OPNG;
77 /* block */
78 typedef struct {
79 short layer;
80 short color;
81 ID refid;
82 PRISM p;
83 int nopenings;
84 OPNG *opening;
85 } BLOCK;
86 /* point format */
87 char ptfmt[] = "\t%12.9g %12.9g %12.9g\n";
88 /* antimatter modifier id for openings */
89 char openmod[] = "opening";
90 /* return flags for checkface() */
91 #define T1_OK 1
92 #define T2_OK 2
93 #define QL_OK 4
94
95 char *progname; /* argv[0] */
96
97
98 main(argc, argv) /* translate Architrion file */
99 int argc;
100 char *argv[];
101 {
102 int donames = 0; /* -n flag, produce namelist */
103 int i;
104
105 progname = argv[0];
106 for (i = 1; i < argc && argv[i][0] == '-'; i++)
107 switch (argv[i][1]) {
108 case 'n': /* just produce name list */
109 donames++;
110 break;
111 case 'm': /* use custom mapfile */
112 ourmap = getmapping(argv[++i], &qlist);
113 break;
114 default:
115 goto userr;
116 }
117 if (i < argc-1)
118 goto userr;
119 if (i == argc-1)
120 if (freopen(argv[i], "r", stdin) == NULL) {
121 fprintf(stderr, "%s: cannot open\n", argv[i]);
122 exit(1);
123 }
124 getfhead(stdin); /* get Architrion header */
125 if (donames) { /* scan for ids */
126 arch2names(stdin);
127 printf("filename \"%s\"\n", fhead.filename);
128 printf("filetype \"Architrion\"\n");
129 write_quals(&qlist, qual, stdout);
130 } else { /* translate file */
131 if (ourmap == NULL)
132 ourmap = getmapping(DEFMAPFILE, &qlist);
133 arch2rad(stdin, stdout);
134 }
135 return(0);
136 userr:
137 fprintf(stderr, "Usage: %s [-n][-m mapfile] [input]\n", argv[0]);
138 exit(1);
139 }
140
141
142 arch2rad(inp, out) /* translate Architrion file to Radiance */
143 FILE *inp, *out;
144 {
145 int nbs, nos;
146 BLOCK blk;
147
148 puthead(out);
149 nbs = nos = 0;
150 while (getblock(&blk, inp) != EOF) {
151 putblock(&blk, out);
152 nbs++;
153 nos += blk.nopenings;
154 doneblock(&blk);
155 }
156 if (nbs != fhead.nblocks)
157 fprintf(stderr,
158 "%s: warning -- block count incorrect (%d != %d)\n",
159 progname, nbs, fhead.nblocks);
160 if (nos != fhead.nopenings)
161 fprintf(stderr,
162 "%s: warning -- opening count incorrect (%d != %d)\n",
163 progname, nos, fhead.nopenings);
164 }
165
166
167 arch2names(inp) /* get name list from an Architrion file */
168 FILE *inp;
169 {
170 BLOCK blk;
171
172 while (getblock(&blk, inp) != EOF) {
173 if (ourmap == NULL || hasmatch(&blk, ourmap))
174 add2quals(&blk);
175 doneblock(&blk);
176 }
177 }
178
179
180 hasmatch(bp, mp) /* check for any match in rule list */
181 BLOCK *bp;
182 RULEHD *mp;
183 {
184 if (mp == NULL)
185 return(0);
186 if (hasmatch(bp, mp->next)) /* check in order -- more likely */
187 return(1);
188 return(matchrule(bp, mp));
189 }
190
191
192 getfhead(fp) /* get file header */
193 FILE *fp;
194 {
195 char buf[MAXSTR];
196 int i, n;
197 register int c;
198 /* get file name */
199 if (fgets(buf, MAXSTR, fp) == NULL)
200 goto readerr;
201 buf[strlen(buf)-1] = '\0';
202 fhead.filename = savestr(buf);
203 /* get layers */
204 fhead.layer[0] = "Worksheet";
205 for (i = 1; i <= 8; i++) {
206 if (fscanf(fp, "L%*[^0-8]%d", &n) != 1 || n != i)
207 goto readerr;
208 while ((c = getc(fp)) != EOF && (c == ' ' || c == '\t'))
209 ;
210 if (c == EOF)
211 goto readerr;
212 ungetc(c, fp);
213 if (fgets(buf, MAXSTR, fp) == NULL)
214 goto readerr;
215 buf[strlen(buf)-1] = '\0';
216 if (buf[0])
217 fhead.layer[i] = savestr(buf);
218 else
219 fhead.layer[i] = NULL;
220 }
221 /* get units */
222 if (fgets(buf, MAXSTR, fp) == NULL)
223 goto readerr;
224 if (sscanf(buf, "0 %*f %s %*f %s\n",
225 fhead.length_u, fhead.area_u) != 2) {
226 fhead.length_u[0] = '\0';
227 fhead.area_u[0] = '\0';
228 }
229 if (fgets(buf, MAXSTR, fp) == NULL ||
230 sscanf(buf, "0 %lf\n", &fhead.length_f) != 1)
231 goto readerr;
232 if (fgets(buf, MAXSTR, fp) == NULL ||
233 sscanf(buf, "0 %lf\n", &fhead.area_f) != 1)
234 goto readerr;
235 /* get number of blocks and openings */
236 if (fgets(buf, MAXSTR, fp) == NULL ||
237 sscanf(buf, "0 %d %d\n", &fhead.nblocks,
238 &fhead.nopenings) != 2)
239 goto readerr;
240 return;
241 readerr:
242 fprintf(stderr, "%s: error reading Architrion header\n", progname);
243 exit(1);
244 }
245
246
247 puthead(fp) /* put out header information */
248 FILE *fp;
249 {
250 register int i;
251
252 fprintf(fp, "# File created by: %s\n", progname);
253 fprintf(fp, "# Input file: %s\n", fhead.filename);
254 fprintf(fp, "# Input units: %s\n", fhead.length_u);
255 fprintf(fp, "# Output units: meters\n");
256 fprintf(fp, "# Named layers:\n");
257 for (i = 0; i < 8; i++)
258 if (fhead.layer[i] != NULL)
259 fprintf(fp, "#\tLayer No. %d\t%s\n", i, fhead.layer[i]);
260 }
261
262
263 getblock(bp, fp) /* get an Architrion block */
264 register BLOCK *bp;
265 FILE *fp;
266 {
267 char word[32];
268 int i;
269
270 if (fgets(word, sizeof(word), fp) == NULL)
271 return(EOF);
272 if (strncmp(word, "Block", 5))
273 return(EOF);
274 if (fscanf(fp, "1 %hd %hd %d", &bp->layer,
275 &bp->color, &bp->nopenings) != 3)
276 return(EOF);
277 if (fgetid(&bp->refid, "\n", fp) == EOF)
278 return(EOF);
279 if (fscanf(fp, "1 %d %d %d %d %d %d %d %d\n",
280 &bp->p.x[0], &bp->p.y[0], &bp->p.z[0], &bp->p.h[0],
281 &bp->p.x[1], &bp->p.y[1], &bp->p.z[1], &bp->p.h[1]) != 8)
282 return(EOF);
283 if (fscanf(fp, "1 %d %d %d %d %d %d %d %d\n",
284 &bp->p.x[2], &bp->p.y[2], &bp->p.z[2], &bp->p.h[2],
285 &bp->p.x[3], &bp->p.y[3], &bp->p.z[3], &bp->p.h[3]) != 8)
286 return(EOF);
287 if (bp->nopenings == 0) {
288 bp->opening = NULL;
289 return(0);
290 }
291 bp->opening = (OPNG *)malloc(bp->nopenings*sizeof(OPNG));
292 if (bp->opening == NULL)
293 goto memerr;
294 for (i = 0; i < bp->nopenings; i++)
295 if (getopening(&bp->opening[i], fp) < 0)
296 return(EOF);
297 return(0);
298 memerr:
299 fprintf(stderr, "%s: out of memory in getblock\n", progname);
300 exit(1);
301 }
302
303
304 getopening(op, fp) /* read in opening from fp */
305 register OPNG *op;
306 FILE *fp;
307 {
308 register int c;
309 char word[32];
310
311 if (fgets(word, sizeof(word), fp) == NULL)
312 return(EOF);
313 if (strncmp(word, "Opening", 7))
314 return(EOF);
315 if (fscanf(fp, "2 %d %d %d %d %d %d %d %d\n",
316 &op->p.x[0], &op->p.y[0],
317 &op->p.z[0], &op->p.h[0],
318 &op->p.x[1], &op->p.y[1],
319 &op->p.z[1], &op->p.h[1]) != 8)
320 return(EOF);
321 if (fscanf(fp, "2 %d %d %d %d %d %d %d %d\n",
322 &op->p.x[2], &op->p.y[2],
323 &op->p.z[2], &op->p.h[2],
324 &op->p.x[3], &op->p.y[3],
325 &op->p.z[3], &op->p.h[3]) != 8)
326 return(EOF);
327 c = getc(fp);
328 if (c == '3') {
329 if (fscanf(fp, "%d %d", &op->corner, &op->depth) != 2)
330 return(EOF);
331 if (fgetid(&op->frame, "\n", fp) == EOF)
332 return(EOF);
333 } else {
334 op->corner = -1;
335 op->frame.name = NULL;
336 if (c != EOF)
337 ungetc(c, fp);
338 }
339 return(0);
340 }
341
342
343 doneblock(bp) /* free data associated with bp */
344 register BLOCK *bp;
345 {
346 register int i;
347
348 if (bp->nopenings > 0) {
349 for (i = 0; i < bp->nopenings; i++)
350 doneid(&bp->opening[i].frame);
351 free((char *)bp->opening);
352 }
353 doneid(&bp->refid);
354 }
355
356
357 add2quals(bp) /* add to qualifier lists */
358 register BLOCK *bp;
359 {
360 ID tmpid;
361
362 if (fhead.layer[bp->layer] == NULL) {
363 tmpid.name = NULL;
364 tmpid.number = bp->layer;
365 } else {
366 tmpid.name = fhead.layer[bp->layer];
367 tmpid.number = 0;
368 }
369 findid(&qual[Q_LAY], &tmpid, 1);
370 tmpid.name = NULL;
371 tmpid.number = bp->color;
372 findid(&qual[Q_COL], &tmpid, 1);
373 findid(&qual[Q_REF], &bp->refid, 1);
374 }
375
376
377 putblock(bp, fp) /* put out a block */
378 BLOCK *bp;
379 FILE *fp;
380 {
381 RULEHD *rp;
382 char *mod[NFACES], *sillmod;
383 int nmods, i;
384 int donematch, newmatch;
385
386 nmods = 0; sillmod = NULL;
387 donematch = 0;
388 for (rp = ourmap; rp != NULL; rp = rp->next) {
389 newmatch = matchrule(bp, rp); /* test this rule */
390 newmatch &= ~donematch; /* don't repeat */
391 if (newmatch == 0)
392 continue;
393 mod[nmods++] = rp->mnam;
394 if (sillmod == NULL && newmatch&F_SIL)
395 sillmod = rp->mnam;
396 putfaces(rp->mnam, bp, newmatch, fp); /* put out new faces */
397 donematch |= newmatch;
398 if (donematch == (1<<NFACES)-1)
399 break; /* done all faces */
400 }
401 /* put out openings */
402 if (donematch && bp->nopenings > 0) {
403 putopenmod(sillmod, mod, nmods, fp);
404 for (i = 0; i < bp->nopenings; i++)
405 putopening(&bp->opening[i], fp);
406 }
407 if (ferror(fp)) {
408 fprintf(stderr, "%s: write error in putblock\n", progname);
409 exit(1);
410 }
411 }
412
413
414 putopenmod(sm, ml, nm, fp) /* put out opening modifier */
415 char *sm, *ml[];
416 int nm;
417 FILE *fp;
418 {
419 int rept, nrepts;
420 register int i, j;
421
422 if (sm == NULL) { /* if no sill modifier, use list */
423 sm = *ml++;
424 nm--;
425 }
426 /* check for repeats */
427 rept = 0; nrepts = 0;
428 for (i = 0; i < nm; i++) {
429 if (ml[i] == sm) {
430 rept |= 1<<i;
431 nrepts++;
432 }
433 for (j = 0; j < i; j++)
434 if (ml[j] == ml[i]) {
435 rept |= 1<<j;
436 nrepts++;
437 }
438 }
439 /* print antimatter and modlist */
440 fprintf(fp, "\nvoid antimatter %s\n", openmod);
441 fprintf(fp, "%d %s", 1+nm-nrepts, sm);
442 for (i = 0; i < nm; i++)
443 if (!(rept & 1<<i))
444 fprintf(fp, " %s", ml[i]);
445 fprintf(fp, "\n0\n0\n");
446 }
447
448
449 putopening(op, fp) /* put out an opening */
450 OPNG *op;
451 FILE *fp;
452 {
453 static int nopens = 0;
454 char buf[32];
455 register PRISM *p = &op->p;
456 PRISM newp;
457 register int i;
458 /* copy original prism */
459 for (i = 0; i < 4; i++) {
460 newp.x[i] = p->x[i];
461 newp.y[i] = p->y[i];
462 newp.z[i] = p->z[i];
463 newp.h[i] = p->h[i];
464 }
465 /* spread reference and opposite */
466 if (p->x[1] > p->x[0]) {
467 newp.x[0] -= 2;
468 newp.x[1] += 2;
469 newp.x[2] += 2;
470 newp.x[3] -= 2;
471 } else if (p->x[0] > p->x[1]) {
472 newp.x[0] += 2;
473 newp.x[1] -= 2;
474 newp.x[2] -= 2;
475 newp.x[3] += 2;
476 }
477 if (p->y[1] > p->y[0]) {
478 newp.y[0] -= 2;
479 newp.y[1] += 2;
480 newp.y[2] += 2;
481 newp.y[3] -= 2;
482 } else if (p->y[0] > p->y[1]) {
483 newp.y[0] += 2;
484 newp.y[1] -= 2;
485 newp.y[2] -= 2;
486 newp.y[3] += 2;
487 }
488 /* put out faces */
489 sprintf(buf, "op%d", ++nopens);
490 putface(openmod, buf, "ref", &newp, 3, 7, 4, 0, fp);
491 putface(openmod, buf, "opp", &newp, 5, 6, 2, 1, fp);
492 putface(openmod, buf, "end1", &newp, 2, 6, 7, 3, fp);
493 putface(openmod, buf, "end2", &newp, 4, 5, 1, 0, fp);
494 putface(openmod, buf, "bot", &newp, 1, 2, 3, 0, fp);
495 putface(openmod, buf, "top", &newp, 7, 6, 5, 4, fp);
496 }
497
498
499 int
500 matchrule(bp, rp) /* see if block matches this rule */
501 register BLOCK *bp;
502 register RULEHD *rp;
503 {
504 register int i;
505 ID tmpid;
506
507 if (rp->qflg & FL(Q_LAY)) { /* check layer */
508 tmpid.name = NULL;
509 tmpid.number = bp->layer;
510 if (!matchid(&tmpid, &idm(rp)[Q_LAY]))
511 return(0);
512 }
513 if (rp->qflg & FL(Q_COL)) { /* check color */
514 tmpid.name = NULL;
515 tmpid.number = bp->color;
516 if (!matchid(&tmpid, &idm(rp)[Q_COL]))
517 return(0);
518 }
519 if (rp->qflg & FL(Q_REF)) { /* check reference id */
520 if (!matchid(&bp->refid, &idm(rp)[Q_REF]))
521 return(0);
522 }
523 if (rp->qflg & FL(Q_FAC)) { /* check faces */
524 for (i = 0; i < NFACES; i++)
525 if (matchid(&faceId[i], &idm(rp)[Q_FAC]))
526 return(1<<i); /* match single face */
527 return(0);
528 }
529 return((1<<NFACES)-1); /* matched all faces */
530 }
531
532
533 putfaces(m, bp, ff, fp) /* put out faces */
534 char *m;
535 BLOCK *bp;
536 register int ff;
537 FILE *fp;
538 {
539 char *blkname(), *bn;
540
541 if (!strcmp(m, VOIDID))
542 return;
543 bn = blkname(bp);
544 if (ff & 1<<F_REF)
545 putface(m, bn, "ref", &bp->p, 3, 7, 4, 0, fp);
546 if (ff & 1<<F_OPP)
547 putface(m, bn, "opp", &bp->p, 5, 6, 2, 1, fp);
548 if (ff & 1<<F_END) {
549 putface(m, bn, "end1", &bp->p, 2, 6, 7, 3, fp);
550 putface(m, bn, "end2", &bp->p, 4, 5, 1, 0, fp);
551 }
552 if (ff & 1<<F_BOT)
553 putface(m, bn, "bot", &bp->p, 1, 2, 3, 0, fp);
554 if (ff & 1<<F_TOP)
555 putface(m, bn, "top", &bp->p, 7, 6, 5, 4, fp);
556 }
557
558
559 char *
560 blkname(bp) /* think up a good name for this block */
561 register BLOCK *bp;
562 {
563 static char nambuf[32];
564 static int blkcnt = 0;
565 register char *nam;
566 register int i;
567
568 nam = bp->refid.name;
569 if (nam == NULL)
570 nam = fhead.layer[bp->layer];
571 if (nam == NULL) {
572 sprintf(nambuf, "l%d.", bp->layer);
573 i = strlen(nambuf);
574 } else {
575 for (i = 0; i < 12 && nam[i]; i++) {
576 if (nam[i] == ' ' || nam[i] == '\t')
577 nambuf[i] = '_';
578 else
579 nambuf[i] = nam[i];
580 }
581 nambuf[i++] = '.';
582 }
583 if (bp->refid.number != 0) {
584 sprintf(nambuf+i, "r%d.", bp->refid.number);
585 i = strlen(nambuf);
586 }
587 sprintf(nambuf+i, "b%d", ++blkcnt);
588 return(nambuf);
589 }
590
591
592 putface(m, bn, fn, p, a, b, c, d, fp) /* put out a face */
593 char *m;
594 char *bn, *fn;
595 PRISM *p;
596 int a, b, c, d;
597 FILE *fp;
598 {
599 int cf;
600
601 cf = checkface(p, a, b, c, d);
602 if (cf & QL_OK) {
603 fprintf(fp, "\n%s polygon %s.%s\n", m, bn, fn);
604 fprintf(fp, "0\n0\n12\n");
605 putpoint(p, a, fp);
606 putpoint(p, b, fp);
607 putpoint(p, c, fp);
608 putpoint(p, d, fp);
609 return;
610 }
611 if (cf & T1_OK) {
612 fprintf(fp, "\n%s polygon %s.%sA\n", m, bn, fn);
613 fprintf(fp, "0\n0\n9\n");
614 putpoint(p, d, fp);
615 putpoint(p, a, fp);
616 putpoint(p, b, fp);
617 }
618 if (cf & T2_OK) {
619 fprintf(fp, "\n%s polygon %s.%sB\n", m, bn, fn);
620 fprintf(fp, "0\n0\n9\n");
621 putpoint(p, b, fp);
622 putpoint(p, c, fp);
623 putpoint(p, d, fp);
624 }
625 }
626
627
628 #define ldot(v1,v2) (v1[0]*v2[0]+v1[1]*v2[1]+v1[2]*v2[2])
629
630
631 long
632 lcross(vr, v1, v2) /* compute cross product */
633 register long vr[3], v1[3], v2[3];
634 {
635 vr[0] = v1[1]*v2[2] - v1[2]*v2[1];
636 vr[1] = v1[2]*v2[0] - v1[0]*v2[2];
637 vr[2] = v1[0]*v2[1] - v1[1]*v2[0];
638 }
639
640
641 #define labs(a) ((a)>0 ? (a) : -(a))
642
643
644 checkface(p, a, b, c, d) /* check a face for validity */
645 register PRISM *p;
646 int a, b, c, d;
647 {
648 int rval = 0;
649 long lt;
650 long vc1[3], vc2[3], vt1[3], vt2[3];
651 long vc1l, vc2l, vc1vc2;
652 /* check first triangle */
653 vt1[0] = p_x(p,b) - p_x(p,a);
654 vt1[1] = p_y(p,b) - p_y(p,a);
655 vt1[2] = p_z(p,b) - p_z(p,a);
656 vt2[0] = p_x(p,d) - p_x(p,a);
657 vt2[1] = p_y(p,d) - p_y(p,a);
658 vt2[2] = p_z(p,d) - p_z(p,a);
659 lcross(vc1, vt1, vt2);
660 lt = labs(vc1[0]) + labs(vc1[1]) + labs(vc1[2]);
661 if (lt > 1L<<18) lt = 16;
662 else if (lt > 1L<<12) lt = 8;
663 else lt = 0;
664 if (lt) { vc1[0] >>= lt; vc1[1] >>= lt; vc1[2] >>= lt; }
665 vc1l = ldot(vc1,vc1);
666 if (vc1l > 4)
667 rval |= T1_OK;
668 /* check second triangle */
669 vt1[0] = p_x(p,d) - p_x(p,c);
670 vt1[1] = p_y(p,d) - p_y(p,c);
671 vt1[2] = p_z(p,d) - p_z(p,c);
672 vt2[0] = p_x(p,b) - p_x(p,c);
673 vt2[1] = p_y(p,b) - p_y(p,c);
674 vt2[2] = p_z(p,b) - p_z(p,c);
675 lcross(vc2, vt1, vt2);
676 lt = labs(vc2[0]) + labs(vc2[1]) + labs(vc2[2]);
677 if (lt > 1L<<18) lt = 16;
678 else if (lt > 1L<<12) lt = 8;
679 else lt = 0;
680 if (lt) { vc2[0] >>= lt; vc2[1] >>= lt; vc2[2] >>= lt; }
681 vc2l = ldot(vc2,vc2);
682 if (vc2l > 4)
683 rval |= T2_OK;
684 /* check quadrilateral */
685 if (rval == (T1_OK|T2_OK)) {
686 vc1vc2 = ldot(vc1,vc2);
687 if (vc1vc2*vc1vc2 >= vc1l*vc2l-8)
688 rval |= QL_OK;
689 }
690 return(rval);
691 }
692
693
694 putpoint(p, n, fp) /* put out a point */
695 register PRISM *p;
696 int n;
697 FILE *fp;
698 {
699 register int i = n&3;
700
701 fprintf(fp, ptfmt, p->x[i]*fhead.length_f, p->y[i]*fhead.length_f,
702 (n&4 ? p->h[i] : p->z[i])*fhead.length_f);
703 }
704
705
706 eputs(s)
707 char *s;
708 {
709 fputs(s, stderr);
710 }
711
712
713 quit(code)
714 int code;
715 {
716 exit(code);
717 }
