| 1 |
from __future__ import division, print_function, unicode_literals |
| 2 |
| 3 |
import os |
| 4 |
| 5 |
Import ('env') |
| 6 |
| 7 |
# math libs |
| 8 |
mlib = env['RAD_MLIB'] |
| 9 |
| 10 |
# compose paths |
| 11 |
def rbin(name): return os.path.join(env['RAD_BUILDBIN'], name) |
| 12 |
| 13 |
trans = env.Object(source="trans.c") |
| 14 |
bsdfrep = env.Object(source="bsdfrep.c") |
| 15 |
bsdfinterp = env.Object(source="bsdfinterp.c") |
| 16 |
| 17 |
# standard targets |
| 18 |
PROGS = [ |
| 19 |
('3ds2mgf', Split('3ds2mgf.c rayopt3ds.c vect3ds.c'), ['mgf','rtrad'] + mlib), |
| 20 |
('ies2rad', ['ies2rad.c'], ['rtrad'] + mlib), |
| 21 |
#('arch2rad', ['arch2rad.c',trans],['rtrad'] + mlib), |
| 22 |
('nff2rad', ['nff2rad.c'], []), |
| 23 |
('lampcolor', ['lampcolor.c'], ['rtrad'] ), |
| 24 |
('tmesh2rad', ['tmesh2rad.c'], ['rtrad'] + mlib), |
| 25 |
('obj2rad', ['obj2rad.c',trans], ['rtrad'] + mlib), |
| 26 |
('mgf2rad', ['mgf2rad.c'], ['mgf','rtrad'] + mlib), |
| 27 |
('rad2mgf', ['rad2mgf.c'], ['rtrad'] + mlib), |
| 28 |
('mgfilt', ['mgfilt.c'], ['mgf','rtrad'] + mlib), |
| 29 |
('mgf2inv', ['mgf2inv.c'], ['mgf','rtrad'] + mlib), |
| 30 |
('pabopto2bsdf', |
| 31 |
['pabopto2bsdf.c',bsdfrep,'bsdfrbf.c', 'bsdfmesh.c', 'bsdftrans.cpp',], |
| 32 |
| 33 |
('bsdf2klems',['bsdf2klems.c', bsdfrep, bsdfinterp,], ['rtrad'] + mlib), |
| 34 |
('bsdf2ttree',['bsdf2ttree.c', bsdfrep, bsdfinterp,], ['rtrad'] + mlib), |
| 35 |
('pkgBSDF', ['pkgBSDF.c', ], ['rtrad'] + mlib), |
| 36 |
('epw2wea', ['epw2wea.c', ], ['rtrad'] + mlib), |
| 37 |
('mgf2meta', ['mgf2meta.c'], ['meta', 'mgf','rtrad'] + mlib, |
| 38 |
[os.path.join('#src','meta')]), |
| 39 |
| 40 |
for p in PROGS: |
| 41 |
if len(p) == 4: inclp = env.get('CPPPATH', []) + [os.path.join('#src','meta')], |
| 42 |
else: inclp = env.get('CPPPATH', []) |
| 43 |
prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=p[2], CPPPATH=inclp) |
| 44 |
Default(prog) |
| 45 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) |
| 46 |
| 47 |
LIBFILES = Split('bsdf2rad.cal source.cal tilt.cal window.cal') |
| 48 |
env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES)) |
| 49 |
| 50 |
if os.name == 'posix': |
| 51 |
for s in Split('''optics2rad'''): |
| 52 |
Default(env.InstallScript(rbin(s), s + '.csh')) |
| 53 |
| 54 |
# vim: set syntax=python: |
| 55 |
# vi: set ts=4 sw=4 : |
