| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: arch2rad.c,v 2.3 2003/11/15 17:54:06 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Convert Architrion file to Radiance
| 6 |
| 7 |
* Greg Ward
| 8 |
| 9 |
| 10 |
#include <stdlib.h>
| 11 |
| 12 |
#include "rtio.h"
| 13 |
#include "trans.h"
| 14 |
| 15 |
#define DEFMAPFILE "/usr/local/lib/ray/lib/arch.map"
| 16 |
| 17 |
/* qualifiers */
| 18 |
#define Q_COL 0
| 19 |
#define Q_FAC 1
| 20 |
#define Q_LAY 2
| 21 |
#define Q_REF 3
| 22 |
#define NQUALS 4
| 23 |
| 24 |
char *qname[NQUALS] = {
| 25 |
"Color",
| 26 |
"Face",
| 27 |
"Layer",
| 28 |
"RefId",
| 29 |
| 30 |
| 31 |
QLIST qlist = {NQUALS, qname};
| 32 |
/* face ids */
| 33 |
#define F_BOT 0
| 34 |
#define F_END 1
| 35 |
#define F_OPP 2
| 36 |
#define F_REF 3
| 37 |
#define F_SIL 4
| 38 |
#define F_TOP 5
| 39 |
#define NFACES 6
| 40 |
ID faceId[NFACES] = {
| 41 |
{"bottom"},{"end"},{"opposite"},{"reference"},{"sill"},{"top"}
| 42 |
| 43 |
/* valid qualifier ids */
| 44 |
IDLIST qual[NQUALS] = {
| 45 |
{ 0, NULL },
| 46 |
{ NFACES, faceId },
| 47 |
{ 0, NULL },
| 48 |
{ 0, NULL },
| 49 |
| 50 |
/* mapping rules */
| 51 |
RULEHD *ourmap = NULL;
| 52 |
/* file header */
| 53 |
struct header {
| 54 |
char *filename;
| 55 |
char *layer[9];
| 56 |
char length_u[16], area_u[16];
| 57 |
double length_f, area_f;
| 58 |
int nblocks, nopenings;
| 59 |
} fhead;
| 60 |
/* block or opening geometry */
| 61 |
typedef struct {
| 62 |
int x[4], y[4], z[4], h[4];
| 63 |
} PRISM;
| 64 |
/* macros for x,y,z */
| 65 |
#define p_x(p,i) ((p)->x[(i)&3])
| 66 |
#define p_y(p,i) ((p)->y[(i)&3])
| 67 |
#define p_z(p,i) ((i)&4 ? (p)->h[(i)&3] : (p)->z[i])
| 68 |
/* opening */
| 69 |
typedef struct {
| 70 |
PRISM p;
| 71 |
int corner;
| 72 |
int depth;
| 73 |
ID frame;
| 74 |
} OPNG;
| 75 |
/* block */
| 76 |
typedef struct {
| 77 |
short layer;
| 78 |
short color;
| 79 |
ID refid;
| 80 |
PRISM p;
| 81 |
int nopenings;
| 82 |
OPNG *opening;
| 83 |
} BLOCK;
| 84 |
/* point format */
| 85 |
char ptfmt[] = "\t%12.9g %12.9g %12.9g\n";
| 86 |
/* antimatter modifier id for openings */
| 87 |
char openmod[] = "opening";
| 88 |
/* return flags for checkface() */
| 89 |
#define T1_OK 1
| 90 |
#define T2_OK 2
| 91 |
#define QL_OK 4
| 92 |
| 93 |
char *progname; /* argv[0] */
| 94 |
| 95 |
void arch2rad(FILE *inp, FILE *out);
| 96 |
void arch2names(FILE *inp);
| 97 |
| 98 |
int hasmatch(BLOCK *bp, RULEHD *mp);
| 99 |
| 100 |
void getfhead(FILE *fp);
| 101 |
void puthead(FILE *fp);
| 102 |
| 103 |
int getblock(BLOCK *bp, FILE *fp);
| 104 |
void putblock(BLOCK *bp, FILE *fp);
| 105 |
void doneblock(BLOCK *bp);
| 106 |
| 107 |
int getopening(OPNG *op, FILE *fp);
| 108 |
void add2quals(BLOCK *bp);
| 109 |
int matchrule(BLOCK *bp, RULEHD *rp);
| 110 |
| 111 |
void putopenmod(char *sm, char *ml[], int nm, FILE *fp);
| 112 |
void putface(char *m, char *bn, char *fn, PRISM *p,
| 113 |
int a, int b, int c, int d, FILE *fp);
| 114 |
void putfaces(char *m, BLOCK *bp, int ff, FILE *fp);
| 115 |
void putpoint(PRISM *p, int n, FILE *fp);
| 116 |
void putopening(OPNG *op, FILE *fp);
| 117 |
| 118 |
int checkface(PRISM *p, int a, int b, int c, int d);
| 119 |
| 120 |
void lcross(long vr[3], long v1[3], long v2[3]);
| 121 |
| 122 |
| 123 |
int
| 124 |
main( /* translate Architrion file */
| 125 |
int argc,
| 126 |
char *argv[]
| 127 |
| 128 |
| 129 |
int donames = 0; /* -n flag, produce namelist */
| 130 |
int i;
| 131 |
| 132 |
progname = argv[0];
| 133 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 134 |
switch (argv[i][1]) {
| 135 |
case 'n': /* just produce name list */
| 136 |
donames++;
| 137 |
break;
| 138 |
case 'm': /* use custom mapfile */
| 139 |
ourmap = getmapping(argv[++i], &qlist);
| 140 |
break;
| 141 |
default:
| 142 |
goto userr;
| 143 |
| 144 |
if (i < argc-1)
| 145 |
goto userr;
| 146 |
if (i == argc-1)
| 147 |
if (freopen(argv[i], "r", stdin) == NULL) {
| 148 |
fprintf(stderr, "%s: cannot open\n", argv[i]);
| 149 |
exit(1);
| 150 |
| 151 |
getfhead(stdin); /* get Architrion header */
| 152 |
if (donames) { /* scan for ids */
| 153 |
arch2names(stdin);
| 154 |
printf("filename \"%s\"\n", fhead.filename);
| 155 |
printf("filetype \"Architrion\"\n");
| 156 |
write_quals(&qlist, qual, stdout);
| 157 |
} else { /* translate file */
| 158 |
if (ourmap == NULL)
| 159 |
ourmap = getmapping(DEFMAPFILE, &qlist);
| 160 |
arch2rad(stdin, stdout);
| 161 |
| 162 |
return(0);
| 163 |
userr:
| 164 |
fprintf(stderr, "Usage: %s [-n][-m mapfile] [input]\n", argv[0]);
| 165 |
exit(1);
| 166 |
| 167 |
| 168 |
| 169 |
void
| 170 |
arch2rad( /* translate Architrion file to Radiance */
| 171 |
FILE *inp,
| 172 |
FILE *out
| 173 |
| 174 |
| 175 |
int nbs, nos;
| 176 |
BLOCK blk;
| 177 |
| 178 |
puthead(out);
| 179 |
nbs = nos = 0;
| 180 |
while (getblock(&blk, inp) != EOF) {
| 181 |
putblock(&blk, out);
| 182 |
nbs++;
| 183 |
nos += blk.nopenings;
| 184 |
doneblock(&blk);
| 185 |
| 186 |
if (nbs != fhead.nblocks)
| 187 |
fprintf(stderr,
| 188 |
"%s: warning -- block count incorrect (%d != %d)\n",
| 189 |
progname, nbs, fhead.nblocks);
| 190 |
if (nos != fhead.nopenings)
| 191 |
fprintf(stderr,
| 192 |
"%s: warning -- opening count incorrect (%d != %d)\n",
| 193 |
progname, nos, fhead.nopenings);
| 194 |
| 195 |
| 196 |
| 197 |
void
| 198 |
arch2names( /* get name list from an Architrion file */
| 199 |
FILE *inp
| 200 |
| 201 |
| 202 |
BLOCK blk;
| 203 |
| 204 |
| 205 |
if (ourmap == NULL || hasmatch(&blk, ourmap))
| 206 |
add2quals(&blk);
| 207 |
doneblock(&blk);
| 208 |
| 209 |
| 210 |
| 211 |
| 212 |
int
| 213 |
hasmatch( /* check for any match in rule list */
| 214 |
BLOCK *bp,
| 215 |
RULEHD *mp
| 216 |
| 217 |
| 218 |
if (mp == NULL)
| 219 |
return(0);
| 220 |
if (hasmatch(bp, mp->next)) /* check in order -- more likely */
| 221 |
return(1);
| 222 |
return(matchrule(bp, mp));
| 223 |
| 224 |
| 225 |
| 226 |
void
| 227 |
getfhead( /* get file header */
| 228 |
FILE *fp
| 229 |
| 230 |
| 231 |
char buf[MAXSTR];
| 232 |
int i, n;
| 233 |
register int c;
| 234 |
/* get file name */
| 235 |
if (fgets(buf, MAXSTR, fp) == NULL)
| 236 |
goto readerr;
| 237 |
buf[strlen(buf)-1] = '\0';
| 238 |
fhead.filename = savestr(buf);
| 239 |
/* get layers */
| 240 |
fhead.layer[0] = "Worksheet";
| 241 |
for (i = 1; i <= 8; i++) {
| 242 |
if (fscanf(fp, "L%*[^0-8]%d", &n) != 1 || n != i)
| 243 |
goto readerr;
| 244 |
while ((c = getc(fp)) != EOF && (c == ' ' || c == '\t'))
| 245 |
| 246 |
if (c == EOF)
| 247 |
goto readerr;
| 248 |
ungetc(c, fp);
| 249 |
| 250 |
goto readerr;
| 251 |
| 252 |
if (buf[0])
| 253 |
fhead.layer[i] = savestr(buf);
| 254 |
else
| 255 |
fhead.layer[i] = NULL;
| 256 |
| 257 |
/* get units */
| 258 |
| 259 |
goto readerr;
| 260 |
if (sscanf(buf, "0 %*f %s %*f %s\n",
| 261 |
fhead.length_u, fhead.area_u) != 2) {
| 262 |
fhead.length_u[0] = '\0';
| 263 |
fhead.area_u[0] = '\0';
| 264 |
| 265 |
if (fgets(buf, MAXSTR, fp) == NULL ||
| 266 |
sscanf(buf, "0 %lf\n", &fhead.length_f) != 1)
| 267 |
goto readerr;
| 268 |
| 269 |
sscanf(buf, "0 %lf\n", &fhead.area_f) != 1)
| 270 |
goto readerr;
| 271 |
/* get number of blocks and openings */
| 272 |
| 273 |
sscanf(buf, "0 %d %d\n", &fhead.nblocks,
| 274 |
&fhead.nopenings) != 2)
| 275 |
goto readerr;
| 276 |
return;
| 277 |
readerr:
| 278 |
fprintf(stderr, "%s: error reading Architrion header\n", progname);
| 279 |
exit(1);
| 280 |
| 281 |
| 282 |
| 283 |
void
| 284 |
puthead( /* put out header information */
| 285 |
FILE *fp
| 286 |
| 287 |
| 288 |
register int i;
| 289 |
| 290 |
fprintf(fp, "# File created by: %s\n", progname);
| 291 |
fprintf(fp, "# Input file: %s\n", fhead.filename);
| 292 |
fprintf(fp, "# Input units: %s\n", fhead.length_u);
| 293 |
fprintf(fp, "# Output units: meters\n");
| 294 |
fprintf(fp, "# Named layers:\n");
| 295 |
for (i = 0; i < 8; i++)
| 296 |
if (fhead.layer[i] != NULL)
| 297 |
fprintf(fp, "#\tLayer No. %d\t%s\n", i, fhead.layer[i]);
| 298 |
| 299 |
| 300 |
| 301 |
int
| 302 |
getblock( /* get an Architrion block */
| 303 |
register BLOCK *bp,
| 304 |
FILE *fp
| 305 |
| 306 |
| 307 |
char word[32];
| 308 |
int i;
| 309 |
| 310 |
if (fgets(word, sizeof(word), fp) == NULL)
| 311 |
return(EOF);
| 312 |
if (strncmp(word, "Block", 5))
| 313 |
return(EOF);
| 314 |
if (fscanf(fp, "1 %hd %hd %d", &bp->layer,
| 315 |
&bp->color, &bp->nopenings) != 3)
| 316 |
return(EOF);
| 317 |
if (fgetid(&bp->refid, "\n", fp) == EOF)
| 318 |
return(EOF);
| 319 |
if (fscanf(fp, "1 %d %d %d %d %d %d %d %d\n",
| 320 |
&bp->p.x[0], &bp->p.y[0], &bp->p.z[0], &bp->p.h[0],
| 321 |
&bp->p.x[1], &bp->p.y[1], &bp->p.z[1], &bp->p.h[1]) != 8)
| 322 |
return(EOF);
| 323 |
| 324 |
&bp->p.x[2], &bp->p.y[2], &bp->p.z[2], &bp->p.h[2],
| 325 |
&bp->p.x[3], &bp->p.y[3], &bp->p.z[3], &bp->p.h[3]) != 8)
| 326 |
return(EOF);
| 327 |
if (bp->nopenings == 0) {
| 328 |
bp->opening = NULL;
| 329 |
return(0);
| 330 |
| 331 |
bp->opening = (OPNG *)malloc(bp->nopenings*sizeof(OPNG));
| 332 |
if (bp->opening == NULL)
| 333 |
goto memerr;
| 334 |
for (i = 0; i < bp->nopenings; i++)
| 335 |
if (getopening(&bp->opening[i], fp) < 0)
| 336 |
return(EOF);
| 337 |
return(0);
| 338 |
memerr:
| 339 |
fprintf(stderr, "%s: out of memory in getblock\n", progname);
| 340 |
exit(1);
| 341 |
| 342 |
| 343 |
| 344 |
int
| 345 |
getopening( /* read in opening from fp */
| 346 |
register OPNG *op,
| 347 |
FILE *fp
| 348 |
| 349 |
| 350 |
register int c;
| 351 |
char word[32];
| 352 |
| 353 |
| 354 |
return(EOF);
| 355 |
if (strncmp(word, "Opening", 7))
| 356 |
return(EOF);
| 357 |
if (fscanf(fp, "2 %d %d %d %d %d %d %d %d\n",
| 358 |
&op->p.x[0], &op->p.y[0],
| 359 |
&op->p.z[0], &op->p.h[0],
| 360 |
&op->p.x[1], &op->p.y[1],
| 361 |
&op->p.z[1], &op->p.h[1]) != 8)
| 362 |
return(EOF);
| 363 |
| 364 |
&op->p.x[2], &op->p.y[2],
| 365 |
&op->p.z[2], &op->p.h[2],
| 366 |
&op->p.x[3], &op->p.y[3],
| 367 |
&op->p.z[3], &op->p.h[3]) != 8)
| 368 |
return(EOF);
| 369 |
c = getc(fp);
| 370 |
if (c == '3') {
| 371 |
if (fscanf(fp, "%d %d", &op->corner, &op->depth) != 2)
| 372 |
return(EOF);
| 373 |
if (fgetid(&op->frame, "\n", fp) == EOF)
| 374 |
return(EOF);
| 375 |
} else {
| 376 |
op->corner = -1;
| 377 |
op->frame.name = NULL;
| 378 |
if (c != EOF)
| 379 |
ungetc(c, fp);
| 380 |
| 381 |
return(0);
| 382 |
| 383 |
| 384 |
| 385 |
void
| 386 |
doneblock( /* free data associated with bp */
| 387 |
register BLOCK *bp
| 388 |
| 389 |
| 390 |
register int i;
| 391 |
| 392 |
if (bp->nopenings > 0) {
| 393 |
| 394 |
doneid(&bp->opening[i].frame);
| 395 |
free((void *)bp->opening);
| 396 |
| 397 |
doneid(&bp->refid);
| 398 |
| 399 |
| 400 |
| 401 |
void
| 402 |
add2quals( /* add to qualifier lists */
| 403 |
register BLOCK *bp
| 404 |
| 405 |
| 406 |
ID tmpid;
| 407 |
| 408 |
if (fhead.layer[bp->layer] == NULL) {
| 409 |
tmpid.name = NULL;
| 410 |
tmpid.number = bp->layer;
| 411 |
} else {
| 412 |
tmpid.name = fhead.layer[bp->layer];
| 413 |
tmpid.number = 0;
| 414 |
| 415 |
findid(&qual[Q_LAY], &tmpid, 1);
| 416 |
tmpid.name = NULL;
| 417 |
tmpid.number = bp->color;
| 418 |
findid(&qual[Q_COL], &tmpid, 1);
| 419 |
findid(&qual[Q_REF], &bp->refid, 1);
| 420 |
| 421 |
| 422 |
| 423 |
void
| 424 |
putblock( /* put out a block */
| 425 |
BLOCK *bp,
| 426 |
FILE *fp
| 427 |
| 428 |
| 429 |
RULEHD *rp;
| 430 |
char *mod[NFACES], *sillmod;
| 431 |
int nmods, i;
| 432 |
int donematch, newmatch;
| 433 |
| 434 |
nmods = 0; sillmod = NULL;
| 435 |
donematch = 0;
| 436 |
for (rp = ourmap; rp != NULL; rp = rp->next) {
| 437 |
newmatch = matchrule(bp, rp); /* test this rule */
| 438 |
newmatch &= ~donematch; /* don't repeat */
| 439 |
if (newmatch == 0)
| 440 |
continue;
| 441 |
mod[nmods++] = rp->mnam;
| 442 |
if (sillmod == NULL && newmatch&F_SIL)
| 443 |
sillmod = rp->mnam;
| 444 |
putfaces(rp->mnam, bp, newmatch, fp); /* put out new faces */
| 445 |
donematch |= newmatch;
| 446 |
if (donematch == (1<<NFACES)-1)
| 447 |
break; /* done all faces */
| 448 |
| 449 |
/* put out openings */
| 450 |
if (donematch && bp->nopenings > 0) {
| 451 |
putopenmod(sillmod, mod, nmods, fp);
| 452 |
| 453 |
putopening(&bp->opening[i], fp);
| 454 |
| 455 |
if (ferror(fp)) {
| 456 |
fprintf(stderr, "%s: write error in putblock\n", progname);
| 457 |
exit(1);
| 458 |
| 459 |
| 460 |
| 461 |
| 462 |
void
| 463 |
putopenmod( /* put out opening modifier */
| 464 |
char *sm,
| 465 |
char *ml[],
| 466 |
int nm,
| 467 |
FILE *fp
| 468 |
| 469 |
| 470 |
int rept, nrepts;
| 471 |
register int i, j;
| 472 |
| 473 |
if (sm == NULL) { /* if no sill modifier, use list */
| 474 |
sm = *ml++;
| 475 |
nm--;
| 476 |
| 477 |
/* check for repeats */
| 478 |
rept = 0; nrepts = 0;
| 479 |
for (i = 0; i < nm; i++) {
| 480 |
if (ml[i] == sm || !strcmp(ml[i], VOIDID)) {
| 481 |
rept |= 1<<i;
| 482 |
nrepts++;
| 483 |
continue;
| 484 |
| 485 |
for (j = 0; j < i; j++)
| 486 |
if (!(rept & 1<<j) && ml[j] == ml[i]) {
| 487 |
rept |= 1<<j;
| 488 |
nrepts++;
| 489 |
| 490 |
| 491 |
/* print antimatter and modlist */
| 492 |
fprintf(fp, "\n%s antimatter %s\n", VOIDID, openmod);
| 493 |
fprintf(fp, "%d %s", 1+nm-nrepts, sm);
| 494 |
| 495 |
if (!(rept & 1<<i))
| 496 |
fprintf(fp, " %s", ml[i]);
| 497 |
fprintf(fp, "\n0\n0\n");
| 498 |
| 499 |
| 500 |
| 501 |
void
| 502 |
putopening( /* put out an opening */
| 503 |
OPNG *op,
| 504 |
FILE *fp
| 505 |
| 506 |
| 507 |
static int nopens = 0;
| 508 |
char buf[32];
| 509 |
register PRISM *p = &op->p;
| 510 |
PRISM newp;
| 511 |
register int i;
| 512 |
/* copy original prism */
| 513 |
for (i = 0; i < 4; i++) {
| 514 |
newp.x[i] = p->x[i];
| 515 |
newp.y[i] = p->y[i];
| 516 |
newp.z[i] = p->z[i];
| 517 |
newp.h[i] = p->h[i];
| 518 |
| 519 |
/* spread reference and opposite */
| 520 |
if (p->x[2] > p->x[0]) {
| 521 |
newp.x[0] -= 2;
| 522 |
newp.x[1] -= 2;
| 523 |
newp.x[2] += 2;
| 524 |
newp.x[3] += 2;
| 525 |
} else if (p->x[0] > p->x[2]) {
| 526 |
newp.x[0] += 2;
| 527 |
newp.x[1] += 2;
| 528 |
newp.x[2] -= 2;
| 529 |
newp.x[3] -= 2;
| 530 |
| 531 |
if (p->y[2] > p->y[0]) {
| 532 |
newp.y[0] -= 2;
| 533 |
newp.y[1] -= 2;
| 534 |
newp.y[2] += 2;
| 535 |
newp.y[3] += 2;
| 536 |
} else if (p->y[0] > p->y[2]) {
| 537 |
newp.y[0] += 2;
| 538 |
newp.y[1] += 2;
| 539 |
newp.y[2] -= 2;
| 540 |
newp.y[3] -= 2;
| 541 |
| 542 |
/* put out faces */
| 543 |
sprintf(buf, "op%d", ++nopens);
| 544 |
putface(openmod, buf, "ref", &newp, 4, 5, 1, 0, fp);
| 545 |
putface(openmod, buf, "opp", &newp, 2, 6, 7, 3, fp);
| 546 |
putface(openmod, buf, "end1", &newp, 5, 6, 2, 1, fp);
| 547 |
putface(openmod, buf, "end2", &newp, 3, 7, 4, 0, fp);
| 548 |
putface(openmod, buf, "bot", &newp, 1, 2, 3, 0, fp);
| 549 |
putface(openmod, buf, "top", &newp, 7, 6, 5, 4, fp);
| 550 |
| 551 |
| 552 |
| 553 |
int
| 554 |
matchrule( /* see if block matches this rule */
| 555 |
register BLOCK *bp,
| 556 |
register RULEHD *rp
| 557 |
| 558 |
| 559 |
register int i;
| 560 |
ID tmpid;
| 561 |
| 562 |
if (rp->qflg & FL(Q_LAY)) { /* check layer */
| 563 |
| 564 |
| 565 |
if (!matchid(&tmpid, &idm(rp)[Q_LAY]))
| 566 |
return(0);
| 567 |
| 568 |
if (rp->qflg & FL(Q_COL)) { /* check color */
| 569 |
tmpid.name = NULL;
| 570 |
| 571 |
if (!matchid(&tmpid, &idm(rp)[Q_COL]))
| 572 |
return(0);
| 573 |
| 574 |
if (rp->qflg & FL(Q_REF)) { /* check reference id */
| 575 |
if (!matchid(&bp->refid, &idm(rp)[Q_REF]))
| 576 |
return(0);
| 577 |
| 578 |
if (rp->qflg & FL(Q_FAC)) { /* check faces */
| 579 |
for (i = 0; i < NFACES; i++)
| 580 |
if (matchid(&faceId[i], &idm(rp)[Q_FAC]))
| 581 |
return(1<<i); /* match single face */
| 582 |
return(0);
| 583 |
| 584 |
return((1<<NFACES)-1); /* matched all faces */
| 585 |
| 586 |
| 587 |
| 588 |
void
| 589 |
putfaces( /* put out faces */
| 590 |
char *m,
| 591 |
BLOCK *bp,
| 592 |
register int ff,
| 593 |
FILE *fp
| 594 |
| 595 |
| 596 |
char *blkname(), *bn;
| 597 |
| 598 |
if (!strcmp(m, VOIDID))
| 599 |
return;
| 600 |
bn = blkname(bp);
| 601 |
if (ff & 1<<F_REF)
| 602 |
putface(m, bn, "ref", &bp->p, 4, 5, 1, 0, fp);
| 603 |
if (ff & 1<<F_OPP)
| 604 |
putface(m, bn, "opp", &bp->p, 2, 6, 7, 3, fp);
| 605 |
if (ff & 1<<F_END) {
| 606 |
putface(m, bn, "end1", &bp->p, 5, 6, 2, 1, fp);
| 607 |
putface(m, bn, "end2", &bp->p, 3, 7, 4, 0, fp);
| 608 |
| 609 |
if (ff & 1<<F_BOT)
| 610 |
putface(m, bn, "bot", &bp->p, 1, 2, 3, 0, fp);
| 611 |
if (ff & 1<<F_TOP)
| 612 |
putface(m, bn, "top", &bp->p, 7, 6, 5, 4, fp);
| 613 |
| 614 |
| 615 |
| 616 |
char *
| 617 |
blkname( /* think up a good name for this block */
| 618 |
register BLOCK *bp
| 619 |
| 620 |
| 621 |
static char nambuf[32];
| 622 |
static int blkcnt = 0;
| 623 |
register char *nam;
| 624 |
register int i, j;
| 625 |
| 626 |
sprintf(nambuf, "l%d.", bp->layer);
| 627 |
i = strlen(nambuf);
| 628 |
nam = bp->refid.name;
| 629 |
if (nam == NULL) {
| 630 |
nam = fhead.layer[bp->layer];
| 631 |
if (nam != NULL)
| 632 |
i = 0;
| 633 |
| 634 |
if (nam != NULL) {
| 635 |
for (j = 0; j < 12 && nam[j]; j++) {
| 636 |
if (nam[j] == ' ' || nam[j] == '\t')
| 637 |
nambuf[i++] = '_';
| 638 |
else
| 639 |
nambuf[i++] = nam[j];
| 640 |
| 641 |
nambuf[i++] = '.';
| 642 |
| 643 |
if (bp->refid.number != 0) {
| 644 |
sprintf(nambuf+i, "r%d.", bp->refid.number);
| 645 |
i = strlen(nambuf);
| 646 |
| 647 |
sprintf(nambuf+i, "b%d", ++blkcnt);
| 648 |
return(nambuf);
| 649 |
| 650 |
| 651 |
| 652 |
void
| 653 |
putface( /* put out a face */
| 654 |
char *m,
| 655 |
char *bn,
| 656 |
char *fn,
| 657 |
PRISM *p,
| 658 |
int a,
| 659 |
int b,
| 660 |
int c,
| 661 |
int d,
| 662 |
FILE *fp
| 663 |
| 664 |
| 665 |
int cf;
| 666 |
| 667 |
cf = checkface(p, a, b, c, d);
| 668 |
if (cf & QL_OK) {
| 669 |
fprintf(fp, "\n%s polygon %s.%s\n", m, bn, fn);
| 670 |
fprintf(fp, "0\n0\n12\n");
| 671 |
putpoint(p, a, fp);
| 672 |
putpoint(p, b, fp);
| 673 |
putpoint(p, c, fp);
| 674 |
putpoint(p, d, fp);
| 675 |
return;
| 676 |
| 677 |
if (cf & T1_OK) {
| 678 |
fprintf(fp, "\n%s polygon %s.%sA\n", m, bn, fn);
| 679 |
fprintf(fp, "0\n0\n9\n");
| 680 |
putpoint(p, d, fp);
| 681 |
putpoint(p, a, fp);
| 682 |
putpoint(p, b, fp);
| 683 |
| 684 |
if (cf & T2_OK) {
| 685 |
fprintf(fp, "\n%s polygon %s.%sB\n", m, bn, fn);
| 686 |
| 687 |
putpoint(p, b, fp);
| 688 |
putpoint(p, c, fp);
| 689 |
putpoint(p, d, fp);
| 690 |
| 691 |
| 692 |
| 693 |
| 694 |
#define ldot(v1,v2) (v1[0]*v2[0]+v1[1]*v2[1]+v1[2]*v2[2])
| 695 |
| 696 |
| 697 |
void
| 698 |
lcross( /* compute cross product */
| 699 |
register long vr[3],
| 700 |
register long v1[3],
| 701 |
register long v2[3]
| 702 |
| 703 |
| 704 |
vr[0] = v1[1]*v2[2] - v1[2]*v2[1];
| 705 |
vr[1] = v1[2]*v2[0] - v1[0]*v2[2];
| 706 |
vr[2] = v1[0]*v2[1] - v1[1]*v2[0];
| 707 |
| 708 |
| 709 |
| 710 |
#define labs(a) ((a)>0 ? (a) : -(a))
| 711 |
| 712 |
| 713 |
int
| 714 |
checkface( /* check a face for validity */
| 715 |
register PRISM *p,
| 716 |
int a,
| 717 |
int b,
| 718 |
int c,
| 719 |
int d
| 720 |
| 721 |
| 722 |
int rval = 0;
| 723 |
long lt;
| 724 |
long vc1[3], vc2[3], vt1[3], vt2[3];
| 725 |
long vc1l, vc2l, vc1vc2;
| 726 |
/* check first triangle */
| 727 |
vt1[0] = p_x(p,b) - p_x(p,a);
| 728 |
vt1[1] = p_y(p,b) - p_y(p,a);
| 729 |
vt1[2] = p_z(p,b) - p_z(p,a);
| 730 |
vt2[0] = p_x(p,d) - p_x(p,a);
| 731 |
vt2[1] = p_y(p,d) - p_y(p,a);
| 732 |
vt2[2] = p_z(p,d) - p_z(p,a);
| 733 |
lcross(vc1, vt1, vt2);
| 734 |
lt = labs(vc1[0]) + labs(vc1[1]) + labs(vc1[2]);
| 735 |
if (lt > 1L<<18) lt = 16;
| 736 |
else if (lt > 1L<<12) lt = 8;
| 737 |
else lt = 0;
| 738 |
if (lt) { vc1[0] >>= lt; vc1[1] >>= lt; vc1[2] >>= lt; }
| 739 |
vc1l = ldot(vc1,vc1);
| 740 |
if (vc1l > 4)
| 741 |
rval |= T1_OK;
| 742 |
/* check second triangle */
| 743 |
vt1[0] = p_x(p,d) - p_x(p,c);
| 744 |
vt1[1] = p_y(p,d) - p_y(p,c);
| 745 |
vt1[2] = p_z(p,d) - p_z(p,c);
| 746 |
vt2[0] = p_x(p,b) - p_x(p,c);
| 747 |
vt2[1] = p_y(p,b) - p_y(p,c);
| 748 |
vt2[2] = p_z(p,b) - p_z(p,c);
| 749 |
lcross(vc2, vt1, vt2);
| 750 |
lt = labs(vc2[0]) + labs(vc2[1]) + labs(vc2[2]);
| 751 |
| 752 |
| 753 |
else lt = 0;
| 754 |
if (lt) { vc2[0] >>= lt; vc2[1] >>= lt; vc2[2] >>= lt; }
| 755 |
vc2l = ldot(vc2,vc2);
| 756 |
if (vc2l > 4)
| 757 |
rval |= T2_OK;
| 758 |
/* check quadrilateral */
| 759 |
if (rval == (T1_OK|T2_OK)) {
| 760 |
vc1vc2 = ldot(vc1,vc2);
| 761 |
if (vc1vc2*vc1vc2 >= vc1l*vc2l-8)
| 762 |
rval |= QL_OK;
| 763 |
| 764 |
return(rval);
| 765 |
| 766 |
| 767 |
| 768 |
void
| 769 |
putpoint( /* put out a point */
| 770 |
register PRISM *p,
| 771 |
int n,
| 772 |
FILE *fp
| 773 |
| 774 |
| 775 |
register int i = n&3;
| 776 |
| 777 |
fprintf(fp, ptfmt, p->x[i]*fhead.length_f, p->y[i]*fhead.length_f,
| 778 |
(n&4 ? p->h[i] : p->z[i])*fhead.length_f);
| 779 |
| 780 |
| 781 |
| 782 |
void
| 783 |
eputs(
| 784 |
char *s
| 785 |
| 786 |
| 787 |
fputs(s, stderr);
| 788 |
| 789 |
| 790 |
| 791 |
void
| 792 |
quit(
| 793 |
int code
| 794 |
| 795 |
| 796 |
exit(code);
| 797 |
| 798 |
