root/radiance/ray/src/cv/SConscript
Fri Apr 15 21:52:16 2011 UTC (13 years, 1 month ago) by greg
Changes since 1.10: +53 -60 lines
Diff to previous 1.10 , to selected 1.5
SCONS fixes for latest build
Wed Dec 15 21:51:46 2010 UTC (13 years, 5 months ago) by greg
Changes since 1.9: +60 -59 lines
Diff to previous 1.9 , to selected 1.5
Additional fixes for MINGW thanks to Guy Vaessen
Fri Jul 9 15:24:44 2010 UTC (13 years, 10 months ago) by greg
Diff to previous 1.8 , to selected 1.5
Removed duplicate installs and added dctimestep
Wed Jun 7 17:52:03 2006 UTC (17 years, 11 months ago) by schorsch
Diff to previous 1.7 , to selected 1.5
Tue Jun 6 22:30:07 2006 UTC (17 years, 11 months ago) by schorsch
Changes since 1.6: +4 -2 lines
Diff to previous 1.6 , to selected 1.5
Added window.cal to SCons
Mon Sep 12 14:44:09 2005 UTC (18 years, 8 months ago) by schorsch
Changes since 1.5: +9 -9 lines
Diff to previous 1.5
Updates to SConscripts for 3R7.
Fri Nov 5 22:15:43 2004 UTC (19 years, 6 months ago) by schorsch
Changes since 1.4: +0 -1 lines
Diff to previous 1.4
Fri Mar 26 21:33:52 2004 UTC (20 years, 2 months ago) by schorsch
Lampcolor needs rtio.a.
Sat Nov 15 17:54:06 2003 UTC (20 years, 6 months ago) by schorsch
Changes since 1.2: +5 -2 lines
Mon Oct 27 10:35:42 2003 UTC (20 years, 6 months ago) by schorsch
Changes since 1.1: +16 -12 lines
Tue Oct 21 19:27:28 2003 UTC (20 years, 7 months ago) by schorsch
Diff to selected 1.5
