1 |
import os |
2 |
3 |
Import ('env') |
4 |
5 |
# math libs |
6 |
mlib = env['RAD_MLIB'] |
7 |
8 |
# compose paths |
9 |
def rbin(name): return os.path.join(env['RAD_BUILDBIN'], name) |
10 |
def rlib(name): return os.path.join(env['RAD_BUILDLIB'], name) |
11 |
def mgfs(src): return map(lambda s:os.path.join('mgflib', s), src) |
12 |
13 |
MGFSRC = Split('''parser.c context.c xf.c object.c lookup.c badarg.c |
14 |
words.c |
15 |
fvect.c''') |
16 |
libmgf = env.StaticLibrary(rlib('mgf'), source=mgfs(MGFSRC)) |
17 |
18 |
MGFPROGS = ( |
19 |
('mgfilt', Split('mgfilt.c')), |
20 |
('mgf2inv', Split('mgf2inv.c cvrgb.c')), |
21 |
('3ds2mgf', Split('3ds2mgf.c rayopt.c vect.c')), |
22 |
23 |
for p in MGFPROGS: |
24 |
prog = env.Program(target=rbin(p[0]), source=mgfs(p[1]), LIBS=mlib+['mgf']) |
25 |
Default(prog) |
26 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) |
27 |
28 |
trans = env.Object(source="trans.c") |
29 |
30 |
# standard targets |
31 |
PROGS = [ |
32 |
('ies2rad', ['ies2rad.c'], ['rtlamps','rtcolor','rtio','rtpath']+ mlib), |
33 |
('arch2rad', ['arch2rad.c',trans],['rtcont','rtmem'] + mlib), |
34 |
('nff2rad', ['nff2rad.c'], []), |
35 |
('lampcolor', ['lampcolor.c'], ['rtlamps','rtcolor','rtio','rtpath']), |
36 |
('tmesh2rad', ['tmesh2rad.c'], ['rtscene','rtmath'] + mlib), |
37 |
('obj2rad', ['obj2rad.c',trans], |
38 |
['rtscene','rtargs','rtio','rtcont','rtmem','rtmath','rterror'] + mlib), |
39 |
('mgf2rad', ['mgf2rad.c'], ['rtscene','rtcolor','mgf'] + mlib), |
40 |
('rad2mgf', ['rad2mgf.c'], |
41 |
['rtproc', 'rtpath', # for win_popen() |
42 |
'rtscene','rtio','rtcolor','rtcont','rtmem','rterror'] + mlib), |
43 |
44 |
for p in PROGS: |
45 |
prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=p[2]) |
46 |
Default(prog) |
47 |
48 |
49 |
# meta targets |
50 |
prog = env.Program(target=rbin('mgf2meta'), source=['mgf2meta.c'], |
51 |
CPPPATH=env.get('CPPPATH', []) + [os.path.join('#src','meta')], |
52 |
LIBS=['meta','rtmath','rtcont','rtmem','rterror','mgf'] + mlib) |
53 |
54 |
LIBFILES = Split('source.cal tilt.cal window.cal') |
55 |
env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES)) |
56 |
57 |
if os.name == 'posix': |
58 |
for s in Split('''optics2rad'''): |
59 |
Default(env.InstallCsh(rbin(s), s + '.csh')) |
