root/radiance/ray/src/cv/arch2rad.c
Thu Feb 9 21:54:10 2023 UTC (2 years, 5 months ago) by greg
Changes since 2.4: +25 -25 lines
Diff to previous 2.4 , to selected 1.4
fix: compile error fixes related to redeclaration of eputs() and wputs()
Sat Dec 28 18:05:14 2019 UTC (5 years, 7 months ago) by greg
Changes since 2.3: +1 -3 lines
Diff to previous 2.3 , to selected 1.4
Sat Nov 15 17:54:06 2003 UTC (21 years, 8 months ago) by schorsch
Changes since 2.2: +146 -67 lines
Diff to previous 2.2 , to selected 1.4
Sat Feb 22 02:07:23 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.1: +6 -5 lines
Diff to previous 2.1 , to selected 1.4
Tue Nov 12 17:02:07 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.7 , to selected 1.4
Mon Oct 14 09:51:16 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.6: +4 -3 lines
Diff to previous 1.6 , to selected 1.4
fixed bugs relating to opening clip modifier
Mon Mar 11 13:10:26 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.5: +12 -12 lines
Diff to previous 1.5 , to selected 1.4
fixed expansion of openings in putopening() (bug from 1.5 change)
Thu Feb 14 13:18:30 1991 UTC (34 years, 6 months ago) by greg
Changes since 1.4: +8 -8 lines
Diff to previous 1.4
corrected assignment of reference and opposite faces (bug fix)
Revision 1.4 - (view) (download) (annotate) - [selected]
Mon Feb 11 18:18:53 1991 UTC (34 years, 6 months ago) by greg
Changes since 1.3: +13 -11 lines
Diff to previous 1.3
changed id naming to include layer name
fixed rule matching for layer id's (bug fix)
Mon Dec 17 14:43:08 1990 UTC (34 years, 7 months ago) by greg
Changes since 1.2: +6 -7 lines
Diff to previous 1.2 , to selected 1.4
made reading headers a little more flexible
Thu Dec 13 16:02:42 1990 UTC (34 years, 8 months ago) by greg
Diff to previous 1.1 , to selected 1.4
reversed orientation of opening surfaces (bug)
Tue Dec 11 08:45:46 1990 UTC (34 years, 8 months ago) by greg
Diff to selected 1.4
