--- ray/src/cv/SConscript 2004/11/05 22:15:43 1.5 +++ ray/src/cv/SConscript 2005/09/12 14:44:09 1.6 @@ -6,22 +6,22 @@ Import ('env') mlib = env['RAD_MLIB'] # compose paths -def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name) -def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name) -def mgfsf(src): return map(lambda s:os.path.join('mgflib', s), src) +def rbin(name): return os.path.join(env['RAD_BUILDBIN'], name) +def rlib(name): return os.path.join(env['RAD_BUILDLIB'], name) +def mgfs(src): return map(lambda s:os.path.join('mgflib', s), src) MGFSRC = Split('''parser.c context.c xf.c object.c lookup.c badarg.c words.c fvect.c''') -libmgf = env.StaticLibrary(radlib('mgf'), source=mgfsf(MGFSRC)) +libmgf = env.StaticLibrary(rlib('mgf'), source=mgfs(MGFSRC)) + MGFPROGS = ( ('mgfilt', Split('mgfilt.c')), ('mgf2inv', Split('mgf2inv.c cvrgb.c')), ('3ds2mgf', Split('3ds2mgf.c rayopt.c vect.c')), ) for p in MGFPROGS: - prog = env.Program(target=radbin(p[0]), source=mgfsf(p[1]) + [libmgf], - LIBS=mlib) + prog = env.Program(target=rbin(p[0]), source=mgfs(p[1]), LIBS=mlib+['mgf']) Default(prog) env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) @@ -42,16 +42,16 @@ PROGS = [ 'rtscene','rtio','rtcolor','rtcont','rtmem','rterror'] + mlib), ] for p in PROGS: - prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]) + prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=p[2]) Default(prog) env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) # meta targets -prog = env.Program(target=radbin('mgf2meta'), source=['mgf2meta.c'], +prog = env.Program(target=rbin('mgf2meta'), source=['mgf2meta.c'], CPPPATH=env.get('CPPPATH', []) + [os.path.join('#src','meta')], LIBS=['meta','rtmath','rtcont','rtmem','rterror','mgf'] + mlib) -LIBFILES = Split('source.cal tilt.cal')# lamp.tab') +LIBFILES = Split('source.cal tilt.cal lamp.tab') env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES))
