| 1 |
import os
| 2 |
| 3 |
Import ('env')
| 4 |
| 5 |
# math libs
| 6 |
mlib = env['RAD_MLIB']
| 7 |
| 8 |
# compose paths
| 9 |
def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
| 10 |
def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
| 11 |
def mgfsf(src): return map(lambda s:os.path.join('mgflib', s), src)
| 12 |
| 13 |
MGFSRC = Split('''parser.c context.c xf.c object.c lookup.c badarg.c
| 14 |
words.c
| 15 |
fvect.c''')
| 16 |
libmgf = env.StaticLibrary(radlib('mgf'), source=mgfsf(MGFSRC))
| 17 |
MGFPROGS = (
| 18 |
('mgfilt', Split('mgfilt.c')),
| 19 |
('mgf2inv', Split('mgf2inv.c cvrgb.c')),
| 20 |
('3ds2mgf', Split('3ds2mgf.c rayopt.c vect.c')),
| 21 |
| 22 |
for p in MGFPROGS:
| 23 |
prog = env.Program(target=radbin(p[0]), source=mgfsf(p[1]) + [libmgf],
| 24 |
LIBS=mlib)
| 25 |
Default(prog)
| 26 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
| 27 |
| 28 |
# standard targets
| 29 |
PROGS = [
| 30 |
('thf2rad', Split('thf2rad.c'), []),
| 31 |
('ies2rad', Split('ies2rad.c'), ['rt'] + mlib),
| 32 |
('arch2rad', Split('arch2rad.c trans.c'), ['rt'] + mlib),
| 33 |
('nff2rad', Split('nff2rad.c'), []),
| 34 |
('lampcolor', Split('lampcolor.c'), ['rt']),
| 35 |
('tmesh2rad', Split('tmesh2rad.c'), ['rt'] + mlib),
| 36 |
('obj2rad', Split('obj2rad.c trans.c'), ['rt'] + mlib),
| 37 |
#('mgf2rad', Split('mgf2rad.c')+[libmgf], ['rt'] + mlib),
| 38 |
('rad2mgf', Split('rad2mgf.c'), ['rt'] + mlib),
| 39 |
('mgf2meta', Split('mgf2meta.c')+[libmgf], ['meta','rt'] + mlib),
| 40 |
| 41 |
if not os.name == 'nt': # XXX until we sort out the library conflicts
| 42 |
PROGS.append(('mgf2rad', Split('mgf2rad.c')+[libmgf], ['rt'] + mlib))
| 43 |
for p in PROGS:
| 44 |
prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2])
| 45 |
Default(prog)
| 46 |
| 47 |
| 48 |
LIBFILES = Split('source.cal tilt.cal')# lamp.tab')
| 49 |
env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES))
| 50 |
| 51 |
