--- ray/src/cv/SConscript 2006/06/07 17:52:03 1.8 +++ ray/src/cv/SConscript 2016/03/10 21:43:22 1.15 @@ -7,53 +7,46 @@ mlib = env['RAD_MLIB'] # compose paths def rbin(name): return os.path.join(env['RAD_BUILDBIN'], name) -def rlib(name): return os.path.join(env['RAD_BUILDLIB'], name) -def mgfs(src): return map(lambda s:os.path.join('mgflib', s), src) -MGFSRC = Split('''parser.c context.c xf.c object.c lookup.c badarg.c - words.c - fvect.c''') -libmgf = env.StaticLibrary(rlib('mgf'), source=mgfs(MGFSRC)) - -MGFPROGS = ( -('mgfilt', Split('mgfilt.c')), -('mgf2inv', Split('mgf2inv.c cvrgb.c')), -('3ds2mgf', Split('3ds2mgf.c rayopt.c vect.c')), -) -for p in MGFPROGS: - prog = env.Program(target=rbin(p[0]), source=mgfs(p[1]), LIBS=mlib+['mgf']) - Default(prog) - env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) - trans = env.Object(source="trans.c") +bsdfrep = env.Object(source="bsdfrep.c") +bsdfinterp = env.Object(source="bsdfinterp.c") # standard targets PROGS = [ -('ies2rad', ['ies2rad.c'], ['rtlamps','rtcolor','rtio','rtpath']+ mlib), -('arch2rad', ['arch2rad.c',trans],['rtcont','rtmem'] + mlib), +('3ds2mgf', Split('3ds2mgf.c rayopt3ds.c vect3ds.c'), ['mgf','rtrad'] + mlib), +('ies2rad', ['ies2rad.c'], ['rtrad'] + mlib), +#('arch2rad', ['arch2rad.c',trans],['rtrad'] + mlib), ('nff2rad', ['nff2rad.c'], []), -('lampcolor', ['lampcolor.c'], ['rtlamps','rtcolor','rtio','rtpath']), -('tmesh2rad', ['tmesh2rad.c'], ['rtscene','rtmath'] + mlib), -('obj2rad', ['obj2rad.c',trans], - ['rtscene','rtargs','rtio','rtcont','rtmem','rtmath','rterror'] + mlib), -('mgf2rad', ['mgf2rad.c'], ['rtscene','rtcolor','mgf'] + mlib), -('rad2mgf', ['rad2mgf.c'], - ['rtproc', 'rtpath', # for win_popen() - 'rtscene','rtio','rtcolor','rtcont','rtmem','rterror'] + mlib), +('lampcolor', ['lampcolor.c'], ['rtrad'] ), +('tmesh2rad', ['tmesh2rad.c'], ['rtrad'] + mlib), +('obj2rad', ['obj2rad.c',trans], ['rtrad'] + mlib), +('mgf2rad', ['mgf2rad.c'], ['mgf','rtrad'] + mlib), +('rad2mgf', ['rad2mgf.c'], ['rtrad'] + mlib), +('mgfilt', ['mgfilt.c'], ['mgf','rtrad'] + mlib), +('mgf2inv', ['mgf2inv.c'], ['mgf','rtrad'] + mlib), +('pabopto2bsdf', + ['pabopto2bsdf.c',bsdfrep,'bsdfrbf.c', 'bsdfmesh.c', 'bsdftrans.cpp',], + ['rtrad'] + mlib), +('bsdf2klems',['bsdf2klems.c', bsdfrep, bsdfinterp,], ['rtrad'] + mlib), +('bsdf2ttree',['bsdf2ttree.c', bsdfrep, bsdfinterp,], ['rtrad'] + mlib), +('pkgBSDF', ['pkgBSDF.c', ], ['rtrad'] + mlib), +('epw2wea', ['epw2wea.c', ], ['rtrad'] + mlib), +('mgf2meta', ['mgf2meta.c'], ['meta', 'mgf','rtrad'] + mlib, + [os.path.join('#src','meta')]), ] for p in PROGS: - prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=p[2]) + if len(p) == 4: inclp = env.get('CPPPATH', []) + [os.path.join('#src','meta')], + else: inclp = env.get('CPPPATH', []) + prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=p[2], CPPPATH=inclp) Default(prog) env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) -# meta targets -prog = env.Program(target=rbin('mgf2meta'), source=['mgf2meta.c'], - CPPPATH=env.get('CPPPATH', []) + [os.path.join('#src','meta')], - LIBS=['meta','rtmath','rtcont','rtmem','rterror','mgf'] + mlib) - -LIBFILES = Split('source.cal tilt.cal lamp.tab window.cal') +LIBFILES = Split('source.cal tilt.cal window.cal') env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES)) if os.name == 'posix': for s in Split('''optics2rad'''): - Default(env.InstallCsh(rbin(s), s + '.csh')) + Default(env.InstallScript(rbin(s), s + '.csh')) + +# vim: set syntax=python:
