--- ray/src/cv/SConscript 2003/11/15 17:54:06 1.3 +++ ray/src/cv/SConscript 2010/12/15 21:51:46 1.10 @@ -1,58 +1,60 @@ -import os - -Import ('env') - -# math libs -mlib = env['RAD_MLIB'] - -# compose paths -def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name) -def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name) -def mgfsf(src): return map(lambda s:os.path.join('mgflib', s), src) - -MGFSRC = Split('''parser.c context.c xf.c object.c lookup.c badarg.c - words.c - fvect.c''') -libmgf = env.StaticLibrary(radlib('mgf'), source=mgfsf(MGFSRC)) -MGFPROGS = ( -('mgfilt', Split('mgfilt.c')), -('mgf2inv', Split('mgf2inv.c cvrgb.c')), -('3ds2mgf', Split('3ds2mgf.c rayopt.c vect.c')), -) -for p in MGFPROGS: - prog = env.Program(target=radbin(p[0]), source=mgfsf(p[1]) + [libmgf], - LIBS=mlib) - Default(prog) - env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) - -trans = env.Object(source="trans.c") - -# standard targets -PROGS = [ -('thf2rad', ['thf2rad.c'], []), -('ies2rad', ['ies2rad.c'], ['rtlamps','rtcolor','rtio','rtpath']+ mlib), -('arch2rad', ['arch2rad.c',trans],['rtcont','rtmem'] + mlib), -('nff2rad', ['nff2rad.c'], []), -('lampcolor', ['lampcolor.c'], ['rtlamps','rtcolor','rtpath']), -('tmesh2rad', ['tmesh2rad.c'], ['rtscene','rtmath'] + mlib), -('obj2rad', ['obj2rad.c',trans], - ['rtscene','rtargs','rtio','rtcont','rtmem','rtmath','rterror'] + mlib), -('mgf2rad', ['mgf2rad.c'], ['rtscene','rtcolor','mgf'] + mlib), -('rad2mgf', ['rad2mgf.c'], - ['rtproc', 'rtpath', # for win_popen() - 'rtscene','rtio','rtcolor','rtcont','rtmem','rterror'] + mlib), -] -for p in PROGS: - prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]) - Default(prog) - env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) - -# meta targets -prog = env.Program(target=radbin('mgf2meta'), source=['mgf2meta.c'], - CPPPATH=env.get('CPPPATH', []) + [os.path.join('#src','meta')], - LIBS=['meta','rtmath','rtcont','rtmem','rterror','mgf'] + mlib) - -LIBFILES = Split('source.cal tilt.cal')# lamp.tab') -env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES)) - - +import os + +Import ('env') + +# math libs +mlib = env['RAD_MLIB'] + +# compose paths +def rbin(name): return os.path.join(env['RAD_BUILDBIN'], name) +def rlib(name): return os.path.join(env['RAD_BUILDLIB'], name) +def mgfs(src): return map(lambda s:os.path.join('mgflib', s), src) + +MGFSRC = Split('''parser.c context.c xf.c object.c lookup.c badarg.c + words.c + fvect.c''') +libmgf = env.StaticLibrary(rlib('mgf'), source=mgfs(MGFSRC)) + +MGFPROGS = ( +('mgfilt', Split('mgfilt.c')), +('mgf2inv', Split('mgf2inv.c cvrgb.c')), +('3ds2mgf', Split('3ds2mgf.c rayopt.c vect.c')), +) +for p in MGFPROGS: + prog = env.Program(target=rbin(p[0]), source=mgfs(p[1]), LIBS=mlib+['mgf']) + Default(prog) + env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) + +trans = env.Object(source="trans.c") + +# standard targets +PROGS = [ +('ies2rad', ['ies2rad.c'], ['rtlamps','rtcolor','rtio','rtpath']+ mlib), +('arch2rad', ['arch2rad.c',trans],['rtcont','rtmem'] + mlib), +('nff2rad', ['nff2rad.c'], []), +('lampcolor', ['lampcolor.c'], ['rtlamps','rtcolor','rtio','rtpath']), +('tmesh2rad', ['tmesh2rad.c'], ['rtscene','rtmath'] + mlib), +('obj2rad', ['obj2rad.c',trans], + ['rtscene','rtargs','rtio','rtcont','rtmem','rtmath','rterror'] + mlib), +('mgf2rad', ['mgf2rad.c'], ['rtscene','rtcolor','mgf'] + mlib), +('rad2mgf', ['rad2mgf.c'], + ['rtproc', 'rtpath', # for win_popen() + 'rtscene','rtio','rtcolor','rtcont','rtmem','rterror'] + mlib), +] +for p in PROGS: + prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=p[2]) + Default(prog) + env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) + +# meta targets +prog = env.Program(target=rbin('mgf2meta'), source=['mgf2meta.c'], + CPPPATH=env.get('CPPPATH', []) + [os.path.join('#src','meta')], + LIBS=['meta','rtmath','rtcont','rtmem','rterror','mgf'] + mlib) +env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) + +LIBFILES = Split('source.cal tilt.cal window.cal') +env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES)) + +if os.name == 'posix': + for s in Split('''optics2rad'''): + Default(env.InstallCsh(rbin(s), s + '.csh'))
