--- ray/src/cv/SConscript 2016/03/05 13:24:58 1.13 +++ ray/src/cv/SConscript 2016/03/10 21:43:22 1.15 @@ -8,52 +8,39 @@ mlib = env['RAD_MLIB'] # compose paths def rbin(name): return os.path.join(env['RAD_BUILDBIN'], name) -MGFPROGS = ( -('3ds2mgf', Split('3ds2mgf.c rayopt3ds.c vect3ds.c')), -) -for p in MGFPROGS: - prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=mlib+['mgf','rtcont']) - Default(prog) - env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) - trans = env.Object(source="trans.c") bsdfrep = env.Object(source="bsdfrep.c") bsdfinterp = env.Object(source="bsdfinterp.c") - # standard targets PROGS = [ -('ies2rad', ['ies2rad.c'], ['rtlamps','rtcolor','rtio','rtpath']+ mlib), -#('arch2rad', ['arch2rad.c',trans],['rtcont','rtmem'] + mlib), +('3ds2mgf', Split('3ds2mgf.c rayopt3ds.c vect3ds.c'), ['mgf','rtrad'] + mlib), +('ies2rad', ['ies2rad.c'], ['rtrad'] + mlib), +#('arch2rad', ['arch2rad.c',trans],['rtrad'] + mlib), ('nff2rad', ['nff2rad.c'], []), -('lampcolor', ['lampcolor.c'], ['rtlamps','rtcolor','rtio','rtpath']), -('tmesh2rad', ['tmesh2rad.c'], ['rtscene','rtmath'] + mlib), -('obj2rad', ['obj2rad.c',trans], - ['rtscene','rtargs','rtio','rtcont','rtmem','rtmath','rterror'] + mlib), -('mgf2rad', ['mgf2rad.c'], ['mgf','rtall'] + mlib), -('rad2mgf', ['rad2mgf.c'], - ['rtproc', 'rtpath', # for win_popen() - 'rtscene','rtio','rtcolor','rtcont','rtmem','rterror'] + mlib), -('mgfilt', ['mgfilt.c'], ['mgf','rtall'] + mlib), -('mgf2inv', ['mgf2inv.c'], ['mgf','rtall'] + mlib), +('lampcolor', ['lampcolor.c'], ['rtrad'] ), +('tmesh2rad', ['tmesh2rad.c'], ['rtrad'] + mlib), +('obj2rad', ['obj2rad.c',trans], ['rtrad'] + mlib), +('mgf2rad', ['mgf2rad.c'], ['mgf','rtrad'] + mlib), +('rad2mgf', ['rad2mgf.c'], ['rtrad'] + mlib), +('mgfilt', ['mgfilt.c'], ['mgf','rtrad'] + mlib), +('mgf2inv', ['mgf2inv.c'], ['mgf','rtrad'] + mlib), ('pabopto2bsdf', ['pabopto2bsdf.c',bsdfrep,'bsdfrbf.c', 'bsdfmesh.c', 'bsdftrans.cpp',], - ['rtall'] + mlib), -('bsdf2klems',['bsdf2klems.c',bsdfrep,bsdfinterp, ], ['rtall'] + mlib), -('bsdf2ttree',['bsdf2ttree.c',bsdfrep,bsdfinterp, ], ['rtall'] + mlib), -('pkgBSDF', ['pkgBSDF.c', ], ['rtall'] + mlib), -('epw2wea', ['epw2wea.c', ], ['rtall'] + mlib), + ['rtrad'] + mlib), +('bsdf2klems',['bsdf2klems.c', bsdfrep, bsdfinterp,], ['rtrad'] + mlib), +('bsdf2ttree',['bsdf2ttree.c', bsdfrep, bsdfinterp,], ['rtrad'] + mlib), +('pkgBSDF', ['pkgBSDF.c', ], ['rtrad'] + mlib), +('epw2wea', ['epw2wea.c', ], ['rtrad'] + mlib), +('mgf2meta', ['mgf2meta.c'], ['meta', 'mgf','rtrad'] + mlib, + [os.path.join('#src','meta')]), ] for p in PROGS: - prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=p[2]) + if len(p) == 4: inclp = env.get('CPPPATH', []) + [os.path.join('#src','meta')], + else: inclp = env.get('CPPPATH', []) + prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=p[2], CPPPATH=inclp) Default(prog) env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) - -# meta targets -prog = env.Program(target=rbin('mgf2meta'), source=['mgf2meta.c'], - CPPPATH=env.get('CPPPATH', []) + [os.path.join('#src','meta')], - LIBS=['meta','mgf','rtall'] + mlib) -env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) LIBFILES = Split('source.cal tilt.cal window.cal') env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES))
