root/Development/ray/src/cv/SConscript
Revision: 1.1
Committed: Tue Oct 21 19:27:28 2003 UTC (22 years ago) by schorsch
1 import os
2
3 Import ('env')
4
5 # math libs
6 mlib = env['RAD_MLIB']
7
8 # compose paths
9 def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
10 def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
11 def mgfsf(src): return map(lambda s:os.path.join('mgflib', s), src)
12
13 MGFSRC = Split('''parser.c context.c xf.c object.c lookup.c badarg.c
14 words.c
15 fvect.c''')
16 libmgf = env.StaticLibrary(radlib('mgf'), source=mgfsf(MGFSRC))
17 MGFPROGS = (
18 ('mgfilt', Split('mgfilt.c')),
19 ('mgf2inv', Split('mgf2inv.c cvrgb.c')),
20 ('3ds2mgf', Split('3ds2mgf.c rayopt.c vect.c')),
21 )
22 for p in MGFPROGS:
23 prog = env.Program(target=radbin(p[0]), source=mgfsf(p[1]) + [libmgf],
24 LIBS=mlib)
25 Default(prog)
26 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
27
28 # standard targets
29 PROGS = [
30 ('thf2rad', Split('thf2rad.c'), []),
31 ('ies2rad', Split('ies2rad.c'), ['rt'] + mlib),
32 ('arch2rad', Split('arch2rad.c trans.c'), ['rt'] + mlib),
33 ('nff2rad', Split('nff2rad.c'), []),
34 ('lampcolor', Split('lampcolor.c'), ['rt']),
35 ('tmesh2rad', Split('tmesh2rad.c'), ['rt'] + mlib),
36 ('obj2rad', Split('obj2rad.c trans.c'), ['rt'] + mlib),
37 #('mgf2rad', Split('mgf2rad.c')+[libmgf], ['rt'] + mlib),
38 ('rad2mgf', Split('rad2mgf.c'), ['rt'] + mlib),
39 ('mgf2meta', Split('mgf2meta.c')+[libmgf], ['meta','rt'] + mlib),
40 ]
41 if not os.name == 'nt': # XXX until we sort out the library conflicts
42 PROGS.append(('mgf2rad', Split('mgf2rad.c')+[libmgf], ['rt'] + mlib))
43 for p in PROGS:
44 prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2])
45 Default(prog)
46 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
47
48 LIBFILES = Split('source.cal tilt.cal')# lamp.tab')
49 env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES))
50
51
