root/radiance/ray/src/cv/SConscript
Wed Jun 7 17:52:03 2006 UTC (19 years ago) by schorsch
Diff to previous 1.7 , to selected 1.6
Tue Jun 6 22:30:07 2006 UTC (19 years ago) by schorsch
Changes since 1.6: +4 -2 lines
Diff to previous 1.6
Added window.cal to SCons
Revision 1.6 - (view) (download) (annotate) - [selected]
Mon Sep 12 14:44:09 2005 UTC (19 years, 9 months ago) by schorsch
Changes since 1.5: +9 -9 lines
Diff to previous 1.5
Updates to SConscripts for 3R7.
Fri Nov 5 22:15:43 2004 UTC (20 years, 7 months ago) by schorsch
Changes since 1.4: +0 -1 lines
Diff to previous 1.4 , to selected 1.6
Fri Mar 26 21:33:52 2004 UTC (21 years, 3 months ago) by schorsch
Diff to previous 1.3 , to selected 1.6
Lampcolor needs rtio.a.
Sat Nov 15 17:54:06 2003 UTC (21 years, 7 months ago) by schorsch
Changes since 1.2: +5 -2 lines
Diff to previous 1.2 , to selected 1.6
Mon Oct 27 10:35:42 2003 UTC (21 years, 8 months ago) by schorsch
Changes since 1.1: +16 -12 lines
Diff to previous 1.1 , to selected 1.6
Tue Oct 21 19:27:28 2003 UTC (21 years, 8 months ago) by schorsch
Diff to selected 1.6
