root/radiance/ray/src/cv/SConscript
Mon Jan 8 13:38:37 2018 UTC (6 years, 3 months ago) by schorsch
Changes since 1.15: +4 -1 lines
Diff to previous 1.15 , to selected 1.12
Thu Mar 10 21:43:22 2016 UTC (8 years, 1 month ago) by schorsch
Changes since 1.14: +20 -33 lines
Diff to previous 1.14 , to selected 1.12
Sun Mar 6 01:13:17 2016 UTC (8 years, 2 months ago) by schorsch
Changes since 1.13: +2 -2 lines
Diff to previous 1.13 , to selected 1.12
Sat Mar 5 13:24:58 2016 UTC (8 years, 2 months ago) by schorsch
Changes since 1.12: +15 -3 lines
Diff to previous 1.12
Revision 1.12 - (view) (download) (annotate) - [selected]
Sat Mar 5 00:29:28 2016 UTC (8 years, 2 months ago) by schorsch
Diff to previous 1.11
update SCons
Fri Apr 15 21:52:16 2011 UTC (13 years ago) by greg
Changes since 1.10: +53 -60 lines
Diff to previous 1.10 , to selected 1.12
SCONS fixes for latest build
Wed Dec 15 21:51:46 2010 UTC (13 years, 4 months ago) by greg
Changes since 1.9: +60 -59 lines
Diff to previous 1.9 , to selected 1.12
Additional fixes for MINGW thanks to Guy Vaessen
Fri Jul 9 15:24:44 2010 UTC (13 years, 10 months ago) by greg
Diff to previous 1.8 , to selected 1.12
Removed duplicate installs and added dctimestep
Wed Jun 7 17:52:03 2006 UTC (17 years, 11 months ago) by schorsch
Diff to previous 1.7 , to selected 1.12
Tue Jun 6 22:30:07 2006 UTC (17 years, 11 months ago) by schorsch
Changes since 1.6: +4 -2 lines
Diff to previous 1.6 , to selected 1.12
Added window.cal to SCons
Mon Sep 12 14:44:09 2005 UTC (18 years, 7 months ago) by schorsch
Changes since 1.5: +9 -9 lines
Diff to previous 1.5 , to selected 1.12
Updates to SConscripts for 3R7.
Fri Nov 5 22:15:43 2004 UTC (19 years, 6 months ago) by schorsch
Changes since 1.4: +0 -1 lines
Diff to previous 1.4 , to selected 1.12
Fri Mar 26 21:33:52 2004 UTC (20 years, 1 month ago) by schorsch
Diff to previous 1.3 , to selected 1.12
Lampcolor needs rtio.a.
Sat Nov 15 17:54:06 2003 UTC (20 years, 5 months ago) by schorsch
Changes since 1.2: +5 -2 lines
Diff to previous 1.2 , to selected 1.12
Mon Oct 27 10:35:42 2003 UTC (20 years, 6 months ago) by schorsch
Changes since 1.1: +16 -12 lines
Diff to previous 1.1 , to selected 1.12
Tue Oct 21 19:27:28 2003 UTC (20 years, 6 months ago) by schorsch
Diff to selected 1.12
