root/radiance/ray/src/cv/SConscript
Revision: 1.14
Committed: Sun Mar 6 01:13:17 2016 UTC (9 years, 5 months ago) by schorsch
Changes since 1.13: +2 -2 lines
1 import os
2
3 Import ('env')
4
5 # math libs
6 mlib = env['RAD_MLIB']
7
8 # compose paths
9 def rbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
10
11 MGFPROGS = (
12 ('3ds2mgf', Split('3ds2mgf.c rayopt3ds.c vect3ds.c')),
13 )
14 for p in MGFPROGS:
15 prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=mlib+['mgf','rtcont'])
16 Default(prog)
17 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
18
19 trans = env.Object(source="trans.c")
20 bsdfrep = env.Object(source="bsdfrep.c")
21 bsdfinterp = env.Object(source="bsdfinterp.c")
22
23
24 # standard targets
25 PROGS = [
26 ('ies2rad', ['ies2rad.c'], ['rtlamps','rtcolor','rtio','rtpath']+ mlib),
27 #('arch2rad', ['arch2rad.c',trans],['rtcont','rtmem'] + mlib),
28 ('nff2rad', ['nff2rad.c'], []),
29 ('lampcolor', ['lampcolor.c'], ['rtlamps','rtcolor','rtio','rtpath']),
30 ('tmesh2rad', ['tmesh2rad.c'], ['rtscene','rtmath'] + mlib),
31 ('obj2rad', ['obj2rad.c',trans],
32 ['rtscene','rtargs','rtio','rtcont','rtmem','rtmath','rterror'] + mlib),
33 ('mgf2rad', ['mgf2rad.c'], ['mgf','rtall'] + mlib),
34 ('rad2mgf', ['rad2mgf.c'],
35 ['rtproc', 'rtpath', # for win_popen()
36 'rtscene','rtio','rtcolor','rtcont','rtmem','rterror'] + mlib),
37 ('mgfilt', ['mgfilt.c'], ['mgf','rtall'] + mlib),
38 ('mgf2inv', ['mgf2inv.c'], ['mgf','rtall'] + mlib),
39 ('pabopto2bsdf',
40 ['pabopto2bsdf.c',bsdfrep,'bsdfrbf.c', 'bsdfmesh.c', 'bsdftrans.cpp',],
41 ['rtall'] + mlib),
42 ('bsdf2klems',['bsdf2klems.c', bsdfrep, bsdfinterp,], ['rtall'] + mlib),
43 ('bsdf2ttree',['bsdf2ttree.c', bsdfrep, bsdfinterp,], ['rtall'] + mlib),
44 ('pkgBSDF', ['pkgBSDF.c', ], ['rtall'] + mlib),
45 ('epw2wea', ['epw2wea.c', ], ['rtall'] + mlib),
46 ]
47 for p in PROGS:
48 prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=p[2])
49 Default(prog)
50 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
51
52 # meta targets
53 prog = env.Program(target=rbin('mgf2meta'), source=['mgf2meta.c'],
54 CPPPATH=env.get('CPPPATH', []) + [os.path.join('#src','meta')],
55 LIBS=['meta','mgf','rtall'] + mlib)
56 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
57
58 LIBFILES = Split('source.cal tilt.cal window.cal')
59 env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES))
60
61 if os.name == 'posix':
62 for s in Split('''optics2rad'''):
63 Default(env.InstallScript(rbin(s), s + '.csh'))
64
65 # vim: set syntax=python:
