root/radiance/ray/src/cv/SConscript
Revision: 1.11
Committed: Fri Apr 15 21:52:16 2011 UTC (13 years, 2 months ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad4R2, rad4R1, rad4R2P1
Changes since 1.10: +53 -60 lines
SCONS fixes for latest build
# User Rev Content
1 greg 1.11 import os
2
3     Import ('env')
4
5     # math libs
6     mlib = env['RAD_MLIB']
7
8     # compose paths
9     def rbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
10
11     MGFPROGS = (
12     ('3ds2mgf', Split('3ds2mgf.c rayopt3ds.c vect3ds.c')),
13     )
14     for p in MGFPROGS:
15     prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=mlib+['mgf','rtcont'])
16     Default(prog)
17     env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
18
19     trans = env.Object(source="trans.c")
20
21     # standard targets
22     PROGS = [
23     ('ies2rad', ['ies2rad.c'], ['rtlamps','rtcolor','rtio','rtpath']+ mlib),
24     ('arch2rad', ['arch2rad.c',trans],['rtcont','rtmem'] + mlib),
25     ('nff2rad', ['nff2rad.c'], []),
26     ('lampcolor', ['lampcolor.c'], ['rtlamps','rtcolor','rtio','rtpath']),
27     ('tmesh2rad', ['tmesh2rad.c'], ['rtscene','rtmath'] + mlib),
28     ('mgf2inv', ['mgf2inv.c'], ['mgf','rtall'] + mlib),
29     ('obj2rad', ['obj2rad.c',trans],
30     ['rtscene','rtargs','rtio','rtcont','rtmem','rtmath','rterror'] + mlib),
31     ('mgf2rad', ['mgf2rad.c'], ['mgf','rtall'] + mlib),
32     ('mgfilt', ['mgfilt.c'], ['mgf','rtall'] + mlib),
33     ('rad2mgf', ['rad2mgf.c'],
34     ['rtproc', 'rtpath', # for win_popen()
35     'rtscene','rtio','rtcolor','rtcont','rtmem','rterror'] + mlib),
36     ]
37     for p in PROGS:
38     prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=p[2])
39     Default(prog)
40     env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
41
42     # meta targets
43     prog = env.Program(target=rbin('mgf2meta'), source=['mgf2meta.c'],
44     CPPPATH=env.get('CPPPATH', []) + [os.path.join('#src','meta')],
45     LIBS=['meta','mgf','rtall'] + mlib)
46     env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
47
48     LIBFILES = Split('source.cal tilt.cal window.cal')
49     env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES))
50
51     if os.name == 'posix':
52     for s in Split('''optics2rad'''):
53     Default(env.InstallCsh(rbin(s), s + '.csh'))
