root/radiance/ray/src/cv/arch2rad.c
Sat Nov 15 17:54:06 2003 UTC (20 years, 7 months ago) by schorsch
Changes since 2.2: +146 -67 lines
Changes since 2.1: +6 -5 lines
Tue Nov 12 17:02:07 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.7 , to selected 1.2
Mon Oct 14 09:51:16 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.6: +4 -3 lines
fixed bugs relating to opening clip modifier
Mon Mar 11 13:10:26 1991 UTC (33 years, 3 months ago) by greg
Changes since 1.5: +12 -12 lines
fixed expansion of openings in putopening() (bug from 1.5 change)
Thu Feb 14 13:18:30 1991 UTC (33 years, 4 months ago) by greg
Changes since 1.4: +8 -8 lines
corrected assignment of reference and opposite faces (bug fix)
Mon Feb 11 18:18:53 1991 UTC (33 years, 4 months ago) by greg
Changes since 1.3: +13 -11 lines
changed id naming to include layer name
fixed rule matching for layer id's (bug fix)
Mon Dec 17 14:43:08 1990 UTC (33 years, 6 months ago) by greg
Changes since 1.2: +6 -7 lines
Diff to previous 1.2
made reading headers a little more flexible
Thu Dec 13 16:02:42 1990 UTC (33 years, 6 months ago) by greg
Diff to previous 1.1
reversed orientation of opening surfaces (bug)
Tue Dec 11 08:45:46 1990 UTC (33 years, 6 months ago) by greg
Diff to selected 1.2
