--- ray/src/cv/SConscript 2003/11/15 17:54:06 1.3 +++ ray/src/cv/SConscript 2006/06/07 17:52:03 1.8 @@ -6,22 +6,22 @@ Import ('env') mlib = env['RAD_MLIB'] # compose paths -def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name) -def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name) -def mgfsf(src): return map(lambda s:os.path.join('mgflib', s), src) +def rbin(name): return os.path.join(env['RAD_BUILDBIN'], name) +def rlib(name): return os.path.join(env['RAD_BUILDLIB'], name) +def mgfs(src): return map(lambda s:os.path.join('mgflib', s), src) MGFSRC = Split('''parser.c context.c xf.c object.c lookup.c badarg.c words.c fvect.c''') -libmgf = env.StaticLibrary(radlib('mgf'), source=mgfsf(MGFSRC)) +libmgf = env.StaticLibrary(rlib('mgf'), source=mgfs(MGFSRC)) + MGFPROGS = ( ('mgfilt', Split('mgfilt.c')), ('mgf2inv', Split('mgf2inv.c cvrgb.c')), ('3ds2mgf', Split('3ds2mgf.c rayopt.c vect.c')), ) for p in MGFPROGS: - prog = env.Program(target=radbin(p[0]), source=mgfsf(p[1]) + [libmgf], - LIBS=mlib) + prog = env.Program(target=rbin(p[0]), source=mgfs(p[1]), LIBS=mlib+['mgf']) Default(prog) env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) @@ -29,11 +29,10 @@ trans = env.Object(source="trans.c") # standard targets PROGS = [ -('thf2rad', ['thf2rad.c'], []), ('ies2rad', ['ies2rad.c'], ['rtlamps','rtcolor','rtio','rtpath']+ mlib), ('arch2rad', ['arch2rad.c',trans],['rtcont','rtmem'] + mlib), ('nff2rad', ['nff2rad.c'], []), -('lampcolor', ['lampcolor.c'], ['rtlamps','rtcolor','rtpath']), +('lampcolor', ['lampcolor.c'], ['rtlamps','rtcolor','rtio','rtpath']), ('tmesh2rad', ['tmesh2rad.c'], ['rtscene','rtmath'] + mlib), ('obj2rad', ['obj2rad.c',trans], ['rtscene','rtargs','rtio','rtcont','rtmem','rtmath','rterror'] + mlib), @@ -43,16 +42,18 @@ PROGS = [ 'rtscene','rtio','rtcolor','rtcont','rtmem','rterror'] + mlib), ] for p in PROGS: - prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]) + prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=p[2]) Default(prog) env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) # meta targets -prog = env.Program(target=radbin('mgf2meta'), source=['mgf2meta.c'], +prog = env.Program(target=rbin('mgf2meta'), source=['mgf2meta.c'], CPPPATH=env.get('CPPPATH', []) + [os.path.join('#src','meta')], LIBS=['meta','rtmath','rtcont','rtmem','rterror','mgf'] + mlib) -LIBFILES = Split('source.cal tilt.cal')# lamp.tab') +LIBFILES = Split('source.cal tilt.cal lamp.tab window.cal') env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES)) - +if os.name == 'posix': + for s in Split('''optics2rad'''): + Default(env.InstallCsh(rbin(s), s + '.csh'))
