--- ray/src/cv/SConscript 2006/06/06 22:30:07 1.7 +++ ray/src/cv/SConscript 2010/07/09 15:24:44 1.9 @@ -51,9 +51,9 @@ prog = env.Program(target=rbin('mgf2meta'), source=['m CPPPATH=env.get('CPPPATH', []) + [os.path.join('#src','meta')], LIBS=['meta','rtmath','rtcont','rtmem','rterror','mgf'] + mlib) -LIBFILES = Split('source.cal tilt.cal lamp.tab window.cal') +LIBFILES = Split('source.cal tilt.cal window.cal') env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES)) if os.name == 'posix': for s in Split('''optics2rad'''): - Default(env.InstallCsh(radbin(s), s + '.csh')) + Default(env.InstallCsh(rbin(s), s + '.csh'))
