root/radiance/ray/src/cv/SConscript
Revision: 1.8
Committed: Wed Jun 7 17:52:03 2006 UTC (19 years, 1 month ago) by schorsch
CVS Tags: rad4R0, rad3R8, rad3R9
# User Rev Content
1 schorsch 1.1 import os
2
3     Import ('env')
4
5     # math libs
6     mlib = env['RAD_MLIB']
7
8     # compose paths
9 schorsch 1.6 def rbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
10     def rlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
11     def mgfs(src): return map(lambda s:os.path.join('mgflib', s), src)
12 schorsch 1.1
13     MGFSRC = Split('''parser.c context.c xf.c object.c lookup.c badarg.c
14     words.c
15     fvect.c''')
16 schorsch 1.6 libmgf = env.StaticLibrary(rlib('mgf'), source=mgfs(MGFSRC))
17
18 schorsch 1.1 MGFPROGS = (
19     ('mgfilt', Split('mgfilt.c')),
20     ('mgf2inv', Split('mgf2inv.c cvrgb.c')),
21     ('3ds2mgf', Split('3ds2mgf.c rayopt.c vect.c')),
22     )
23     for p in MGFPROGS:
24 schorsch 1.6 prog = env.Program(target=rbin(p[0]), source=mgfs(p[1]), LIBS=mlib+['mgf'])
25 schorsch 1.1 Default(prog)
26     env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
27
28 schorsch 1.2 trans = env.Object(source="trans.c")
29
30 schorsch 1.1 # standard targets
31     PROGS = [
32 schorsch 1.2 ('ies2rad', ['ies2rad.c'], ['rtlamps','rtcolor','rtio','rtpath']+ mlib),
33     ('arch2rad', ['arch2rad.c',trans],['rtcont','rtmem'] + mlib),
34     ('nff2rad', ['nff2rad.c'], []),
35 schorsch 1.4 ('lampcolor', ['lampcolor.c'], ['rtlamps','rtcolor','rtio','rtpath']),
36 schorsch 1.2 ('tmesh2rad', ['tmesh2rad.c'], ['rtscene','rtmath'] + mlib),
37     ('obj2rad', ['obj2rad.c',trans],
38     ['rtscene','rtargs','rtio','rtcont','rtmem','rtmath','rterror'] + mlib),
39     ('mgf2rad', ['mgf2rad.c'], ['rtscene','rtcolor','mgf'] + mlib),
40     ('rad2mgf', ['rad2mgf.c'],
41     ['rtproc', 'rtpath', # for win_popen()
42     'rtscene','rtio','rtcolor','rtcont','rtmem','rterror'] + mlib),
43 schorsch 1.1 ]
44     for p in PROGS:
45 schorsch 1.6 prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=p[2])
46 schorsch 1.1 Default(prog)
47     env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
48 schorsch 1.3
49     # meta targets
50 schorsch 1.6 prog = env.Program(target=rbin('mgf2meta'), source=['mgf2meta.c'],
51 schorsch 1.3 CPPPATH=env.get('CPPPATH', []) + [os.path.join('#src','meta')],
52     LIBS=['meta','rtmath','rtcont','rtmem','rterror','mgf'] + mlib)
53 schorsch 1.1
54 schorsch 1.7 LIBFILES = Split('source.cal tilt.cal lamp.tab window.cal')
55 schorsch 1.1 env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES))
56
57 schorsch 1.7 if os.name == 'posix':
58     for s in Split('''optics2rad'''):
59 schorsch 1.8 Default(env.InstallCsh(rbin(s), s + '.csh'))
