--- ray/src/cv/SConscript 2004/11/05 22:15:43 1.5 +++ ray/src/cv/SConscript 2011/04/15 21:52:16 1.11 @@ -6,22 +6,13 @@ Import ('env') mlib = env['RAD_MLIB'] # compose paths -def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name) -def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name) -def mgfsf(src): return map(lambda s:os.path.join('mgflib', s), src) +def rbin(name): return os.path.join(env['RAD_BUILDBIN'], name) -MGFSRC = Split('''parser.c context.c xf.c object.c lookup.c badarg.c - words.c - fvect.c''') -libmgf = env.StaticLibrary(radlib('mgf'), source=mgfsf(MGFSRC)) MGFPROGS = ( -('mgfilt', Split('mgfilt.c')), -('mgf2inv', Split('mgf2inv.c cvrgb.c')), -('3ds2mgf', Split('3ds2mgf.c rayopt.c vect.c')), +('3ds2mgf', Split('3ds2mgf.c rayopt3ds.c vect3ds.c')), ) for p in MGFPROGS: - prog = env.Program(target=radbin(p[0]), source=mgfsf(p[1]) + [libmgf], - LIBS=mlib) + prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=mlib+['mgf','rtcont']) Default(prog) env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) @@ -34,24 +25,29 @@ PROGS = [ ('nff2rad', ['nff2rad.c'], []), ('lampcolor', ['lampcolor.c'], ['rtlamps','rtcolor','rtio','rtpath']), ('tmesh2rad', ['tmesh2rad.c'], ['rtscene','rtmath'] + mlib), +('mgf2inv', ['mgf2inv.c'], ['mgf','rtall'] + mlib), ('obj2rad', ['obj2rad.c',trans], ['rtscene','rtargs','rtio','rtcont','rtmem','rtmath','rterror'] + mlib), -('mgf2rad', ['mgf2rad.c'], ['rtscene','rtcolor','mgf'] + mlib), +('mgf2rad', ['mgf2rad.c'], ['mgf','rtall'] + mlib), +('mgfilt', ['mgfilt.c'], ['mgf','rtall'] + mlib), ('rad2mgf', ['rad2mgf.c'], ['rtproc', 'rtpath', # for win_popen() 'rtscene','rtio','rtcolor','rtcont','rtmem','rterror'] + mlib), ] for p in PROGS: - prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]) + prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=p[2]) Default(prog) env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) # meta targets -prog = env.Program(target=radbin('mgf2meta'), source=['mgf2meta.c'], +prog = env.Program(target=rbin('mgf2meta'), source=['mgf2meta.c'], CPPPATH=env.get('CPPPATH', []) + [os.path.join('#src','meta')], - LIBS=['meta','rtmath','rtcont','rtmem','rterror','mgf'] + mlib) + LIBS=['meta','mgf','rtall'] + mlib) +env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) -LIBFILES = Split('source.cal tilt.cal')# lamp.tab') +LIBFILES = Split('source.cal tilt.cal window.cal') env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES)) - +if os.name == 'posix': + for s in Split('''optics2rad'''): + Default(env.InstallCsh(rbin(s), s + '.csh'))
